Staro 02.03.2025., 09:24   #3961
strikoo
strikoo's Avatar
Postovi: 951
Mint
+1
strikoo je offline   Reply With Quote
Staro 03.03.2025., 19:54   #3962
zgking
Postovi: 81
Mint
Hvala ti.
Javim kak dela i kak se budem snašao sa istim pošto sam novi na Linuxu .
zgking je offline   Reply With Quote
Staro 03.03.2025., 20:38   #3963
strikoo
strikoo's Avatar
Postovi: 951
Autor zgking Pregled postova
Hvala ti.
Na tvom laptopu bi trebao savrseno raditi. imao sam hp 640 (g4 cini mi se) sa slicnim procesorom, sve je sljakalo kako treba.
za sve ostalo tu smo, sretno
Staro 10.03.2025., 08:30   #3964
medo
#erase startup-config
medo's Avatar
Postovi: 3,657
Linux OS - info, how-to, pitanja, novosti, savjeti, problemi...
Hmm
https://www.bleepingcomputer.com/new...llion-devices/
Nema puno veze s Linuxom ali bi informacija mogla ovdje najviše koristiti.
Code:
The ubiquitous ESP32 microchip made by Chinese manufacturer Espressif and used by over 1 billion units as of 2023 contains undocumented commands that could be leveraged for attacks.
The undocumented commands allow spoofing of trusted devices, unauthorized data access, pivoting to other devices on the network, and potentially establishing long-term persistence.
Staro 10.03.2025., 08:47   #3965
c-shadow
c-shadow's Avatar
Postovi: 3,464
Ta priča staje ovdje:
Code:
This is especially the case if an attacker already has root access,  planted malware, or pushed a malicious update on the device that opens  up low-level access.
Staro 10.03.2025., 17:51   #3966
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,706
Heads up!
Socket researchers have identified an active, malicious campaign penetrating the Go ecosystem with typosquatted packages. These packages deliver hidden loader malware that targets Linux and macOS systems.
The malicious actor behind this campaign has released a minimum of seven packages impersonating popular Go libraries, including one that targets developers in the financial sector. The packages have repeated malicious filenames and share obfuscation tactics, indicating the threat actor behind them is coordinated and capable of pivoting.
In February 2025, the malicious actor published four packages on the Go Module Mirror, mimicking legitimate tool for testing HTTP API clients. The typosquatted mimics have concealed functions embedded to allow remote code execution. Their end goal is to steal data and credentials.
https://www.securitymagazine.com/art...-macos-systems
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / 1TB Micron M.2 2242 / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad T540p || Intel Core i7-4700MQ / 16GB DDR3 / 240GB Sandisk SSD Plus / nVidia Geforce GT 730 / FreeBSD 14.3
Staro 11.03.2025., 19:41   #3967
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,750
Kratko par fotki sa ovogodišnjeg NetDeva u Zagrebu. Galerija: https://imgur.com/a/tWCdV6e
Totalno sam zaboravio reci da je krajem prosle godine vrlo dobro prosao vjerojatno prvi OpenSource hackaton na ovim prostorima, gdje je (mainline) Linux bio glavna tema!
Programer
Staro 11.03.2025., 20:01   #3968
tomek@vz
tomek@vz's Avatar
Postovi: 4,706
Autor Bubba Pregled postova
Nice
Staro 13.03.2025., 11:08   #3969
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,005
Pohvale
Sent from my 23127PN0CC using Tapatalk
Staro 13.03.2025., 12:09   #3970
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,016
Staro 14.03.2025., 08:43   #3971
tomek@vz
tomek@vz's Avatar
Postovi: 4,706
Decrypting Akira Ransomware on Linux/ESXi Without Paying Hackers
Staro 14.03.2025., 13:34   #3972
tomek@vz
tomek@vz's Avatar
Postovi: 4,706
Microsoft is out today with their newest monthly update to their in-house Linux distribution, Azure Linux, with all available package and security updates through this month's Patch Tuesday.
