Staro 18.08.2023., 09:14   #1
Ninz
Datum registracije: May 2019
Postovi: 96
Updates na Windows11 bez TPM2?
Bok ekipa,
nešto se priča da Win11 koji je instaliran na računala koja ne podržavaju TPM neće dobivati updates(za sad to radi normalno), jel to istina ili su samo spekulacije.
Isprike ako je tema već bila, tražio jesam ali nisam našao.
Ninz je offline   Reply With Quote
Staro 10.09.2023., 05:48   #2
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,253
Autor Ninz Pregled postova
Bok ekipa,
Istina je, ako npr već nisi na 22H2 nećeš ni moć, neće ti ga ni nuditi. Ostali updatei za trenutnu verziju će se uredno instalirati.
Dakle samo ovi veliki updatei na novije verzije/service packovi sigurno ne rade.
Slobodno me dodajte na PSN
Staro 10.09.2023., 06:37   #3
BinaryJesus
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 278
Autor Disco Pregled postova
Ne rade po defaultu ali se to lako zaobiđe.
Code:
Get 11 on 'unsupported' PC via Windows Update or mounted ISO (no patching needed)
  - use Skip_TPM_Check_on_Dynamic_Update.cmd v9+ to add /Product Server on-the-fly
  - and finally start Windows Update and select Upgrade to Windows 11
Get 11 on 'unsupported' PC via MediaCreationTool.bat
 - use MediaCreationTool.bat  to Auto Upgrade, Create ISO or Create USB with detected edition and  language, or Select between consumer or business (Enterprise) media
   Script creates media that will automatically skip clean install checks
   setup.exe will not automatically skip upgrade checks - launch the included auto.cmd instead!
You already have an ISO, USB or extracted ISO Files and want to add bypass to it for both clean install and upgrade:
 -use Quick_11_iso_esd_wim_TPM_toggle.cmd to add <INSTALLATIONTYPE>Server without mounting
  This one toggles installation type to Server (or back to Client if run again on the same file, restoring hash)
  directly on the iso / esd or wim file - so there's no mounting / dism, just powershell-based hex..
  Server type bypasses all hardware checks properly and cleanly
BinaryJesus je online   Reply With Quote
Staro 14.09.2023., 05:09   #4
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,253
Autor BinaryJesus Pregled postova
Code:
Ne vidim da se tu spominju update-i nego upgrade-i. Si probao što od toga?
Ja sam pred neko vrijeme probao na jednom starijem laptopu i išlo je samo kako sam opisao, 22H1 sigurnosni updatei, ali 22H2 mi nije nudio iako je bio dostupan.
Ili ti misliš da svaki put kada izađe novija verzija W11 napravi in-place upgrade na noviju verziju?
Nije to nešto strašno, ali nije ni zgodno.
Staro 14.09.2023., 05:24   #5
BinaryJesus
Postovi: 278
Pa to je ista stvar. Govorim o većim updatima. Ne ovim mjesečnim zakrpama.
Staro 16.09.2023., 11:51   #6
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,253
Ma je isto, ali nije zgodno jer svaki put treba skinut Mediacreationtool i onda s njime skinut image i upgradeat. OK, za naprednog korisnika to je niš, za običnog je to SF.
Staro 16.09.2023., 13:09   #7
BinaryJesus
Postovi: 278
Ma ona prva opcija koju sam naveo "Skip_TPM_Check_on_Dynamic_Update.cmd" omogućava upgrade preko windows update. All to će opet biti inplace update. Znači windows update skida ESD image windowsa od 3-4 GB i inicijalizira update iz toga.
Staro 17.09.2023., 06:38   #8
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,253
Hvala za info.
Staro 17.09.2023., 13:06   #9
flyer1
flyer1's Avatar
Lokacija: home
Postovi: 572
cek, ovo me cisto iz znatizelje zanima...jel ide klasicni media creation tool i ako je, na koji nacin iniciras skriptu da funkcionira unutar MCT-a?
flyer1 je offline   Reply With Quote
Staro 17.09.2023., 13:34   #10
BinaryJesus
Postovi: 278
Autor flyer1 Pregled postova
Znači instaliraš skriptu (Skip_TPM_Check_on_Dynamic_Update.cmd) na računalo. Pokreneš windows update i to je to. Ako windows update ne pronalazi update ima ovdje i skripta za reset (windows_update_refresh.bat).
Alternativa je bilo gdje nabaviti Win11 ISO i patchirati ga skriptom " Quick_11_iso_esd_wim_TPM_toggle.bat".
Sve je na MDL forumu ili na githubu.
Staro 17.09.2023., 13:46   #11
flyer1
flyer1's Avatar
Lokacija: home
Postovi: 572
ok tenks na pojasnjenju.
nije za mene, jer moja platforma zadovoljava tpm2.0 uvjet, ali par frendova bi zeljeli probat win 11 bez obzira na sve, pa da im proslijedim uputu...a jamacno su kratki za tpm funkcionalnost jer su im konfiguracije starijeg datuma.
Staro 17.09.2023., 15:00   #12
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,515
Dotični znatiželjnici nek svakako isključe Core isolation/Memory integrity funkciju jer to ubija performanse na starijim procesorima (prije Zen2/Gen7).
Staro 17.09.2023., 16:19   #13
flyer1
flyer1's Avatar
Lokacija: home
Postovi: 572
Autor kopija Pregled postova
obojica su na intelu, jedan od njih jamacno nije gen7 jer vozi na mom starom 4590 a sumnjam i da je drugi na 3 generacije novijoj arhitekturi od haswella....
taman kopiram, pa cu poslat kao dopunu uz linkove kolege Jesusa, nek se momci zabavljaju kad imaju volje....
