Staro 23.03.2006., 17:13   #1
RaNz0
Lokacija: Zagreb/Križevci
Postovi: 346
acer HITNO
odluka je pala...ACER...ali 3024WLMi, ili 3025WLMi???? - trebam savjet, mišljenje, da li se isplati dati 800kn više za 3025??
karakteristike:
CPU Mobile AMD Sempron™ 3100+ or higher with 128 KB L2 cache, AMD PowerNow!™ technology, and AMD HyperTransport™ technology support
OS Microsoft® Windows® XP Home Edition (Service Pack 2); Microsoft® Windows® XP Media Center Edition
Display 15.4" WXGA Acer CrystalBrite color TFT LCD, 1280 x 800 pixel resolution, supporting simultaneous multi-window viewing on dual displays via Acer GridVista;
Memory 512 MB of DDR333 memory, upgradeable to 2 GB using two soDIMM modules
Chipset ATI RADEON® XPRESS 200M chipset
Graphics ATI MOBILITY™ RADEON® X600, with 64 MB of external DDR VRAM; Microsoft® DirectX® 9.0 support; DualView™ support
Wireless LAN Integrated Acer InviLink™ 802.11g Wi-Fi CERTIFIED™ solution, supporting Acer SignalUp wireless technology
Audio Audio system with two built-in speakers; MS Sound compatible; Built-in microphone
HDD 60 GB ATA/100 hard disk drive
Optical drive "DVD-Dual double-layer drive: – Read: 8X DVD-R, 4X DVD-RW, 8X DVD+R, 4X DVD+RW, 24X CD-ROM, 8X DVD-ROM, 2.4X DVD+R DL (double-layer) – Write: 8X DVD-R, 4X DVD-RW, 8X DVD+R, 4X DVD+RW, 24X CD-R, 10X CD-RW, 2.4X DVD+R DL (double-layer)"
Card Reader 6-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), SmartMedia™, xD-Picture Card™, Memory Stick® and Memory Stick PRO™
Ports Four USB 2.0 ports; 6-in-1 card reader; PC Card slot (one Type II); IEEE 1394 port; Infrared (FIR) port; External display (VGA) port; S-video/TV-out (NTSC/PAL) port; Headphones/speaker/line-out port; Microphone/line-in jack; Ethernet (RJ-45) port; Modem (RJ-11) port; DC-in jack for AC adapter
Battery "ACPI 1.0b power management standard: supports Standby and Hibernation power-saving modes; 60 W Li-ion battery pack (8-cell, 4400 mAH) "
Battery life 3-hour battery life; 2.5-hour quick-charge; 3.5-hour charge-in-use; 90 W AC adapter
Keyboard 88-/89-key keyboard; inverted "T" cursor layout; 2.5 mm (minimum) key travel; 12 function keys, four cursor keys, two Windows® keys, hotkey controls, embedded numeric keypad, international language support; Six easy-launch buttons: Internet browser, email with LED, WLAN, Acer Empowering Key and one user-programmable button
Weight 3.07 kg for 15.4" LCD model
Pointing device Touchpad with 4-way scroll button
Software1 Acer eManager (ePresentation, eRecovery, eSettings); Acer GridVista; Acer Arcade; Acer Launch Manager; Acer System Recovery CD; Norton AntiVirus™; Adobe® Reader®; CyberLink PowerProducer™; NTI CD-Maker™
Warranty One-year International Travelers Warranty (ITW
i drugi:
CPU Mobile AMD Sempron™ processor 3300+ or higher with 128/256 KB L2 cache, AMD PowerNow!™ technology, and AMD HyperTransport™ technology support
Memory (2X256) 512 MB of DDR333 memory, upgradeable to 2 GB using two soDIMM modules
Graphics ATI MOBILITY™ RADEON® X700, with 128 MB of external DDR VRAM; Microsoft® DirectX® 9.0 support; DualView™ support
HDD 80 GB ATA/100 hard disk drive
Keyboard 88-/89-key keyboard; inverted "T" cursor layout; 2.5 mm (minimum) key travel; 12 function keys, four cursor keys, two Windows® keys, hotkey controls, embedded numeric keypad, international language support; Six easy-launch buttons: Internet browser, email with LED, WLAN, Bluetooth®, Acer Empowering Key and one user-programmable button
Weight 3.07 kg
Warranty One-year International Travelers Warranty (ITW)
očite razlike su:
3024 - sempron M 3100+, 60GB hard, x600
3025 - sempron M 3300+, 80GB hard, x700
molim, prosvjetlite me
RaNz0 je offline   Reply With Quote
Staro 23.03.2006., 21:35   #2
atha
atha's Avatar
Postovi: 9,067
to i jesu jedine razlike, i to ujedno i nosi razliku u cijeni.
ako si na "knap" sa novcima,
i tih 800kn ti dosta znachi,
nema potrebe da uzimash 3025wlmi,
jer i 3024 je odlichan, samo sa nehsto slabijim procesorom,
diskom i malo slabijom grafichkom.
