Staro 10.08.2023., 07:46   #1
strikoo
strikoo's Avatar
Postovi: 1,018
Android/Google TV
Nisam nasao temu koja pokriva Android/Google TV OS.
Imam izazov
Kupio sam zamjenski daljinac za Philips koji nema tipku Quick Settings, a zgodna mi je kod brzog prebacivanja na soundbar. Ionako koristim Button Mapper, pa mi se nije cinilo kao neki problem, ali...
Tipku prijavljuje kao 602 FAC_FAC
Nasao sam koja je to aktivnost koju treba pokrenuti i preko adb ide bez problema
Code:
adb shell am start -n org.droidtv.settings/org.droidtv.settings.quicksettings.QuickSettingsActivity
Ako u Button Mapper pokrecem kao shell kaze da trebam biti root... mozda je i to opcija, a prije toga pokusati napisati app koja pokrece samo tu aktivnost pa mapirati na tipku (#neadamise)
Radio netko nesto slicno?
strikoo je offline   Reply With Quote
Staro 15.08.2023., 11:29   #2
strikoo
strikoo's Avatar
Postovi: 1,018
Ovako sam na kraju riješio.
Instalirao Tasker
Dodao akciju pokretanja aplikacije i izabrao njenu aktivnost
U Button Mapperu za single tap dodao pokretanje Tasker prečaca
bam
Staro 27.11.2025., 17:59   #3
strikoo
strikoo's Avatar
Postovi: 1,018
Smart Tune S nestao sa tv-a
Important Announcement
Friends, it seems that my digital signature has been exposed. This signature protects the app from fake and malicious updates, so there is a risk that someone may try to release counterfeit versions under my name.
To completely eliminate any threats, I’ve decided to stop using the current signature and switch to a new one. Because of this, the app’s identifier will also change. You don’t need to delete the old app (but it will no longer receive updates) — the new one will install as a separate app and will need to be configured again.
Thank you for your understanding and attention to security.
https://github.com/yuliskov/SmartTub...g/notification
Staro 27.11.2025., 19:53   #4
tiki66
tiki
tiki66's Avatar
Postovi: 2,755
Dobro da si obavijestio, tko zna kad bih to skuzio
Staro 28.11.2025., 12:35   #5
strikoo
strikoo's Avatar
Postovi: 1,018
Staro 05.12.2025., 13:02   #6
strikoo
strikoo's Avatar
Postovi: 1,018
stigli friski apk-ovi pa zamijenite
https://github.com/yuliskov/SmartTube/releases
Staro 05.12.2025., 13:58   #7
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,833
Neki dan sam beta skinuo, što trebam ponovno sada?
Staro 05.12.2025., 14:12   #8
strikoo
strikoo's Avatar
Postovi: 1,018
Autor Libertus Pregled postova
nez koji dan je to bilo, skkni ponovo za svaki slučaj
