Staro 30.08.2025., 05:55   #5101
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 4,952
For months we have been gathering and gradually testing AMD B850 motherboards, and we are finally ready to share the data for the most affordable models we have on hand. There is a lot to cover, so let's get started.
This first part of the roundup comprises 23 motherboards, while part 2 will feature an additional 20+ models that are a tad more expensive, and we will include the combined data for all B850 boards in that huge roundup.
> Techspot
Staro 15.09.2025., 15:16   #5102
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Od danas sam na gb b850 gaming x wifi6 pa cemo vidjeti
MojSkuter
Zadnje izmijenjeno od: Eladio. 15.09.2025. u 15:39.
Staro 15.09.2025., 16:15   #5103
Dottore
Dottore's Avatar
Postovi: 7,660
Autor Eladio Pregled postova
Nije valjda wifi 6E?
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 15.09.2025., 16:38   #5104
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Autor Dottore Pregled postova
Ma da, Gaming X WIFI6E, ...nesto joj fali?
MojSkuter
Zadnje izmijenjeno od: Eladio. 15.09.2025. u 16:45.
Staro 06.10.2025., 22:34   #5105
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,226
krenuo malo gledat sta bi bilo ok uzet za AM5. glava me pocela bolit.
kolko kuzim treba gledat b650, x670, b850 i njihove "e" verzije, ako je to uopce bitno za nekoga ko koristi za gaming sa jednim GPU i ako sama "e" verzija ne znaci puno skuplju plocu.
ono sto mene buni/brine je limit USB konektora jer koliko ja vidim sve imaju dosta malo il ja tu nest nisam dobro shvatil?
nebih bas mATX, klasika ak je moguce.
sta bi bilo po vama ok za uzet za 3d proc (koji?), 32gb (suggestion do 130e?), radenku 9070 (probably) i 1 il 2 nvme + moguscnost kojeg SATA SSD-a.
nikakvi posebni fičrsi, wifiji na ploci, USB-i 4 i sl. nisu bitni, al mora imati min 6 USB-a straga (2x USB 3.0, ostali nebitno jer su za mis, tast, sluske, mob,..), i 2x front na caseu (3,0 po mogucnosti) za stickove.
SPDIF opticki izlaz must!
potencjalni CPU OC down the road, ak je to uopce jos "in" jer pojma nemam nis nakon AM4 (koji nikad nisam OC/UV jer nisam ufatio vremena).
mislim da bi 150€ bio nekakav plafon.
nekak se koncentriram na MSI. kolko vidim gaming plus i pro verzije koje su mi prve zapele za oko mogu zaboravit jer nemaju optiku. znaci zalazim vec vanka budgeta i gledam tomahawk?
mozete i nest drugo navest, ak je bas u tom cjenovnom rangu.
vjerovatno bi islo iz mind-a, ako se odlucim poslat hebenu ID mailbox-u na "verification" .
We all must hang together, or surly we will hang separately.
Staro 07.10.2025., 12:15   #5106
Postovi: 8,332
IMHO jedino te obavezni SPDIF "koči" u kupnji bilo koje solidne ploče, neovisno da li je riječ o B650, X670 ili novijim B850 i X870, jer su sve to identični čipseti samo prepakirani za "nove" ploče. MSI MAG B650 Tomahawk Wi-Fi je trenutno 168€ na Mindfactory cjeniku, tak da nisi previše van budžeta, ako svakak mora biti SPDIF.
Staro 07.10.2025., 13:47   #5107
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,310
Samo preskoči Asrock jer još ni sami izgleda nisu skužili gdje su zasrali.
Slobodno me dodajte na PSN
Staro 07.10.2025., 15:03   #5108
geronimo_2
geronimo_2's Avatar
Postovi: 4,226
Fala dečki.
Asrock ne gledam jer sam vec vidil da ste spominjali neke probleme.
Nekak gledam najvise msi.
edit: koliko generacija/godina unapred gledano bi se moglo pokazati da mi fali PCIe 5.0 ak se ne uzme "e"? pretpostavljam da je trenutno totlano nebitan (sto se tice grafe). za nVME me ne zanima, sasvim su mi dovoljne normalne brzine koje su sad "in".
edit2: i malo brine compatibilitiy sa noctua nh-d14. nisam siguran sta im znaci ono napisano (offset). moram nac kutiju i krenut proucavat. ak netko zna zasigurno da ide na navedenu maticnu... AM4/AM5 kit imam.
Zadnje izmijenjeno od: geronimo_2. 07.10.2025. u 17:25.
Staro 07.10.2025., 20:21   #5109
Dottore
Dottore's Avatar
Postovi: 7,660
Paše ti, imam ja NH -D12L i bio je na AM4 i AM5. u biti isti utor.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 07.10.2025., 20:30   #5110
Postovi: 8,332
Ja imam Noctua NH-U12A chromax.black na tri MSI MAG B650 Tomahawk Wi-Fi ploče uparene sa 9950X, 7950X i 7600 procesorima, tak da i ovaj tvoj Noctua model svakak paše, dok se offset odnosi na mogućnost pomicanja samog coolera u odnosu na IHS i chiplete ispod. Prilikom montiranja hladnjaka možeš odabrati offset montažu i potencijalno dobiš par stupnjeva nižu temperaturu. Kak god ti paše, jer s tim hladnjakom, 7600X3D bude se svakak dobro ponašal.
Staro 07.10.2025., 20:30   #5111
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,559
https://gamersnexus.net/gpus/nvidia-...ing-benchmarks
Ne da je razlika 5.0 vs 4.0 praktički beznačajna, razlika 3.0 vs 5.0 je praktički beznačajna, na RTX 5090.
Staro 08.10.2025., 12:21   #5112
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,335
Ako grafička ima X8 stazica, što je prisutno na nekim modelima, onda uđe u probleme na pci 3.0. 4.0 će u x16 situaciji biti u redu još dugo dugo.