___________
Just atha
x
Staro 23.03.2006., 22:59   #3
Facelessone
Facelessone's Avatar
Postovi: 4,204
pa po mojem se def. isplati jer dobivas 20gb harda, brži proc i bolju grafu sa 128mb
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 24.03.2006., 10:34   #4
Bran
nemam kaj napisati
Bran's Avatar
Datum registracije: May 2003
Lokacija: Međimurje
Postovi: 1,303
Pa sad ak možeš odvojiti još tih 800 kn onda uzmi skuplji. Isplati se zbog 20 GB većeg diska, nezamjetno bržeg procesora i jače grafičke.
Staro 24.03.2006., 21:08   #5
RaNz0
Postovi: 346
Autor Bran
hvala, 3025
Staro 24.03.2006., 21:12   #6
gangster
Lokacija: somewhere
Postovi: 7
ajd kad ga kupiš napiši dojmove. kolko baterija traje i čitao sam u bugu da se često pale oni bućni ventilatori, sad neznam kolko je to bućno.
A643500+freezer64,k8nxp-sli,2x512ocz gold el 2-2-2-5,6600gt 550/1300+zalmanvf700alcu,tagan430-easycon,ss2,lcd15",dvd-rw+dvd-rom,logitech z2300 2.1,mx518+ultraX-flat keyb
gangster je offline   Reply With Quote
Staro 26.03.2006., 19:52   #7
RaNz0
Postovi: 346
Autor gangster
bojim se da neće biti puno na bateriji
Staro 17.04.2006., 05:16   #8
edge
edge's Avatar
Lokacija: Šibenik / Zagreb
Postovi: 78
Jesi mozda kupio 3025 ?
Gdje si ga kupio, koliko si ga tocno platio, i kako se drzi ?
edge je offline   Reply With Quote
Staro 17.04.2006., 21:15   #9
NortonCommander
Orthodox file manager
NortonCommander's Avatar
Postovi: 422
Evo ja sam kupio 3025 i prezadovoljan sam. Baterija poprilicno traje (nisam tocno mjeria ali nesto vise nego sto pise u Bug-u za 3023)
3dmark03 je oko 7000, ekran je zakon, ventilatori se cesto pale ali uopce nisu bucni (oni u u bugu su malo razmaženi, ja primjetim da su ventilatori upaljeni samo kada stavim ruku na odvod zraka). Jedina zamjerka su mi pretihi zvucnici (nisam cuo tise na nijednom laptopu).
NortonCommander je offline   Reply With Quote
Staro 21.04.2006., 13:49   #10
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
koja je grafa unutra?
trenutno radim na ACER 9052, sa x700 grafom, giga rama... solidan laptop, ali tipkovnica ima nekih problema...
ne mogu brzo tipkati, jer joj treba vremena da prenese otipkano na ekran, a ako brzo tipkam, onda preskače slova... ide u trzajimakako,, eško za objasniti...
evo, vidi se gore ovo što sam pisao, te greske su zbog tipkovnice.. jer na mom kompu i tipkovnici za 70kn, nema ovakvih problema sa pisanjem...
zna li tko rješenje prblema..
Staro 21.04.2006., 19:57   #11
NortonCommander
Postovi: 422
Grafa je kao i u tebe. Nemam problema sa tipkovnicom. Mozda bi mogao to reklamirat. Jesi li pokusao spojit tu tipkovnicu sa kompa na laptop preko usb to ps2 convertera (oko 20kn)?
Staro 24.04.2006., 12:57   #12
edge
edge's Avatar
Postovi: 78
Autor NortonCommander
Kolega mi ima nekog HP-ića sa istim problemom. Čini mi se da je kvaka samo u tome što treba malo "okomitije" tipkati po tipkama, jer u protivnom ne hvata iz prve svaku tipku.
