Staro 02.05.2025., 00:02   #7141
Postovi: 10,054
A koja je kartica u pitanju? Vidim u opisu drivera se spominje kako vise nema novih verzija drivera za neke kartice koje su end-of-life, ukljucujuci i popularnu AC 8260
"From the release 22.210.0 package onwards, this software no longer includes drivers for discontinued wireless products: Intel® Dual Band Wireless-AC 8260 and Intel® Dual Band Wireless-AC 8265. For 8260 and 8265 Bluetooth® drivers, see Intel® Wireless Bluetooth® Drivers for Intel® Dual Band Wireless-AC 8260 and Intel® Dual Band Wireless-AC 8265."
Staro 02.05.2025., 09:52   #7142
Dottore
Dottore's Avatar
Postovi: 7,645
Autor chillout23 Pregled postova
Maknuo oba drivera kroz DM.
Nakon deinstalacije restart laptopa...preko instalera pokrenuo novi BT...isti problem kao i prije...
Ponovio postupak i kroz BT settings maknuo device/zvučnik i pobovo pokrenuo spajanje kroz settings...isti problem.
Pogledam driver verziju i opet ista 22.140.0.4
WiFi: odmah nakon restarta laptopa nakon deinstalacije, driver je opet bio tu i WiFi opcija u taskbaru omogućena (?!), samo me kod spajanje tražio da ponovo upišem wifi password...
Odem u DM i vidim da je isti driver ostao...ponovo uninstall kroz DM i restart i WiFi opet tu i sve isto...
Driver verzija ista, naravno 20.70.3.3
Dakle uopće ne miče WiFi driver...kad odem na update driver i manual install, javi da je najbolji mogući driver već instaliran i ne mogu ga maknut uopće da dobijem u DM da fali driver i da ga povučem...
Ne kroz device managera, moraš ih unistall app u postavkama.
Zato ti ona vuče iste drivere.
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 02.05.2025., 10:52   #7143
chillout23
Your God is in your mind.
chillout23's Avatar
Datum registracije: Jun 2017
Lokacija: Planet Earth
Postovi: 642
Autor xlr Pregled postova
Ta je
Autor Dottore Pregled postova
Aha, ok...idem pokušat, hvala ti
Mjesto rođenja: Zemlja, Rasa: čovjek, Politika: sloboda, Religija: ljubav
chillout23 je offline   Reply With Quote
Staro 02.05.2025., 20:25   #7144
chillout23
chillout23's Avatar
Postovi: 642
Pokušao par puta i svaki puta je wifi odma tu...
Maknuo sam ih kasnije i sa DriverStoreExplorerom...WiFi opet nakon reseta ovdje...BT samo pokušal onaj driver kaj si mi dao i ništa - ne pozna ga.
Išao sam onda na Lenovo site, preko SN tražio update drivera i ponudio je i WiFi i BT...povukao oba, ali opet one iste verzije koje imam ionako...
Staro 02.05.2025., 20:51   #7145
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
Zamijeni wlan karticu.
Spoiler alert!
Staro 02.05.2025., 21:13   #7146
chillout23
chillout23's Avatar
Postovi: 642
Morat ću...vidim da se spominje kod Wlan kartice i BT spojivost..da li je to jedna kartica sa oba modula?
Gledam da bi išao na AX200...ima na aliju..
Ili AX210...meni je svejedno koja od njih...za moje potrebe ne igra ulogu...
Jel ok da uzmem od tamo ili netko ima možda bolju/jeftiniju/whatever opciju? Sa alija bi čekao sigurno 20ak dana--
Nego, @calypso ima iz T490 karticu...da li bi mi ona pasala u T480s?
Kaže da ne zna koja je...
Zadnje izmijenjeno od: chillout23. 02.05.2025. u 22:28.
Staro 02.05.2025., 21:14   #7147
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
Isprobaj. Jel whitelist kod tih modela prisutan?
Spoiler alert!
Staro 02.05.2025., 21:49   #7148
medo
#erase startup-config
medo's Avatar
Postovi: 3,705
U bivšoj firmi je bilo Thinkpada sa polukrepanim WiFi modulima koji zezaju. To je najviše mučilo kabrončeke Gen3 - na svima njima bi to krepalo nakon 3-4 godine. WWAN moduli također.
Simptomi su bili: puca wifi ili se uopće ne želi spojiti pa sporadično nekada možda proradi…
Navodno ima fora da se prefleša BIOS da primi bilo koju wifi karticu.
Staro 02.05.2025., 22:35   #7149
chillout23
chillout23's Avatar
Postovi: 642
Ne mogu se baš igrat i isprobavat jel više nisam u Zg i ne dolazim često...
Ne znam za whitelist, ali ima brdo ekipe koji su uzeli jednu od te 2 kartice za par TP modela i svi jako zadovoljni...nisam naletio na nijedan nezadovoljan feedback nigdi..
