Staro 28.02.2025., 14:02   #1
Postovi: 8,197
Arrow AMD Radeon RX 9000 series (Navi RDNA4) ‎
AMD Radeon RX 9070 Series Technical Deep Dive
Today AMD is announcing only the top Radeon RX 9070 series from this generation. The two aim to provide enthusiast-class gaming experience in the performance segment at prices that could disrupt NVIDIA's performance-segment offerings from the RTX 5070 series. Historically, the xx70 series have sold in large volumes, and AMD itself has had a track record of unsettling NVIDIA in this segment with the original RDNA RX 5700 series versus the RTX 20-series, and so the company could be on to something. The series consists of just two SKUs for now, the top Radeon RX 9070 XT, and the next-best Radeon RX 9070, both are performance-segment products based on a common silicon, the 4 nm Navi 48.
The Navi 48 silicon is technically a performance-segment chip, logically its predecessors would have to be the Navi 32, the Navi 22, and the Navi 10, but there's more to this story because AMD changed the nomenclature of Radeon RX with this generation. The Navi 48 silicon physically has 64 compute units, and a 256-bit wide GDDR6 memory bus driving 16 GB of memory on both cards. The RX 9070 XT maxes it out, enabling all 64 CU (4,096 stream processors), and the highest possible clock speeds, while the RX 9070 gets 56 CU (3,584 stream processors). The RX 9070 XT also comes with 128 AI accelerators, and 64 RT accelerators, besides 512 TMUs and 128 ROPs. The RX 9070, on the other hand, offers 112 AI accelerators, 56 RT accelerators, 448 TMUs, and 112 ROPs. The RX 9070 XT boosts up to 2.97 GHz, while the RX 9070 goes up to 2.52 GHz.
FSR 4 makes its debut as a Radeon RX 9000 series exclusive technology, with up to 30 game titles expected at launch and at least 75 titles in 2025. The biggest change with FSR 4 is a new AI ML-based super resolution component that vastly improves image quality at a given performance preset. FSR 4 now more closely resembles DLSS in the way it works. AMD now has its own FSR 4 AI data-center made up of AMD Instinct AI GPUs, on which the company trains custom, game-specific ML models, which the FSR 4 upscaling algorithm uses to reconstruct details in upscaled frames. On the client side, the ML-based upscaler needs an AI acceleration throughput of 779 AI TOPS, which the RX 9070 series more than sufficiently meet (around 1200 TOPS for the RX 9070, and around 1500 TOPS for the RX 9070 XT).
Zadnje izmijenjeno od: The Exiled. 28.02.2025. u 14:11.
Staro 28.02.2025., 14:29   #2
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 414
9070 cijena mi bas nema pretjeranog smisla pored samo 50$ skuplje 9070XT.
Opet slicno kao launch 7900 serije kada su 7900XT cijenu stavili preblizu cijene 7900XTX.
Ako 9070XT bude po performansama tu kao i 5070TI onda je 599$ fakat dobra cijena, taman 20% nize.
Cekaju se revieowi, pa da se vidi koliko je stvarno dobra/losa cijena 9070XT...
If you are not paranoid you don't have enough information
Tumor je offline   Reply With Quote
Staro 28.02.2025., 14:42   #3
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Nebulozni kao i do sada, a za cijenu treba vidjet kolika će biti u dućanu, MSRP je mrtvo slovo na papiru.
I naravno treba vidjeti i prave performanse.
Ne bi me čudilo da ako ovo ispadne OK i cijenom i performansama, da se odjednom nađe hrpetina blackwella u prodaji, tj 5070 Ti i 5070.
Slobodno me dodajte na PSN
Staro 28.02.2025., 14:49   #4
markecSMB
Lokacija: Cro
Postovi: 1,028
Autor Tumor Pregled postova
Meni se nvidija baš ogadila s 5000 serijom.
Ali, 20% manja cijena, dobiješ manje.
Dobiješ ddr6 umjesto 7 (i znatno manju propusnost). Dobiješ znatno lošiji software paket...
Mogli su to i niže. Al svejedno, nadam se da će ljudi kupovat.
Staro 28.02.2025., 14:52   #5
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,160
Cijena zvuci dobro, ali stvarno stanje će biti vjerovatno dosta drugačije.
Vidjet ćemo za tjedan dana kada izađu performanse i cijene.
