Staro 26.02.2025., 17:54   #1801
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,498
W11 još uvijek u beti, sudeći po changelogu.
Staro 01.03.2025., 08:23   #1802
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,708
Microsoft Edge is following Chrome's lead by disabling uBlock Origin and other Manifest V2-based extensions in its browser. Neowin reports: The latest Edge Canary version started disabling Manifest V2-based extensions with the following message: "This extension is no longer supported. Microsoft Edge recommends that you remove it." Although the browser turns off old extensions without asking, you can still make them work by clicking "Manage extension" and toggling it back (you will have to acknowledge another prompt).
Google started phasing out Manifest V2 extensions in June 2024, and it has a clear roadmap for the process. Microsoft's documentation, however, still says "TBD," so the exact dates are not known yet. This leads to some speculating about the situation being one of "unexpected changes" coming from Chromium. Either way, sooner or later, Microsoft will ditch MV2-based extensions, so get ready as we wait for Microsoft to shine some light on its plans.
Another thing worth noting is that the change does not appear to be affecting Edge's stable release or Beta/Dev Channels. For now, only Canary versions disable uBlock Origin and other MV2 extensions, leaving users a way to toggle them back on. Also, the uBlock Origin is still available in the Edge Add-ons store, which recently received a big update.
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / 1TB Micron M.2 2242 / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad T540p || Intel Core i7-4700MQ / 16GB DDR3 / 240GB Sandisk SSD Plus / nVidia Geforce GT 730 / FreeBSD 14.3
Staro 02.03.2025., 14:32   #1803
tomek@vz
tomek@vz's Avatar
Postovi: 4,708
Coool
For the past several years my desktop has also had a disk dedicated to maintaining a Windows install. I’d prefer to use the space in my PC case for disks for Linux. Since I already run a home NAS, and my Windows usage is infrequent, I wondered if I could offload the Windows install to my NAS instead. This lead me down the course of netbooting Windows 11 and writing up these notes on how to do a simplified “modern” version.
↫ Terin Stock
The setup Terin Stock ended up with is rather ingenious, to be honest. They had to create not just an environment in which netbooting through iXPE using iSCSI, but also a customised Windows PE ISO that included the necessary drivers to make installing Windows onto a iSCSI-connected remote drive possible in the first place, because they’re not included in the Windows installation ISO. This isn’t exactly a standard setup, of course, so there were a few roadblocks to clear before getting there.
They now have Windows 11 booting from a drive in their NAS, and it seems it doesn’t affect gaming – the reason why they did this in the first place is an online game that hard-requires Windows – at all. Installing the game through Steam took a bit longer, sure, but regular gameplay seems unaffected, and there’s no saturation on the network or disk. You’d think this would be wholly too slow to be suitable for gaming, but I guess at least some games handle this just fine. My uneducated guess is that more demanding games that rely on a ton of disk activity to load textures and so on will have a much more difficult time running.
Staro 04.03.2025., 12:30   #1804
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,748
Danas se prijavljujem na amazon.de da bi nešto kupio. Koristim Firefox, zadnji dostupni.
Nakon što mi je Firefox popunio username / password i stisnuo da se prijavim, iskače WINDOWS OS popup gdje me pita da li želim spremiti Amazon lozinku u Windowse...
WTF!?
Nisam se snašao jer sam se žurio kupiti stvar pa sam mahinalno stisnuo NE ili prvo što mi je ličilo na NE i nastavio.
Kakva su ovo sada nova izmišljanja od Win11? Kako uopće prate da sam ja na Amazon stranici? Ne koristim Edge, zato i napominjem da sam na Firefoxu.
EDIT: Evo slike, probao se logirati s drugim računom pa ponovno iskočilo.
Staro 04.03.2025., 12:42   #1805
medo
#erase startup-config
medo's Avatar
Postovi: 3,657
Furaju se na Apple
Staro 04.03.2025., 12:55   #1806
Postovi: 10,003
Pristupni ključ, lol
Ugl guglaj passkey i kako je njegova podrska implementirana u W11 te kako radi. Ovo nije spremanje passworda kao takvog nego passkeya koji je korak prema passwordless scenariju (kada lijepo radi i kada je lijepo implementiran u uslugu na koju se logiras).
