Povratak   PC Ekspert Forum > Računala > Overclocking > Memorije
Staro 21.11.2019., 09:21   #241
quazar912
quazar912's Avatar
Lokacija: north-northwest
Postovi: 1,990
pa i bio bi red jer je stigo DDR4
al opet može to još niže
...and fly...
Thule nosač
Staro 21.11.2019., 12:16   #242
nino
nino's Avatar
Postovi: 12,613
Koliko sam skuzio, ovo je opcenito za ram, ne samo ddr3.
Btw, uvijek nakon niske cijene, stize povecanje na duplo.
Staro 21.11.2019., 13:35   #243
Postovi: 8,229
Autor nino Pregled postova
Da, kao EOL bla bla, ne pravi se više. Il će biti poplava opet.
Staro 21.11.2019., 13:46   #244
srale7
srale7's Avatar
Postovi: 5,789
Pa valjda se gleda aktualni ram i njegove cijene (ddr4) a ne prevaziđene generacije
Staro 06.10.2020., 19:43   #245
Postovi: 8,512
SK hynix Launches World’s First DDR5 DRAM
DDR5 is the next stage of platform memory for use in the majority of major compute platforms. The specification (as released in July 2020) brings the main voltage down from 1.2 V to 1.1 V, increases the maximum silicon die density by a factor 4, doubles the maximum data rate, doubles the burst length, and doubles the number of bank groups. Simply put, the JEDEC DDR specifications allows for a 128 GB unbuffered module running at DDR5-6400. RDIMMs and LRDIMMs should be able to go much higher, power permitting.
With DDR5, one of the major changes to help drive this is the way the memory is seen by the system. Rather than being a single 64-bit data channel per module, DDR5 is seen as two 32-bit data channels per module (or 40 bits in ECC). The burst length has doubled, meaning that each 32-bit channel will still deliver 64 bytes per operation, but can do so in a more interleaved fashion. That means the standard ‘two 64-bit channel DDR4’ system will morph into a ‘quad 32-bit channel DDR5’ arrangement, although each memory stick provides a total of 64-bits but in a more controllable way. This also makes doubling the data rate, a key element in increasing peak bandwidth, easier, as well as a finer-grained bank refresh feature, which allows for asynchronous operations on the memory while it is in use, reducing latency.
Voltage regulation is also being moved from the motherboard to the memory module, allowing the module to regulate its own needs. It also puts power management in the hands of the module vendor rather than the motherboard manufacturer, allowing the module manufacturer to size up what is required for faster memory – it will be interesting to see how different firmware cope with non-JEDEC standard gaming memory that will undoubtedly go above specification.
SK Hynix’s announcement today is that they are ready to start shipping DDR5 ECC memory to module manufacturers – specifically 16 gigabit dies built on its 1Ynm process that support DDR5-4800 to DDR5-5600 at 1.1 volts. With the right packaging technology (such as 3D TSV), SK Hynix says that partners can build 256 GB LRDIMMs. Additional binning of the chips for better-than-JEDEC speeds will have to be done by the module manufacturers themselves. SK Hynix also appears to have its own modules, specifically 32GB and 64GB RDIMMs at DDR5-4800, and has previously promised to offer memory up to DDR5-8400.
As part of the announcement, it was interesting to see Intel as one of the lead partners for these modules. Intel has committed (1 - 2) to enabling DDR5 on its Sapphire Rapids Xeon processor platform, due for initial launch in late 2021/2022. AMD was not mentioned with the announcement, and neither were any Arm partners. SK Hynix quotes that DDR5 is expected to be 10% of the global market in 2021, increasing to 43% in 2024.
Izvor: AnandTech
Staro 28.11.2020., 06:05   #246
ne0mage
ne0mage's Avatar
Datum registracije: Nov 2020
Postovi: 3
Bok ljudi, zanima me ako netko zna da li ima igdje kupiti Corsair Dominator Platinum ( CMD8GX4M2B3000C15 ) ?
Do sada sam imao 4x4GB, jedan stick je odnia vrag tako da sam u potrazi za 1x4GB ili 2x4GB.
Surfam već satima i nema sreće, pa ako netko ima da prodaje . Spasio bi me.
LP
ne0mage je offline   Reply With Quote
Staro 28.11.2020., 13:55   #247
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,639
U potrazi sam za 2666 DDR4 koji bi kombinirao sa i5-10400. Posto je ogranicen proc na 2666, planirao sam uzeti neku sa nizom latencijom.
Sto uzeti https://www.protis.hr/products/index/memorija/106?
Ima li smisla uzeti brzu memu pa je downclockati i zategnuti cas ili da idem na 2666 memu cl13?