Staro 15.03.2025., 12:59   #3973
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,016
Razmišljam da ubijem jedan Proxmox na jednom NUC-u i stavim čisti Debian s Dockerom i gore staviti Paperless-ngx, Print server,... Možda još kaj vidim da bi moglo.
Mislim sada je Proxmox pa virtualka Debiana gdje je Docker (virtualka je jer nisam uspio složiti mount na LXC kontejner).
Proxmox bi ostao na 2 NUC-a.
Staro 15.03.2025., 13:48   #3974
Postovi: 10,003
Osobno dajem plus proxmox rješenju samo iz razloga backupa te virtualke i lakog restoranja kad zatreba, te mogućnosti snapshotanja prije recimo velikih updejtova unutar same virtualke. Ako nešto ode na kvasinu, lako se vratiš korak nazad. Vrtio sam takve kontejnere na koječemu, ali mi je na proxmoxu bila najmanja briga oko održavanja tog setupa. Sa strane Average Jožeta, dajem prednost proxmoxu.
Mountanje pathova prema LXC kontejnerima je priča za sebe (ne sjećam se jesam li to ikada do kraja shvatio), da ne spominjem raznorazne errore kod backupiranja istih ako koristiš proxmox backup jobove (e ovo nikad nisam riješio)... Zapravo, ovaj drugi problem sam riješio prelaskom na proxmox backup server, on nema problema s tim i sve žvače.
Staro 15.03.2025., 14:31   #3975
tomek@vz
tomek@vz's Avatar
Postovi: 4,706
Autor spiderhr Pregled postova
Sto te sprecava da instaliras Docker direktno na Debian (Proxmox) ?
Staro 15.03.2025., 18:05   #3976
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,016
Autor xlr Pregled postova
Da, to se slažem da je unutar Proxmoxa sve lakše.
Jedino to mountanje na LXC nisam skužio. A i na Proxmoxu je dashboard koliko je zauzeće CPU, RAM,...
A-ha, mislio si i Docker i Proxmox da vrtim kao bare metal?Vidiš to mi u trenutku pisanja posta nije palo na pamet.
Ovo su samo moja razmišljanja na glas pa i da čujem kaj ćete svi vi reći.
Staro 15.03.2025., 18:16   #3977
tomek@vz
tomek@vz's Avatar
Postovi: 4,706
Proxmox je ispod haube punokrvni Debian , mozes s njim raditi sto god zelis.
Staro 15.03.2025., 18:22   #3978
strikoo
strikoo's Avatar
Postovi: 951
da bi mountali u lxc morate ukljuciti u opcijama
nesting=1
Staro 16.03.2025., 12:02   #3979
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,016
Koji je ovo set ikona?
Staro 16.03.2025., 13:44   #3980
tomek@vz
tomek@vz's Avatar
Postovi: 4,706
Izgleda mi kao nesto iz Haiku projekta. Cekiraj tu mozda naletis na nekaj kaj ti se svidi.
Staro 17.03.2025., 07:57   #3981
medo
medo's Avatar
Postovi: 3,657
Dok ne napraviš prvi update Proxmoxa pa ti on više-manje sve pregazi
Staro 17.03.2025., 08:10   #3982
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,016
Nope. Mislim da je to Tango set
Ali stavio sam temu BlueCurve, kao i ikone. Malo me nostalgija povukla.
Zadnje izmijenjeno od: spiderhr. 17.03.2025. u 08:15.
Staro 17.03.2025., 09:32   #3983
tomek@vz
tomek@vz's Avatar
Postovi: 4,706
Autor medo Pregled postova
Zato postoje repo prioriteti .
Staro 19.03.2025., 23:21   #3984
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,936
Razmišljati o Proxmoxu kao Debian sustavu sa nekim dodatnim softverom na njemu je kao razmišljati o autu da su kotači sa komadom lima gore.
Da, može se svašta, ali može te i ujesti za stražnjicu nakon godinu dana neki update koji će ti ubiti funkcionalnost sideloaded aplikacije ili servisa, pa ti troubleshootaj kako odjednom ne radi.
Kao što na ESXi-u nećeš ( niti možeš ) instalirati dodatne aplikacije, niti na Hyper-Vu nećeš staviti na baremetal dodatne servise, tako to nije pametno ni za PVE.
