I encompass, and I eclips
Datum registracije: Jul 2010
Lokacija: Plazikur
Postovi: 1,012
Helldivers 2
HELLDIVERS™ 2 is a 3rd person squad-based shooter that sees the elite forces of the Helldivers battling to win an intergalactic struggle to rid the galaxy of the rising alien threats. From a 3rd person perspective, players use a variety of weapons (pistols, machine guns, flamethrowers) and stratagems (turrets, airstrikes, etc.) to shoot and kill the alien threats. Players can also aim down the sights for a more accurate 1st person camera view. Combat is accompanied by frequent sprays of blood and dismemberment as players exterminate the alien forces or players and squad mates are hit by environmental explosions or friendly fire. Enemy encampments and battlefield environments depict bloodstains and dismembered corpses. Dakle makljaža, u 4 player coopu, s izuzetno zanimljivim mehanikama koje će začiniti klasični PVE survival mode. Dugo se nisam zabavio tako, nema sweata, nema sekiranja, igra se i uživa. 40e, u današnje vrijeme kad su igre 70 80e... nezz, svi pričaju o tome. ako netko bude igrao neka me adda na avion2208, uvijek dobro dođe teammate
Lokacija: HR Zagorje
Postovi: 249
Ja igram na PS5, tek sam lvl5. Moremo odigrati koju skupa, ima tu valjda još ljudi kaj igraju... Poslano sa mog SM-A528B koristeći Tapatalk |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,529
Samo pazite kaj govorite, Goli otok je mila majka. |
Lokacija: Plazikur
Postovi: 1,012
bio peč, nerfali metu, buffali nešto i tako. I naravno hrpa novih bugova i gejm krešova. Good day Helldivers! Today we have a slightly bigger update for you all to assist in the liberation efforts of our galaxy as well as some new environmental threats to watch out for. May Liberty guide your path. Overview This update includes: -Balance changes to missions, stratagems, weapons, enemies and Helldivers. -General fixes and stability improvements. - Increased Level Cap [EDIT] Gameplay Planetary Hazard additions Blizzards Sandstorms Increased level cap Level cap has been increased from 50 to 150 Balancing Missions Retrieve Essential Personnel Moved the enemy spawn points further away from the objective to give players a fairer chance of defending the location. There are fewer civilians required to complete the mission on higher difficulties. Destroy Command Bunkers Now has more objective locations, the mission was too easy before compared to other missions. It can now appear in operations from difficulty 5. Operation Modifiers Halved the negative effect of operation modifiers that increase stratagem cooldowns or call in times. Primary, Secondary, & Support Weapons Arc Thrower: fixed charging inconsistencies; it will now always take 1s to charge a shot. Arc Thrower: reduced distance from 50m to 35m. Arc Thrower: increased stagger force. Guard Dog: now restores full ammo from supply boxes. Anti-Materiel Rifle: damage increased by 30%. Breaker Incendiary: damage per bullet increased from 15 per bullet to 20 per bullet. Fire damage per tick increased by 50% (from all sources). Liberator Penetrator: now has a full auto mode. Dominator: increased damage from 200 to 300. Dominator: increased stagger. Diligence Counter Sniper: increased armor penetration from light to medium. Slugger: reduced stagger. Slugger: reduced damage from 280 to 250. Slugger: reduced demolition force. Slugger: fixed armor penetration tag in the menu. Slugger, Liberator Concussive, Senator: fixed incorrect armor penetration tags in the menu. Recoilless Rifle: increased the number of rockets you restore from supply boxes from 2 to 3. Spear: increased the number of missiles you restore from supply boxes from 1 to 2. Heavy Machine Gun: the highest fire rate mode reduced from 1200 rpm to a more moderate 950. Stratagems Patriot Exosuit: rockets will now penetrate armor only on direct hit. Enemies Balancing adjustments have