Staro 07.08.2021., 16:27   #248
Postovi: 8,512
DDR5 memory will need better cooling as VRMs move to the module
DDR5 modules will be faster and hold more memory than DDR4 ever did. That's partly due to the shift of power management ICs and voltage regulating modules from the motherboard to the module itself, increasing the number of heat sources therefore generating more heat. Many believe DDR4 and older modules do not generate enough heat to justify the use of heatsinks, but because of some inherent changes of DDR5 memory, it looks like decent cooling solutions will be needed. One such difference is the move of power management ICs (PMIC) and voltage regulating modules (VRM) to the module, generating more heat compared to their predecessors. In Corsair's case, they will use its DHX technology, which uses fins to dissipate heat from the outer part of the chips, and another set of fins to cool the inner part.
This technology was first used in its Dominator DDR1 modules and has since been used on all other Dominator series modules until now. Now that DDR5 modules will include the PMIC and VRM on the PCB, these will need to be cooled. Corsair will probably take care of them by upgrading its DHX solution, but other manufacturers will also have to adapt their solutions to meet the new cooling needs. DDR5 memory is already out in the market, but there's an absence of platforms supporting it. That's expected to change later this year with the release of Intel Alder Lake a.k.a. 12th generation Core processors. Meanwhile, memory manufacturers have been showing off some specifications of this new type of memory, capable of reaching 12,600MT/s speeds and up to 128GB per module while operating at up to 1.6V.
Izvor: TechSpot
Staro 26.09.2021., 10:14   #249
Starsylph
Datum registracije: Oct 2010
Lokacija: Sfera
Postovi: 408
Jel se zna cijena novih DDR5? Ono sto je Exiled napisao "channels per module 2" znaci li to da će 64GB memku moci staviti u jedan slot?
Starsylph je offline   Reply With Quote
Staro 15.10.2021., 21:14   #250
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Autor Starsylph Pregled postova
128 gb ce ic na jedan slot. Cijene jos nisu poznate, a prvo ce izac neke "obicne" memorije, a tek kasnije (to moze bit za 3 mj a moze za godinu) sa vecim brzinama i nizim latencijama, odnosno neke extreme, clockerske, gamerske memorije...
Staro 15.10.2021., 22:08   #251
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
Baš me zanima kolko ce mainstream procesori novih generacija max rama podržavati. Za sada je to u prosjeku 128gb.
Staro 19.10.2021., 16:58   #252
Postovi: 8,512
DDR5's going to be extremely expensive at launch: DDR5 memory is expected to have a 50-60% price premium over DDR4
Intel's 12th Generation Core CPUs are due to launch very soon, and with this will come a next-generation CPU platform and multiple new technologies for the PC marketplace. These technologies include DDR5 memory, PCIe 5.0 connectivity, and more widespread adoption for standards like Thunderbolt 4 and WIFI 6E. DDR5 memory support is a major feature of Intel's Alder Lake processors, offering PC users significantly more bandwidth than DDR4 memory modules. Beyond that, DDR5 is due to be more power-efficient and overclockable thanks to changes within JEDEC's DDR memory standards. In a recent blog post, MSI has confirmed something that we have long expected. At launch, MSI expects DDR5 memory to have a "50-60% price premium" over DDR4 memory. Furthermore, MSI doesn't expect DDR5 pricing to reach parity with DDR4 for "around two years".
Izvor: OC3D
Staro 26.10.2021., 22:07   #253
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,503
Staro 19.11.2021., 16:54   #254
Postovi: 8,512
DDR5 already facing production issues in wake of global chip shortages
DDR5 is being directly impacted by the current logistics issues due to lack of adequate Power Management Integrated Circuit (PMIC) chips - which DDR5 has integrated in the DIMM proper. Currently, lead times for PMIC orders are estimated at 35 weeks, placing additional strain on system assemblers and DRAM manufacturers - and forcing delays and bottlenecks throughout the supply chain. Additionally, the fact that PMIC chips for DDR5 are ten times as expensive as equivalent DDR4 power management solutions doesn't bode well for future price action on DDR. Should this situation continue, higher prices for DDR5 modules are to be expected due to a deteriorating supply/demand ratio - particularly relevant if you're thinking about putting together a build based on Intel's Alder Lake platform.
Izvor: TechPowerUp
Fast memory: Samsung talks about DDR6, DDR6+ and GDDR7
With DDR6, the doubling continues and for DDR6 up to 12,800 MT/s are planned, for DDR6+ it should be 17,000 MT/s. Samsung is working with other JEDEC members from DRAM and SoC manufacturer circles to complete the DDR6 standard, which is currently scheduled for 2024. In the run-up, one of SK Hynix's chief engineers had indicated that it could take a little longer with this generation. Samsung now admits that it is still in the"early stages of development"of DDR6. The number of memory channels per module is to increase to four with DDR6 and thus be doubled again compared to DDR5. The number of banks also increases by a factor of two to 64, which in turn means four times that of DDR4.
