Staro 24.10.2024., 17:01   #31
Postovi: 8,170
Intel Core Ultra 200S in the test: Core Ultra 9 285K, 7 265K & 5 245K disappoint efficiently
Intel Core Ultra 9 285K "Arrow Lake" Delivers Strong Linux Performance
When taking the geometric mean of nearly 400 benchmarks tested across these processors, the Core Ultra 9 285K was 12% faster than the Core i9 14900K overall. Or about 14% faster when switching to DDR5-8000 memory. This put the Core Ultra 9 285K right inline with the performance of the AMD Ryzen 9 7950X prior generation process overall or around 95% the performance of the AMD Ryzen 9 9900X or 84% the speed of the AMD Ryzen 9 9950X for this wide mix of workloads tested under Linux.
The generational Raptor Lake to Arrow Lake performance is more impressive when factoring in power use. The Core Ultra 9 285K on average was at around 136 Watts during the entire span of workloads tested, right inline with the average of 137 Watts on the Ryzen 9 9950X and much lower than the 156 Watt average with the Core i9 14900K. The Core Ultra 9 285K did have a peak recorded power use at 248 Watts, above the 201 Watts found with the Ryzen 9 9950X but at least much lower than the 347 Watt peak with the i9-14900K. The power efficiency improvements with Arrow Lake are real.
Zadnje izmijenjeno od: The Exiled. 24.10.2024. u 18:15.
Staro 24.10.2024., 18:38   #32
Dr. Strange
Datum registracije: Aug 2020
Postovi: 892
Kakav epski fail od Intela, ali na to smo navikli u zadnje vrijeme. Ono što me fascinira je potrošnja 7800X3D u igrama – ima najbolje gaming performanse uz najnižu potrošnju, što je izvanredan omjer. Ne pamtim da smo ikada u povijesti imali takav omjer između performansi i potrošnje. Također treba spomenuti i 5800X3D, koji se ne da – i dan-danas je konkurentan proizvod, a postao je još bolji s novim Windows update-om.
Staro 24.10.2024., 18:43   #33
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,523
Baš išo pogledat kolko je dionica potonula, kad ono ništa, ko da se ništ nije dogodilo.
Staro 24.10.2024., 18:59   #34
Postovi: 8,170
Arrow Lake je samo manja kap u moru sranja u kojem Intel pliva zadnjih sedam-osam godina, tak da bude to vidljivo tek sa sljedećim kvartalnim izvješćem.
Autor Dr. Strange Pregled postova
Zen 5 je od istih ovih recenzenta okarakteriziran kao FAIL i FLOP, jer nije ponudil očekivani skok u gaming performansama na Windows platformi, a sad sfušani Arrow Lake nudi još manji skok, uz dodatne pogodnosti poput nestabilnosti sustava, visokih latencija zahvaljujući njihovoj verziji chiplet pristupa gdje su SoC i I/O razdvojeni, a mogli su biti dio istog pakiranja, pa kojekakve peripetije čisto da bude zanimljivo, BSOD izleti, nema čega nema, ali Intel se trudi.
Zadnje izmijenjeno od: The Exiled. 24.10.2024. u 19:26.
Staro 24.10.2024., 19:15   #35
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,253
Dakle MLID ovaj put nije gatao iz kugle koliko kužim po vašim komentarima.
Pogledam sutra rivjue.
Mene više zanima ponašanje 265 od 285.
Slobodno me dodajte na PSN
Staro 24.10.2024., 19:19   #36
Postovi: 8,170
Da, KitGuru, Level1Techs i HUB su mu ionak često u gostima, tak da je njihove probleme stavil u onaj video, a zapravo su svi imali neko sranje s LGA-1851 platformom.
Zadnje izmijenjeno od: The Exiled. 24.10.2024. u 19:33.
Staro 24.10.2024., 20:01   #37
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,502
Ajme užasa, a ja prvo mislio ić na ovaj 265K
Btw. sad sam skužio iz postova kolege Exiled da AMD ima 2,5 puta veći market cap od Intela, kad se to desilo Da mi je to netko rekao prije 5-6 godina...
Intel je failao žešće, ali kad gledam te grafove u biti je zaključak da ako netko ima zen3/alder lake i mainstream/high end grafu i igra na 1440p, CPU nikad pa ni onda neće biti bottleneck.
To se lijepo vidi u dobrom broju game benchmarka od GN Stevice, rainbow six, f1, total war, sve nekakve igre koje 5600x vrti u 400 fpsa, svašta.
Staro 24.10.2024., 20:29   #38
Dr. Strange
Postovi: 892
Minuta šutnje za Intel družinu.....
