Staro 25.01.2023., 18:30   #121
Postovi: 10,217
Ako su iste kao onda - svakako bih promjenio.
Staro 28.02.2023., 12:10   #122
Postovi: 8,482
Friški nastavak LastPass sage ...
The company has now disclosed how the threat actors performed this attack, stating that they used information stolen in an August breach, information from another data breach, and a remote code execution vulnerability to install a keylogger on a senior DevOps engineer's computer. As only four LastPass DevOps engineers had access to these decryption keys, the threat actor targeted one of the engineers. Ultimately, the hackers successfully installed a keylogger on the employee's device by exploiting a remote code execution vulnerability in a third-party media software package. As part of today's disclosure, LastPass has released more detailed information on what customer information was stolen in the attack. Depending on the particular customer, this data is wide and varied, ranging from Multifactor Authentication (MFA) seeds, MFA API integration secrets, and to Split knowledge component (“K2”) Key for Federated business customers.
Ukratko, pokradeno im je sve moguće.
Staro 28.02.2023., 12:25   #123
Dottore
Dottore's Avatar
Postovi: 7,696
Ja sam otišao od 10mj i još nisam imao problema.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 17.05.2023., 15:11   #124
Neo-ST
Neo-ST's Avatar
Postovi: 8,523
Staro 17.05.2023., 20:24   #125
Postovi: 8,482
  • For the PoC tool to work, you need the process dump, swap file (pagefile.sys), hibernation file (hiberfil.sys) or a RAM dump of the entire system.
  • It has been fixed in the test versions of KeePass v2.54 – the official release is expected by July 2023.
  • KeepassXC – a fork of KeePassX, which is a cross-platform port of KeePass – is not affected.
Staro 23.05.2023., 14:14   #126
Neo-ST
Neo-ST's Avatar
Postovi: 8,523
Staro 23.05.2023., 14:37   #127
Postovi: 8,482
Nema veze s KeePassom, ovo je neki/nečiji iOS KeePass, dok je ovdje popis pravih službenih iOS aplikacija.
Staro 24.05.2023., 10:31   #128
Night
Lokacija: Dbk
Postovi: 1,316
Autor Neo-ST Pregled postova
Najnezgodniji dio je ovo što navodno može ostaviti plaintext password u pagefile.sys, još jedna preporuka za koristiti full-disk encryption.
Probao sam runati PoC kod na jednom pagefile.sys dumpu sa kompa koji ima KeePass ali nije mi ništa izbacio, memory dump još nisam testirao.
Autoru kao da se baš ne žuri sa ispravkom ovog dosta ozbiljnog propusta.
Staro 03.06.2023., 21:27   #129
Postovi: 8,482
KeePass 2.54 released
New Features:
  • Triggers, global URL overrides, password generator profiles and a few more settings are now stored in the enforced configuration file.
  • Added dialog 'Enforce Options (All Users)' (menu 'Tools' → 'Advanced Tools' → 'Enforce Options'), which facilitates storing certain options in the enforced configuration file.
  • Export confirmation dialog banners now have a yellow-orange background.
  • In export confirmation dialogs, the text of the 'OK' button is now changed to 'Confirm Export'.
  • In report dialogs, passwords (and other sensitive data) are now hidden using asterisks by default (if hiding is activated in the main window); the hiding can be toggled using the new '***' button in the toolbar.
  • The 'Print' command in most report dialogs now requires the 'Print' application policy flag, and the master key must be entered if the 'Print - No Key Repeat' application policy flag is deactivated.
  • The 'Export' command in most report dialogs now requires the 'Export' application policy flag, and the master key must be entered.
  • Single line edit dialogs now support hiding the value using asterisks.
  • On Unix-like systems, commands that require elevation now have a shield icon (like on Windows).
  • TrlUtil: added 'Move Selected Unused Text to Dialog Control' command.
Improvements:
  • Improved process memory protection of secure edit controls.
  • The content mode of the configuration elements '/Configuration/Application/TriggerSystem', '/Configuration/Integration/UrlSchemeOverrides' and '/Configuration/PasswordGenerator/UserProfiles' is now 'Replace' by default.