Staro 02.05.2025., 22:41   #7150
Postovi: 10,054
Na x280 imam AX210, nema problema s whitelistanjem. Koliko vidim to su maltene modeli istih specki po pitanju wifija (ista su generacija).
Ta kartica je no brainer, naknadno sam je ugradio u dva desktop kompa i to je sve sto mi treba u zivotu. (Skoro) gigabit preko wifija
Staro 02.05.2025., 23:18   #7151
chillout23
chillout23's Avatar
Postovi: 642
Da li je ta kartica i wlan i BT ili za BT trebam neku drugu?
Staro 02.05.2025., 23:56   #7152
Postovi: 10,054
Jedna je kartica za bt i wifi 👍
Ako ti je bas jako jako hica mogu ti poslati jednu moju karticu. Svako malo nesto uzimam na amazonu pa si lako narucim novu.
Staro 04.05.2025., 09:36   #7153
chillout23
chillout23's Avatar
Postovi: 642
Poslao sam ti poruku
Staro 06.05.2025., 00:48   #7154
Neo-ST
Neo-ST's Avatar
Postovi: 8,329
Ekipa zna li netko nekog ili neku trgovinu di bi se još mogao naći novi (ili barem kao novi) T480 (ne S) ?
Znam da su šanse male ali eto da pitam.
Hvala.
Staro 06.05.2025., 09:50   #7155
chillout23
chillout23's Avatar
Postovi: 642
AX210, nema problema s whitelistanjem...
Upravo naručio jednu...ova u lapu sve više radi probleme i uvjeren sam da je do nje.
Navodno bi trebala doći kroz maks 15 dana, pa kad je ugradim javim dojmove i kak je prošlo...
hvala ti na namjeri i hintu i hvala @Dottore i @De5tr0yer na savjetima
Staro 06.05.2025., 19:59   #7156
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
Javi jesi riješio problem.
Spoiler alert!
Staro 08.05.2025., 09:41   #7157
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,166
dali znate za jos koju provjerenu firmu (inside EU) koja se bavi prodajom refurbisher lenovo kao BF?
trebao bi mi jos jedan 11-12". preferiram x280. neznam kakvi su ovi drugi. koliko vidim uopce ih nema vise. na BF-u pratim vec neko vrijeme. samo 13" pa na gore.
PTM7950 u moj x280 ugraden. totlani preporod sto se tice temp i batt life. nesto nevjerovatno. vratio sam staru org lenovo batt u lap i do dan danas mi pise da je tek na 14,x wear level. ja neznam kako on to tocno gleda i mjeri. ocito je false. uglavnom puno mi duze batt traje sa postavkama kroz ThrottleStop:
battery saver:
turbo limit na 2,4
coreV: -122,1
cacheV: -121,1
balanced:
turbo limit na 3,6
coreV: -100,6
cacheV: -100,6
na balanced se nisam bas stigao jos poizgrat ici nize, al vecinu vremena mi je lap na batt saver...
ovaj ThrottleStop treba dobiti oscar-a
We all must hang together, or surly we will hang separately.
Zadnje izmijenjeno od: geronimo_2. 08.05.2025. u 10:26.
Staro 08.05.2025., 10:05   #7158
Postovi: 10,054
Na BF nisam vidio x280 zadnjih par mj barem. Samo x390.
Dosta su ti dobre postavke, jesi ti to testirao na -100mV i nize?
I ja sam prilicno happy sa x280 zasad. Kako ga koristim uglavnom navecer za pogledat film, malo surfati ili odigrati sat vremena nesto, jedno punjenje mi potraje i po 4-5 dana.
Nije mi vrag dao mira pa sam na kraju uzeo bateriju na dw4it. Dojmovi idu za par tjedana dok je malo testiram, trebala bi stici ovih dana.
Staro 08.05.2025., 10:26   #7159
geronimo_2
geronimo_2's Avatar
Postovi: 4,166
testirao battery saver postavku sa x komada throttlestop test, nekoliko testova cinebench-a, ne sjecam se koliko minuta prime95, najduzi test hyperPi. koristim ga tako vec 10ak dana i niti jedan crash ni nista. meni se cini rock solid, al vidjet cemo. vjerovatno mu je i dovoljno obzirom da ga lockam na 2,4
Staro 08.05.2025., 10:32   #7160
Postovi: 10,054
Idle zna biti veci problem, tj nekad stresove prodje ok, a u idleu bsod-a. Al u 10 dana bi to primjetio. Onda imas samo dobar chip 👍
Staro 08.05.2025., 10:38   #7161
chillout23
chillout23's Avatar
Postovi: 642
Jesi pogledal na luxnote?
Staro 08.05.2025., 10:51   #7162
geronimo_2
geronimo_2's Avatar
Postovi: 4,166
Nisam. Budem. Thx.
