Staro 04.03.2025., 19:07   #721
Postovi: 8,206
HUB Steve, a posebice Tim u svojim podcast izdanjima pričaju kao da direktno komuniciraju s Radeon divizijom, do te mjere da si sve mislim da je njima netko iz te šrot AMD firme nekaj gadno privatno skrivil, jer je u pitanju točno to Exy spominje - najbolje da AMD poklanja kartice, a i onda ne bi bilo dobro, jer to nije nVidia GeForce brand koji sad jebe sve svoje vjerne JayzTwoCents i sl. obožavatalje do te mjere da iskreno za drugo i nisu. Danas nije bilo ni jedne pozitivne recenzije, a to je samo posljednja u nizu katastrofalno loših RTX 5000 kartica i opet se očekuje da Radeon košta neku siću, a ne bude, jer tek sad mogu prodati sve, kad imaju višemjesečnu zalihu, dok nVidia nema apsolutno ništa. Sutra kaj god da bude u recenzijama, teško da bude se netko žalil previše.
EDIT:
Based on the information we have gathered from multiple retailers, AMD may have more day-1 RX 9070 series stock than all of Nvidia’s RTX 50-series GPU launches combined (at least in the UK). Retailers will have a much larger pile of GPUs inside their warehouses to sell. As such, we do not expect AMD’s new GPUs to sell out as quickly as their Nvidia counterparts. With the launch of their Radeon RX 9070 and RX 9070 XT, AMD has supplied retailers with more graphics cards than any GPU launch in recent history. We don’t expect these new graphics cards to be instantly out of stock. However, we expect demand for these GPUs to he high, which means they will likely sell out at some point. Regardless, this high level of supply means that buying one of these GPUs on day 1 is a realistic possibility. Kudos to AMD for actually attempting to launch a graphics card with sufficient supply
Zadnje izmijenjeno od: The Exiled. 04.03.2025. u 19:36.
Staro 04.03.2025., 19:55   #722
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,543
Psi laju karavane prolaze.
kopija je online   Reply With Quote
Staro 04.03.2025., 20:21   #723
Postovi: 8,206
Staro 05.03.2025., 06:03   #724
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Pa kako ne kužite poantu, treba sada doslovno izgubiti lovu da bi se prodavali da bi prosječan PC gejmer i ne gejmer čuli i za Radeon jer im je tržišni udio sramotan.
E kada se čuje za njih, i kada se ljudi u te npr dvije godine naviknu, onda im možeš prodavat muda za bubrege kao Jakna.
Sranje u cijeloj priči je jedino što je MLID neki dan pričao da su mu ''kontakti iz nevidije'' rekli da Jensen kad osjeti neku prijetnju i/ili varijaciju na temu ''ulazi u beast mode'' ili tako nekako i da tu onda trava više ne raste. S razlogom su na vrhu u svim segmentima.
Ne znam, će da vidimo kako će ovo proći za godinu-dvije. Početnog booma će sigurno biti i to ne računam ni kod jednih ni kod drugih.
Slobodno me dodajte na PSN
Staro 05.03.2025., 09:03   #725
Postovi: 8,206
IMHO jasno je itekak da bi najbolje bilo da RX 9070 košta 250$, a RX 9070 XT 350$ i to bi utopilo kompletnu RXT 5000 seriju, a bome i u nekoliko navrata sam spomenul da AMD danas ima više novaca, nego ikada u povijesti firme, tak da bez problema mogu prodavati RDNA 4 s gubitkom. Jedino kaj je problem da to više nije onaj AMD prije Zen ere, pa su jedno naše želje, čestitke i pozdravi, a realnost nešto sasvim drugo.
Tearing Down a GPU No One Should Buy | RTX 5070 Founders Edition Disassembly
Staro 05.03.2025., 09:17   #726
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,503
To se radi kad imaš inferioran proizvod i hrpu konkurencije. To je radio Intel prije sto godina kad je prodavao i740 ispod proizvodne cijene, rezultati su poznati. Ne razumijem ovaj argument da se to mora napravit jer bi onda "ljudi čuli za Radeon", pa taj brand je skoro pa stariji od GeForcea
Nije poanta povećat tržišni udjel za 0,2%, od tržišnih udjela samih po sebi se ne živi, pogotovo ako su stvoreni gubljenjem novaca, to je potpuno bizarna ideja.