  • The built-in override for the 'ssh' URI scheme is now deactivated by default (it can be activated in the 'URL Overrides' dialog).
  • When opening the password generator dialog without a derived profile, the '(Automatically generated passwords for new entries)' profile is now selected by default, if profiles are enabled (otherwise the default profile is used).
  • Improved UI update performance in the password generator dialog.
  • Improved and renamed dialog banner styles.
  • The separator line of light dialog banners is gray now.
  • Improved serialization/deserialization of custom configuration settings (used by plugins).
  • Improved reporting of unknown database header fields.
  • On Unix-like systems, the clipboard workarounds are now disabled by default (they are not needed anymore on most systems).
  • Improved clipboard clearing on Unix-like systems.
  • Improved starting of an elevated process on Unix-like systems.
  • TrlUtil: improved keyboard shortcut assignment and toolbar construction.
  • Installer: the desktop shortcut is now created for all users (if the option 'Create a desktop shortcut' is activated).
  • Installer: removed the Quick Launch shortcut option.
  • Upgraded installer.
  • Various UI text improvements.
  • Various code optimizations.
  • Minor other improvements.
Staro 04.06.2023., 10:50   #130
kreso75
Postovi: 53
Jesu ispravili sigurnosni propust da se može doći do master passworda na Windowsima?
Iz opisa na "New features" i "Imporvements" mi se ne čini da su to naveli...
kreso75 je offline   Reply With Quote
Staro 04.06.2023., 13:20   #131
Postovi: 8,482
Da, popravljeno (1 - 2) je i to nekih dva mjeseca prije od planiranog.
The vulnerability was assigned CVE-2023-32784 and fixed in KeePass 2.54. Thanks again to Dominik Reichl for his fast response and creative fix!
EDIT:
Users of KeePass 1.x, Strongbox, or KeePassXC are not impacted by CVE-2023-32784 and, thus, do not need to migrate to a newer release. To fix the vulnerability, KeePass is now using a Windows API to set or retrieve data from text boxes, preventing the creation of managed strings that can potentially be dumped from memory. Reichl also introduced "dummy strings" with random characters into the memory of the KeePass process to make it harder to retrieve fragments of the password from memory and combine them into a valid master password. KeePass 2.54 also introduces other security enhancements, such as moving 'Triggers,' 'Global URL overrides,' and 'Password generator profiles' into the enforced configuration file, which provides additional security from attacks that modify the KeePass configuration file.
Izvor: BleepingComputer
Zadnje izmijenjeno od: The Exiled. 05.06.2023. u 19:15.
Staro 24.06.2023., 21:25   #132
Postovi: 8,482
LastPass users furious after being locked out due to MFA resets
LastPass password manager users have been experiencing significant login issues starting early May after being prompted to reset their authenticator apps. The company first announced that users might need to log back into their LastPass account and reset their multifactor authentication preference due to planned security upgrades on May 9. However, since then, numerous users have been locked out of their accounts and unable to access their LastPass vault, even after successfully resetting their MFA applications (e.g., LastPass Authenticator, Microsoft Authenticator, Google Authenticator). Compounding the problem, affected customers cannot seek assistance from support since reaching out to LastPass support requires logging into their accounts which they can't do because they're locked in an infinite loop of being prompted to reset their MFA authenticator. LastPass says the MFA resets were announced via in-app messages for "several weeks" before the initial announcement.​
Staro 26.06.2023., 12:31   #133
Night
Lokacija: Dbk
Postovi: 1,316
Nakon što su im procurili master kodovi sa developerovog Plexa jer je valjda normalna stvar koristiti istu mašinu za pornjavu i za master keyeve ... onaj tko je ostao na LastPassu je teška klasa Optimist
Staro 07.09.2023., 18:09   #134
Postovi: 8,482
Experts fear crooks are cracking keys stolen in LastPass breach
Taylor Monahan is lead product manager of MetaMask, a popular software cryptocurrency wallet used to interact with the Ethereum blockchain. Since late December 2022, Monahan and other researchers have identified a highly reliable set of clues that they say connect recent thefts targeting more than 150 people, Collectively, these individuals have been robbed of more than $35 million worth of crypto. Monahan has been documenting the crypto thefts via Twitter/X since March 2023, frequently expressing frustration in the search for a common cause among the victims. Then on Aug. 28, Monahan said she’d concluded that the common thread among nearly every victim was that they’d previously used LastPass to store their “seed phrase,” the private key needed to unlock access to their cryptocurrency investments. Armed with your secret seed phrase, anyone can instantly access all of the cryptocurrency holdings tied to that cryptographic key, and move the funds to anywhere they like.