Mislim, nisi obvezan to i koristiti, valjda postoji nacin da se onemoguci passkey podrska u W11 pa i to proguglaj.
Staro 04.03.2025., 13:03   #1807
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,714
da, passkey opcija.
Dobra će to biti stvar, pogotovo ako imaš fingerprint na uređaju, ne moraš se sa passwordima zezati.
Staro 04.03.2025., 13:21   #1808
dadoremix
dadoremix's Avatar
Postovi: 4,684
i onda kad se svi na to priviknemo.. puff odu svi passwordi ili ih hackaju
Staro 04.03.2025., 14:03   #1809
medo
medo's Avatar
Postovi: 3,657
Bez privatnog ključa koji je u nekom sigurnosnom chipu (Yubikey, Secure Enclave, TPM…) i bez kvantnog računala nije problem ako ti maznu password
Staro 04.03.2025., 14:07   #1810
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,226
zato ja spavam sa 2 yubikeya ispod jastuka
Staro 04.03.2025., 14:34   #1811
tomek@vz
tomek@vz's Avatar
Postovi: 4,708
Problem je da je kod Win 11 to automatika. Automatikom ti kreira Passkey na Amazonu i sprema u lokalni Windows Hello Account. Been there, done that
Staro 04.03.2025., 14:35   #1812
Postovi: 10,003
Ne valja ako su oba ispod istog jastuka
Edit
jedan ispod ženinog, logično
Hehe samo to sam htio cuti
Zadnje izmijenjeno od: xlr. 04.03.2025. u 15:34.
Staro 04.03.2025., 14:38   #1813
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,226
Staro 04.03.2025., 15:55   #1814
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,323
Koja prednost ove funkcije pred nekim password managerom? Pitam koja je prednost, jer manu (više njih, actually) znam.
Autor George Carlin
But there’s a reason. There’s a reason. There’s a reason for this, there’s a reason education sucks, and it’s the same reason that it will never, ever, ever be fixed. It’s never gonna get any better. Don’t look for it. Be happy with what you got. Because the owners of this country don't want that. I'm talking about the real owners now, the real owners, the big wealthy business interests that control things and make all the important decisions. Forget the politicians. The politicians are put there to give you the idea that you have freedom of choice. You don't. You have no choice. You have owners. They own you. They own everything. They own all the important land. They own and control the corporations. They’ve long since bought and paid for the senate, the congress, the state houses, the city halls, they got the judges in their back pockets and they own all the big media companies so they control just about all of the news and information you get to hear. They got you by the balls. They spend billions of dollars every year lobbying, lobbying, to get what they want. Well, we know what they want. They want more for themselves and less for everybody else, but I'll tell you what they don’t want: They don’t want a population of citizens capable of critical thinking. They don’t want well informed, well educated people capable of critical thinking. They’re not interested in that. That doesn’t help them. Thats against their interests. Thats right. They don’t want people who are smart enough to sit around a kitchen table to figure out how badly they’re getting f*cked by a system that threw them overboard 30 f*cking years ago. They don’t want that. You know what they want? They want obedient workers. Obedient workers. People who are just smart enough to run the machines and do the paperwork, and just dumb enough to passively accept all these increasingly shittier jobs with the lower pay, the longer hours, the reduced benefits, the end of overtime and the vanishing pension that disappears the minute you go to collect it, and now they’re coming for your Social Security money. They want your retirement money. They want it back so they can give it to their criminal friends on Wall Street, and you know something? They’ll get it. They’ll get it all from you, sooner or later, 'cause they own this f*cking place. It's a big club, and you ain’t in it. You and I are not in the big club. And by the way, it's the same big club they use to beat you over the head with all day long when they tell you what to believe. All day long beating you over the head in their media telling you what to believe, what to think and what to buy. The table is tilted folks. The game is rigged, and nobody seems to notice, nobody seems to care. Good honest hard-working people -- white collar, blue collar, it doesn’t matter what color shirt you have on -- good honest hard-working people continue -- these are people of modest means -- continue to elect these rich c*cksuckers who don’t give a f*ck about them. They don’t give a f*ck about you. They don’t give a f*ck about you. They don't care about you at all -- at all -- at all. And nobody seems to notice, nobody seems to care. That's what the owners count on; the fact that Americans will probably remain willfully ignorant of the big red, white and blue dick that's being jammed up their assholes everyday. Because the owners of this country know the truth: it's called the American Dream, because you have to be asleep to believe it.