been made to Chargers normal melee attack now does less damage against Exosuits. Bile Spewer and Nursing Spewer do less damage with their puke. The Bile Titan can no longer be stunned. Shriekers no longer create bug breaches. Shriekers hitting you while they are dead now does significantly less damage. Helldiver Balancing adjustments have been made to Heavy and medium armor protects better and you now take about 10% less damage than before while wearing heavy and about 5% less when wearing medium armor. Fortified commando and light armor is unchanged. Fixes Fixed issue where save settings for PS5 would be reset when the game is rebooted, causing things such as loadout and hint settings to reset. Enemies now properly target Exosuits. Previously, many enemies effectively ignored Exosuits if a helldiver on foot was available for them to target. Fixed Exosuits being able to fire their weapons while opening the minimap. The Helldiver and the Exosuit both had a bug that made them sometimes take explosion damage multiple times making things like automaton rockets be too deadly, this is now fixed. Automaton enemy constellations that preferred to spawn more of certain Devastators types did not work and are now functioning as they should. This means that sometimes when playing against the Automatons you will face more Devastators instead of other enemy types. We have improved the system that prevents hellpod steering close to large or important objects. We have solved issues where the effective area around objects was a lot larger than intended. We have reduced the number of objects that prevent hellpod steering. Note: This system is intended to prevent softlocks where players can drop on important interaction points, or drop into unintended places. We will continue to monitor the state of the system after the update to see if additional tweaks are necessary. Fixed cases where the ground under some assets could be bombed causing them to float. Ballistic Shield changes Collision mesh has been slightly increased in size for more forgiveness Changed shield poses so that less of the helldiver is exposed Addressed bug where parts of the helldiver would become vulnerable while using the shield in first person Tutorial Invisible collision partially blocking the doorway leading to the launch pad in the Tutorial Known Issues These are issues that were either introduced by this patch and are being worked on, or are from a previous version and have not yet been fixed. Game might crash when picking up a snowball or throwing back a grenade Various issues involving friend invites and cross-play Cross-platform friend invites might not show up in the Friend Requests tab. Players cannot unfriend other players befriended via friend code. Players cannot unblock players that were not in their Friends list beforehand. Players cannot befriend players with Steam names shorter than 3 characters Explosive weapon stats include only direct hit damage but not explosive damage. Explosions do not break your limbs (except for when you fly into a rock). Planet liberation reaches 100% at the end of every Defend mission. Drowning in deep water with a Vitality Booster equipped puts Helldiver in a broken state. Stratagem beam might attach itself to an enemy but it will deploy to its original location. Some player customizations (like title or body type) may reset after restarting the game.
Lokacija: Gračac
Postovi: 476
Da dosta se crasha ne stat screnu nakon sto je misija gotova. Isto nije napisano ali dodali su dvije nove vrste protivnika kod Automatona gunships i neki veliki AT-AT. Znaći veci je od bile titana. Kao zgrada koja mice se. Sastavili smo u njega 500KG, orbital strike, dva eagle airstrike i par Quasara i ATE i onda je tek pao. A radi takav supressing fire da to nije istina. I nerfali su Slugger koji mi je bio primary nakon sto su nerfali Breaker, sada treba naci nesto novo. Ako tko zeli igrati s domacom ekipom ima nas par igramo skoro svaku vecer. Starija smo ekipa svi vec blize 40. Ovo je discord pa ako tko zeli s nama https://discord.gg/NTaMv2Zq |
