Staro 16.02.2025., 09:18   #331
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,382
To je opet 800+€ kod nas, ali kad pogledaš nV ovo je čaba...
A ovi što su ih kupili si ih mogu prištekat u guzu dok ne izađu driveri.
Slobodno me dodajte na PSN
Staro 16.02.2025., 15:22   #332
Dottore
Dottore's Avatar
Postovi: 7,703
Preporučeno napajanje će biti na razini RTX 5xxx.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 16.02.2025., 16:21   #333
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,309
Pa koliko struje na kraju treba 9070xt?
Nalazim podatak da treba manje od 300W a preporuceno napajanje 850-900W.
6800XT treba vise snage pa je preporuceno 750W.
Chuby je offline   Reply With Quote
Staro 16.02.2025., 16:38   #334
Postovi: 8,545
Na kraju bude ovisilo o modelu pojedinog proizvođača, ali općenito su kartice u rangu s onim kaj smo i dosad imali na tržištu.
The Red Devil Radeon RX 9070 XT, which we already revealed has a 3.0 GHz boost clock out of the box, will also have high power supply requirement of 900-watt. The box indicates that the RX 9070 XT will need a 900W PSU. Quick check confirms that there are indeed overclocked variants with increased power requirements; however, the stock (reference) requirement seems to be 750W. For instance:
  • PowerColor RX 9070 Reaper: 650W (2x 8-pin) AMD Reference Specs
  • PowerColor RX 9070 XT Reaper: 750W (2x 8-pin) AMD Reference Specs
  • PowerColor RX 9070 XT Red Devil: 900W (3x 8-pin) OC Specs
As you can see, the default is 750W. If you opt for a reference model or anything priced at MSRP, chances are you will not need to upgrade your PSU. Furthermore, the non-XT version is said to have a 650W PSU requirement. For comparison, PowerColor’s RX 7700 XT Fighter (AMD reference spec) needs a 750W PSU, and the 7900 GRE also needs a 750W PSU. In fact, even the 7800 XT Fighter needs 750W. As we can see, the power requirement hasn’t changed, and we are definitely looking at a sub-300W TBP, given that all these cards have 245-263W specs. The Red Devil, however, should exceed 300W.
Primjera radi, referentna RX 7800 XT zapravo troši ~250W, dok custom modeli idu na kakvih 275W+ ili 300W+, a svi imaju preporučeno napajanje od 750W.
I sad bude slična situacija, odnosno RX 9070 modeli imaju preporučena napajanja (za cijelu konfiguraciju) koja uvelike nadilaze njihove realne potrošnje.
Zadnje izmijenjeno od: The Exiled. 16.02.2025. u 16:53.
Staro 16.02.2025., 21:22   #335
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Autor Chuby Pregled postova
Ocito nabrijani modeli idu blizu 400W kad dolaze sa 3x8pina.
Staro 21.02.2025., 13:26   #336
Postovi: 8,545
AMD Radeon RX 9070 XT confirmed as 304W card, RX 9070 non-XT is 220W
The official power metrics for the Radeon RX 9070 series are in. AMD held a press briefing today, and there are new leaks straight from the presentation. The Radeon RX 9070 XT is confirmed to have a 2970 MHz boost clock and 304W TBP (Total Board Power), whereas the RX 9070 non-XT will launch with a 2520 MHz boost and 220W TBP. Note that these figures are for AMD reference specs, and so far, AMD has not confirmed whether the reference design pictured above will go on sale.
We also learn that the PCIe 5.0 x16 specs are correct, so the GeForce RTX 50 series will no longer be the only consumer GPUs with this standard. AMD has also confirmed 56 and 64 Compute Unit configurations for the RX 9070 and 9070 XT, respectively, which should provide 3584 and 4096 Stream Processors, respectively. Both RX 9070 cards will launch with 16GB GDDR6 memory, although the official specs do not mention the speed. AMD has also confirmed DisplayPort 2.1a and HDMI 2.1b specs, so these will match the RTX 50 series as well. AMD has not confirmed pricing yet.