Mislio sam ubost nitro+ ali i oni prešli na 12V 2x6.
Poslano sa mog SM-S928B koristeći Tapatalk
Staro 28.02.2025., 14:54   #6
Postovi: 8,197
Autor Disco Pregled postova
... za cijenu treba vidjet kolika će biti u dućanu, MSRP je mrtvo slovo na papiru.
Da, kad RTX 5000 serija nema nikakve zalihe, dok je RDNA 4 već tri mjeseca u povećim količinama na skladištima raznih dućana diljem svijeta.
Iskreno, ovo se čini i više, nego vredu, a nakon recenzija još kad se dodatno sve kockice poslože, moglo bi ispasti OK za kritiku i publiku.
Autor Gemmy Pregled postova
Veli čovek da ne bi trebalo biti problema, a i kartice troše osjetno manje od Blackwell izdanja.
Sapphire has confirmed that RX 9070 non-XT has TBP of 245W (25W higher than AMD specs), while RX 9070 XT NITRO+ has 330W specification, which is 26W higher than AMD’s.
Zadnje izmijenjeno od: The Exiled. 28.02.2025. u 15:34.
Staro 28.02.2025., 15:06   #7
Roverinho
Datum registracije: Mar 2021
Postovi: 38
Nakon i previše godina s Nvidijom, prvi put ću sad da idem na AMD.
Cijena za XT i nije tako loša,pogotovo ako bude i nešto brža od 5070TI kao što su prikazali.
Za non-XT su trebali nižu stavit, jer praktički će svatko dodati 50 više i uzeti XT.
Možda im je to i taktika
Treba vidit Benchove u srijedu pa da se bolje zna.
Samo se nadam da kod nas dućani neće previše dizat cijenu, pogotovo za ove obične modele od XT.
Uz porez i sve,valjda neće prelazit 750
Roverinho je offline   Reply With Quote
Staro 28.02.2025., 16:04   #8
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
4070 super je bila 600$ pa je bila preko 800 eura kod nas kad je izasla. 800-900 eura za XT a 9070 su shebali ko 7700xt, steta.
MAGARAC je online   Reply With Quote
Staro 28.02.2025., 16:30   #9
Roverinho
Postovi: 38
Autor MAGARAC Pregled postova
Mislim da je cijena od 600 za xt realna i ok.
Moraju i oni zaradit tu,neće poklanjat kartice.
Kod nas bi mogla doći oko 750-800 što nije tako strašno ako pogledaš 5070TI koja je i skoro duplo skuplja
Staro 01.03.2025., 09:22   #10
Tumor
Tumor's Avatar
Postovi: 414
Staro 01.03.2025., 13:15   #11
Roverinho
Postovi: 38
Da,pričalo se o tome da će bit podrške i za starije kartice
Staro 01.03.2025., 14:47   #12
Tirion
Datum registracije: Oct 2021
Postovi: 68
Kakve su ove AMD-ove grafičke što se tiče kvalitete drivera? Svojedobno tamo još pred 20 i više godina tadašnje ATI Radeon grafičke nisu bile poznate kao neka sreća, driveri su bili dosta bugoviti i problematični, pa me zanima kakva je situacija zadnjih godina što se toga tiče.
Kako razmišljam o nabavci nove konfiguracije ova nova serija izgleda više nego zanimljivo ako će performansama biti tu negdje s Nvidijinom serijom 5000, koja ispada kao teži promašaj em zbog apsurdnih cijena, problema s kvalitetom, samozapaljenja itd. Sve neodoljivo podsjeća na situaciju s Intel 13 i 14 gen procesorima koja je eskalirala prošlo ljeto.
Do sad sam bio na Intel/Nvidia kombinaciji što se tiče procesora i grafičke, no evo kako je Intel praktički gotov i pred kolapsom a Nvidia se jako osramotila s 5000 serijom, izgleda da full AMD opcija postaje zapravo jedino razumno i nažalost smisleno rješenje...