Staro 24.10.2024., 22:48   #39
Postovi: 8,170
To je ta firma s uvijek jasnom vizijom, planom i programom uz direktora koji drži pravi kurs.
Kaj se Intela tiče, sve je to lijepo i krasno sad kad su još na monolitnim izdanjima, ali Lunar i Arrow Lake uvode chiplet/tile i sve nakon njih ide tim istim "problematičnim" AMD putem kad i u Intel slučaju, TSMC ne može nešto previše napraviti po pitanju I/O skaliranja, zato je i kod njih išla slična kombinacija, gdje I/O ostaje na 6nm, dok jezgre idu na 3nm. Ništ, budemo lijepo pričekali jesen da vidimo kaj su pripremili.
It can't hurt to look at this aspect of Arrow Lake, especially since games, the Achilles' heel, are very dependent on latency. Raptor Lake serves as a basis for comparison. At first glance the result (see below) looks like a wild mess, but at second glance the changed structure of the processor die becomes clear. The faster P-cores with the lower latencies are no longer installed in one corner of the chip as before, but are divided into three blocks (2×2 cores and 1×4 cores in the middle), with the E-cores sitting in between. Latencies are also an issue when it comes to storage. Arrow Lake shows high values ​​here, on average they are over 20 percent higher than with Raptor Lake with the same RAM equipment.
Staro 25.10.2024., 10:34   #40
Postovi: 8,170
Zadnje izmijenjeno od: The Exiled. 25.10.2024. u 13:01.
Staro 25.10.2024., 14:21   #41
Dr. Strange
Postovi: 892
Može li ovaj čovjek spasiti Arrow Lake? Od muke nije objavio nijedan video o Arrow Lakeu od trenutka njegova izlaska.
Staro 25.10.2024., 14:40   #42
Postovi: 8,170
Iskreno, malo je na knap, gužva mu je na poslu, taman sad u ove ključne trenutke, a i drži predavanja za one koji su voljni platiti.
Makar, realno, Arrow Lake ne treba spasiti, jer sve je i više nego OK, zapravo odlično.
Staro 25.10.2024., 15:13   #43
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,253
Ispada da su ne znam 12400, 12600K, 5700X3D the CPUi za gejmanje ako ne želiš iskrcat previše love i ako ne želiš plaćat velik račun za struju. 7800X3D je bio bog i batina dok je bio na 300€, naravno čim je AMD skužio što još uvijek ima, su podigli cijenu. I dalje je naj za igranje, samo je debelo manje isplativ na 400+€.
Niš, čekamo zen5 X3D da vidimo kako diše.
A AL je očito fail sa ovim nestabilnostima i nebuloznim rezultatima.
Ajd možda popeglaju to sve skupa, da je bar stvarno štedljiv kao AMD, ali trenutno su u svemu ni vrit ni mimo. Mislim ja da se ovo ne može ispravit preko BIOS-a, ali bumo vidjeli.
Staro 25.10.2024., 15:19   #44
Postovi: 8,170
IMHO najgore bude, ako ispadne da je Arrow Lake jedino kaj misle imati na LGA-1851, jer do 2026. nema naznaka za nekog nasljednika. Ljudi budu svašta pretrpjeli po pitanju ovih pizdarija koje su trenutno aktualne, ali nema šanse da budu oprostili samo jednu i to ovak sfušanu generaciju, pa onda ajmo opet sve novo kaj već misle izbaciti, jer u Intelu se više nažalost ne zna kaj tko radi.
EDIT:
Intel Z890 motherboards facing crashes and reboots when upgrading to Win11 24H2, BIOS updated required
Z890 motherboards may experience crashes or random reboots when updating Windows 11 to version 24H2. This issue reportedly affects the Core Ultra 200S series and its integrated Xe-LPG graphics. Apparently, a conflict between the discrete GPU and integrated GPU may occur with this Windows update. The solution is relatively straightforward: users are required to either disable the integrated graphics before updating the system or update the BIOS. However, neither option is simple for users who are unfamiliar with or hesitant about updating firmware or tinkering with BIOS settings. We have already asked other reviewers, and it appears that the issue is indeed affecting other brands (Gigabyte, MSI and ASRock), who have released new BIOS updates to address it. The important thing to know is that if you plan on installing the latest version of Windows, make sure to update the firmware to avoid this problem.
Izvor: VideoCardz
Zadnje izmijenjeno od: The Exiled. 28.10.2024. u 11:30.