Izvor: VideoCardz
Staro 21.02.2025., 20:03   #337
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 432
Za moju PowerColor RX 7800XT Red Devil na PowerColor stranici pise:
³Recommended power supply for AMD Radeon RX 7800 XT graphics card is minimum 800W or greater power supply with 12V output > 62A. Minimum recommended system power supply wattage is based on a PC configured with an AMD Ryzen 9 7950X processor plus typical power requirements of other system components. Your system requirements may differ.
Ja sam ju bez problema drzao na EVGA SuperNova G2 650W dugo vremena. Doduse, uparenu sa 12400F koji i nije neki potrosac, ali ipak na 650W dobrom napajanju isla bez beda.
If you are not paranoid you don't have enough information
Tumor je offline   Reply With Quote
Staro 21.02.2025., 20:08   #338
tuna3
Datum registracije: Mar 2009
Postovi: 474
tuna3 je offline   Reply With Quote
Staro 25.02.2025., 11:34   #339
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,382
Radeon RX 9070 XT At Work On Linux: 3.24 GHz Clock at 330 Watts
A ove cijene iznad su odlične, ODLIČNE, baš u AMD stilu.
Još malo pa će vidimo "prave" cijene.
Zadnje izmijenjeno od: Disco. 25.02.2025. u 11:43.
Staro 25.02.2025., 12:11   #340
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,664
Autor Tumor Pregled postova
Ma te fore sa napajanjem su da se zaštite od likova sa sumnjivim kutijicama teškim 100 grama nazivne snage 1200W
Meni je 7800XT bio na 550W napajanju i mogao sam još štošta spojit na to, par žarulja
Dobre su ovo cijene za 9070XT, možda je samo placeholder a možda je FSR4 bolji od DLSS-a 4
Staro 25.02.2025., 12:19   #341
Postovi: 8,545
Cijene smo već komentirali, kaj u ovoj, kaj u RTX 5000 temi, tak jasno da one cifre nemaju veze s vezom, a krajem ovog i sredinom sljedećeg tjedna bude sve jasno.
EDIT:
AMD teases Radeon RX 9070 focusing on sub-$700 price point
From what we have been told and shared during the media briefing, AMD showed one slide that may confirm where the prices will be. The Radeon RX 9070 series is focusing on a sub-$700 price point, and AMD wants their cards to be “more accessible”. AMD says that 85% of gamers buy cards below $700, and this is what the RDNA 4 series will focus on. AMD also mentions three other focus points for the Radeon RX 9070 series: higher resolutions, clearly aiming at 1440p and 4K (as indicated in the performance leak), as well as more performance with ray tracing and easier upgrades, given that most RDNA 4 cards will use 8-pin power connectors.
Izvor: VideoCardz
Zadnje izmijenjeno od: The Exiled. 25.02.2025. u 16:23.
Staro 26.02.2025., 00:12   #342
Taproot7
mag.math.
Taproot7's Avatar
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 366
Prema zadnjim informacijama, cijene su 649 američkih dolara za Radeon RX 9070XT model i 499 američkih dolara za RX 9070 model. No to neće imati puno veze ako se iste nađu kod trgovina koje će odrediti cijene koje oni misle da bi bile prikladne. nVidia GeForce 5070Ti grafičke kartice imaju 750 američkih dolara preporučenu cijenu ali vidimo cijene koje su skoro 100 posto veće ali ne kod naprimjer Amazon-a nego trgovaca koji imaju jedan ili malo više komada dostupno za isporuku odmah. Ukoliko AMD Radeon bude isporučio veće količine i to većim trgovinama poput Amazon-a ili po Europi MediaMarkt-a cijene ne bi trebale biti u rango ovih od 1200 i više eura već vrlo blizu preporučene cijene. Američki dolar i euro su ionako sada skoro pa 1:1.
Taproot7 je offline   Reply With Quote
Staro 26.02.2025., 06:33   #343
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,382
Eto, AMD marketing nije razočarao.
Lupaju oni po svom i boli ih briga, mogu samo zaključiti da su očito općenito zadovoljni prodajom.
A naravno za koji mj slijedi neslužbeno spuštanje cijene.
