Staro 26.03.2025., 12:57   #61
prileee
laser
prileee's Avatar
Postovi: 2,338
Samo da ostavim info, ako nekome u buducnosti bude trebalo, na kraju sam kupio key sa https://www.allkeyshop.com/blog/buy-...ompare-prices/ odabrao sa Wincdkey i onaj koji ima GLOBAL pod regions a ne phone activation i radi.
Staro 03.04.2025., 07:17   #62
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,715
Microsoft Urges Businesses To Abandon Office Perpetual Licenses
Microsoft is pushing businesses to shift away from perpetual Office licenses to Microsoft 365 subscriptions, citing collaboration limitations and rising IT costs associated with standalone software. "You may have started noticing limitations," Microsoft says in a post. "Your apps are stuck on your desktop, limiting productivity anytime you're away from your office. You can't easily access your files or collaborate when working remotely."
In its pitch, the Windows-maker says Microsoft 365 includes Office applications as well as security features, AI tools, and cloud storage. The post cites a Microsoft-commissioned Forrester study that claims the subscription model delivers "223% ROI over three years, with a payback period of less than six months" and "over $500,000 in benefits over three years."
Aha
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / 1TB Micron M.2 2242 / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad T540p || Intel Core i7-4700MQ / 16GB DDR3 / 240GB Sandisk SSD Plus / nVidia Geforce GT 730 / FreeBSD 14.3
Staro 10.04.2025., 08:26   #63
tomek@vz
tomek@vz's Avatar
Postovi: 4,715
Čisto informativno...danas sam nanovo instalirao Win11 na lapu i naravno htio instalirat Office 2019 Pro Plus Retail koji sam kupio pred nekih 3 godine sa jednog od respektabilnih "sivih" sajtova po cca 50 Eura (reko aj necu za 1 Euro sigurno je scam). Čini se da je ključ blacklistan:
https://support.microsoft.com/en-us/...7-554a6076c910
Meni osobno ne pere samo mi diže tlak usljed hrpe istih sajtova po netu i kad ekipa takve ključeve koristi i za službene uređaje i svi tvrde da je to OK. Nije legalno i nebi se trebalo promovirat. Ne samo da je piratluk nego je još gore - piratluk koji se plaća. Hvala al ne hvala al onda ću radije ili koristiti alternativu koja ne košta ništ ili ću iskeširat kolko treba za legalnu verziju direktno kod MS i bok (uostalom M365 je 10 Eura mjesečno, ak imam za kavu imam i za to).
/rant off
Zadnje izmijenjeno od: tomek@vz. 10.04.2025. u 10:46.
Staro 10.04.2025., 08:56   #64
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,750
Koliko je meni objasnjeno, kljuc nije "blacklistan", nego ga mozes aktivirati samo jednom. Ocito ga nije moguce "deaktivirati", jebiga...
Programer
Staro 10.04.2025., 09:08   #65
tomek@vz
tomek@vz's Avatar
Postovi: 4,715
Autor Bubba Pregled postova
Ma prošao sam u zadnjih nekoliko godina više reinstalacija Win10/11 na 3 računala (uvijek aktiviran samo na jednom) i nikad u 3 godine problema. Jebaj ga.
Staro 10.04.2025., 09:35   #66
nino
nino's Avatar
Postovi: 12,602
Si pokusao preko ms acc aktivirat?
Staro 10.04.2025., 09:39   #67
tomek@vz
tomek@vz's Avatar
Postovi: 4,715
Autor nino Pregled postova
Yep.
Staro 10.04.2025., 10:04   #68
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,750
Možda je do broja aktivacija na raznim računalima?
Staro 10.04.2025., 10:44   #69
tomek@vz
tomek@vz's Avatar
Postovi: 4,715
Autor Libertus Pregled postova
RETAIL
Staro 10.04.2025., 13:13   #70
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,034
Broj aktivacija na različite kompove, mislim da je 5...
Nazovi onaj 0800 broj pa aktiviraj telefonom, to kad sam davno delal je pomoglo
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 17.04.2025., 04:41   #71
tomek@vz
tomek@vz's Avatar
Postovi: 4,715
Microsoft has acknowledged that Classic Outlook can mysteriously transform into a system resource hog, causing CPU usage spikes between 30-50% and significantly increasing power consumption on both Windows 10 and 11 systems.
Users first reported the issue in November 2024, but Microsoft only confirmed the problem this week, offering little resolution beyond stating that "the Outlook Team is investigating this issue." The company's sole workaround involves forcing a switch to the Semi-Annual Channel update through registry edits -- an approach many enterprise environments will likely avoid. Microsoft hasn't announced a definitive end date for Classic Outlook, but the company continues pushing users toward its New Outlook client despite its incomplete feature set.
Staro 17.04.2025., 04:46   #72
njOob
njOob's Avatar
Lokacija: Jug
Postovi: 497
Ja sam prije par godina uzeo bio za 15 eura kljuc koji je bindan za account i evo nisam ni znao tocno kako ide ali na kraju ispalo na kojem god kompu da imam svoj account logiran imam i office 2021 aktiviran.
Edit: sad isti taj bindan je 59$
https://wholsalekeys.com/shop/micros...essional-plus/
Sent from my SM-S926U1 using Tapatalk
njOob je offline   Reply With Quote
Staro 02.05.2025., 06:42   #73
tomek@vz
tomek@vz's Avatar
Postovi: 4,715
We are introducing a new Startup Boost task from the Microsoft Office installer to optimize performance and load-time of experiences within Office applications. After the system performs the task, the app remains in a paused state until the app launches and the sequence resumes, or the system removes the app from memory to reclaim resources. The system can perform this task for an app after a device reboot and periodically as system conditions allow.
MC1041470 – New Startup Boost task from Microsoft Office installer for Office applications
Staro 25.07.2025., 08:12   #74
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,017
Hah ovo ide i MS i Libreoffice i vjerojatno sve ostale Office alate koji su alternative MS Officea...
An artificially complex XML schema as a lock-in tool
Staro 25.07.2025., 13:06   #75
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,750
To je tako godinama. MS želi zadržati svoj monopol i komplicira gdje god stigne svoj xml. Kada je ods proglašen standardom, ms je podmazao da se i jedna njegova verzija proglasi standardom.
Koliko je sjećam ni ms office ne otvara ms standard format kako treba.
Za EU bi vjerojatno izlaz iz toga bilo da proglasi ods obavezan standard za sve države i agencije. MS isto podržava ods ali namjerno loše.
S vremenom kada bi većina datoteka bila ods, i to službena verzija ne neka izmišljena od strane ms, bilo bi svima svejedno koji office alat koriste.
