Staro 20.04.2006., 16:56   #1
alimilano
alimilano's Avatar
Lokacija: Split Hrvatska
Postovi: 936
mod starog kućišta
..evo bilo mi dosadno pa krenio preuređivat neko staro kućište.....unutra je mmx200 sa 32 edo...rastavio kompletno i uzeo brusilicu i deri..neznam ni sam šta bi..staviću neke slike pa komentirajte..sve je još u izradi..
[URL=http://img110.imageshack.us/my.php?image=p10101020fh.jpg][IMG]http://img110.imageshack.us/im
[URL=http://img72.imageshack.us/my.php?image=p10101019wm.jpg][IMG]http://img72.imageshack.us/img
http://img72.imageshack.us/img72/1316/p10101018eg.jpg
http://img102.imageshack.us/img102/4370/p10101100mr.jpg
http://img71.imageshack.us/img71/4078/p10101040xz.jpg
..nisam još koristio imageshack pa neznan je li dobro namišteno, je su li prevelike,da li koristiti direct link ili thumbnails for forums ,rsize opciju itd...može i za to savjet pa ću uplodat ostatak......
sad mi nije ništa jasno..kako kopirat ove kodove sa imageshack??..neka tema o ovome??
alimilano je offline   Reply With Quote
Staro 20.04.2006., 17:16   #2
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,221
linkowi...ti ne radhe...uploadiraj slikichu i kopiraj nam link...
Staro 20.04.2006., 17:27   #3
Facelessone
Facelessone's Avatar
Postovi: 4,203
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 20.04.2006., 17:33   #4
alimilano
alimilano's Avatar
Postovi: 936
Staro 20.04.2006., 18:14   #5
alimilano
alimilano's Avatar
Postovi: 936
http://img431.imageshack.us/my.php?i...10101075aq.jpg stara bakrena ručka koju triba još ulaštit
http://img102.imageshack.us/img102/9930/p10101051kx.jpg čepovi za dno
http://img102.imageshack.us/img102/5123/p10101085jk.jpg alat sa kojim je rezano i brušeno u nedostatku boljeg
http://img102.imageshack.us/img102/5297/p10101126mh.jpg bakreni lim sa kojim još neznam što ću
http://img149.imageshack.us/img149/5368/p10101117wx.jpg gomila škovaca..izvor sirovina
http://img102.imageshack.us/img102/6378/p10100042xp.jpg nekakva stakloplastika 2mm debljine umisto pleksija
http://img102.imageshack.us/img102/2340/p10100024dx.jpg ugrubo sastavljeno
http://img102.imageshack.us/img102/5822/p10100035nd.jpg zasad jedina investicija 17kn
....iman još zlatni i srebrni sprej..razmišljam o kombinaciji zlatno-crveno
.....pošto ovde nije potrebno neko hlađenje vjerovatno neću stavljat ventilatore...pa bi glavni cilj bio što tiše i lakše...možda da napravim mjesto za neke možda buduće..
...razmišljam o dodavanju drvenih elemenata pošto imam raznih drvenih sirovina.......svaki prijedlog je dobrodošao....sutra slijedi nastavak........
Staro 21.04.2006., 12:47   #6
Damarko
Damarko's Avatar
Postovi: 447
gle
NHF ali kućište je bilo ružno ali kako tek sad zgleda - to je straaaašno
neprecizno do bola, ne znam zašto si sa strane matišne ploče rezao da bi gledao u donji dio matične
sry ali ne sviđa mi se
Damarko je offline   Reply With Quote
Staro 21.04.2006., 12:56   #7
z3D
z3D's Avatar
Datum registracije: Aug 2002
Lokacija: Zagreb, Croatia
Postovi: 1,332
uzevsi u obzir uvjete u kojima je radjeno? flekserica i turpijetina rofl jos je dobro i ispalo
check out my photography work
z3D je offline   Reply With Quote
Staro 21.04.2006., 13:31   #8
crni16du
crni16du's Avatar
Lokacija: iz ugla
Postovi: 212
moze to bolje
crni16du je offline   Reply With Quote
Staro 21.04.2006., 14:02   #9
alimilano
alimilano's Avatar
Postovi: 936
Autor Damarko
gle
slažem se sa prvim redom ali to je još u fazi izrade..šta se tiče rezanja sa strane matične to sam napravio baš zato što to nitko ne radi...
