Staro 05.04.2006., 23:27   #1
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
Talking - pomoc - Spajanje X850XT napajanja
Ovako, upiknuo sam si u agp x850xt i na njoj je molex konektor za dodatno napajanje, no uz njega je i jos jedan mali zuti konektor koji lici na konektor za zvuk koji ide u dvd-rom..uglavnom, nisam ga ukopcavao, no interesira me cemu sluzi jer nemogu naci nigdje zasto je to.
Evo slika x850xt, samo ovo je PCI verzija pa je malo drugacija (nema molex nego ovaj crni konektor), ali isto ima taj zuti konektor
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Zadnje izmijenjeno od: Brown Acid. 05.04.2006. u 23:44.
Brown Acid je offline   Reply With Quote
Staro 05.04.2006., 23:51   #2
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Audio CD, imas to i na ploci, al sluzi vise nicem ( bar meni sve dela i bez toga) siguran sam da ima netko tko vise zna i tko ce mi pokazati krivost mojih rijeci....
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 06.04.2006., 00:12   #3
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Moj frend ima takvu grafu, nije spajao taj zuti konektor, spojio je samo molex... Super mu radi...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 06.04.2006., 00:20   #4
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
pa to zuto nije za struju... Danger of sprz
takav konektor imate i na CD/DVD romovima i odgovarajuci i na ploci
Grunf je moj idol!
Staro 06.04.2006., 00:31   #5
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
vidio sam na jednoj grafičkoj onaj mali zvučnik, piskavac. možda služi da grafa daje zvučno upozorenje, kod pregrijavanja il tak neš.
AMD Ryzen 7700X + Noctua NH-D15
Asus X670 Prime
2x8GB Kingston Fury Beast 6000MHz CL40
XFX RX6800 16GB Qick 319
Kingston NV2 250GB + Crucial P5+ 1TB + Seagate 2TB HDD
EVGA 650W SuperNOVA GQ, 80+ Gold
Fractal Design 7 Compact
23.8" AOC 24G2SPU 165Hz
Windows 10 x64
Logitech G402
Razer Cynosa V2
OveRkiLL je offline   Reply With Quote
Staro 06.04.2006., 00:54   #6
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
NOPE. Cemu kabel koji NIJE Strujni? Pistavac ne ovis o nicemu osim o biosu grafe.
Rekoh audio CD konekor, na plocama ti i psie pored njega audio CD. Pogledaj si na plocu i naci ces ga, pogledaj na CD/DVD i naci ces ga.
Grunf je moj idol!
Staro 06.04.2006., 03:16   #7
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
da znam, al kaj to radi na grafičkoj?
Asus X670 Prime
Windows 10 x64
Logitech G402
Razer Cynosa V2
Staro 06.04.2006., 10:13   #8
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
ne. na matichnima je jedan audio-cd takav kakav vidimo na grafi (negdje su dva jer postoje 2 konektora) i AUX s istim takvim konektorom, koji sluzi za spajanje na tv ili slicnu karticu.
e sad, neznam cem to zapravo sluzi, al mslim da ima veze s vivom...
Staro 06.04.2006., 14:06   #9
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 894
konektor za zvuk-kada snimaš nešto preko DVD-a Ili imaš na starom VHS-u na primjer ,nešto za prebaciti na comp.
Inače po tome odmah vidiš da grafa ima *čuveni* VIVO
i služi samo za to -ako nećeš raditi nešto slično zaboravi na taj konektor i pichi
damir1 je offline   Reply With Quote
Staro 06.04.2006., 14:59   #10
Smarty
Smarty's Avatar
Datum registracije: May 2005
Postovi: 1,285
A jel ti sta pise u opustvima?
Smarty je offline   Reply With Quote
Staro 06.04.2006., 23:35   #11
MAHER
Postovi: 1,583
ja isto imam taj konektor na ploči i zvučnoj,nije spojen i nisam mogao dokučiti ćemu služi
MAHER je offline   Reply With Quote
Staro 07.04.2006., 11:50   #12
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 894
Pa hebo Vas ,jeste slijepi. NApisao sam Vam lijepo. TO JE KONEKTOR ZA ZVUK NA *VIVO* KARTICAMA ako skidaš nešto sa starog vhs-a npr. preko toga snimaš zvuk od dotičnog materijala -znači bitno je spojiti za video in-video out inače baš Vas briga.Za igre itd Vam ne treba i nije ni bitno dali je spojeno ili ne.
Staro 07.04.2006., 11:53   #13
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 894
Autor MAHER
Na ploču se spajaš ako npr imaš tv karticu (na njoj imaš isto takav konektor)
bez toga bi preko tv kartice snimio samo sliku bez zvuka ili moraš odrediti da zvuk prima od negdje dalje(opet mora biti spojeno)...................
Staro 07.04.2006., 13:17   #14
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
ja imam vivo na 6600GT i nema taj konektor.
Asus X670 Prime
Windows 10 x64
Logitech G402
Razer Cynosa V2
Staro 07.04.2006., 18:26   #15
domy_os
domy_os's Avatar
Postovi: 18,950
Pa ni ne treba kad slika ide na grafu, a zvuk na zvučnu, sve izvana.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
