#31 |
Datum registracije: Oct 2001
Postovi: 2,735
pa vani se prica po forumima da ce se performanse na fx-ici vidjeti tek s detonatorima 50.xx i nekakva ubrzanja od cak 25%...ali vidjet cemo jel to je do sada samo rekla-kazala |
#32 | ||||||||||
Postovi: 3,263
Mozda jos nesto i bude od te FX-ice ![]()
#33 | |
Napokon dočekao DNF :)
Postovi: 1,460
I dont know you. I dont know what you want. If you leave, that will be the end. I wont look for you, I wont pursue you. But if you dont, I will look for you, I will find you and I will ignore you. |