Što mene briga za njihov tržišni udjel, kupit ću 9070XT ako je bolja od 5070Ti tj. ako je price/performance bolji. Ako opet bude inferioran proizvod, opet ih nitko neće kupovat kao što je bilo i do sada. Zašto bi Radeon grafa bila jeftina ako nudi isto što i nvidia? Upravo takve stvari uništavaju brand.
Staro 05.03.2025., 09:32   #727
Postovi: 8,206
E, ali HUB Steve i Tim već godinama uporno trube da Radeon mora biti osjetno jeftiniji, jer to nije GeForce brand, pa čak i kad/ako nude sve isto, opet to nije dovoljno dobro i moraju biti minimalno 50% jeftinije. I sad kad se pogleda, RDNA 4 budu stvarno skoro duplo jeftnije. Intel se pak bajno usrećil s ARC modelima, a bili su dočekani kao spasitelj GPU tržišta, pa su izveli Raja salto u rikverc.
Staro 05.03.2025., 09:44   #728
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Pa zato jer je to razmišljanje prosječnog kupca grafičke kartice. Sam udio u prodaji to govori bolje od ičega.
Znam ja jako dobro koliko je Radeon star, ali očito ne zna ogromna većina.
Nemojmo mjeriti po sebi.
Nema tu riječi o tome da je Radeon loš ili nešto, nego samo da vuku loše poteze i da ne postavljaju trendove da se tako izrazim. Jebemu meni je zadnje u sjećanju da je Radeon pokušao sa TrueForm kerfekom koja je mislim an kraju jedino korištena u RTCW, i sjećam se da je Radeon prvi imao Bum Mapping (prciznije samo su Radeonke u to doba vrtile onog svjetlucavog svemirca u 3D marku, GF nije).
Nažalost, moraju se potrudit sa iskoristivim fićrima ili da skinu gaće.
I naravno najviše sa marketingom.
Ugl, živi bili pa vidili, dobili su priliku kakve dugo nije bilo jer Jensena očito boli pipi za sve osim AI...pa ćemo vidjeti kako prosječan kupac diše i koliko će ih AMD uloviti.
Nisu neuhvatljivi, jer je Zen razvalio, ali je imao i neki svoj početak, a sada su brži bolji jači, plus postavljaju trendove tj uvode nove fićre, dok se Intel koprca sa izmišljanjem tople vode.
Staro 05.03.2025., 09:54   #729
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,160
Nemora biti 50% jeftinije, ali barem 20% radi boljeg upscalinga/rt i podrške u vise igri
To je psihologija i marketing na dijelu.
Ako su dva slicna proizvoda istih performansi, jedan tvoj omiljeni brand na koji si navikao, a drugi koji ti je bio meh dosada. Koliko bi taj drugi trebao biti jeftiniji da ga kupis. Ja ispod 20% nebi ni razmisljao. preko 20 vec pocinje pa mogao bi im dati šansu.
Poslano sa mog SM-S928B koristeći Tapatalk
Staro 05.03.2025., 09:56   #730
Postovi: 8,206
Autor Disco Pregled postova
... dok se Intel koprca sa izmišljanjem tople vode.
Intel sve više izgleda kao firma koja je praktički mrtvo slovo na papiru, a sve kaj se trenutno odvija je kombinacija Idiocracy, Don't Look Up i Black Mirror dokumentarca uz finu dozu South Park parodije.
Staro 05.03.2025., 12:03   #731
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Autor Gemmy Pregled postova
Eto, mislimo više-manje isto, ti si se puno bolje izrazio.
To AMD treba skužit, prvo ide skidanje svojih gaća, a onda izuvanje kupaca iz cipelica.
Znalo se i ko je AMD u doba Athlona i Athlona 64, pa su već sa Phenomom počeli venut, a bageri ih pokopali (pun intended).
Pa je išlo skidanje gaća sa Zenom da se ljudi opet prisjete što je AMD, a sada je izuvanje iz cipelica i kupaca i konkurencije.
I kako su još skinuli gaće....pa ima ono nešto što se zove AM4 dugovječnost i recikliranje na pravi način. A ne ovo što nV upravo izvodi, doslovno preimenovanje proizvoda i softversko ''poboljšanje'' koje to nije.
BTW, kada sam se već dotaknuo AM4, vj se ne sjećate kako na isti taj softverski (BIOS) način zen3 nije mogao 3XX i 4XX chipsete...pa kad su skužili da i tu leži lova u prodaji CPU-a je bilo u stilu, teškim naporima smo se izborili. E shvatili su. Još samo da dopuste Radeon odjelu da shvati i tj šefovima, i to je to, na konju su. Netko od YT ekipe je spomenuo da su u Radeonu očajni i razočarani jer ih doslovno bojkotiraju te face iz AMD-a (AMD im je očito maćeha)...a baš zbog toga usranog Radeona imaju konzole, HH PC-e, mini PC-e i slično pod sobom, tu su doslovno bez konkurencije.
