Staro 31.03.2003., 12:48   #1
Studano
Studano's Avatar
Datum registracije: May 2002
Postovi: 75
Kako promjeniti serial # u XP
Da se nebi ponovo sve instaliralo dali postoji neki drugi nacin promjene seriskog broja u XP. Razlog promjene seriskog broja je radi Updatea XP preko MS sitea.
Ili dali postoji drugaciji nacin updatea ... iako je seriski broj vec u upotrebi????
THX>
Take the path that is your own...INDIVIDUALITY.
Studano je offline   Reply With Quote
Staro 31.03.2003., 13:31   #2
Kova
***2CROwded***
Kova's Avatar
Datum registracije: Mar 2002
Lokacija: Cro
Postovi: 1,610
Iskreno... ne bih ti preporucao mijenjanje serijskog no ako bas moras, evo:
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. In the left pane, locate and then click the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current Version\WPAEvents
4. In the right pane, right-click OOBETimer, and then click Modify.
5. Change at least one digit of this value to deactivate Windows.
6. Click Start, and then click Run.
7. In the Open box, type the following command, and then click OK.
%systemroot%\system32\oobe\msoobe.exe /a
8. Click Yes, I want to telephone a customer service representative to activate Windows, and then click Next.
9. Click Change Product key.
10. Type the new product key in the New key boxes, and then click Update. If you are returned to the previous window, click Remind me later, and then restart the computer.
11. Repeat steps 6 and 7 to verify that Windows is activated. You receive the following message:
12. Windows is already activated. Click OK to exit.
13. Click OK.
14. Install SP1 for Windows XP.
Nadam se da ti je pomoglo.
Kova je offline   Reply With Quote
Staro 31.03.2003., 15:01   #3
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
:confused:
Zašto ???
Pa ja to radim kod svake instalacije/reinstalacije i nikome ništa
Staro 31.03.2003., 15:05   #4
Studano
Studano's Avatar
Postovi: 75
Hvala na savjetu... probati cu danas navecer...
Staro 31.03.2003., 19:14   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Originally posted by Paske
:confused:
Zašto ???
A zašto jednostavno ne ukucaš broj koji je OK odmah kod instalacije?!
Staro 31.03.2003., 20:31   #6
Kova
***2CROwded***
Kova's Avatar
Lokacija: Cro
Postovi: 1,610
Zašto nije dobro mijenjati nakon instalacije !?
Pa nije zdravo prčkati po registry-u.
A kao drugo to je još ok nakon same instalacije, no nakon instalacije programa i sl. nije nikako preporučljivo, nije da neće raditi, no u većini slučajeva se neće moći instalirati SP1 onda.
Evo imam ja listu od 100 injak serijskih brojeva i svi su ok, nisu black listed.
Čovjek je pitao, ja sam mu odgovorio ...
To što se može to je jedno, to što postoji vjerovatnost da neće biti ok to je drugo i ....
:burn:
Staro 31.03.2003., 23:48   #7
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
:burn:
Nije zdravo prčakti po bilo čemu onda ali kako češ onda nešto naučiti (ako ne sjebeš nešto). Iz grešaka se najviše nauči...
Staro 01.04.2003., 13:12   #8
Kova
***2CROwded***
Kova's Avatar
Lokacija: Cro
Postovi: 1,610
heheh.. Ajde slupaj auto pa ga idi popravljati ))
Ma slažem se... no ako neželiš cijeli dan izgubiti na formatiranje i instaliranje.. onda..
Staro 01.04.2003., 19:19   #9
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
A jebiga nekad kad nemam pametnijeg posla.... Sastavim neku kramicu od ovog smeća ispod stola i ubijem ga u pojam s eksperimentima. Pomaže kod oslobađanja od stresa, frustracija, nejebice
Staro 01.04.2003., 19:51   #10
Kova
***2CROwded***
Kova's Avatar
Lokacija: Cro
Postovi: 1,610
A čuj nije da mi je kučište zašarafljeno )) I ja stalno kopam, pa to se vidi iz postova
No baš da ću se igrati s nečime gdje mi piše, ZABRANJENO!??! Hm, jedino ako znam točno o čemu se radi. Neću skidati npr. cooler s proca ako to neznam, tj. ako nisam to prije radio. No danas, sada?! Skinem pogledam serijski, pa ponovno, pa provjerim da li sam dosta paste stavio, pa da li je previse ))) (pretjerujem no ne bi bio problem)
A registry je dosta zeznut kod kompjutera.. i s njima ako nije nešto u redu, onda ti odmah windosi mogu sr.
Pa čak i oni koji znaju tu imaju više zezancije.. No puno puta će proći da je sve ok, makar nije pametno
No dobro dosta filozofije, mislim da se i ti slažeš da nije pametno serijski naknadno mijenjati, no što se mora nije teško
Staro 01.04.2003., 23:41   #11
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Ma evo pive i btw thx na plextoolsu, radi.
Staro 01.04.2003., 23:51   #12
Kova
***2CROwded***
Kova's Avatar
Lokacija: Cro
Postovi: 1,610
Ma znao sam da radi...
Uživaj !