Tirion je offline   Reply With Quote
Staro 01.03.2025., 16:08   #13
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,160
meni uz 6700xt nije radila niti jedan problem sta se tice igri i rusenja, ali mi nije htio drzat undervolt na bilo kojim postavkama, svako malo se srusilo adrenaline i resetiralo iz cista mira, ali ne u igrama nego nakon sta bi izasao ih njih
na defaultu sve radilo bez greske
Staro 01.03.2025., 18:29   #14
Tirion
Postovi: 68
Super za čuti, to kako defaultno rade me najviše i zanima jer nikad se nisam bavio overclockanjem i sličnim niti namjeravam, u svakom slučaju to je onda jedna prava alternativa Nvidiji.
A budući da je AMD-ov čip dovoljno dobar da pogoni grafiku u Playstationu 5 i to je jedna vrsta preporuke da očito s tom RDNA arhitekturom odrađuju odličan posao.
Staro 01.03.2025., 18:46   #15
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Misliš bio je dovoljno jeftin za Sony?
Inače Ati/AMD su još bili u Nintendo Gamecubu pa nadalje u raznim konzolama (Gamecube, Wii, Wii U, X360,X1,XSX/S,PS4,PS5), dok je nV bila u prvom XBOXu, PS3 i Switchu te Switchu 2.
Čekamo Intel, on je za sada samo u MSI Claw. :P
Staro 01.03.2025., 18:55   #16
Postovi: 8,197
Malo fali da Intel bude u svemu.
Seamus Blackley apologized on Twitter to the AMD engineers who worked with Microsoft to create the prototype Xbox consoles that the company used in the lead-up to the OG Xbox's release in November 2001. To AMD CEO Lisa Su, Blackley said, "I beg mercy." "I was standing there on the stage for the announcement, with [Bill Gates], and there they were right there, front row, looking so sad," he said of AMD engineers in the room. "I'll never forget it. They had helped so much with the prototypes. Prototypes that were literally running the launch announcement demos ON AMD HARDWARE." "I felt like such an ass," Blackley said. Microsoft dropped AMD in favor of Intel due to "pure politics," Blackley said.
Sve u svemu, šrot AMD se postepeno iz generacije u generaciju posložil kao i više nego solidan izbor, da bi u današnje vrijeme nadišli Intel i popratne im peripetije.
Zadnje izmijenjeno od: The Exiled. 01.03.2025. u 19:02.
Staro 02.03.2025., 15:49   #17
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Nego, kada idu recenzije ovih čudesa?
Staro 02.03.2025., 16:17   #18
Postovi: 8,197
Ovu srijedu (05.03.) su RDNA 4 recenzije, taman kad RTX 5070 ide u prodaju.
Staro 04.03.2025., 08:55   #19
Tumor
Tumor's Avatar
Postovi: 414
Onda bi sutra mogli i Adrenalin 25.3.1 pustiti za download pretpostavljam.
Ili u cetvrtak najkasnije.
Staro 04.03.2025., 09:11   #20
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Vj su drivere rivjueri dobili svi direktno još u petak, a raja će ih dobiti tek 6.3.
Poanta je da popeglaju neke gadne bugove ako ih ima prije prodaje.
Staro 04.03.2025., 09:34   #21
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,303
AMD i popravak drivera. To ne ide u roku kracem od 3 mjeseca
Chuby je offline   Reply With Quote
Staro 04.03.2025., 15:39   #22
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,383
Ajde ako ne bude AMD morao "popravljati" osakaćeni hardware kroz drivere bude to OK
Autor George Carlin
But there’s a reason. There’s a reason. There’s a reason for this, there’s a reason education sucks, and it’s the same reason that it will never, ever, ever be fixed. It’s never gonna get any better. Don’t look for it. Be happy with what you got. Because the owners of this country don't want that. I'm talking about the real owners now, the real owners, the big wealthy business interests that control things and make all the important decisions. Forget the politicians. The politicians are put there to give you the idea that you have freedom of choice. You don't. You have no choice. You have owners. They own you. They own everything. They own all the important land. They own and control the corporations. They’ve long since bought and paid for the senate, the congress, the state houses, the city halls, they got the judges in their back pockets and they own all the big media companies so they control just about all of the news and information you get to hear. They got you by the balls. They spend billions of dollars every year lobbying, lobbying, to get what they want. Well, we know what they want. They want more for themselves and less for everybody else, but I'll tell you what they don’t want: They don’t want a population of citizens capable of critical thinking. They don’t want well informed, well educated people capable of critical thinking. They’re