Izvor: ComputerBase
Staro 09.01.2022., 22:08   #255
DANCI
Postovi: 735
Ja sam malo gledao na youtube i uspredba ddr4 i ddr5 i nije neka veća razlika u fps-ovima. Ako se radi o igri ispod 100 fps-a onda je razlika jedva 5-10fps ?
Jel to zbog latencije koje su dosta visoke ili što ?
DANCI je offline   Reply With Quote
Staro 10.01.2022., 04:14   #256
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,199
Pogledaj donji video za objašnjenje.
DDR5 is FINALLY HERE... and I've got it
0:00 Intro
0:57 DDR5's physically different
2:29 DDR cash money
3:10 Advantages over DDR4
4:04 Why not just go faster?
5:25 Getting around the bottlenecks
7:07 This isn't dual channel
7:51 In-chip bit flip protection (no, it's not "real" ECC)
8:40 DDR4 is FASTER??? Overclock time! +RGB
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 12.01.2022., 20:59   #257
DANCI
Postovi: 735
Dobro vidim da se spominje bottlenecks kao razlog tomu, a koje je riješenje svemu tome da ima smisla prijeći na DDR5 jer ovako gledajući šta ja znam...
Ne vidim smisao prelaska s DDR4 na DDR5, ionako današnja računala ovisno o zahtjevnosti korisnika dovoljno je 8-16 i 32GB rama što DDR4 može ionako pružiti preko 4 slota.
Staro 03.09.2022., 21:26   #258
Postovi: 8,512
Entry-level DDR5 prices expected to drop rapidly this year
According to a report by DigiTimes Asia, DDR5 memory prices are expected to plunge in the 2nd half of 2022 and continue to drop in 2023. DDR5 contract prices reportedly fell by 20% in July, and chip vendors have begun 'offloading' entry-level DDR5 chips, with consumer DDR5 module pricing at channel distributors falling below that of memory module manufacturers. DigiTimes say prices will continue to drop rapidly in the second half of 2022 and will hit the "sweet spot" in 2023. Falling DDR5 prices are also expected to boost the adoption rate of DDR5. This is on top of the rapid price reductions on DDR5 this year. Unfortunately, these sources don't say DDR5's sweet spot pricing, but we expect optimal prices to be close to current DDR4 pricing, if not identical. The timing of reduced DDR5 pricing couldn't be better. With the release of AMD's DDR5-only Ryzen 7000 series processors, DDR5 will become a high-demand item very soon. Lower prices will also help AMD stay competitive with Intel's cheaper DDR4-supporting Alder Lake and Raptor Lake alternatives.
Despite this, even Intel will also benefit from the DDR5 price reductions. Intel has already supported DDR5 for almost a year with Alder Lake, but due to pricing issues, most of Intel's user base has stuck with DDR4 instead of moving to DDR5. Once DDR5 demand increases and prices decrease, we can expect new Intel buyers to follow suit and purchase high-speed DDR5 memory kits instead of DDR4 kits. This will be optimal for Intel since its Alder Lake architecture can take advantage of DDR5's immense bandwidth upgrades in various workloads. Currently, DDR5 prices are already very low compared to where they were in late 2021. A baseline 4800MHz 32GB dual channel kit of DDR5 memory costs $149.99 at the time of this writing, with a higher frequency kit costing about as much as DDR4 was during the memory shortage a few years ago. For instance, prices for a 32GB 6000MHz kit with decently tight CL36 timings cost $239.99.
For reference, DDR5 pricing just nine months ago was double these prices at the very least, with high end kits going for upwards of $800-$900.
With sources saying prices will rapidly decline again as they did in 2021, we should expect DDR5 prices to continue to slide throughout 2023.
Izvor: Tom's Hardware
Staro 04.09.2022., 06:59   #259
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,710
Ne samo ddr5, sve ide dolje.
NAND -50% do kraja godine.
Još kad bi i dolar pao, puna šaka brade za kupce hardvera.
Staro 04.09.2022., 10:50   #260
medo
#erase startup-config
medo's Avatar
Postovi: 3,732
Preporuke kupovine i novosti na tržištu RAM-a
Meni je u banani što nema full ECC podrške za consumer DDR5. Pričalo se da će svaki DDR4 imati ECC pa od toga nije bilo ništa. DDR5 je dobio ECC ali navodno samo u modulima. Nema ECC do CPUa. Ako se dogodi bit-flip između CPUa i RAMa neće biti detektiran. Iako bolji i to nego da nema uopće samo ne znam kako će CPU detektirati bit flip u modulu?