LastPass declined to answer questions about the research highlighted in this story, citing an ongoing law enforcement investigation and pending litigation against the company in response to its 2022 data breach. LastPass has always emphasized that if you lose this master password, that’s too bad because they don’t store it and their encryption is so strong that even they can’t help you recover it. But experts say all bets are off when cybercrooks can get their hands on the encrypted vault data itself — as opposed to having to interact with LastPass via its website. These so-called “offline” attacks allow the bad guys to conduct unlimited and unfettered “brute force” password cracking attempts against the encrypted data using powerful computers that can each try millions of password guesses per second.
Izvor: Krebs on Security
Staro 24.10.2023., 15:20   #135
Postovi: 8,482
1Password discloses security incident linked to Okta breach
1Password, a popular password management platform used by over 100,000 businesses, suffered a security incident after hackers gained access to its Okta ID management tenant. On Friday, Okta disclosed that threat actors breached its support case management system using stolen credentials. In a report released Monday afternoon, 1Password says threat actors breached its Okta tenant using a stolen session cookie for an IT employee. According to the report, a member of the 1Password IT team opened a support case with Okta and provided a HAR file created from the Chrome Dev Tools. This HAR file contains the same Okta authentication session used to gain unauthorized access to the Okta administrative portal. However, there appears to be some confusion about how 1Password was breached, as Okta claims that their logs do not show that the IT employee's HAR file was accessed until after 1Password’s security incident. 1Password states that they have since rotated all of the IT employee's credentials and modified their Okta configuration, including denying logins from non-Okta IDPs, reducing session times for administrative users, tighter rules on MFA for administrative users, and reducing the number of super administrators.
Staro 13.02.2024., 11:54   #136
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,798
Ima koji lokalni password manager da je ok i da se može instalirati kao docker container?
Maknuo bi se konačno od LastPassa...
tintin je online   Reply With Quote
Staro 13.02.2024., 12:01   #137
RainZG
Postovi: 717
keeweb
pwm
passbolt
to je ono za kaj ja znam
da li su OK ili ne ovisi o tome sto ti treba.
Ja sam vec godinama na Dashlaneu, placam godisnju pretplatu za njega i zadovoljan sam
Zadnje izmijenjeno od: RainZG. 13.02.2024. u 12:18.
RainZG je offline   Reply With Quote
Staro 13.02.2024., 12:25   #138
Postovi: 8,482
Autor tintin Pregled postova
Bitwarden.
Staro 13.02.2024., 12:36   #139
Postovi: 10,217
Bitwarden.
Preporucio bih Vaultwarden, jer Bitwarden je malo tlaka setupirati na svom hardveru. Trosi vise resursa i odrzavanje je kompliciranije. Ovaj spomenuti koristim godinama i nema greske. Ako uz to rijesis i backup (enkriptirani, da ne bi bilo), onda bi trebao biti miran godinama:
https://github.com/dani-garcia/vaultwarden
https://github.com/Bruceforce/vaultwarden-backup
Za selfhosted Bitwarden ti treba domena sa validnim certifikatom. Mozda se moze sloziti domena samo lokalno, kroz kucni dns resolver (npr. pihole), bez izlaganja Bitwardena prema netu, ali svakako treba pravi certifikat, ne self-signed/staging certifikat.
Staro 13.02.2024., 16:28   #140
kvaju
kvaju's Avatar
Lokacija: Cirkus
Postovi: 642
Radi to već danas, i pobriši sve s lastpassa ako već nisi, čitam po tw da dosta korisnika ima problema da su im leak passwordi sa njega.
