Staro 27.11.2025., 18:41   #4831
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,200
Well folks, it’s the beginning of a new era: after nearly three decades of KDE desktop environments running on X11, the future KDE Plasma 6.8 release will be Wayland-exclusive! Support for X11 applications will be fully entrusted to Xwayland, and the Plasma X11 session will no longer be included.
↫ The Plasma Team
Staro 27.11.2025., 18:54   #4832
domy_os
domy_os's Avatar
Postovi: 18,928
Znači negdje do verzije 12 ću izbjegavati KDE...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 27.11.2025., 22:32   #4833
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,200
Autor domy_os Pregled postova
Zasto? Koristim Wayland zadnje 2 godine na lapu (nvidia) i stolnoj masini (amd) te na malom prijenosnom sticku sa vlastitom linux distrom koju piknem u bilo sto da imam svoj komp na raspolaganju i nemam primjedbi na Wayland zadnjih godinu dana iskreno.
Staro Jučer, 07:11   #4834
domy_os
domy_os's Avatar
Postovi: 18,928
Onda su možda ispeglali sve mušice. Posljednje tri godine sam primarno na Windowsima, a prije toga isprobao Wayland i to nije bilo upotrebljivo pa ostao na X11. Fractional scaling isto radi dobro?
Staro Jučer, 08:03   #4835
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,200
Nemoj zaboraviti da je 6 mjeseci za Linux ko 1 godina za Windows....stosta se moze izmjeniti. Fractional Scaling ...na Fedori i Archu - Gnome i KDE - nikad problema Debian testing branch jos uvijek po defaultu u Gnome ne nudi opciju, KDE nisam vec duze isprobao. Sa ostalim distrama se nisam zamarao.
Staro Jučer, 16:09   #4836
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,200
The HQspinlock is described in Thursday's patch proposal as:
"In a high contention case, existing Linux kernel spinlock implementations can become inefficient on modern NUMA-systems due to frequent and expensive cross-NUMA cache-line transfers.
This might happen due to following reasons:
- on "contender enqueue" each lock contender updates a shared lock structure
- on "MCS handoff" cross-NUMA cache-line transfer occurs when two contenders are from different NUMA nodes.
We introduce Hierarchical Queued Spinlock (HQ spinlock), aiming to reduce cross-NUMA cache line traffic and thus improving lock/unlock throughput for high-contention cases.
This idea might be considered as a combination of cohort-locking by Dave Dice and Linux kernel queued spinlock."
> HQspinlock Proposal For Linux Shows Very Nice Performance Benefits For Large Servers
Lucas De Marchi sent in the latest batch of Xe driver fixes today ahead of the Linux 6.18 stable release expected this weekend. In that Direct Rendering Manager pull request he noted:
"Here are the fixes towards 6.18. This is also my last pull request as xe maintainer as I'm leaving Intel. Patch to the MAINTAINERS files will be merged soon. Rodrigo and Thomas will continue sending the fixes if we don't have a release this week."
> One Of Intel's Xe Open-Source Linux Graphics Driver Maintainers Is Departing
Qualcomm's Snapdragon 8 Elite Gen 5 achieves a historic milestone with same-day upstream Linux support, eliminating the lag between hardware release and software adoption. This deep dive explores how this shift challenges x86 dominance, empowers the industrial IoT sector, and redefines the economics of long-term device support.
The synchronized release of silicon and software definitions represents a radical departure from the fragmented development cycles that have historically plagued the ARM ecosystem, effectively eliminating the technical debt that previously stifled innovation in non-Android markets.
> Silicon Synchronicity: How Qualcomm’s Day-Zero Linux Support for Snapdragon 8 Elite Gen 5 Rewrites the Rules of Hardware Adoption
Staro Jučer, 20:13   #4837
domy_os
domy_os's Avatar
Postovi: 18,928
Kako za koji feature ili bug, često je i obratno. Krenimo baš od tog fractional scalinga koji je podržan otkad ono? Windowsi su debelo napredniji što se toga tiče. Zatim razvoj aplikacija, drivera, power management, HW encoding videa dugo nije radio,... Dosta bi se o tome moglo pisati.
Staro Jučer, 22:55   #4838
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,200
Naravno, vidi gore slucaj koji je imao Mario92. Podrska ili PUNA podrska za odredeni hardwer je cesto Ahilova peta Linux strane. Al to je opet ona prica koke i jajeta a pile se izgubilo na raznju.
Staro Danas, 04:28   #4839
radi.neradi
Datum registracije: May 2023
Lokacija: Mrkopalj
Postovi: 82
Autor xlr Pregled postova
Zvuk u igrama magično radi ako napravim sljedeće:
Upalim browser, pustim yt, krene muzika
Upalim igru, također krene zvuk iz igre
Alt-tabam se u browser i pauziram yt
Vidi šta alsactl i pw-* alati kažu, možda primarno pw-cli, pw-dump, pw-metadata i pw-mon. Možda i pw-top. Pokušaj dumpati stanje odnosno parametre - kada zvuk ne radi i kada radi, pa napravi diff.
https://docs.pipewire.org/page_programs.html
pw-metadata ima -m = Keeps running and log the changes to the metadata.
pw-dump ima -m = Monitor PipeWire state changes, and output JSON arrays describing changes.
Prvo izlistaj sve parametre sa dump ili metadata. Zatim istraži node.pause-on-idle i node.suspend parametre koje možeš primjenit sa pw-metadata. Ako proradi, na nekoliko mjesta po internetu piše da su to Lua skripte unutar WirePlumber-a, i da dosta ljudi ima kojekakvih problema sa odlaskom uređaja u nekakav suspend mode.
radi.neradi je offline   Reply With Quote