Ne da vam se zezati sa LXCevima? Fair enough, instalirajte Ubuntu VM po nodeu koji će služiti samo za Dockere, valjda si možete priuštiti tih <512MB RAMa za host VM koji će supportati konteNJere. Jednostavan je backup, em ste skalabilni, em ste u čokoladni, em ste u boji.
Ići micati PVE da bi stavio čisti Debian i zatim Docker na baremetal? Ako me sad nije šlagiralo...
Staro 20.03.2025., 04:47   #3985
tomek@vz
tomek@vz's Avatar
Postovi: 4,706
Autor m4dm4n Pregled postova
Za produkcijiski Proxmox u nekoj firmi? Definitivno se slazem s tobom. Za po doma? Who cares. Stvar sljaka AKO onaj pred ekranom zna sto radi i sposoban/a je van ChatGPT-a jos uvijek googlat i shvaca najprije Proxmox kao koncept a nakon toga i Linux kao Server i Linux kao Desktop OS. Kaj se tice LXC vs Docker kontejnera - i jedno i drugo ima svoje prednosti i nedostatke i zato tko brani da netko koristi oboje na Proxmoxu .
Staro 20.03.2025., 08:21   #3986
domy_os
domy_os's Avatar
Postovi: 18,821
Meni je neki update skršio ZeroTier na Proxmoxu, mjesec dana sam izgubio dok nije proradilo jer ne mogu stalno restartati server, a i dalje ne znam što se dogodilo, je li ZeroTier ili Proxmox update kriv. Skripta s ifreload je u startupu normalno radila godinu dana i odjednom prestala. Kad bi se Proxmox podigao, ručno pokretanje skripte je radilo, ali u startupu nije, otišla bi u timeout. Nakon što sam izbacio ifreload iz nje i dodao brctl addif i ip link set <interface> up, problem je nestao.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 20.03.2025., 08:43   #3987
tomek@vz
tomek@vz's Avatar
Postovi: 4,706
GNOME 48 desktop environment has been released after six months of development with major new features that have been expected for more than four years, such as dynamic triple buffering, HDR support, and much more. 9to5Linux reports:
"Highlights of GNOME 48 include dynamic triple buffering to boost the performance on low-end GPUs, such as Intel integrated graphics or Raspberry Pi computers, Wayland color management protocol support, new Adwaita fonts, HDR (High Dynamic Range) support, and a new Wellbeing feature with screen time tracking.
"GNOME 48 also introduces a new GNOME Display Control (gdctl) utility to view the active monitor configuration and set new monitor configuration using command line arguments, implements a11y keyboard monitoring support, adds output luminance settings, and it now centers new windows by default."
https://release.gnome.org/48/
Staro 21.03.2025., 05:39   #3988
tomek@vz
tomek@vz's Avatar
Postovi: 4,706
What do SourceHut, GNOME’s GitLab, and KDE’s GitLab have in common, other than all three of them being forges? Well, it turns out all three of them have been dealing with immense amounts of traffic from “AI” scrapers, who are effectively performing DDoS attacks with such ferocity it’s bringing down the infrastructures of these major open source projects. Being open source, and thus publicly accessible, means these scrapers have unlimited access, unlike with proprietary projects.
These “AI” scrapers do not respect robots.txt, and have so many expensive endpoints it’s putting insane amounts of pressure on infrastructure. Of course, they use random user agents from an effectively infinite number of IP addresses. Blocking is a game of whack-a-mole you can’t win, and so the GNOME project is using a rather nuclear option called Anubis now, which aims to block “AI” scrapers with a heavy-handed approach that sometimes blocks real, genuine users as well.
The numbers are insane, as Niccolò Venerandi at Libre News details.
Staro 21.03.2025., 16:59   #3989
strikoo
strikoo's Avatar
Postovi: 951
Hvala za ovo, mi imamo sličnih problema, proslijedio
Staro 21.03.2025., 18:14   #3990
tomek@vz
tomek@vz's Avatar
Postovi: 4,706
Autor strikoo Pregled postova