Zadnje izmijenjeno od: Disco. 05.03.2025. u 12:27.
Staro 05.03.2025., 12:13   #732
Postovi: 8,206
Australci su to spomenuli, a ne kuže da kreten zvan Frank Azor koji direktno odgovara Lisi Su, ne prikazuje Radeon diviziju u realnom stanju, nego priča bajke i čim prije ga potjeraju, tim bolje.
Staro 06.03.2025., 09:39   #733
Taproot7
mag.math.
Taproot7's Avatar
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 361
Autor kopija Pregled postova
Obzirom na okruženje u kojem se nalazimo pa čak i na ovom PC Ekspert forumu, može se olako doći do zaključka da je ovo što ste kolega prikazali u ovom grafu - bespotrebno jer se hardware gleda samo koliko će dobro odrađivati neki neoptimizirani komad software-a što se popularno naziva video-igra. Samo je to bitno i zato su ljudi ljuti na nVidia-u jer je podbacila u najvažnijem segmentu - igranju računalnih igara dok ne shvaćaju da baš zbog ovog dijagrama gospodin Jensen Huang urinira po svojim korisnicima i svima onima koji ga štuju jer im je pružio mnogo pogotovo što mogu gledati refleksiju svjetla sa neonskih reklama u lokvi vode tijekom realnog vremena u popularnim video igrama a za uzvrat nije tražio ništa. I svejedno su ljudi stajali u redovima da kupuju elektronički otpad. Svi se ismijavaju a ljudi i dalje kampiraju ispred trgovina i šalju tisuće i tisuće upita trgovinama o dostupnosti tog istog otpada. nVidia je dvostruki pobjednik - neprikosnoveni u AI segmentu tržišta jer nemaju konkurencije te neprikosnoveni u ovom važnijem dijelu kućnih korisnika jer ljudi kupuju otpad i na svoju štetu tumaće kako nedostatak ROP jedinica neće previše utjecati na njihove performanse jer je tu DLSS 4 koji će iznivelirati taj nedostatak. Tri put hura za gospodina Jensena.
Autor Exy Pregled postova
Kolega, pogledajte jučerašnji video uradak gospodina Stevea Burkea. Lijepo je naveo da velik tojest ogroman dio tržišta nikad nije čuo za Gamer Nexus i slične hardware recenzente i da AMD ima "uphill battle" jer je GeForce sinonim kvalitete i brige za dobrobit korisnika dok se Radeon predstavlja kao lošiji proizvod nego to u suštini je. Samo iz tog razloga Radeon mora biti jeftiniji jer je narativ društva takav. To vam je kao i u politici kad osoba kaže svi su oni isti i opet glasa za nekoga zbog koga mu je dijete otišlo raditi u inozemstvo. U ovom slučaju ljudi kažu da im treba jeftini i konkuretni Radeon kako bi jeftinije kupili nVidia grafičku karticu. Plus ono što sam ranije naveo pa ste mi savjetovali da ne pratim ljude nego da se okrenem sebi - to da je bitnija i ljepša slika na društvenoj mreži ona sa zelenom kutijom nego ona sa crvenom. Ono što mislim je to da je za Radeon prekasno tojest da ne ovise o sebi nego o tome da nVidia iduću seriju kolosalno zabrlja kao što je i ovu, što cjenovno što logistički što kvalitetom.
Taproot7 je offline   Reply With Quote
Staro 06.03.2025., 18:45   #734
Postovi: 8,206
nVidia’s RTX 50 Laptop GPUs also hit by missing ROPs, production delays expected - ovo se navodno popravlja s nadolazećim DLSS 5 izdanjem.
EDIT:
Retailer claims nVidia is recalling ‘large number’ of RTX 5090 graphics cards due to fire hazard
Your Game Specialist, a retailer in the Netherlands, has emailed customers stating that “nVidia has recalled a large number of video cards due to various safety issues”. One of our YouTube channel viewers reached out to us to supply us with a copy of the email along with proof of their RTX 5090 order. This viewer specifically ordered an MSI RTX 5090 Suprim graphics card. Here is what the retailer email said, translated from Dutch to English: “nVidia has recalled a large number of video cards due to various safety issues. We currently have five units of this model in stock, but they all have to be returned due to an increased fire hazard. In this situation, we do not give priority to anyone; all customers are treated equally based on the ranking when pre-ordering or ordering the video cards.”