mkey je online   Reply With Quote
Staro 04.03.2025., 16:07   #1815
tomek@vz
tomek@vz's Avatar
Postovi: 4,708
Autor mkey Pregled postova
Ukratko....lozinka sa extra koracima. Navodno dosta sigurno rijesenje - zasad.
https://blog.1password.com/passkeys-...nderstandings/
https://hub.easycrypto.com/what-are-...-secure-logins
https://www.pcmag.com/explainers/pas...u-need-it-asap
Kao i svako rijesenje - toliko sigurno koliko i ostale karike u lancu sigurnosti korisnika.
Staro 04.03.2025., 17:20   #1816
medo
medo's Avatar
Postovi: 3,657
Windows 11 - info, how-to, pitanja, novosti, savjeti...
Prednost je što ti ne treba password manager. Imaš ga u OSu i synca se sa svime što je u tvojem Microsoft/Google/Apple accountu.
Većini je to plus a iskreno i meni za NEKE stvari.
Problem je što ne možeš backupirati privatne ključeve a samim time ne možeš napraviti data recovery ukoliko izgubiš hardware s privatnim ključevima. Tu nastaje problem jer je sikjuriti morao biti oslabljen da bi data recovery bio moguć.
Staro 04.03.2025., 21:49   #1817
potemkin.hr
Akutna lijenčina
potemkin.hr's Avatar
Lokacija: Fiume
Postovi: 1,833
Autor medo Pregled postova
Zato ne volim hardware based koji prdne i ako nema neki recovery kako spada da vidiš veselja. KeepassXC uveo support za passkeyeve al ne bi se igrao s tim
potemkin.hr je offline   Reply With Quote
Staro 05.03.2025., 06:12   #1818
tomek@vz
tomek@vz's Avatar
Postovi: 4,708
Nebi bas smjelo do takvog scenarija doci (prvi link gore koji sam postao):
Misunderstanding: You can’t sign in to your accounts if you don’t have the device that contains your passkeys
What happens if you arrive at work and realize you’ve forgotten the phone that has all your passkeys? Will you be locked out of all your online accounts? Not necessarily.
Google, Apple, and Microsoft will sync your passkeys across devices using their respective cloud-based storage services. So if you create a passkey using an iPhone, you can access the same passkey on your other Apple devices via iCloud.
Okay, but what happens if you’ve forgotten your iPhone, but need to use a Windows PC in a public library? In this scenario, you should be given a second option to sign in. For example, a website might send you a “magic link” — a one-time link that lets you instantly sign in — to your chosen email address.
...ali da je to jedini nacin authentifikcije - da onda bi bio problem.
Staro 11.03.2025., 19:08   #1819
tomek@vz
tomek@vz's Avatar
Postovi: 4,708
Giant, AI ads are coming to Windows Copilot. Thanks, Microsoft
https://www.pcworld.com/article/2633...microsoft.html
Staro 19.03.2025., 18:00   #1820
NoNic2
NoNic2's Avatar
Lokacija: zadar
Postovi: 103
Microsoft ide u smjeru da kopira Google i bude ad company a software koji pruža besplatno ili jeftino bude samo most koji spaja korisnike i reklame.
NoNic2 je offline   Reply With Quote
Staro 19.03.2025., 19:54   #1821
Deamon101
Deamon101's Avatar
Postovi: 614
Kako prestaje support za windows 10 pred kraj godine, koliko opušteno odnosno koliko po ps-u će te u firmama izvršiti zamjenu OS-a?
U principu zahtjevi su malo kontradiktorni, ali realno 1ghz, 64gb disk, 4gb ram, i ono najvažnije, tpm 2.0 su jedini uvjeti.