Staro 10.05.2006., 16:38   #13
santos
santos's Avatar
Lokacija: Čakovec / AT
Postovi: 1,782
(3025 wlmi )ja ti imam ovaj , radi super, i umjesto 80gb dobis 100 gb hard, mislim da je na svim acerima tako jer mi frend ima isto acera s turionom, i umjesto 80gb ima 100.
sad: i meni i njemu je nakon nekog vremena poceo srati dvd rom/przilica.
dok stavim cd ili dvd unutra i dok pocnem kopirati, sve zivo pocne cukati, od winampa, misa, zvukova na msnu, icq-u.
puni dvd na 4x mi je przilo 4h 30min, a ovaj vikend dok sam si htio sprzit dbz na dvd, nakon sat vremena jos uvijek je bilo na 1%
frend mi je nesto govorio da neke postavke moraju biti na API mod (?)
i da je bios zakljucan, da pola postavki nema.
sad bi ga trebal odnesti na garanciju da to rijese, ali ne mogu si priustiti da ostanem bez laptopa, sve do ljeta, dok ne budem doma, a ne na faksu.
eto, pa da znas na cemu si. pozz !
sta se tice graficke, rula, usporedjivali smo tu konfu i konfu mojeg frenda sa pentium 4 2,8, 512 ddr 400 i 6600 gt (leadtek) i lap je po 3dmarkovima slabiji za cca 15-20% sta mislim da je cisto ok.
samo da napomenem da sve ostalo radi i vise nego odlicno !
nego, da vas pitam, kako mogu dodatno smanjiti potrosnju baterije? (iskljucivanje IRDA porta, smanjivanje kontrasta na zaslonu, btw. dal ima kakav proggie s kojim bi mogao proc stalno drzat na 800mhz recimo, dok mi ne treba vise, jer cim se pokrene neka aplikacija, on radi na 2 ghz)
super mi je dok putujem od cakovca do rijeke, sjednem u bus, spojim se na mobile carnet, pustim mjuzu igram ogame i boli me kita
santos je offline   Reply With Quote
Staro 11.05.2006., 08:45   #14
atha
atha's Avatar
Postovi: 9,067
Daklem ovako....to je model sa sempronom jelda?
Na cd-u sa driverima si dobio drivere za procesor. Sa njima mozes omoguciti tehnologiju Cool'n'Quiet,
a to je ocito ono sto tebi treba.
Instaliraj drivere, i u power options ukljuci "minimal power management".
Ovdje mozes procitati vise od Cool'n'Quiet.
___________
Just atha
x
Staro 11.05.2006., 15:25   #15
ExCenTric
ExCenTric's Avatar
Lokacija: Hrv. Zagorje
Postovi: 40
evo da pitam vlasnike 3025-ice. kolko ste ga platili i di. vidim da je u m-computersu najeftiniji(po nabavi.net). ja kupujem laptop ovaj tjedan i neznam kaj da kupim. radim u autocadu pa mi treba minimalno ta grafa (x700). e sad. ja sam lagano odustao d tog modela jer je navodno procesor jako los, zapravo da su opcenito semproni losi. uglavnom bolje je uzet turiona. e sad sam ja u nedoumici, pa bih zelio iz prve ruke cut kak se procesor ponasa.
sad razmisljam o modelu 5024. on ima turiona u sebi, a drugo je prakticki sve isto. od hp-a ili ibm-a sam odustao jer za tu cijenu necu naci nesto s takvom grafikom. raspolazem s lovom do max. 9500-10 000
ExCenTric je offline   Reply With Quote
Staro 11.05.2006., 18:37   #16
santos
santos's Avatar
Postovi: 1,782
@ atha: moram pogledat dal sam uopce dobil koji cd osim origigi windoza
@ excentric : a po cemu je to taj proc los? ja nemam nikakvih primjedbi.
ne znam dal je prikladna usporedba ali evo: vrtim nfs:mw na high detaljima, i tu i tamo malo zna zacukat al to je zbog 512mb rama (need more )
ja sam ga platil malo jeftinije, kupljen je u 12. mj prosle godine, cijena mu je bila oko 8800 kn najjeftinija na nabava.net
Staro 12.05.2006., 05:43   #17
Mad_Duke
CPU Mobile AMD Sempron™ 3300+ or higher with 128/256 KB L2 cache
Sta znaci ovo 128/256 KB??? Koje je onda.
Ja mislim da ti se isplati dati 800 kuna vise, dobise 20 gigi, bolju grafika, ali prvenstveno mislim da ako ovaj ima duplo vise L2 cache-a da bi ti se isplatilo jerbo, 128 je uuuuzasno malo!