Lokacija: Gračac
Postovi: 476
Mi smo sada bili na bot fronti skoro tjedan dana i totalno je durgacije kao da drugu igru igras. Bas me zanima kako ce biti sada kada Illuminate uvedu. Jucer odradili sedmicu protiv buba samo da stalwart personal order rijesimo. Ja sam uzeo stlawart, gas orbital i gaitling gun na kraju sam imao 455 killova. Presmjesno. Stalwart je zakon za bube. |
#10 | |
Lokacija: Plazikur
Postovi: 1,012
ima svojih momenata igra to definitvno
Lokacija: Gračac
Postovi: 476
Evo trajni link na helldivers discord za nasu ekipu, vec je dosta ekipe doslo ali su mi se neki javili da je link istekao. https://discord.gg/CUsh99QP3D |
#12 | |
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,455
Zadnje izmijenjeno od: Old.machine. 03.05.2024. u 20:45. |
DIY DILETANT
Postovi: 3,529
Lokacija: ______
Postovi: 1,455
Zadnje izmijenjeno od: Old.machine. 04.05.2024. u 19:58. |
#16 |
Lokacija: ______
Postovi: 1,455
ArrowHead Community manager Misty admits that "the sole reason for the PSN linking is so they can more effictively ban players". Deletes the tweet and Locks her account as soon as people started to notice. The Community Manager Just Doesn't Understand Steam... Helldivers 2 has now received 84,000 negative reviews in the past day. Steam has granted me a refund with over 14 hours playtime. Refunds on Steam work - here is good guy Steam accepting simple, straightforward logic. Zadnje izmijenjeno od: Old.machine. 04.05.2024. u 20:50. |
#17 |
Lokacija: Plazikur
Postovi: 1,012
tako je to danas...gejmeri su sve glasniji i koriste alate koje su im dostupni da pokažu nezadovoljstvo. nije fer ni korektno prema ljudima u državama gdje psn nije dostupan. ili su odmah trebali to staviti i dobro, ali onda nebi prodaja išla ovako dobro sigurno. U svakom slučaju, šupački potez, sad neka ih bombaju i ne nisu gejmeri razmažene p*ičke već samo dižu glas nezadovoljstva, da je češće ovako, malo bi se svi ti velike ribe zapitale, dali želimo bijes nezadovoljnih gejmera pa bi igre možda i ličile na nešto.
#18 |
Prvoklasni Krkan
Postovi: 5,256
Ne igram ovo i ne zanima me, ali da, ovo su retardirani potezi. Koji će mi kuki ulogiravanje u 75 računa da bi igrao igru? Meni osobno smeta i što na tom istom playstationu, moram imati npr EA račun za igranje njihovih igara i slično. Nije ni na konzolama bajno. To im ga valjda dođe da mogu boostat broj PSN računa i kurčit se time bez neke osnove. A jao si ga nama ako MS stvarno odustane od konzola, ostaju samo N i Sony i ne znaš koji ima gluplje i po korisnika štetnije poteze (dobro, dobro, N je tu neprikosnoveni kralj). slijedi vj vrlo zanimljivo razdoblje. |
#19 |
Postovi: 4,324
Nek vrate ljudima pare koji to žele. A Sony nek se povuće sa PC tržišta i nema više drame. Tko želi igrati njihove igre nek si kupi konzolu i pristane na njihove uvjete. Ja baš planiram uzeti ali okljevam jer nema se vremena pratiti baš svaku igru, ali sretan sam kaj mogu igrat novu Sony igru na PC-u za 29 eura. |
#21 |
DIY DILETANT
Postovi: 3,529
Ja sam u jogurt vodama pa ne kužim tu problematiku, jel mi može netko ko da imam pet godina objasniti taj sonijev potez? |
#22 |
Buying Bitcoin
Postovi: 8,311
Vidim po redditu da ljudima sa preko 100h vraćaju pare zbog ovoga. Prijatelj i ja smo je kupili i odigrali zajedno 6h, igra je bzvz... svaka misija na isti kalup, dosadi brzo. Jučer sam zatražio refund preko Steama, pokušavajući iskoristiti ovu situaciju + jer ionako više ne igram igru, međutim odbili su me jer sam igrao više od 2h (njihov policy), šta je bilo očekivano. Da li je doduše itko pokušao refund, da ima preko 2h i da su mu dopustili ? |
#30 |
Postovi: 4,324
Nemam pojma, ja se ne zamaram takvim stvarima kupujem tamo redovito i živim sretno. |
