#10291 | |
Postovi: 8,478
![]() ![]() Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#10292 | ||
Postovi: 8,478
#10294 | ||
Postovi: 8,478
Da, tak ispada, a Intel si je nažalost fino smjestil, dok ovi u AMD-u više ne znaju za mjeru, pa polako, ali sigurno sve moguće serverske ubojice fazana s vremenom dovode na desktop i HEDT. ![]() Citiraj:
#10295 | |||
Postovi: 8,478
#10296 | |
Postovi: 8,478
#10298 |
Postovi: 8,478
#10299 | ||
Postovi: 8,478
Uopće ne sumnjam da će Harvard i za Gelsingera složiti zasebno istraživanje i popratno predavanje na temu vođenja firme, samo bude naglasak na malo drugačijim lekcijama i potezima od onih koje je Lisa Su implementirala.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 10.12.2024. u 20:58. |
#10301 |
Postovi: 8,478
Mislim da ne bude ništ od toga, tj. da oni nauče iz AMD + Lisa Su lekcija, evo Daniel Nenni u zadnjoj epizodi priča kak se nVidiji posrećilo sa CUDA/AI dijelom priče, a AMD je bil i ostal mala firma koja bez TSMC-a ne bi bila nigdje, makar vidimo kak to Intel odrađuje kad ima napredni TSMC 3nm proces za Arrow Lake. Reko, jebote, pa ovaj je gori i od Gelsingera, čije prezime uporno krivo izgovora, a kao on se pozna sa svim važnim direktorima. U prijašnjim gostovanjima je čak i imal koju pametnu za reći, ali pošto ovakav stručLJak priča takve pizdarije, sve se bojim kaj društvo u Intelu misli kak im ide. Žalosno je da nakon svih Intelovih zajeba, Daniel Nenni i njemu slični pričaju nekaj kaj nema veze s realnošću, ko da je Intel sav jadan sasvim slučajno nabasal na nagaznu minu, pa ih sad treba žaliti i pomoći im na sve moguće načine, jer jedino to je ispravan put i Intel je jedina američka firma vrijedna spomena. Daniel Nenni je komotno ovo gostovanje i izjave mogel poslati mailom. ![]()
#10302 | |
Postovi: 375
To sam baš i ja pomislio. Vidim svi nešto kao "ovo je stručnjaaaaak u PM", a ja si mislim, pa ovo su čiste pizdarije šta lik priča, jesam li ja lud? Ozbiljno sam mislio da ja nešto ne kužim ili propuštam. |
#10303 |
Postovi: 8,478
Moguće da tip ima neke gadne pare uložene u Intel, pa je sad lagano panika i zato idu ovakve priče. Makar i u prijašnjim gostovanjima je imal kojekakvih bisera, pa puna usta hvale za direktora Pata koji je "pravi inženjer, on će njih posložiti i postrojiti". Svašta je Daniel napričal, ovisno o tome kak je vjetar zapuhal, ali ova friška epizoda je u rangu bulažnjenja nekog dede koji je davno radil nešto u svijetu mikroprocesora i poluvodiča, pa sad pametuje, a sav zbunjen ne zna da li mu je nešto zagorilo na šporetu.
#10304 |
Postovi: 375
haha, tek sada sam dogledao do kraja. Veli on na kraju, u stilu velemudre izjave insajderskog kužera, "I think AMD's graphics chips are actually very good. I think they're better than Intel's." Đizs. |
#10305 |
Postovi: 8,478
Da, nadrobil je svašta u tom razgovoru, ali čak i sve njegove gluposti vezano za AMD na stranu, reći da se nVidiji posrećilo na polju CUDA/AI rješenja, stvarno moraš biti stručLJak ko Daniel Nenni. nVidia je skupa s AMD-om kod TSMC-a već nekoliko desetljeća, pa dobro da i nVidiju nije okarakteriziral kao i AMD u kontekstu da je to mala firma, praktički friški startup koji bez TSMC-a nema ništa konkretno. Jadno sve skupa, a za dobru mjeru, veli Daniel u nekoliko navrata Intel 4nm i 3nm proces su ovo-ovo, pa mislim si, frajer ti si još davno pisal članke na temu da Intel 4 i Intel 3 nemaju veze s vezom, jer su zapravo bliže 7nm i 7nm+, a i sve je to ionako samo marketing, pa nema veze kak god se okrene. Jedini zajeb je da neovisno o marketinškom imenu, TSMC i svi njihovi klijenti (uključujući Intel) imaju pristup novim tehnologijama, ali uzalud Intelu najmodernija TSMC rješenja kad su izgubljeni u prostoru i vremenu, dok Daniel Nenni valjda žali za nekim odavnom prošlim zlatnim godinama.
#10306 |
Master Of Disaster
Datum registracije: Nov 2002
Postovi: 1,271
nisam vidio do sada da AMD ima jos prostora za skalirati, ali nakon ovih par stvari. double down on AMD, vrijeme za poduplati dionice i cekati 2030u zajedno s Nvidiom ![]() samo na temelju HBMa ici ce im market share na serverima do 50% bez problema.
#10307 | |||||
Postovi: 8,478
#10308 | ||||
Postovi: 8,478
EDIT:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 17.01.2025. u 10:18. |
#10309 | ||
Postovi: 8,478
#10310 | ||
Postovi: 8,478
#10311 | ||
Postovi: 8,478
#10312 |
Lokacija: zadar
Postovi: 103
Ako Zen 6 bude 12 Core CCD i bude kompatibilan sa AM5 platformom to će zaista biti spektakularan način za završiti AM5 platformu. Ja sam bio kupio 7600x "za prvu ruku" kad je tada tek izašao i kada bi za ~ god. dana u isti taj socket mogao ubaciti 12 Core + 3d cash zvijer bio mi miran zaista jako dugo vremena. Vjerovatno cijelu PS6 generaciju igrica |
#10313 |
Postovi: 8,478
Izgleda da bude od svega pomalo uz naglasak na mnoštvo APU modela, dok je Zen 6 dodatno potvrđen za AM5 platformu. ![]() AMD Zen 6 specs leak: 6GHz+ TSMC N2X, 26 Cores, 2-Hi X3D, RDNA 4 (Medusa, Olympic, Gator, Bumblebee)
#10315 |
#erase startup-config
Postovi: 3,732
Nadolazeći AMD socketi, ploče i procesori
A i taj TDP… već sad entry level modeli mogu cuclati od 65W do 120-140W ovisi kako podesiš u BIOSu. |
#10316 |
ODUZIMAM VAM RIJEČ
Postovi: 13,482
jedno OT pitanje, nisam baš pratio AMD ali kako stvari stoje, počet ću zanima me sljedeće, zašto je recimo 9800x3d ryzen 7, a 9950x3d je ryzen 9 to ovisi samo o broju corova ili? meni bi bilo logično da je ryzen 7 7800x3d, ryzen 9 9800x3d, ali nije tako ![]()
#10317 |
Postovi: 8,478
#10319 |
Lokacija: Chakovec
Postovi: 420
Ako ćeš se rješavat tog svojeg i7 13th, javljam se sa štovanjem. (Vjerojatno nije defektan.) |
