Staro 23.11.2025., 05:57   #3001
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,178
PowerToys 0.96 upgrades Advanced Paste with a redesigned UI and support for multiple AI endpoints, including Azure, OpenAI, Gemini, Mistral, and local models like Foundry Local and Ollama. The release also improves the Command Palette and PowerRename tools.
> PowerToys 0.96 upgrades Advanced Paste with local AI support
Staro 23.11.2025., 11:37   #3002
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,178
"Copilot Actions on Windows 11" is currently available in Insider builds (version 26220.7262) as part of Copilot Labs, according to a recent report, "and is off by default, requiring admin access to set it up."
But maybe it's off for a good reason...besides the fact that it can access any apps installed on your system:
In a support document, Microsoft admits that features like Copilot Actions introduce " novel security risks ." They warn about cross-prompt injection (XPIA), where malicious content in documents or UI elements can override the AI's instructions. The result? " Unintended actions like data exfiltration or malware installation ."
Yeah, you read that right. Microsoft is shipping a feature that could be tricked into installing malware on your system. Microsoft's own warning hits hard: "We recommend that you only enable this feature if you understand the security implications." When you try to enable these experimental features, Windows shows you a warning dialog that you have to acknowledge. ["This feature is still being tested and may impact the performance or security of your device."]
Even with these warnings, the level of access Copilot Actions demands is concerning. When you enable the feature, it gets read and write access to your Documents, Downloads, Desktop, Pictures, Videos, and Music folders... Microsoft says they are implementing safeguards. All actions are logged, users must approve data access requests, the feature operates in isolated workspaces, and the system uses audit logs to track activity.
But you are still giving an AI system that can "hallucinate and produce unexpected outputs" (Microsoft's words, not mine) full access to your personal files.
To address this, Ars Technica notes, Microsoft added this helpful warning to its support document this week. "As these capabilities are introduced, AI models still face functional limitations in terms of how they behave and occasionally may hallucinate and produce unexpected outputs."
But Microsoft didn't describe "what actions they should take to prevent their devices from being compromised. I asked Microsoft to provide these details, and the company declined..."
Nekad davno ovakve stvari se nisu gurale na korisnicka racunala vec su bile oznacene kao experimentalne dodatne opcije koje je korisnik sam morao instalirati ako ih je zbilja zelio i bio svjestan mogucih posljedica instalacije i koristenja istih.
Staro 23.11.2025., 11:45   #3003
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,680
Nekad davno je postojao odjel za kvalitetu i kompatibilnost. Vidim da su i u 2025 otpustili ljude zaduzene za testiranje i zamjenili ih sa AI-em.
Ovo je 2014, kad je krenulo nizbrdo.
Estimated number of QA testers (SDET/QA) affected: Several thousand (commonly cited internal figure: ~4,000–5,000 SDETs and testers globally)
Key change: Microsoft dramatically reduced the traditional tester-to-developer ratio from roughly 2 testers : 1 developer down to ≈1:1 or lower, effectively eliminating thousands of dedicated testing roles.
Staro 23.11.2025., 12:09   #3004
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,178
Autor Bono Pregled postova
Znam. Ali ovo je odluka managementa - ne developera ni testera. I to je zapravo jedini jebeni problem Windows 11 kao OS-a. Da je to sve opcionalno OS bi bio top. Mislim da cu se poigrat sa Nikky-evom idejom. Problem je samo da je sve to tolko integrirano u sustav da hoces ili neces izbacivanje tih "kljucnih" komponenti rezultira potrganim sustavom.
Staro 23.11.2025., 12:18   #3005
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,680
To je odluka indijca kad je postao CEO:
Satya Narayana Nadella is an Indian-American business executive who is the chairman and chief executive officer of Microsoft, succeeding Steve Ballmer in 2014 as CEO and John W. Thompson in 2021 as chairman.
Sad je all in u AI, kako bi rekli pukovnik ili pokojnik.