Idle me ne brine, vec bi roknul jer lap je bar 50% u idle-u.
Staro 08.05.2025., 12:17   #7163
chillout23
chillout23's Avatar
Postovi: 642
Nisam. Budem. Thx.
Ali njemački
https://www.luxnote-hannover.de/#
Staro 08.05.2025., 12:42   #7164
geronimo_2
geronimo_2's Avatar
Postovi: 4,166
Ma nista. Opet 13 i 14 cola. Nema 11-12 nista :-(.
Staro 09.05.2025., 16:49   #7165
Postovi: 10,054
Stigla danas i blagi sok i nevjerica. Bio sam cijelo vrijeme u kontaktu sa sellerom, pitao je li original, koji je datum, koja je garancija itd... i pitao da mi testira bateriju, dakle da je barem provjeri da je ziva i kaze naravno, to je standardna procedura. Misljenja sam, da je uopce pokusao staviti ovu bateriju u X280 skuzio bi da se faking poklopac ne moze zatvoriti bez savijanja istog. Koji je ovo klinac, baterija izlazi iz gabarita za par milimetara. Ako zatvorim poklopac, laptop se klacka na izbocenju.
https://imgur.com/a/o3lZhzs
Koja depra jebemti
Staro 10.05.2025., 09:39   #7166
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
Iz jednog kuta izgleda već blago napuhnuto, a iz drugog pak izgleda da su sigurnosni džepovi veći od ove prethodne dvije.
Koja dimenzija je problematična?
Sumnjaš da nije original baterija?
Spoiler alert!
Staro 10.05.2025., 09:57   #7167
Postovi: 10,054
Debljina je zapravo najveci problem, ostale dimenzije su ok, sve klikne na mjesto. Samo poklopac baterije tesko i savije se, dobije trbuh.
Takodjer imam neke sumnje da niti nije original baterija. Prvo naljepnice, feeling izrade i kuciste (puno je slicnija zamjenskoj sa slike), i na kraju podaci iz Vantagea - barcode je L1NJXXXSSSS, a first used datum je 1.1.2001 sto nema smisla. Original baterija ima barcode s random brojevima/slovima, a first used datum je realniji datum i prati manufactured datum.
Upalio sam laptop, radio je 10ak min, baterija je stalno pokazivala 97,9% ali valjda jer nije kalibrirana. S obzirom na fizicke probleme, nije imalo smisla raditi nikakve dublje analize i moram je vratiti.
Javim kako je prosao proces s povratom ako moga bude zanimalo.
Staro 10.05.2025., 13:02   #7168
chillout23
chillout23's Avatar
Postovi: 642
Sretno ��
Staro 13.05.2025., 01:08   #7169
tomasini_
tomasini_'s Avatar
Lokacija: Usa
Postovi: 1,164
Autor calypso Pregled postova
Hmhm, ako je za DJ, onda ces se jako napatiti da nadjes neki koji nema problema sa DPC latencijama... Koji god uzmes, slozi ga da radi u realtime modu tako da ima sto manje latencije...
Mislim da trazis masinu sa sto visom nazivnom frekvencijom, s time da bi ti bilo dobro turbo potpuno blokirati... Broj jezgri ti je nebitan... Dakle, zanemari i5 verzije i pogotovo zanemari T490s/T14s verzije jer oni imaju U procesore koji su ultra-low-voltage...
Dodatno, racunaj da T490s/T14s imaju zalemljen RAM, tako da tu nadogradnje RAMa nema... T14 Gen1 bi trebali imati SODIMM utor, tako da su oni OK...
malo kasnim sa pitanjem - zašto bi bilo dobro turbo potpuno blokirati? ima li to veze sa throttlanjem, tj. sa savjetom jednog forumaša da uzmem i5 jer je i7 beznačajno jači a u tako laganom laptopu to samo znači da će jače throttlati?
divovski kompjuteri
tomasini_ je offline   Reply With Quote
Staro 13.05.2025., 01:29   #7170
calypso
calypso's Avatar
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 1,954
Autor tomasini_ Pregled postova
i5 i i7 u visemanje isti, neces osjetiti neku razliku u performansama... i7 ima neke feature koji tebi ne trebaju za DJanje...
Sto se turba tice, svako mijenjanje frekvencije uvodi latencije u pricu i nekad hoce zvuk zakrcat ili preskocit lagano, jedva cujno... Idealno bi bilo da je frekvencija uvijek stabilna i da ne seta, sto se moze postici u Power options negdje... Turbo ili u BIOSu iskljucis ako ima opcija (kod Della ima) ili sa QuickCPU to iskljucis...
GMKTec K8Plus
2x EIZO EV2336WFS3-BK
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4
512GB Samsung PM981, PCI-E 3.0 x4
intel UHD 620
13.3" FullHD IPS Touchscreen
calypso je online   Reply With Quote
