#2612 |
Postovi: 953
#2613 |
#erase startup-config
Postovi: 3,657
Mali update: nakon flashanja Orico PCIe kartice (VL805 USB chip) UASP radi k'o podmazan: Code:
# dd if=/dev/sde of=/dev/null bs=4M status=progress 195693641728 bytes (196 GB, 182 GiB) copied, 498 s, 393 MB/s Code:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-6.2.0-26-generic] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF READ SMART DATA SECTION === SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 284 12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 122 177 Wear_Leveling_Count 0x0013 099 099 000 Pre-fail Always - 2 179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0 181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0 182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0 183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0032 055 053 000 Old_age Always - 45 195 Hardware_ECC_Recovered 0x001a 200 200 000 Old_age Always - 0 199 UDMA_CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0 235 Unknown_Attribute 0x0012 099 099 000 Old_age Always - 18 241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 13257598466 252 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 1 |
#2614 |
Lokacija: München/Varaždin
Postovi: 4,707
Jel imao tko prilike igrat se sa alternativama OpenVas-u? Htio bih postaviti sustav na noge koji ce kao i OpenVas skenirat server (pozeljno agentless) da mogu agirat na sigurnosne updejtove OS-a (konkretno je OpenSuse / SLES) u pitanju. Dosad sam imao na privatnoj masini OpenVas + aktualni Image OS-a ali zelim prebaciti sve na radnu stanicu u uredu - i tu me hebe Firewall (da poslao ticket bla bla ali ekipa koja iza toga stoji vidi rsync kao nekaj kaj samo "hackeri" koriste (da, znam da i mene zaboli mozak kad se sjetim originalne izjave)). Da, znam da zypper ima elegantno rijesenje za to - problem je da to kaj koristimo nije cisti Suse/Sles i koristimo preko 300 posebno patchanih paketa i zypper upgrade ne dolazi u obzir s obzirom da bi skrsio vazne stvari dok si reko keks. Dakle trazim neki nacin da vidim koje sigurnosne propuste imam na sustavu, da ih mogu analizirat. Skinut updejtove i patchat je drugi par rukava al taj dio sam pokrio odavno. P.S.- mora bit free naravno jer gornji management ne zeli iskesirat lovu za nekaj "normalno" pa se moram ovak zahebavat: Code:
Updating NVTs.... /usr/bin/greenbone-nvt-sync rsync: [Receiver] failed to connect to feed.community.greenbone.net (45.135.106.143): Connection timed out (110) rsync: [Receiver] failed to connect to feed.community.greenbone.net (2a0e:6b40:20:106:20c:29ff:fe7f:d2ae): Network is unreachable (101) rsync error: error in socket IO (code 10) at clientserver.c(138) [Receiver=3.2.3] /usr/bin/greenbone-nvt-sync success Updating GVMD_DATA... /usr/sbin/greenbone-feed-sync --type GVMD_DATA rsync: [Receiver] failed to connect to feed.community.greenbone.net (45.135.106.143): Connection timed out (110) rsync: [Receiver] failed to connect to feed.community.greenbone.net (2a0e:6b40:20:106:20c:29ff:fe7f:d2ae): Network is unreachable (101) rsync error: error in socket IO (code 10) at clientserver.c(138) [Receiver=3.2.3] /usr/sbin/greenbone-feed-sync --type GVMD_DATA success Updating SCAP data... /usr/sbin/greenbone-feed-sync --type SCAP rsync: [Receiver] failed to connect to feed.community.greenbone.net (45.135.106.143): Connection timed out (110) rsync: [Receiver] failed to connect to feed.community.greenbone.net (2a0e:6b40:20:106:20c:29ff:fe7f:d2ae): Network is unreachable (101) rsync error: error in socket IO (code 10) at clientserver.c(138) [Receiver=3.2.3] /usr/sbin/greenbone-feed-sync --type SCAP success Updating CERT data... /usr/sbin/greenbone-feed-sync --type CERT rsync: [Receiver] failed to connect to feed.community.greenbone.net (45.135.106.143): Connection timed out (110) rsync: [Receiver] failed to connect to feed.community.greenbone.net (2a0e:6b40:20:106:20c:29ff:fe7f:d2ae): Network is unreachable (101) rsync error: error in socket IO (code 10) at clientserver.c(138) [Receiver=3.2.3] /usr/sbin/greenbone-feed-sync --type CERT success
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / 1TB Micron M.2 2242 / nVidia Geforce RTX 4050 / Windows 11 Pro Lenovo Thinkpad T540p || Intel Core i7-4700MQ / 16GB DDR3 / 240GB Sandisk SSD Plus / nVidia Geforce GT 730 / FreeBSD 14.3 |
#2616 |
Postovi: 4,707
Nisam naletio na misa koji ne radi na Linuxu. P.S. Chrome OS nije Linux.