Crni.........biće bolje
Z3D.........baš tako
Staro 21.04.2006., 23:17   #10
crni16du
crni16du's Avatar
Lokacija: iz ugla
Postovi: 212
Stavi na onu stranu matične mrežicu i pleksi biti ce drama
Staro 28.04.2006., 14:17   #11
alimilano
alimilano's Avatar
Postovi: 936
Staro 28.04.2006., 23:27   #12
Damarko
Damarko's Avatar
Postovi: 447
loool sad je već bolje al kaj ne modaš onu noviju kantu ??:P
Staro 29.04.2006., 02:07   #13
alimilano
alimilano's Avatar
Postovi: 936
Autor Damarko
......to je rodjakov big tower...razmišlja on o tome....možda se i odluči.....
Staro 29.04.2006., 12:49   #14
Damarko
Damarko's Avatar
Postovi: 447
nagovori ga
Staro 29.04.2006., 14:49   #15
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
daj malo smanji te slike, 56k korisnici slobodno mogu na kavu dok se učita...
a meni na adsl-u pojede 5mb dok otvorim
Staro 29.04.2006., 16:45   #16
alimilano
alimilano's Avatar
Postovi: 936
.....pogledaću...u onoj prvoj seriji slika sam stavio na imageshacku da je resiza na 640x480 i ispalo je ok ,tako je bilo i sad namišteno e sad zašto ih nije smanjio neznam.......
Staro 29.04.2006., 19:29   #17
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
trebalo je palva il crna na zlatno...tak se meni chini bolje...
svidj mi se dosad uchinjeno i case opcenito...
smanji sljike...
Staro 29.04.2006., 21:34   #18
Boot
Member
Boot's Avatar
Lokacija: Fort Duare
Postovi: 128
mod starog kućišta
alimilano,
jemas puno lipu makinju, ma ti je najlipji spaker na drva : goood :
Samo naprid : cheers2
Abit IC7 MAX3 - P4 2.8@3.2 - AC Freezer4
4x512 Kingmax SuperRAM PC 3500 - GeCube 9550GT
Seagate 250GB SATA2, Seagate 80GB SATA2 x 2- Chieftec 410W
LiteOn DVD-RW, SyncMaster 913N
Boot je offline   Reply With Quote
Staro 29.04.2006., 23:12   #19
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
http://www.irfanview.com/ - skini to - image - resize stavi 800x600 - file - save as - .jpg - quality - 80%
Pošteni Trgovci: 1,2
Staro 29.04.2006., 23:36   #20
alimilano
alimilano's Avatar
Postovi: 936
Autor SniperWolf
znam kako se to radi...IrfanView imam instaliran na svim računalima i taj postupak koristim kad se radi o jednoj ili dvije slike a ako ih više triba odjednom smanjit onda imageresize.net.....
Staro 29.04.2006., 23:38   #21
alimilano
alimilano's Avatar
Postovi: 936
Autor Boot
alimilano,
a o mašini za šivanje ni riči : cheers2
Staro 03.05.2006., 02:50   #22
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Autor alimilano
Imaš i "batch conversion/rename" u irfanu.
Lipo to izgleda, ali bojim se da će ti se ljuštit boja ako nisi udrija temeljnu ispod...inače odlično. A dobro si zasra monitor
Staro 03.05.2006., 12:27   #23
alimilano
alimilano's Avatar
Postovi: 936
....ma monitor nisan stiga očistit.......a pobrusija san finin vodootpornim..razmišlja san da stavim primer al san odusta.....
Staro 03.05.2006., 13:38   #24
Emissary
ČLAN FKTa
Emissary's Avatar
Postovi: 2,264
Autor alimilano
Pa kako si moga prskat po rupicama od monitora Je li osta živ?
Staro 03.05.2006., 14:09   #25
alimilano
alimilano's Avatar
Postovi: 936
rastavija san ga skroz prije toga kao i sve ostalo (trenutno cd-rom i floppy u obradi)...iman te slike...postaću kad stignem....
Staro 04.05.2006., 19:28   #26
alimilano
alimilano's Avatar
Postovi: 936
....evo još malo slika.......
Staro 04.05.2006., 19:35   #27
Flatline
Flatline's Avatar
Postovi: 196
jedan + za trud
Flatline je offline   Reply With Quote
Staro 04.05.2006., 21:34   #28
Damarko
Damarko's Avatar
Postovi: 447
ako ništa drugo reklama za ould timere
Staro 05.05.2006., 10:31   #29
alimilano
alimilano's Avatar
Postovi: 936
....i još slika....
Staro 05.05.2006., 11:26   #30
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
zasto su one zhice gore u onom debelom :confused:
