Staro 20.10.2024., 20:55   #1861
jucca
jucca's Avatar
Postovi: 1,693
Puno hvala ✌️
Sent from my SM-S908B using Tapatalk
Staro 20.10.2024., 21:03   #1862
Postovi: 23,542
Kao i obično, iIdioti sa svojim property rješenjima
Imaš dva rješenja:
1 - tražiti njihov origigi kao sa slike (samsung mz-jpv1280/0a3)
2 - nabaviti pravi adapter pa u njega normalni M.2 NVME
Info:
https://forums.macrumors.com/threads...-nvme.2034976/
https://forums.macrumors.com/threads...#post-25743057
Staro 20.10.2024., 21:43   #1863
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,103
Nisu ni svi SSD-ovi kompatibilni. Postoje liste onih koji su testirani i rade ok, tako da se ne treba zaletavati s kupovinom prije provjere
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 21.10.2024., 00:02   #1864
Postovi: 23,542
Na linku poviše ima sve te podatke tj. šta provjereno radi a ovisno o modelu i godištu iGofneta
Staro 30.10.2024., 11:15   #1865
Dottore
Dottore's Avatar
Postovi: 7,661
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 30.10.2024., 14:56   #1866
medo
#erase startup-config
medo's Avatar
Postovi: 3,719
“Slows on the 450GB write to 1.2GBps”
Kome će ovo biti dealbreaker?
Staro 31.10.2024., 04:20   #1867
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,623
Autor medo Pregled postova
Tebi i još trojici
Šalu na stranu, za DRAM-less model to je čist pristojno, dealbraker je cijena.
BTW, samo jedan NAND chip na 2TB modelu, impresivno.
Budu za par godina matične po defaultu počele dolazit s 2TB čipom veličine poštanske marke....
Zadnje izmijenjeno od: kopija. 31.10.2024. u 06:44.
Staro 31.10.2024., 13:14   #1868
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,250
I meni je jedan cip na 1tb modelu (wd sn580) 🙂
Iznenadio sam se koliko je laksi od adate sx8200 pro.
Staro 31.10.2024., 14:43   #1869
Dottore
Dottore's Avatar
Postovi: 7,661
Ništa me nije oduševio taj 990 Evo Plus koju ispravlja 990 Evo.
Za laptope nije baš energetski učinikovit. Troši više.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 05.11.2024., 19:31   #1870
Dottore
Dottore's Avatar
Postovi: 7,661
@kopipejst
Vidi ovo niže
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 06.11.2024., 06:59   #1871
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,623
Ne kužim, whats the big deal?
Staro 06.11.2024., 20:47   #1872
Dottore
Dottore's Avatar
Postovi: 7,661
Autor kopija Pregled postova
Pa 6.1W maksimalna potrošnja. Na dobrom putu da budu dostupni prijenosnim računalima.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 07.11.2024., 13:27   #1873
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,226
Napravio bi upgrade SSD diskova u kompu. Imam dva slobodna M.2 slota za 2280 NVMe.
Išao bi možda na 2+2TB varijantu. Jedan za igre drugi za Photo (Photoshop, Lightroom) obradu RAW fajlova.
Do sad sam uvijek ganjao i preporučao Samsung bilo SATA ili M.2. Al kako sada ima dosta drugih koji su isto odlični možda i bolji. Koji bi po vama odgovarao mojim potrebama?
DRAM ili DRAMless? Pasivno hlađenje mi ne treba jer matična ima svoje. Ne mora bit baš najjeftiniji. Samo neka dura i da je brz. Vrsta čipa ovo ono, fakat sam se pogubio već a ne pratim diskove već duže.
Volio bi ulovit nešto na akciji sad kad je vrijeme akcija. Samo se ne znam na što fokusirati, htio bi imat jedan dva na piku i pratit cijene.
Smatrao sam Samsung Pro varijantu kao sigurnjak. Tipa aktualni 990 Pro. Ili nekadašnji EVO Plus. Nekako sam pickupao da više nije "pojam" među diskovima. A nisam ni siguran zašto osim što mi se jedan EVO Plus u mojem slučaju pokvario pa su mi zamijenili za novi, dobro pa je bio pod jamstvom.
Write lock problem. Samo se čitati moglo sa njega podatke, pa nisam ni to izgubio srećom.
Zadnje izmijenjeno od: PR3DA70R. 07.11.2024. u 13:38.
Staro 08.11.2024., 12:09   #1874
Postovi: 23,542
Ako je za rad, kopanje aka puno briši / piši .... možda modeli namjenjeni za NAS (barem jedan) ??
Usporedi / traži što veći TBW + garancija + niža cijena + pcie standard.
Staro 08.11.2024., 13:30   #1875
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,226
A gle jedan je za igre kao što sam napisao. Samo što bi njega vrlo vjerojatno stopio sa Windowsima. Tako da mi igre idu sve na C particiju.
Trenutno imam 3 SSD-a u kompu, M.2 NVMe 500+500 i 1 kom SATA 250. Jedan NVMe koristim za Win i neke igre i ostala dva diska sve za igre.
Jako neorganizirano i razbacano, bezveze mi je to više. Tako da bi jedan brzi M.2 NVMe od minimalno 2TB pa sve te podatke (Win+igre) stopio u jedan disk (C).
Da sad ne kompliciram sa upitom za dva diska. Mislim da je i najpametnije jednostavno dva ista odmah pa jedan za ovo što sam naveo i drugi izolirano samo za foto obradu/mini storage. Sve obrađeno iskrcam na HDD za storage dugoročno i amen.
A ove manje diskove ću vidjet još što ću. Prodat možda...
Dakle koji M.2 NVMe diskovi po vama slove sad kao best u kategoriji? Koji su populatni favoriti?
Zadnje izmijenjeno od: PR3DA70R. 08.11.2024. u 13:57.
Staro 08.11.2024., 14:33   #1876
Dottore
Dottore's Avatar
Postovi: 7,661
Koja je ploča u pitanju?
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 08.11.2024., 15:05   #1877
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,226
Autor Dottore Pregled postova
MSI Z690 Tomahawk WiFi DDR4
Da sry zaboravih navesti. Pcie 4.0 kompatibilna na 3 od 4 slota. Jedan je 3.0.
Staro 12.11.2024., 19:01   #1878
Dottore
Dottore's Avatar
Postovi: 7,661
WD SN850x ili Crucial T500.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 12.11.2024., 20:04   #1879
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor PR3DA70R Pregled postova
Lexar NM790
ili
Patriot Viper VP4300 Lite
Staro 13.11.2024., 02:02   #1880
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,623
Lexar NM790
ili
Taj Viper je loša preporuka, em nema DRAM, em neznaš kaj buju ti uvalili.
Ima puno dobrih diskova, ja bi kolegi Predatoru preporučio da pričeka BF pa cilja na neki od ovdje navedenih.
Svakako gledati da je gara pet godina!
Zadnje izmijenjeno od: kopija. 13.11.2024. u 02:11.
Staro 13.11.2024., 09:58   #1881
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,103
Bacite oko na AliExpress
1TB Orico sam dobio za £24.66
Neću stavljati u temu o akcijama jer ne znam rade li kodovi van UK, ali probajte.
Samo jedan komad po korisniku.
Ide u USB kućište, pa mi je bitniji kapacitet od brzine. Javim dojmove kad stigne
LCD: BENQ PD3200Q
Staro 13.11.2024., 12:16   #1882
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,226
Lexar NM790
ili
Hvala kolege.
Staro 13.11.2024., 13:08   #1883
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Ima li koji približne cijene a da je brži, bilo sa ili bez DRAM-a?
Jedini problem vidim kod 4TB verzije koja je QLC, a ovaj
nedostatak DRAM-a na 2TB verziji očito ne smeta brzini
Solidan i 1600TBW i garancija 5g
https://www.tweaktown.com/reviews/10...ite/index.html
Zadnje izmijenjeno od: segregator. 13.11.2024. u 13:13.
Staro 19.11.2024., 16:55   #1884
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,103
Stigao paket s aliexpressa
1TB SSD i kućište, 38€
LCD: BENQ PD3200Q
Zadnje izmijenjeno od: 1v@n. 19.11.2024. u 18:53.
Staro 30.11.2024., 03:12   #1885
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,623
Guru NewMaxx se potrudio da nam olakša kupnju.
QLC je izašao iz puberteta: link1 link2
DirectStorage obećava čuda:
Zadnje izmijenjeno od: kopija. 08.12.2024. u 03:46.
Staro 07.01.2025., 21:54   #1886
BladeRy
BladeRy's Avatar
Datum registracije: Aug 2008
Postovi: 2,000
Prije godinu dana uzeo WD SN570 1tb, stoji u old mashini ispod graficke, znaci vise manje nikakav airflow. Opalim bench, min 24c-max 36c.
Danas stavio WD SN580 1tb u main mashinu, ovaj je iznad graficke. Software prijavljuje 3 temparature, idle 38c-58c-32c.
Ajde da bencham, 65c-87c-64c.
Jel ovo normalno, jos je fino provjetren case pa da je malne duplo sve od starog 570a.
Nijedan M2 nema nikakav heatsink.
Staro 20.01.2025., 22:42   #1887
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,506
Trebam storage disk 1/2TB. Prioritet su cijena/potrošnja-grijanje (iako mislim da kao storage se ni ne bude grijao).
WD Blue SN580
TEAM GROUP MP44L
Prijedlog?
Staro 20.01.2025., 23:09   #1888
Darko150
Datum registracije: Jul 2017
Lokacija: Velika Gorica
Postovi: 57
Sa WD nećeš pogriješiti. Ovog drugog nisam koristio
Darko150 je offline   Reply With Quote
Staro 21.01.2025., 07:16   #1889
Postovi: 33,998
Crucial P3 zna imati dobru cijenu.
Staro 21.01.2025., 07:49   #1890
tomov
tomov's Avatar
Datum registracije: Feb 2011
Postovi: 591
Autor -POP- Pregled postova
WD Blue SN580
TEAM GROUP MP44L
Prijedlog?
Gledao prije cca 3 tjedna po netu recenzije. Taj western ima sporadične probleme. Preporučili su ti P3 pa bi ja osobno gledao prvo taj. Na Amazon ti znaju biti po turbo niskim cijenama.
tomov je offline   Reply With Quote