Staro 09.07.2025., 10:24   #261
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
evo: https://www.crucial.com/catalog/memo...--64GB@density
sad za nas koji smo škti za TR-e neka slože neki provjereni combo 4x64gb kit i kupujem
Staro 23.07.2025., 12:14   #262
Postovi: 8,512
DDR6 memory arrives in 2027 with 8,800-17,600 MT/s speeds
The semiconductor industry has officially accelerated its next-generation memory development, with DDR6 standard now coming soon. Although enthusiasts won't find these modules available until 2027, key players, Samsung, Micron, and SK Hynix, have already moved past prototype stages and embarked on rigorous validation cycles. In partnership with Intel, AMD, and nVidia, they're targeting an initial throughput of 8,800 MT/s, with plans to scale up to a staggering 17,600 MT/s, effectively doubling the ceiling of today's DDR5. This increase is driven by DDR6's 4×24-bit sub-channel architecture, which requires entirely new approaches to signal integrity. Additionally, it also differs from DDR5's current 2x32-bit sub-channel structure. To overcome the physical limits that DIMM form factors faced at higher speeds, the industry is betting on CAMM2. Early indication is that server platforms will lead the change, with high‑end notebooks following suit once manufacturing ramps up.
Behind the scenes, timelines are being mapped: platform validation is slated for 2026, server deployments in 2027, and broader consumer availability thereafter. This phased rollout mirrors the DDR5 journey; however, analysts predict that DDR6's architectural leap could accelerate adoption in AI and high-performance computing environments. Of course, cutting-edge technology comes with a premium: initial DDR6 modules are expected to carry price tags reminiscent of DDR5's 2021 debut, potentially limiting early adoption to hyperscale data centers and AI research labs. Yet with HPC and AI appetite for bandwidth, memory makers are targeting launch as soon as possible to satisfy the massive deployment of compute. By 2027, CAMM2‑based modules running at DDR6 speeds may well define the new standard for high‑performance systems.
Izvor: TechPowerUp
Staro 23.07.2025., 17:35   #263
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,710
Autor kopija Pregled postova
Heh, post iz 2022.
Dinamično je tržište RAM memorija...
Sad je 4 skuplji od 5.
Kad bi barem grafe napredovale ko keksi.
Staro 28.10.2025., 12:10   #264
Postovi: 8,512
Staro 28.10.2025., 15:06   #265
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 726
Da, počelo je već i kod nas (za poskupljenja ih ne treba tjerat kao kad treba pojeftiniti)
Jučer u Mall.HR, Trident Z5 2x32GB kit 268,81 i 279,69, jutros oba 484,22 €.
(pod oba mislim na dva podmodela, -TZ5N za Expo i -TZ5K XMP).
Na brzinu sam preletio i ostale cjenike i svi su panično digli, neki i na 613€ za RGB varijante. Kod nekih još ima na cjenicima ali će vjerojatno odjednom postati "neisporučivo" .
Staro 29.10.2025., 23:19   #266
Postovi: 8,512
Ode RAM nebu pod oblake do te mjere da sad malo bolji 64GB kompleti koštaju koliko sam prije koji mjesec platil 128GB i 192GB.
Staro 29.10.2025., 23:25   #267
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,360
Ma ludilo totalno.
Ja naso onaj cors veng ddr5 cl30 za 160e u linksu. Jedino objašnjenje da je neko zahebo i nije digo cjenu jer svugdje drugdje, i sve meme otišle u nebo.
Hebo ih AI.
We all must hang together, or surly we will hang separately.
Staro 30.10.2025., 11:05   #268
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 726
Ako netko treba, ima kod tonerpartner.hr još raznih kombinacija (od 16GB single do 96GB kitova) po normalnim cijenama. Web im baš nije bogat filterima pa treba strpljivo kopati jer neke već jesu poskupili.
Uplatio sam jedan Mile Kitić da imam za rezervu ako nevolja potraje
Staro 05.11.2025., 18:58   #269
ICT Avatar
ICT Avatar's Avatar
Datum registracije: Dec 2014
Lokacija: Area 51
Postovi: 242
ICT Avatar je offline   Reply With Quote
Staro 06.11.2025., 17:38   #270
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,710
Teška vremena.
Global memory supply constraints continue to pressure the industrial PC (IPC) market, with Taiwanese technology company Advantech Co. reporting that tight DDR4 memory availability reduced its gross margin by around 1% in the third quarter of 2025. During its third-quarter earnings call, Advantech disclosed that ongoing shortages of DDR4 DRAM chips have significantly impacted the entire supply chain for industrial PCs.
