Lokacija: Zagreb, HR
Postovi: 60
Problem sa RAID-om na NF4 plocama?!
Pozdrav! Isprike ako je ovo vec bilo negdje rečeno. Danas sam, tražeći info za RAID na NF4, našao ovo: http://tinyurl.com/nmhvj I lijepo sam se zabrinuo. Da citiram: "In my experience, they seem to be reliable while both disks work, but when a disk needs to be rebuilt the RAID BIOS seem to pick the source disk at random, as opposed to something radical like using the only valid disk as the source. Originally I thought this was a FreeBSD issue, but replies to my post sugggested it was a common problem, and not just limited to FreeBSD. Indeed, on the hardware I was using (a Sun X2100 server), Solaris had the same problem, and about 50% of the time you'd end up with corrupted or blank disks after a rebuild. Sun have now stopped claiming in the specifications that these machines support RAID, and I'm now using FreeBSD pseudoraid on them." I još iz istog threada: "Lets not mix things up here, this is about the nForce chipsets. The nForce RAID BIOS has problems with choosing the right drive to build from when a mirror fails, this will need a BIOS update to get fixed." Gledao sam na DFI web (Imam DFI LanPartyUT NF4 Ultra ploču) i nema changelog za BIOS, ništa ne spominju ovaj problem.. Ako u ovome ima istine, to je katafakinstrofa!!! Da li je netko nešto čuo o ovome?
-- Mario |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Koliko je meni poznato-nema problema na XP PRO. |
#3 | |
Postovi: 60
Kako ja ovo čitam, ovo nema veze sa OS-om već sa nForce RAID BIOS-om. Onda je svejedno koji OS ti je gore. Googlam dalje, ali zasad nisam ništa pametno našao. Pitanje je da li je itko išao mijenjati disk u mirroru onako za test. Vjerojatno nije. A ako je istina ovo što gore piše, ovo je tempirana bomba koja samo čeka...
-- Mario |
Super Moderators
Postovi: 17,485
Ja govorim za DFI Ultra-D. I XP pro. Osim toga-nije svejetno koje hardove koristiš. Maxtori su znali imati problema npr... Tor je na istoj ploči koliko znam imao RAID i nije se žalio na ništa. |
#5 | |
Postovi: 60
Međutim, kad ti rikne jedan disk, ti ćeš ga zamijeniti i pokrenuti rebuild mirrora. E tu postoji šansa da nForce RAID BIOS uzme krivi disk kao referentni sa kojeg će kopirati podatke pa se kao rezultat dogodi da imaš 2 blank diska. Dakle, problem nije u inicijalnom kreiranju RAID mirrora niti u normalnom radu. Problem je kod zamjene neispravnog diska kad postoji 50% šanse da izgubiš sve podatke i završiš sa oba blank diska.
-- Mario |
#6 | |
Super Moderators
Postovi: 17,485
Ne, za to još nisam čuo. A bogme bi se i netko od forumaša već "pohvalio" da mu se dogodilo nekaj slično. Na sreću-izgleda da nikome nije. ![]() |
#7 | |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,791
#8 | |
Postovi: 60
Toliko o očekivanjima.
-- Mario |
#9 | |
E Pluribus UNIX
Lokacija: M82
Postovi: 6,791
Sistem koji potencijalno i zahtijeva redundanciju vrtiti na enforsu? Smijesno, u najmanju ruku...
#10 | |
Postovi: 60
Takvi kontroleri ne mogu podržati RAID 5 npr, što je i razumljivo. Ali ako netko tvrdi da podržavaju RAID 1 i naštanca manual od 120 strana koji objašnjava što i kako, s pravom očekujem da je u stanju resinkronizirati mirror kad se zamijeni disk. Ako je nekom prihvatljiva mogućnost da se stvar tek tako raspadne i unište se i podaci na zdravom disku prilikom otkazivanja jednog diska u mirroru, bolje da ne spominjem u kakvoj klasi taj plovi (nije kulturno). A s obzirom da je ova rasprava krenula u smjeru 'čija mama ima veću kitu', EOD od mene. Ako netko ima nešto pametno za reći, rado ću poslušati, a priče 'pa šta očekuješ' smatram za OT. Pozdrav!
-- Mario |
#11 | |
Propali Amigaš
Lokacija: Nin
Postovi: 7,006
Ma radi na mojoj Epoxici i raid 5 ![]() Interesantna je stvar da Epox drži 4.76 verziju NVRaid biosa gore otkad je ploča izašla, iako je bilo preko 20 novih verzija u međuvremenu (bar koliko sam uspio vidjeti za druge ploče) Ali changeloga - nigdje |
#12 | |||||
E Pluribus UNIX
Lokacija: M82
Postovi: 6,791
Uostalom, sve i da te zadovolji samo nekakva jadna osnovna redundancije, nije mi jasno kako je moguce uopce manifestirati takvu gresku kad navodno ti kontroleri imaju podrsku za on the fly rebuild i definiranje hot spareova. Citiraj:
![]() Citiraj:
Pazi, nemoj me krivo shvatiti, na ljudskoj razini, sasvim mi je jasan tvoj stav. I s te strane te potpuno shvatjam, razumijem i opravdavam. S druge strane, smijesno mi je tvoje pusenje envidijine marketinske... palice, da li zbog neinformiranosti, da li zbog osjecaja za pravdu (jer, zaista, ako pise da imaju super cool mega uber podrsku za RAID, zasto ta ne radi kako pise?). E cuj, c'est la vie, pogotovo u low low low end IT segmentu.
Propali Amigaš
Lokacija: Nin
Postovi: 7,006
Moram priznati da sam i ja sa priličnom dozom skepse uzeo svoju prvu ploču sa Nvidia chipsetom, ali mogu reći da se pokazala OK. Jedini problem radi hardware firewall, iako i to izgleda kao software problem, jer je sa prethodnom verzijom drivera uredno radilo |
Lokacija: Velika Gorica
Postovi: 1,532
Moram priznati: citam i ne vjerujem komentare ljud koji kakti smatraju da znaju o cemu pisu. Vulgaris RAID1 nije nikakav rocket-science, niti za to trebas kontroler od 200+EUR. Ovdje se ne govori o opcijama hot-swappa, rekonstrukcije RAID-a na 'zivom' sistemu, cacheu, management sofweru, hot-swap diskovima, itd.... nego o obicnom najvulgarnijem RAID1. Dakle, imas 2 diska, jedan umre. Super, stroj se stilta (niti ne ocekujes da ce RAID kontroler prezivjeti 'pad' diska), nikom nista. Zamjenis pokvareni disk. I nakon toga trebas pokrenuti resinkronizaciju iz RAID BIOS-a. I on pocne sinkonizaciju s KRIVOG diska. I tvoj komentar je u stilu 'sto ocekivati od no-name raid kontrolera i sl...'. I na kraju nakon toliko replyjeva, covjeku nitko nije odgovorio sto je pitao, vec proljev stvarno bespotrebnih komentara.
Idiocracy. Kad satira postaje stvarnost. |
Propali Amigaš
Lokacija: Nin
Postovi: 7,006
http://nvidia.custhelp.com/cgi-bin/n...809793&p_olh=0 U teoriji, kako se vidi iz gornjeg dokumenta, rebuild se radi iz windowsa (i to hot plug, ne bi trebalo niti restart raditi) Koliko se sjećam može se raditi i iz BIOS-a, a u oba slučaja bi korisnik trebao biti taj koji bira SA kojeg NA koji disk se rebuild radi |