Ja šta bi uradio, prvo promjenio masterpassword na lastpass, i onda ga izbrisao i sve s njega.
Preporuka za Bitwarden.
kvaju je offline   Reply With Quote
Staro 13.02.2024., 18:45   #141
kvaju
kvaju's Avatar
Lokacija: Cirkus
Postovi: 642
Autor kvaju Pregled postova
https://x.com/neerajka/status/1753160121687888168?s=46
Staro 13.02.2024., 20:12   #142
medo
#erase startup-config
medo's Avatar
Postovi: 3,732
KeePass
Staro 13.02.2024., 21:02   #143
domy_os
domy_os's Avatar
Postovi: 18,925
Bitwarden ima očajno loš UX pa tako:
- autofill često ne radi
- često se sam odjavi
- svako malo baca na vrh liste dok se nešto editira
- history praktički ne postoji, ni u organizaciji
- izvedba foldera koma
- prebacivanje unosa u/iz organizacije ne postoji
- loš exclusion u kojem treba tipkati full app name
- autoupdate sam jedva "ubio" na PC-u
- šećer na kraju, 2FA trebaš platiti 10 eura godišnje
Nakon više od godinu dana korištenja Bitwardena i dalje poželim KeePassov UI i funkcionalnost. Zbog posla sam prešao na cloud, što je, tu je.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 13.02.2024., 22:49   #144
Postovi: 10,217
Da ne bi bilo zabune, 2FA login u Bitwarden account je free. Podrska za 2FA (TOTP) za sve one accounte cije passworde cuvate u Bitwardenu - se placa.
Za 2FA mi ne Aegis jos uvijek bog i batina.
Autofill je musicav na Androidu, ali ne znam je li to kriv BW, Android ili aplikacija. Na kompu koristim browser ekstenziju i tu nema greske.
Web UI uopce ne palim. Jednom sam poslagao foldere, par puta godisnje updejtam to i uredim liste, so far so good. Koristimo ga samo zena i ja (selfhosted s dva profila).
Staro 13.02.2024., 23:58   #145
d0X
Kostolomac
d0X's Avatar
Postovi: 1,533
Autor xlr Pregled postova
Možeš probati "Use accessibility" i "Use draw-over" pod "Auto-fill" u BW-u. Meni generalno radi ok, nisam imao problema.
PSN Steam
Staro 14.02.2024., 00:04   #146
domy_os
domy_os's Avatar
Postovi: 18,925
Na mobitelu je autofill još i OK osim što mi fali jednostavan exclude za neke app, problem je na desktopu. Znam lupati CTRL+SHIFT+L bezbroj puta i ne radi, i na svim browserima tako. Neko vrijeme radi dobro pa se zblesira.
Staro 14.02.2024., 01:01   #147
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,126
I dalje imam mjesta na Dashlaneu kad vam dosade ova polurješenja koja cure na sve strane
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 14.02.2024., 01:35   #148
Postovi: 10,217
Autor d0X Pregled postova
To je sve popaljeno, ali pamtim da mi svako malo neki app/web ne ponudi autofill pop-up. Nije tako cesto, dovoljno da zapamtim
Nisam na kompu koristio global shortcut, budem bas probao kako se ponasa.
Staro 15.02.2024., 11:15   #149
Night
Lokacija: Dbk
Postovi: 1,316
Trebao bi mi neki 2FA (TOTP) autentikator da radi na Windowsima, ali da se editiranje i gledanje seeda može zaključati nekim admin passwordom.
Znači ideja je da ja kao admin unesem seed, korisnik može dobiti šestoznamenkasti broj kad hoće, ali ne može vidjeti koji je seed i kopirati ga u neki svoj autentikator.
Authy nije opcija.
Staro 15.02.2024., 11:56   #150
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,798
Nikako da mi proradi vaultwarden u kombinaciji sa caddy-em.
Mislim da je problem što su mi portovi 80 i 443 na severu zauzeti, a ne uspijevam to upoginiti preko drugih portova.
Radio sam po ovim uputama.