not interested in that. That doesn’t help them. Thats against their interests. Thats right. They don’t want people who are smart enough to sit around a kitchen table to figure out how badly they’re getting f*cked by a system that threw them overboard 30 f*cking years ago. They don’t want that. You know what they want? They want obedient workers. Obedient workers. People who are just smart enough to run the machines and do the paperwork, and just dumb enough to passively accept all these increasingly shittier jobs with the lower pay, the longer hours, the reduced benefits, the end of overtime and the vanishing pension that disappears the minute you go to collect it, and now they’re coming for your Social Security money. They want your retirement money. They want it back so they can give it to their criminal friends on Wall Street, and you know something? They’ll get it. They’ll get it all from you, sooner or later, 'cause they own this f*cking place. It's a big club, and you ain’t in it. You and I are not in the big club. And by the way, it's the same big club they use to beat you over the head with all day long when they tell you what to believe. All day long beating you over the head in their media telling you what to believe, what to think and what to buy. The table is tilted folks. The game is rigged, and nobody seems to notice, nobody seems to care. Good honest hard-working people -- white collar, blue collar, it doesn’t matter what color shirt you have on -- good honest hard-working people continue -- these are people of modest means -- continue to elect these rich c*cksuckers who don’t give a f*ck about them. They don’t give a f*ck about you. They don’t give a f*ck about you. They don't care about you at all -- at all -- at all. And nobody seems to notice, nobody seems to care. That's what the owners count on; the fact that Americans will probably remain willfully ignorant of the big red, white and blue dick that's being jammed up their assholes everyday. Because the owners of this country know the truth: it's called the American Dream, because you have to be asleep to believe it.
mkey je online   Reply With Quote
Staro 05.03.2025., 06:04   #23
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Bacio sam malo oko na 9070XT i čini mi se da jedino Asrock Steel Legend ide do 298mm (meni stane 302mm u kućište). Ima li još koja XT da je do 300mm?
Naravno sve ovisi o cijeni (da li će biti XT, non XT ili ništa ). A nekako bi pričekao mj-dva da vidimo kada ih bude više u opticaju da li ima nekih mana i slično kao kod zelenih.
Uvijek bi radije Sapphire ali čak i Pulsica je mislim 320mm.
Staro 05.03.2025., 06:58   #24
the-rider
ha?
the-rider's Avatar
Lokacija: Poreč
Postovi: 541
nitro ima ono smece od 12 pin napajanja
the-rider je offline   Reply With Quote
Staro 05.03.2025., 08:42   #25
Silthrax
Silthrax's Avatar
Lokacija: Gračac
Postovi: 476
Kolega vidim imas isti problem kao i ja, kod mene je 315 mm. Bas sam se razocarao kad sam vidio duljine grafičkih.
Silthrax je offline   Reply With Quote
Staro 05.03.2025., 08:50   #26
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Ogromne su sve, ne vjerujem da ne mogu u 290-300mm napraviti prihvatljivo hlađenje.
Pulse 9070 vulgaris je 285mm, to je super.
Mislim ja mogu i raskupusat kućište, ali ne bi ako ne moram.
Ovo moje prastaro kućište mi je predobro još uvijek i ne bih ga mijenjao bzvz.
Staro 05.03.2025., 09:04   #27
Postovi: 8,197
Moral budeš jednom kupiti neko novije i modernije kućište, jer na ovaj način ti ništa ne bude pasalo, a znaš da oni ne budu složili karticu kak tebi paše.
Pričekaj sve današnje recenzije, pa dodatno provjeri kakvi se modeli nude, jer možda bude kakvih kraćih XT i običnih izdanja.
Staro 05.03.2025., 09:45   #28
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
Da, Asrock mi baš ne ulijeva povijerenje, ali ono...ima garanciju.
Pa i sada imam Palit, najeftinijeg jeftikanera i radi ko sat.
Staro 05.03.2025., 09:49   #29
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,593
Daj raspili to kućište već jednom da možeš staviti grafu ko normalan čovjek unutra
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 05.03.2025., 10:18   #30
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,502
Nedavno sam jedva ugurao 340mm grafu u matx kučište, bilo je za par milimetara, stvarno je bilo gusto Sa time da sam naravno cage za hdd-e odavno otpremio u smeće.
Morat ćeš stvarno nešto promijenit jer se bezveze ograničavaš, nažalost su grafe danas predimenzionirane, i to neki obični midrangeri.