Izvor: KitGuru
U međuvremenu su se nVidia i MSI oglasili i izjasnili kako su sve ovo čiste laži, jer problema s Blackwell serijom nema.
Zadnje izmijenjeno od: The Exiled. 09.03.2025. u 13:49.
Staro 12.03.2025., 21:49   #735
Postovi: 8,206
Staro 13.03.2025., 05:59   #736
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
EDIT:
A baš, interpolirat će ROPove koji fale....ne kužim što se dešava, cijeli BW je izgleda katastrofalno proizveden. Ako sam dobro shvatio zahvaćena su im i AI servreska čudovišta, gaming, štogod...jel to Jensen prepoustio kontrolu nekom praktikantu ili pak netko iz TSMC-a?
Baš me zanima priča oko ovoga jer mi nije jasan baš ovoliko loš proizvod na gotovo svim poljima...možda jednog dana procuri nešto od nekog nezadovoljnog zaposlenika. :P
Staro 13.03.2025., 08:24   #737
Postovi: 8,206
nVidia je sjebala, do te mjere da je direktor moral javno reći da TSMC nema ništa s tim, Blackwell dizajn je problem, ali je sve kao riješeno, mada vidimo iz priloženog da ipak nije.
Staro 13.03.2025., 13:44   #738
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,384
DLSS 5 to the resuce. Na kraju balade će ispasti da, što se GPU tiče, to što nije bilo artikala za prodati je zapravo pozitivno.
Autor George Carlin
But there’s a reason. There’s a reason. There’s a reason for this, there’s a reason education sucks, and it’s the same reason that it will never, ever, ever be fixed. It’s never gonna get any better. Don’t look for it. Be happy with what you got. Because the owners of this country don't want that. I'm talking about the real owners now, the real owners, the big wealthy business interests that control things and make all the important decisions. Forget the politicians. The politicians are put there to give you the idea that you have freedom of choice. You don't. You have no choice. You have owners. They own you. They own everything. They own all the important land. They own and control the corporations. They’ve long since bought and paid for the senate, the congress, the state houses, the city halls, they got the judges in their back pockets and they own all the big media companies so they control just about all of the news and information you get to hear. They got you by the balls. They spend billions of dollars every year lobbying, lobbying, to get what they want. Well, we know what they want. They want more for themselves and less for everybody else, but I'll tell you what they don’t want: They don’t want a population of citizens capable of critical thinking. They don’t want well informed, well educated people capable of critical thinking. They’re not interested in that. That doesn’t help them. Thats against their interests. Thats right. They don’t want people who are smart enough to sit around a kitchen table to figure out how badly they’re getting f*cked by a system that threw them overboard 30 f*cking years ago. They don’t want that. You know what they want? They want obedient workers. Obedient workers. People who are just smart enough to run the machines and do the paperwork, and just dumb enough to passively accept all these increasingly shittier jobs with the lower pay, the longer hours, the reduced benefits, the end of overtime and the vanishing pension that disappears the minute you go to collect it, and now they’re coming for your Social Security money. They want your retirement money. They want it back so they can give it to their criminal friends on Wall Street, and you know something? They’ll get it. They’ll get it all from you, sooner or later, 'cause they own this f*cking place. It's a big club, and you ain’t in it. You and I are not in the big club. And by the way, it's the same big club they use to beat you over the head with all day long when they tell you what to believe. All day long beating you over the head in their media telling you what to believe, what to think and what to buy. The table is tilted folks. The game is rigged, and nobody seems to notice, nobody seems to care. Good honest hard-working people -- white collar, blue collar, it doesn’t matter what color shirt you have on -- good honest hard-working people continue -- these are people of modest means -- continue to elect these rich c*cksuckers who don’t give a f*ck about them. They don’t give a f*ck about you. They don’t give a f*ck about you. They don't care about you at all -- at all -- at all. And nobody seems to notice, nobody seems to care. That's what the owners count on; the fact that Americans will probably remain willfully ignorant of the big red, white and blue dick that's being jammed up their assholes everyday. Because the owners of this country know the truth: it's called the American Dream, because you have to be asleep to believe it.
