#812 |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,651
PA ima na jobito onaj frajer koji maltretira Indijske scammere. Pred već barem pola godine je bio složio svoj garažni call centar gdje ti njegovi "AI" botovi dovode indijce do ludila i to uživo. Ne znam koliko je roknuo u hardware, ali mislim da je imao istovremeno 12 linija koje roštaju cijeli dan. Kit Boga, kako li se zove.
#813 | |
White Rabbit
Postovi: 5,129
Hilarious ![]() |
#815 |
Uptime 99.99%
Postovi: 2,662
Indijci kad namire lovu nikad ne odustaju. https://youtube.com/shorts/_TaS080vGKc Sent from my SM-S931B using Tapatalk
#816 | |
White Rabbit
Postovi: 5,129
Iduci velik problem o kojem nitko ne prica: Citiraj:
#817 | ||
Postovi: 18,906
Ponavlja se slučaj iz 2017... https://thehackernews.com/2017/07/ir...a-vacuums.html
#819 | ||
White Rabbit
Postovi: 5,129
>> Techradar >> WebProNews Opet problemi sa npm libovima: Citiraj:
> bleepingcomputer |
#820 |
Lokacija: tu
Postovi: 3,651
Ovo je baš nezgodno. Zato ekipa i upozorava da čim više vanjskog softwera koristiš šanse da budeš naletio na neki scam rastu, pošto s vremenom netko može preuzet projekt i raditi ovakve pi*darije.
#821 |
Uptime 99.99%
Postovi: 2,662
EY Data Leak - Massive 4TB SQL Server Backup Exposed Publicly on Microsoft Azure A massive 4TB SQL Server backup file belonging to global accounting giant Ernst & Young (EY) was discovered publicly accessible on Microsoft Azure. The file's naming convention screamed SQL Server backup (.BAK format), which typically contains full database dumps, including schemas, user data, and, crucially, embedded secrets such as API keys, credentials, and authentication tokens. A simple HEAD request designed by researchers to retrieve metadata without downloading content revealed a massive size: 4 terabytes of data, which is equivalent to millions of documents or the contents of an entire library. https://cybersecuritynews.com/ey-data-leak/ Sent from my SM-S931B using Tapatalk
#822 | |
White Rabbit
Postovi: 5,129
auch.... |
#823 | |
White Rabbit
Postovi: 5,129
Na ovo se moram malo nasmijati ![]() Citiraj:
#825 |
Lokacija: Dbk
Postovi: 1,315
Direkt link na screenshot : https://files.catbox.moe/80kwmt.jpg Sad se nameće (retoričko) pitanje zašto Pixela sa standardnim Google provided OSom Cellebrite može otključati, a onoga sa Grapheneom ne može. Zašto Google ne začepi tu rupu koja je već dugo vremena poznata, osim ako je namjerno dopušta. |
#827 | |
8-bit Gen.
Lokacija: Giethoorn - ZG
Postovi: 3,161
Leaked documents expose deep ties between Israeli army and Microsoft Citiraj:
#828 | |
White Rabbit
Postovi: 5,129
Prilično detaljno dokumentirano, topla preporuka: Citiraj:
> Hacking India’s largest automaker: Tata Motors |
#829 | |
White Rabbit
Postovi: 5,129
> CISA Alerts on Linux Kernel Vulnerability Exploited in Ransomware Attacks |
#830 | ||||
White Rabbit
Postovi: 5,129
Ponekad je gluplje i jednostavnije - bolje. |
#831 |
Lokacija: Dalmacija
Postovi: 5,893
https://www.instagram.com/reel/DPHFw...YybGJsdTRsYg== TLDR Auto skuplja podatke o voznji, GM ih prodaje data brokeru, data broker ih prodaje osiguranju. U ovom slucaju covjeku je skocila cijena osiguranja 80% zato jer je imao puno "near crash events at night" crash events at night su bile njegove macke koje izlete pred auto svaku večer jer je dosao kuci. Inace prate kad vozis, koliko vozis, kako vozis, gdje vozis, kako kocis, kako ubrzavas itd. itd. GM kaze sve pise u terms and conditions ![]() Poanta je i kako je on kaznjen, za krive podatke i netocne informacije, tako da nam sljeduje i gore sa AI radnicima, al korporacije nije briga, njima je to profit ![]() |
#833 | |
El Mattador
Lokacija: <->
Postovi: 1,925
U slučaju da je to istina osiguranje bi trebalo navesti razloge poskupljenja i ovaj tip bi to pokazao na videu. Nadalje, da je to istina, pokazali bi i ljude kojima osiguranje NIJE poskupilo a voze isti automobil a nemaju sve gore navedene "prijestupe". Ne kažem da sve to ne bi moglo biti tako ali ovaj gore video ocjenjujem kao clickbait. P.S. Još jedan razlog - "Near collision" ne znači ništa, palo bi na sudu samo tako. Jer j*bati i skoro j*ebati nije ni približno isto. ![]() |
#834 |
Lokacija: tu
Postovi: 3,651
Evo tu imaš dosta više detalja. Slobodno ti dovodi u pitanje sve što želiš, ali mora ti biti jasno da 99% instagram korisnika ima attention span od max dvije minute. https://web.archive.org/web/20250906...a-consent.html Bokte mazo, moraš skinuti video da vidiš koliko traje. Kakve su to legende. Dakle, traje 2:59, vjerojatno se nisu usudili ići na 3 minute jer bi to bio insta mind blown.
#835 | |
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,819
#836 | |
Lokacija: Dalmacija
Postovi: 5,893
Pitao sam chatgpt za factcheck prije postanja rekao mi je "substantially supported by credible sources" good enough for me. Citiraj:
Tocno sam na te ciljao tako ce bit i sa zdravstvom pa bolesne ljude nece osigurati, to se u biti vec sad dogadja, manje u nas nego u ameriki |
#837 | |
Uptime 99.99%
Postovi: 2,662
Takvima nema pomoci...na njihovu nesrecu nisu najbistriji i oni ocekuju od drzave da se pobrine za njih. Takvi najcesce kazu, spijuniraju te ionako cim imas smartphone. A nemojte misliti da je kod nas isto zdravstvo zagarantirano, moglo bi i kod nas biti kao u americi. I kod nas je vec bilo, ako osiguranje sazna da imas rak ne zeli te osigurati, pa sad ti zamisli koliko su im vrijedni ti podaci. Ima i onih koji dobrovoljno dijele, kao i u skandinaviji koji su si dobrovoljno ukljucili na kreditnim karticama pracenje CO2 kod kupnje. Citiraj:
“Those who surrender freedom for security will not have, nor do they deserve, either one.” Zadnje izmijenjeno od: Bono. 02.11.2025. u 18:02. |
#838 | |
#erase startup-config
Postovi: 3,732
Imao sam rak. Mislio sam da me nitko neće osigurati ali evo iz prve ruke sam se pozitivno iznenadio u razgovoru s nekim osiguravateljima. Prema njihovim statistikama određeni postotak preživjelih od raka su manji rizik nego prosječni građani jer se puno više paze (prehrana, kretanje, izbjegavanje poroka…). |
#839 |
Uptime 99.99%
Postovi: 2,662
Croatia osiguranje isto? https://www.index.hr/mobile/vijesti/...a/2709156.aspx Sent from my SM-S931B using Tapatalk
#840 | ||
White Rabbit
Postovi: 5,129
Ne spada direktno u ovu temu ali... Citiraj:
