Staro 30.08.2025., 06:55   #5101
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,127
For months we have been gathering and gradually testing AMD B850 motherboards, and we are finally ready to share the data for the most affordable models we have on hand. There is a lot to cover, so let's get started.
This first part of the roundup comprises 23 motherboards, while part 2 will feature an additional 20+ models that are a tad more expensive, and we will include the combined data for all B850 boards in that huge roundup.
> Techspot
Staro 15.09.2025., 16:16   #5102
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Od danas sam na gb b850 gaming x wifi6 pa cemo vidjeti
MojSkuter
Zadnje izmijenjeno od: Eladio. 15.09.2025. u 16:39.
Staro 15.09.2025., 17:15   #5103
Dottore
Dottore's Avatar
Postovi: 7,691
Autor Eladio Pregled postova
Nije valjda wifi 6E?
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 15.09.2025., 17:38   #5104
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Autor Dottore Pregled postova
Ma da, Gaming X WIFI6E, ...nesto joj fali?
MojSkuter
Zadnje izmijenjeno od: Eladio. 15.09.2025. u 17:45.
Staro 06.10.2025., 23:34   #5105
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,303
krenuo malo gledat sta bi bilo ok uzet za AM5. glava me pocela bolit.
kolko kuzim treba gledat b650, x670, b850 i njihove "e" verzije, ako je to uopce bitno za nekoga ko koristi za gaming sa jednim GPU i ako sama "e" verzija ne znaci puno skuplju plocu.
ono sto mene buni/brine je limit USB konektora jer koliko ja vidim sve imaju dosta malo il ja tu nest nisam dobro shvatil?
nebih bas mATX, klasika ak je moguce.
sta bi bilo po vama ok za uzet za 3d proc (koji?), 32gb (suggestion do 130e?), radenku 9070 (probably) i 1 il 2 nvme + moguscnost kojeg SATA SSD-a.
nikakvi posebni fičrsi, wifiji na ploci, USB-i 4 i sl. nisu bitni, al mora imati min 6 USB-a straga (2x USB 3.0, ostali nebitno jer su za mis, tast, sluske, mob,..), i 2x front na caseu (3,0 po mogucnosti) za stickove.
SPDIF opticki izlaz must!
potencjalni CPU OC down the road, ak je to uopce jos "in" jer pojma nemam nis nakon AM4 (koji nikad nisam OC/UV jer nisam ufatio vremena).
mislim da bi 150€ bio nekakav plafon.
nekak se koncentriram na MSI. kolko vidim gaming plus i pro verzije koje su mi prve zapele za oko mogu zaboravit jer nemaju optiku. znaci zalazim vec vanka budgeta i gledam tomahawk?
mozete i nest drugo navest, ak je bas u tom cjenovnom rangu.
vjerovatno bi islo iz mind-a, ako se odlucim poslat hebenu ID mailbox-u na "verification" .
We all must hang together, or surly we will hang separately.
Staro 07.10.2025., 13:15   #5106
Postovi: 8,448
IMHO jedino te obavezni SPDIF "koči" u kupnji bilo koje solidne ploče, neovisno da li je riječ o B650, X670 ili novijim B850 i X870, jer su sve to identični čipseti samo prepakirani za "nove" ploče. MSI MAG B650 Tomahawk Wi-Fi je trenutno 168€ na Mindfactory cjeniku, tak da nisi previše van budžeta, ako svakak mora biti SPDIF.
Staro 07.10.2025., 14:47   #5107
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,333
Samo preskoči Asrock jer još ni sami izgleda nisu skužili gdje su zasrali.
Slobodno me dodajte na PSN
Staro 07.10.2025., 16:03   #5108
geronimo_2
geronimo_2's Avatar
Postovi: 4,303
Fala dečki.
Asrock ne gledam jer sam vec vidil da ste spominjali neke probleme.
Nekak gledam najvise msi.
edit: koliko generacija/godina unapred gledano bi se moglo pokazati da mi fali PCIe 5.0 ak se ne uzme "e"? pretpostavljam da je trenutno totlano nebitan (sto se tice grafe). za nVME me ne zanima, sasvim su mi dovoljne normalne brzine koje su sad "in".
edit2: i malo brine compatibilitiy sa noctua nh-d14. nisam siguran sta im znaci ono napisano (offset). moram nac kutiju i krenut proucavat. ak netko zna zasigurno da ide na navedenu maticnu... AM4/AM5 kit imam.
Zadnje izmijenjeno od: geronimo_2. 07.10.2025. u 18:25.
Staro 07.10.2025., 21:21   #5109
Dottore
Dottore's Avatar
Postovi: 7,691
Paše ti, imam ja NH -D12L i bio je na AM4 i AM5. u biti isti utor.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 07.10.2025., 21:30   #5110
Postovi: 8,448
Ja imam Noctua NH-U12A chromax.black na tri MSI MAG B650 Tomahawk Wi-Fi ploče uparene sa 9950X, 7950X i 7600 procesorima, tak da i ovaj tvoj Noctua model svakak paše, dok se offset odnosi na mogućnost pomicanja samog coolera u odnosu na IHS i chiplete ispod. Prilikom montiranja hladnjaka možeš odabrati offset montažu i potencijalno dobiš par stupnjeva nižu temperaturu. Kak god ti paše, jer s tim hladnjakom, 7600X3D bude se svakak dobro ponašal.
Staro 07.10.2025., 21:30   #5111
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,611
https://gamersnexus.net/gpus/nvidia-...ing-benchmarks
Ne da je razlika 5.0 vs 4.0 praktički beznačajna, razlika 3.0 vs 5.0 je praktički beznačajna, na RTX 5090.
Staro 08.10.2025., 13:21   #5112
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,338
Ako grafička ima X8 stazica, što je prisutno na nekim modelima, onda uđe u probleme na pci 3.0. 4.0 će u x16 situaciji biti u redu još dugo dugo.
Staro 24.10.2025., 10:47   #5113
spawn
spawn's Avatar
Postovi: 8,459
Malo sam se pogubio s pločama, treba mi za 9070xt i 7500F koji se bar 5 godina nece upgrejdat. Taman se odlucio i onda mi frend baci bubu u uho da noviji chipset 850 radi bolje i da je 9600X puno hladniji od 7500F? Malo sam procackao po netu,nisam bas vidio toliku razliku ali nisam bas svjeze upucen u AMD,do sada sam bio na Intelu i sada sam na 12400F. S obzirom na razliku u cijeni B850M + 9600X ,što ću dobiti u odnosu na B650M + 7500F? I može li preporuka za neku solidnu i stabilnu ploču za 9070xt za gaming osim Asrock-a,koliko vidim crkavaju procesori na njima, do 160-170€. Ne da mi se uzimati izvana, kupio bih kod nekog našeg trgovca osim protis-a.
Zadnje izmijenjeno od: spawn. 24.10.2025. u 10:59.
Staro 24.10.2025., 11:09   #5114
Postovi: 8,448
B650 i B850 su identični čipseti, samo su prepakirani za nove ploče, tak tu nema neke razlike. Kaj se procesora tiče, 7500F je zapravo 7600 bez iGPU, a 9600X je baziran na novijoj Zen 5 arhitekturi, dok su ovi prijašnji temeljeni na Zen 4 arhitekturi. Po pitanju grijanja, odnosno hlađenja, svi spomenuti proceosri nemaju nikakvih problema s tim, a ionako se u BIOS-u podesi na kojem TDP-u i temperaturi želiš da rade i to je to, nemaš brige kasnije.
Staro 24.10.2025., 11:13   #5115
gogoklepci
Datum registracije: Sep 2019
Lokacija: Mostar
Postovi: 352
Autor spawn Pregled postova
https://ibb.co/1GsGJKx9
https://ibb.co/Q7nPF1tX
stock i nocua 14 cooleri
Generally cooler: The 9600X runs cooler, with peak temperatures around 76.1C in one review, compared to the 7600X's 93C under a similar load
gogoklepci je offline   Reply With Quote
Staro 24.10.2025., 12:39   #5116
Exy
Exy's Avatar
Postovi: 2,611
Fala ti na LLM slopu, vrlo je informativan. Čak nisi uspio ubacit prave proceve nego umjesto 7500F si stavio 7600X koji defaultno ima brutalno visoke TDP vrijednosti i temperaturne granice.
Kao što reče kolega Exiled, to su sve procevi kojima sam odrediš temperaturu koja ti se sviđa i to je potpuni non issue. Inače su 7500F i 9600X vrlo blizu u performansama jer zen5 nije donio baš neki IPC gain vs. zen4.
Staro 24.10.2025., 13:59   #5117
Piksa
Piksa's Avatar
Lokacija: Chakovec
Postovi: 415
Ja isto imam 12400F. A jel se stvarno isplati ići na upgrade na 7500F (ili 9600X) s tog proca? Morao bi i ploču i ram i proc, a dobitak upitan. Istina, ja baš i ne igram, ali na 12400F mi sve super radi. Da ne slažem, zaigrao sam novi Painkiller Demo i na konfi iz potpisa na full hd monitoru imam preko 200 FPS na fps counteru.
Piksa je offline   Reply With Quote
Staro 24.10.2025., 17:11   #5118
spawn
spawn's Avatar
Postovi: 8,459
Mijenjao bih zato sto mi konfi istice jamstvo za par mjeseci te imam kupca. A da ne kupujem isto ali novo, trazim nesto bolje. Znaci 7500 moze komotno sa b650. Gigabyte vs Asus vs MSI? Za Asrock citam da ubija neke cpu modele?
Staro 24.10.2025., 17:24   #5119
Odinarius
All-rounder
Postovi: 1,338
Asrock je problem s X3D procesorima, ali i to je riješeno. Valjda, spalilo mi je prvi, ali drugi se zasad drži U prošloj generaciji je Asus pržio X3D proceve?
7500 i B650 best buy, imaš roundupove B650 i B850 ploča na Techspotu odnosno Hardware Unboxed, pa vidi koja je tebi najbolja. Ali osim 2-3 šrot modela sa slabim VRM-om, sve ostalo je sasvim u redu i za budućnost.
https://www.techspot.com/review/2699...-motherboards/
https://www.techspot.com/review/3027...-motherboards/
Staro 24.10.2025., 17:24   #5120
Postovi: 8,448
ASRock je OK za non-3D cache modele, jer su ti (bili) najviše na udaru, ali općenito dokle god ploča nudi sve kaj trebaš, to je to.
Staro 24.10.2025., 17:34   #5121
spawn
spawn's Avatar
Postovi: 8,459
Hvala svima
Staro 01.11.2025., 22:13   #5122
geronimo_2
geronimo_2's Avatar
Postovi: 4,303
poz.
MSI B650 TOMAHAWK WiFi je na putu.
Gledam kako pobost m2 diskove (2 kom). ak dobro kuzim treba prvo M2_1 i M2_2?
M2_3 je kao vezan za chipset? jel to losije/sporije/nestabilnije or what?
stavili su hladnjake na M2_1 i M2_3. jel se moze to skinut sa M2_3 i ubost na M2_2 il to neide?
jesu ti hladnjaci uopce cemu?
edit:
ak popunim sva 3 m2 slota jel brzina ide dole? znam da m2_3 share-a sa PCI_E3, al to necu sigurno koristit...
Staro 01.11.2025., 22:21   #5123
Postovi: 8,448
Vredu su ti M2 hladnjaci, a i možeš ih razmjestiti, dok PCI_E2 i M2_3 dijele bandwidth, tak da imaju manju propusnost kad se koriste istovremeno.
M2_3 & PCI_E2 share the bandwidth. M2_3 will run at x2 speed and PCI_E2 will run at x2 speed when installing devices in both slots.
M2_3 brzina, tj. propusnost bude se smanjila, ako istovremeno imaš u pogonu i sve ostale uređaje (SATA, USB, itd.) koji idu kroz čipset, tj. ako ti se potrefi ta kombinacija opterećenja.
Zadnje izmijenjeno od: The Exiled. 01.11.2025. u 22:29.
Staro 01.11.2025., 22:36   #5124
geronimo_2
geronimo_2's Avatar
Postovi: 4,303
ak sam dobro shvatil, samo M2_3 je affected sa uredajima koje spominjes, M2_1 i M2_2 nisu ni u kojem slucaju cak ni kad se koriste USB-i koji su preko CPU?
edit:
fala exiled
Zadnje izmijenjeno od: geronimo_2. 01.11.2025. u 22:42.
Staro 01.11.2025., 22:38   #5125
Postovi: 8,448
Da, kod sebe sam na ovom primarnom kompjuteru sa 7950X na tu ploču spojil sve osim M2_3, jer jednostavno nemam treći NVMe i sve radi OK.
Staro 01.11.2025., 23:37   #5126
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,900
Koliko sam ja pohvato usporedjujuci ta 2 chipseta, glavna razlika je u tome da B650 podrzava max M.2/​M-Key (PCIe 4.0 x4 ) a B850 podrzava M.2/​M-Key (PCIe 5.0 x4 ).
Znaci na B850 bar jedan M.2 mora biti PCIe 5.0 a B650 ni jednu nisam nasao da podrzava vise od PCIe 4.0.
trebaš seedbox?
Staro 01.11.2025., 23:44   #5127
Postovi: 8,448
Je, AMD im sad uvjetuje PCI-E/M.2 5.0 i USB 4, dok su im prije dali na izbor, makar su to identični ASMedia čipseti, pa ima raznih B650 izdanja.
Staro 02.11.2025., 10:13   #5128
geronimo_2
geronimo_2's Avatar
Postovi: 4,303
poz.
jel se moze koristiti manje nvme od 2260 na maticnima, ako u manualu pise od 2260 na gore? fizicki vidim da nema vijka, al neznam dal su 2230 toliko kratki da im ne treba vijak/stand?
Staro 02.11.2025., 11:29   #5129
Postovi: 8,448
Imaš samo dvije pozicije za šrafić, 2260 i 2280, a 2230 bude ostal u zraku.
Staro 02.11.2025., 12:02   #5130
Postovi: 10,184
Ako imas nacin da ga necim pritisnes, mozes ga ubosti i koristiti. Realno ti ne treba sarafic ako ce komp biti stacionaran.
Ima i adaptera za nabaviti kod kineza ili za isprintati:
https://www.google.com/search?sca_es...h=782&dpr=2.63