Ona nekakva lista sa npr. procesorima koji jesu/nisu podržani, izvršio sam jednu instalaciju za test danas i prošlo je bez problema iako procesor nije službeno podržan. PC ima tpm 2.0, ali je star 10 godina.
Realno veća količina odjednom se neće moći prebaciti na windows 11 odjednom.
Vjerujem da se u principu samo radi o tome da pravno gledano Microsoft se na taj način ograđuje itd. za bilo kakve propuste, odnosno daje si više prostora za manevar i bolje rezultate na sudovima npr.
Plaćanje dodatne potpore za sigurnost za windows 10 ne dolazi u obzir jer košta koliko i windows 11 licenca, te vjerujem da kod mnogih većih firmi koje imaju ugovor sa Microsoft će se jednostavno morati naći na pola puta.
Ja osobno mislim da ćemo uspijeti kroz realno 3 godine sve uspijeti prebaciti obzirom na količinu i lokacije.
p.s. osobno mi je win11 smeće te i dalje koristim win10, ali čini se da ću još bolje morati znati naredbe napamet jer windows 11 je napravljen kao labirint sa opcijama i totalno kontra bilo kakvoj logici.
Zdravoseljački rečeno windows 11 je gay i prekrasan kao i oni koji ga veličaju iznad svega drugog
Zadnje izmijenjeno od: Deamon101. 19.03.2025. u 20:17.
Deamon101 je online   Reply With Quote
Staro 19.03.2025., 20:38   #1822
tomek@vz
tomek@vz's Avatar
Postovi: 4,708
Ha gle - dobio sam dva nova Thinkpada T14s bas radi toga i tu radi ko violina. Ali stari Thinkpad T480 (i7 4th Gen,16GB RAM, 240GB SSD) - da radi nakon sto sam mu puknuo graficke drivere (GT730) sa win 10 jer ovi koje je vukao sa Win Update-a su BSOD-ali sustav konstantno - pa stari T480 se teli iako ima novi SSD unutra. Nisam jos siguran kaj ga tolko davi jer ima trenutke kad radi normalno ali nakon boota par minuta se krmi - ne ko krepana kokos ali nije daleko od toga. Kao sto sam vec kontatirao > Win 11 je jednostavno novi standard i bok.
Staro 19.03.2025., 22:44   #1823
mkey
Lokacija: tu
Postovi: 3,323
Mislim da bude puno laptopa išlo u otpis.
Autor George Carlin
Staro 20.03.2025., 07:38   #1824
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,016
Još samo da do tih novijih laptop mogu nekako doći... Odmah ide gore Debian. Kakvi bakrači kakvi Windowsi...
Staro 20.03.2025., 07:46   #1825
Postovi: 10,003
Oni koji nisu cekali 5 do 12 su vec promjenili opremu, a zaposlenici eventualno otkupili tu opremu. Jos uvijek ceznem za w10 i starim Dell-om 7510 :')
Staro 20.03.2025., 15:32   #1826
mkey
Lokacija: tu
Postovi: 3,323
Autor spiderhr Pregled postova
Laptop će ti biti zahvalan. Kada stavim linux gore doslovno čujem kako komp odahne
xlr, ja, da ti pravo kažem, za svojim starim dellom ne čeznem niti najmanje. Ne znam niti koji je model, XPS nešto nešto. Vratio ga u firmu i rekao im da ga unište.
Autor George Carlin
Staro 24.03.2025., 14:35   #1827
gin.tonic
gin.tonic's Avatar
Postovi: 2,431
Da li je itko stavio Windows 11 na nepodržan hardver?
gin.tonic je offline   Reply With Quote
Staro 24.03.2025., 14:46   #1828
tomek@vz
tomek@vz's Avatar
Postovi: 4,708
Autor gin.tonic Pregled postova
Mnogi Ispravno bi pitanje glasilo: "kako ce win 11 raditi na mojoj kanti?".
Staro 24.03.2025., 15:04   #1829
gin.tonic
gin.tonic's Avatar
Postovi: 2,431
Procesor je u pitanju
Staro 24.03.2025., 15:07   #1830
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,034
11th gen je podržan i dela dobro.
Sve unazad 8 godina je podrzano tak da nema brige.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