Staro 23.11.2025., 14:48   #3006
Promo
Promo's Avatar
Datum registracije: Jun 2024
Lokacija: Space
Postovi: 712
Sad' su to insider korisnici i "get latest update" korisnici. Ali je problem sto MS ne uzima feedback kao prioritet.
Staro 23.11.2025., 15:02   #3007
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,178
Nego...jel netko skuzio da je na celu vecine tih firmi ili neki indijac ili kinez?
Staro Jučer, 09:37   #3008
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,122
Nisam pratio tko je na čelu firme...
Nego zna li se kada bude ms ugradio tvin view u file manager
Staro Jučer, 09:45   #3009
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,352
Autor spiderhr Pregled postova
Otvoriš dva i staviš jedan kraj drugog, još najbolje da se zamaraju time....ne radi dobro ni ovo sada, a ti bi nove fićre.
Slobodno me dodajte na PSN
Zadnje izmijenjeno od: Disco. Jučer u 16:27.
Staro Jučer, 11:16   #3010
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,178
https://multicommander.com/
https://freecommander.com/en/summary/
Ima i ostalih alternativa naravno.
Staro Jučer, 12:44   #3011
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,122
Autor Disco Pregled postova
Otovriš dva i staviš jedan kraj drugog, još najbolje da se zamaraju time....ne radi dobro ni ovo sada, a ti bi nove fićre.
Ah... svašta bi ja da se ugradi kad se već ugrađuje...
Ma znam, imam doma double commander u win/lin ali na poslovno ne bi htel puno toga instalirati.
Staro Jučer, 16:26   #3012
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,352
Ja sam sarkastičan, ali evo ovaj free commander ti je sasvim upotrebljiv, pogotovo ako znaš komande tj shrtcoute još iz doba norton commandera, iste su.
Staro Jučer, 21:43   #3013
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,178
The latest Windows 11 releases, versions 24H2 and 25H2, have a very bizarre bug, where closing Task Manager does not close its process properly, and every other launch results in duplicate processes piling up and eating your system's resources. Right now, there are no official fixes, except for a temporary workaround, where Microsoft recommends users kill duplicated processes with the taskkill.exe /im taskmgr.exe /f command executed as Administrator. However, enthusiasts have already discovered a way to resolve the issue.
> How to fix duplicate Task Manager processes in Windows 11
Starting with Windows 11 version 24H2, Microsoft automatically encrypts all drives when you set up a new computer. In the past, BitLocker was a security feature reserved for Professional SKUs, but now, encryption is standard even on Home editions. While BitLocker is not a bad thing per se (it is for your security, after all), the bad part is that Microsoft is not asking users whether they want it or not. Windows 11 won't even let you know that it just encrypted all your drives, and there are already plenty of horror stories about users losing their data. Not cool.
If you want to install a vanilla Windows 11 version 24H2 or 25H2 without any mods, be aware that Microsoft will encrypt your drives if you sign in with a Microsoft Account during the initial setup or even after it. This could be a nasty surprise for those coming from the now-unsupported Windows 10, especially when trying to move a drive from one PC to another. Fortunately, there is a way to reverse that, and this guide will show you how to remove BitLocker encryption in Windows 11.
> How to remove BitLocker drive encryption in Windows 11
Last month, Microsoft announced that it is introducing a new wake phrase, "Hey, Copilot", that Windows customers can speak to trigger their Copilot experience. This brought back memories of the ill-fated "Hey, Cortana" from 2015, but the jury's still out on how Copilot will fare in this domain. Now, Microsoft is looking to go one step ahead in this area by introducing a new phrase.
In an update on its Microsoft 365 Roadmap, Microsoft has noted that while Microsoft 365 Copilot on Windows already has voice activation through "Hey, Copilot", it is in the process of developing a "semantic goodbye word" as well. In simple terms, you'll be able to invoke Copilot's voice interface through "Hey, Copilot" and disengage with it through a phrase like "Bye, Copilot", making it a hands-free interaction.
> Bye, Copilot: Microsoft is making Copilot a hands-free experience on Windows