Staro 26.02.2025., 09:19   #344
MAGARAC
MAGARAC's Avatar
Postovi: 5,995
500$ za rx 9070 je odlicna cijena. 16gb, pref ko 7900xt, RT bolji od bilo kojeg Radeona do sad i uz malo srece ogroman OC potencijal. Mene 9070 vise interesira nego XT, nista nije pretjerano srezano i sve ima ko XT. Ak nekom to nebu dosta uskoro bu rtx 5070 izasla
Staro 26.02.2025., 09:43   #345
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Autor MAGARAC Pregled postova
500$ msrp je koliko u ducanu? Dodje ti na kraju jaaako blizu cijeni 7900 xt koja ima 20GB vs 16GB. U kojem svemiru je to odlicno?
Staro 26.02.2025., 09:48   #346
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,382
Da, to vrlo alko u stvarnosti dođe 700+€ kod nas.
Ako bude 500€ MPC i na razini 7900XT, kupujem odmah.
Staro 26.02.2025., 09:53   #347
Postovi: 8,545
Ne bude, taman da je 50€ MSRP ne valja, jer nije nVidia GeForce, koja s duplo većom cijenom, imaginarnom raspoloživosti i bonusom samozapaljivanja daje bolji omjer uloženog i dobivenog.
Staro 26.02.2025., 09:54   #348
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,183
ja bi recimo dao 1k max za najbolje modele kao nitro+/red devil, ako su u rangu 4080s, posto su najbolji modeli 5080/5070ti/4080 iznad 1300e
ovaj slabiji me ne interesira, radije bi uzeo 7800xt koji nudi najbolji omjer fps/euro atm
Staro 26.02.2025., 10:40   #349
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Autor Disco Pregled postova
500 je bez pdv-a, znaci preko 600, a 7900 XT lagano nestaju s trzista a znale su biti debelo ispod 700€, jos uvijek ih ima u DE za <700€...
Staro 26.02.2025., 12:51   #350
MAGARAC
MAGARAC's Avatar
Postovi: 5,995
Autor ansha Pregled postova
Kostat ce ko i 7800xt i da odlicno je jer se za iste novce dobije 30tak % vise perf., fsr 4 i konkretan RT. Ne znam kakva vi to ocekivanja imate ali ovo je za trenutnu realnost i vise nego dobro.
7900xt je kostala preko 1000 eura kod nas kad je dosla u ducane. Sadasnje cijene su normalne za 3 godina staru grafu na zalasku i to je uvijek izbor.
Staro 26.02.2025., 13:14   #351
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,382
Nema šanse da košta kao 7800XT.
Namjerno talijanska nabava jer uredno imaju bolje cijene od švaba. Dakle 500-550€.
Dok je 7900XT u prosjeku 800€.
Ima ona jedna Pulsica za 710 što mi se čini kao OK deal.
4070 Ti SUPER po cca 1100€.
(Za razliku kupiš pošten CPU)
5070Ti kreće od 1100€, ali je zapravo velika većina veselih 1500€.
Kad se sve uzme u obzir...AMD je fakat čabe.
....Ali su zato 5090 po 4kile € tj po 6 kila €. Dobije se azbestna dekica i aparat za gašenje uz svaku!
Zadnje izmijenjeno od: Disco. 26.02.2025. u 13:24.
Staro 26.02.2025., 15:28   #352
Postovi: 8,545
Final specifications of AMD Radeon RX 9070 XT and RX 9070 GPUs leaked
AMD has confirmed the full specifications of the Radeon RX 9070 series. Both Radeon RX 9070 cards, launching next month, are equipped with the same Navi 48 GPU, featuring 53.9 billion transistors across a 357 mm² die. Each SKU will have different specifications. The Radeon RX 9070 XT will have a full configuration with 64 RDNA 4 Compute Units, 64 Ray Accelerators, and 128 AI Accelerators. This card has 4096 Stream Processors, clocked at 2400 MHz (game clock) and up to 2970 MHz (boost clock). AMD estimates single-precision compute performance at 48.7 TFLOPS.
The RX 9070 non-XT has 56 Compute Units, which also means 56 Ray Accelerators, 112 AI cores, and 3584 Stream Processors. This model has lower clocks of 2070 MHz (game) and 2540 MHz (boost), as we reported exclusively over a month ago. AMD confirms that both cards will ship with 16GB GDDR6 memory clocked at 20 Gbps. Both cards use a 256-bit memory bus, providing a bandwidth of 640 GB/s. It’s also worth noting that AMD confirmed 64 MB of 3rd Gen Infinity Cache on both cards.
Regarding PCIe specifications, the XT model has a 304W TBP, and the non-XT has a 220W TBP out of the box.
Izvor: VideoCardz
Staro 26.02.2025., 17:00   #353
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,717
Kaže mi Grok da je 4nm TSMC proces na 90-100% utilizacije.
Ako budu iole dobre ne samo da budu skupe neg ih nebu bilo u dućanima uopće.
Staro 26.02.2025., 17:06   #354
Postovi: 8,545
Zen 5 je također na TSMC 4nm, pa ih ima i cijene nisu pretjerane. TSMC 3nm je sad tražena roba u gradu.
EDIT:
Zadnje izmijenjeno od: The Exiled. 27.02.2025. u 08:55.
Staro 27.02.2025., 09:33   #355
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,382
Ljepo je to Stevica US sažeo, ono što uporno svi ponavljamo.
Spustite usranu cijenu jer to vam je jedini izlaz.
Pokazao je kako nV diktira sve, od fićra do cijene i ljudi će uvijek radije nV ako je to sve tu negdje.
I ne sramotite se više sa kao nekim podjebavanjem nV-a na socijalnim mrežama jer svaki put napravite to isto, od količine VRAMa do svega drugo na što ste se zajebavali.
A Jakna i njegovi fino šute, još se Jakna uredno zajebava na svoj račun u prezentacijama i ubiru enormne količine novaca na svim poljima.
Nisam znao da je AMD ovako gadno izgubio udio na tržištu...od 40+% do 10% u zadnjih 15 godina. Treba to znat.
Spomenuo je i to da se očito interno AMD šefovima jebe za Radeon dio i da je ekipa iz Radeona frustrirana jer bi htjeli uspjet, ali im se zapravo stalno bacaju klipovi u kotače ili koji bi već prikladan izraz bio.
Ugl, ajd još jedan dan, ali ja sam siguran da će zasrat cijenu, em će staviti previsok MSRP, em on neće imati veze sa stvarnošću, kao ni oni od Intela i nV.
Staro 27.02.2025., 09:38   #356
Postovi: 8,545
I kaj se tiče sramoćenja i Radeon šefova lijepo je ko i uvijek u svom stilu stavil hrpu materijala vezanog za gospodina Franka Azora koji je glavni akter u neuspješnom podjebavanju.
Staro 27.02.2025., 12:42   #357
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,112
Iskreno se nadam da budu mućnuli glavom i išli *jako* agresivno s cijenom jer 10% marketshare-a je sramota
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 27.02.2025., 14:07   #358
Dr. Strange
Datum registracije: Aug 2020
Postovi: 899
Neka kažu lijepo da ih zaboli ona stvar za Radeon diviziju i doviđenja, ovako nam neizravno to poručuju, i nemaju nikakve koristi od toga, market share im sve više i više pada itd.
Staro 27.02.2025., 14:09   #359
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,183
x3d se prodaje samo uz jaca grafe, a ako su one preskupe, nece bas tako dobro prodavati
nije bas neko prepametno razmisljanje
Staro 27.02.2025., 19:01   #360
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,382
Autor Gemmy Pregled postova
Pa da, ja ću prvi onda uzet G CPU jer mi se fućka za cache koji ne služi ničem kod slabijih grafi tj integruša.
Zapravo da se napravi G X3D CPU, mislim da bi to tek bio hit, ali opet po nekoj OK cijeni jer bi i integruša profitirala i to samo tako od tog cachea, zapravo umjesto da taj dodatni cahe služi za CPU, on bi trebao biti onaj infinity cache za GPU i tu bi razvalio siguran sam. Taman bi se pogurao spori sistemski DDR...
A neka pusta glupa maštanja...