Staro 28.10.2024., 12:53   #45
Flegma
Flegma's Avatar
Datum registracije: Jul 2004
Lokacija: Zagreb/Šibenik
Postovi: 826
Ovo je za svakog tko prati bilo ocekivano, tako da ne mislim da je to neki fail, vise su se pomirili s tim da ce "zrtvovat" jednu generaciju po performansama (okej, ako gledas potrosnju, a vjerojatno s tim i termale i nije zrtvovanje), samo nisam siguran bas ni da imaju neki konkretni plan i ideju za ista sljedece.
S druge strane AMD je imao cekic da zakuca posljednju brukvu u taj lijes, al nazalost mi se cini da su i oni se previse opustili i nisu uspili u tom naumu.
Bila je toliko lijepa da sam poželio da nikad ne otvori usta. A onda mi je nekako objasnila da je nijema. Oženio sam ju Las Vegasu, tjedan dana kasnije. I sad napokon živim sa ženom koju razumijem.
Moj PC - https://www.twitch.tv/flegmoar
Flegma je offline   Reply With Quote
Staro 28.10.2024., 16:20   #46
Dr. Strange
Postovi: 892
Napokon se oglasilo zaštitno lice plavih fanova, trebalo mu je vremena da se oporavi:
https://x.com/ChasersFrame/status/1850787480330809810
Staro 28.10.2024., 16:46   #47
Postovi: 8,170
Huh, valjda bude i povećal satnicu za pomoć Arrow Lakeu.
Intelovo prijašnje i sadašnje voCtvo se u međuvremenu ne može usuglasiti.
Staro 01.11.2024., 11:25   #48
Postovi: 8,170
Staro 09.11.2024., 16:45   #49
Postovi: 8,170
Intel confirms Core Ultra 200 launch didn’t go as planned, promises performance fix by early December
Intel has learned from reviewers that in certain configurations, performance data sometimes diverges significantly from Intel’s official results. Specifically, gaming performance in some cases did not align with Intel’s communicated expectations. The good news is that a fix may be on the way. The more such issues overlap, the more likely a system is to underperform. It’s not solely related to system memory latency, though Intel noted that some reviews reported over 180 ns latency, while the company expected a maximum of 80 ns. However, latency is not the root issue for lower performance.
Certain BIOS versions or system settings may contribute to lower performance, an area that Intel is currently investigating. Hallock did not provide specifics on what exactly is being examined or what fixes users should expect, but he did indicate that these improvements are expected by the end of this month or early December at the latest. We just couldn’t pass the opportunity to ask about Intel’s stance on next-gen CPU support for the LGA-1851 socket. Unfortunately, Hallock couldn’t answer because of legal restrictions. The company can’t share plans or roadmaps, during such interviews. There was nothing stopping Intel from sharing this data during Arrow Lake launch, though.
Izvor: VideoCardz
Ništa čudno da ih sad "pravni razlozi" sprječavaju u potvrđivanju ili osporavanju LGA-1851 Arrow Lake nasljednika.
Taman dok oni poprave Arrow Lake, novi 9800X3D bude već na akcijskim cijenama, a onda se začas Zen 6 smjesti u AM5, dok Intel PR objašnjava opet novi socket i čipset za 2026. godinu.
Staro 12.11.2024., 13:58   #50
Taproot7
mag.math.
Taproot7's Avatar
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 361
Iz toga bi se dalo iščitati da je ovaj socket namjenjen samo za ovu generaciju procesora tojest Arrow Lake mikroarhitekturu.
Popravci? Kakvi?
Taproot7 je offline   Reply With Quote
Staro 12.11.2024., 17:57   #51
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,253
Mene isto baš jako zanima kako će oni ubrzat AL preko BIOS-a.....samo dodavanjem struje, nekako sumnjam da imaju neki normalan fix. Brute force im je moto zadnjih par godina.
Staro 12.11.2024., 21:47   #52
Postovi: 8,170
To kaj ste rekli, plus valjda misle dodatno dotjerati svoj Intel Thread Director uz Windows Scheduler, ali to ne bude vratilo 30% do 40% zaostataka za 9800X3D.
Uzlaud im trud svirači kad je već svima jasno da Intel ne može pratiti konkurenciju na ovaj način kak su to dosad radili.
Zadnje izmijenjeno od: The Exiled. 12.11.2024. u 21:53.
Staro 13.11.2024., 08:53   #53
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,253
Zna se kako se tome može doskočiti, pa tako je i AMD pičio sve do zen3. Cijena, cijena i samo cijena.
Ali izgleda da to ne dopire do njih čak ni sada kada im je voda došla do grla.
Neka oni uredno svake godine izbace novi socket za CPU, ali onda neka ploče koštaju 150-200€ max. Sve je OK, kada je cijena odgovarajuća.