Staro 13.03.2025., 23:16   #739
mkey
Lokacija: tu
Postovi: 3,384
Autor George Carlin
Staro 14.03.2025., 05:54   #740
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Autor mkey Pregled postova
Evo ga. ono gore mi ne daje niš...
Staro 14.03.2025., 11:09   #741
slavonac90
slavonac90's Avatar
Postovi: 1,513
Po nekim leakovima jučer je Nvidia trebala objaviti informacije vezane uz izlazak rtx 5060 i rtx 5060 ti modela, ali zelenaši i dalje šute.
Čisto me zanima što su nam pripremili
slavonac90 je offline   Reply With Quote
Staro 14.03.2025., 11:11   #742
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Autor slavonac90 Pregled postova
Rekao je Stevo the hesus da nema ništa još od nV.
Pripremili su iste grafe sa drugim imenom....za koje je velika šansa i da će doći sa HW defektom.
Naravno skuplje, ekskluziva na defekte.
Staro 14.03.2025., 11:15   #743
slavonac90
slavonac90's Avatar
Postovi: 1,513
Poznavajući njihovo poslovanje, vrlo vjerojatno je tako kako kažeš, ali pokušavam se nadati da bi možda mogao biti slučaj kao sa rtx 3060 ti, pa da ispadne dobra kupnja, ali s obzirom na jače modele, cijene i sve ostalo, teško.
Planiram ubaciti u komp već neko vrijeme rtx 4060 ti čisto neka se nađe ako mi se zaigra nešto, ali reko aj prvo da pričekam ove nove, da ne bi poslije žalio.
Staro 14.03.2025., 11:20   #744
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,160
4060ti je ok grafa, ali jako lose cijene, kao i vecina nvidijinih grafi
do 500e radije gledaj drugi tabor
Staro 14.03.2025., 11:31   #745
slavonac90
slavonac90's Avatar
Postovi: 1,513
Uzeo sam u razmatranje sve, te se nadao da će Rx 9070 biti cjenovno pristupačnija, točnije ispod nekih 700 eurića, kad ispala kifla.
A u tom nižem rangu imam jedino rx 7700 xt i RX 7800 xt koje dosta troše, a to mi se ne sviđa.
Od Rtx 4060 ti modela gledam najjeftiniji Inno3d sa 2 venta za 490 eura na rate, ali pričekam da vidim što ponudi nova serija, ako bi se recimo mogla naći rtx 5060 ti 16 gb za nekih 600-650 eura onda bih išao na tu opciju.
Staro 14.03.2025., 11:33   #746
Postovi: 8,206
Najveći problem sa RTX 4060 Ti je samo 10% porast performansi u odnosu na RTX 3060 Ti, dok bi "nova" RTX 5060 Ti mogla biti na istom tragu, plus ni vrit ni mimo s cijenom i raspoloživosti.
Staro 14.03.2025., 12:05   #747
Piksa
Piksa's Avatar
Lokacija: Chakovec
Postovi: 385
Ni ja nemam puno vremena za igre, ali isto gledam grafu u tom rangu "ako mi se nešto zaigra", da mogu odigrat na medium u full Hd rezi.
RTX 4060 bi mi bila dovoljna, ali vidim da je za slične pare dobavljiva RX 6750 10GB, pa sam lagano u dilemi. Ali pričekat ću i RTX 5060 da vidim šta će iz toga ispast.
Piksa je offline   Reply With Quote
Staro 14.03.2025., 13:35   #748
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Uzmite 7800XT izvana, osjetno je jača od 060 Ti modela i ima 16gb VRAM.
Oko 500€ su, IMHO ovaj tren nekakav best buy.
Staro 14.03.2025., 19:30   #749
Dottore
Dottore's Avatar
Postovi: 7,635
Potvrđujem, ja sam vidio potpuno novu 7800xt za 550 eura. Jaka protiv 3070, a jedva preko 3080. Za novu 5060 seriju neće biti napretka više od 3% od prethodne generacije, škrtarenja na memmoriji i defektnih ropova iz Blackwell serije.
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 14.03.2025., 21:11   #750
NoNic2
NoNic2's Avatar
Lokacija: zadar
Postovi: 103
Cijene su stvarno postale nenormalne, nemogu ni zamisliti kakva će situacija biti kad pređu na 3nm proces. Ispada da danas bez 1000 eura nemožeš više kupiti nekakvu "normalnu" Nvidia karticu. Do prije par mjeseci mogla se bar kupiti 4070 ti super za nekih 800-njak eura a sada je i to premalo novaca.
NoNic2 je offline   Reply With Quote