Staro 13.11.2024., 09:41   #54
Exy
Exy's Avatar
Postovi: 2,502
Ne bi im to imalo smisla, nisu ni AMD-u baš cvjetale ruže kad se morao natjecati cijenom pošto su bili sporiji. To je najgora opcija, time bi i službeno potvrdili da imaju šrot proizvod i to nikad neće napraviti. Pravit će se da je sve u redu, samo gayming malo zeza tu i tamo a to ćemo riješit razno raznim softverskim patchevima. Koliko sam ja gledao, nisu ti procevi toliko loši u productivityju, samo u gaymingu štekaju.
Staro 13.11.2024., 10:58   #55
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,312
Natjecanje u cijeni je najgora opcija za biznis i najbolja za korisnika. Ali zapravo i nemaju izbora, jer će tržište presuditi. A čini se da im ne ide dobro... Mindfactory statistike i drugi reporti govore da se ne prodaju uopće.
Staro 13.11.2024., 16:38   #56
Postovi: 8,170
I onda direktor Pat za dobru mjere sjebe 3nm TSMC 40% popust, pa sad i za to moraju plaćati punu cijenu i još k tome ispoštovati dogovorene kapacitete uz još novih zahtjeva.
Autor Exy Pregled postova
IMHO najveći problem je to kaj je cijela platforma ni vrit ni mimo, lako za performanse, ali kad ni Windows OS ne prolazi bez BSOD-a uz činjenicu da ne žele reći ništa za LGA-1851 nasljednika, jer realno ni nemaju ništa konkretno. Gospoda u Intelu se vode za tim da im je ovo druga CPU generacija na LGA-1851, jer je Meteor Lake trebal biti prvi, pa nije uspjelo, ali su dijelove iskorisiti za Arrow Lake, dok su mu usput otkazali osvježeno izdanje.
Staro 13.11.2024., 16:43   #57
Odinarius
All-rounder
Postovi: 1,312
Pa i dobro da su otkazali kako je krenulo
Productivity nije baš jak selling point za desktop, možda za jedan najjači model za ograničen krug korisnika, ali nipošto za 6 ili 8 core mainstream. Tu je gaming jedino mjerilo. Šteta što je Intel loš jer je sad AMD bez konkurencije.
Staro 13.11.2024., 17:07   #58
Postovi: 8,170
Je, ali su sigurno računali s tim da bude uspješnica, a i neke nofce su potrošili na kakav-takav razvoj, makar je sve skupa žalosno, posebice ovaj jadan direktor koji ne kuži da su takvi ko on sjebali sigurnu stvar - firmu bez konkurencije. I tu nema nikakvog drugog krivca osim njih samih i stava koji su imali i još uvijek imaju, dok su uredno odbijali i propuštali sve do jedne pružene prilike da se barem malo (od)maknu u neke druge vode, koje su se za ostale pokazale itekak uspješne i isplative.
Staro 13.11.2024., 17:19   #59
viper84
viper84's Avatar
Datum registracije: Dec 2012
Lokacija: Vž
Postovi: 270
Ne znam kako vama, ali dosta me sad ovo s Intelom podsjeća na Nokiu
Trgovine: 1, 2, 3, 4
viper84 je offline   Reply With Quote
Staro 13.11.2024., 19:05   #60
Tirion
Datum registracije: Oct 2021
Postovi: 59
Nadam se da ipak neće tako drastično završiti, iako trenutno situacija nije ni najmanje obećavajuća prema svemu viđenom.
13. i 14. generacija teški promašaj i sramota, ovaj Arrow Lake nadajmo se da ipak nije, iako nije ni ništa posebno prema svim testovima do sad.
Ako nisu shvatili da je voda ne došla do grla nego prešla, onda bi moglo još biti svega, sad valjda sve nade polažu na taj 18A proces koji će tek za par godina doći, a sad ako i ti procesori ispadnu fuš e onda je možda zbilja gotovo.
Taman negdje na ljeto razmišljao sam o kupnji novog kućnog pc-a jer eto ovaj Haswell kojeg imam je iz 2014. no kad su sve te vijesti o degradaciji i problemima počele izlaziti rekoh neću sad ništa dok se ne vidi razvoj situacije.
Od gaminga na kompu sam ionako odustao još pred 4-5 godina kad je bilo ono divljanje cijena grafičkih zbog mininga bitcoina, a imam i PS5 za to, za obaviti što trebam za posao imam noviji laptop na kojem je neki 11 gen procesor i to je to...sad grickalice, cola i pratim neopterećeno.
Tirion je offline   Reply With Quote