#2618 |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,750
#2619 | |
Postovi: 4,707
Ok drugi put kava prije reakcija na forumu nakon noci prezderavanja i rakije ![]() ![]()
#2620 |
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,748
Prešao na Linux Mint po drugi puta na kućnom računalu. ![]() Nekako mi se čini da ima puno manje mušica nego prije. Sve radi sa stvarno minimalno podešavanja. Čak je i sve brže nego na Win10, iako to može biti do 3-4 godina stare win instalacije. Klinci su oduševljeni što se Minecraft pokreće za valjda 5 sekundi u odnosu na barem 60+ sekundi na win. Meni Civ VI koji jedini igram već duže vrijeme radi od prve. Samo instalirao Steam i skinuo. Svi ostali osnovni programi koje koristim kući postoje na linuxu ili je već došlo kao dio OS-a. Uglavnom, vrlo pozitivno iskustvo s aspekta kućnog korisnika. |
#2621 | |
Datum registracije: Aug 2020
Postovi: 892
#2622 |
Lokacija: Ramura
Postovi: 2,748
To mi i treba. Računalo uz mene koriste žena i djeca, a oni ni ne primjećuju da se nešto bitno desilo jer je 99% korištenja Firefox + Minecraft. Najveća panika je bila da li ćemo uspjeti prenijeti Minecraft svjetove na novu instalaciju (jesmo). ![]() |
#2623 |
Postovi: 3,464
Ja sam se nedavno nakon dugo godina prebacio s xubuntu na Mint jer su *buntu zakakili sa snap-om. Konzervativna politika mi sasvim odgovara. Ženi sam na laptop stavio Mint XFCE i ne buni se ![]() Kćerka veli da se Minecraft na winblowsima dugo loada, svašta je natrpala, hrpu modova, launcheri razni... ali ne bi se kladio da se na mintu nešto puno brže loada, za java verziju očekivao bi da bude otprilike isto. Ali djecu radi igrica moram držati na windowsima ![]() Gledam kako Mint razvija LMDE, meni se čini da se oni pokušavaju malo pomalo odvojiti od ubuntu i vezati direktno na Debian. |
#2624 | |
Postovi: 4,707
Prije 3 godine mi je bio Daily Driver...cist OK OS. Zavisi s kojeg stajalista gledas > ako znas sto i kako > Debian i bok. Pure, Vanilla i najbolja solucija za sve od workstationa do servera - pa cak i za desktop. Jedini razlog zakaj i dalje primarno Fedoru vrtim da mi se neda trenutno sve krsit jer mi je primarni OS katica za sve od pornjave do gejmanja i dev cickarija.
#2625 |
Postovi: 3,464
Meni je to daily driver već godinama, xcfe i jubuntu ispod, sada mint, čisto radi jednostavnosti instalcije i održavanja jer sam s debian paketnim upoznat za razliku od RHa i derivata. A ionako sve bitno mi je u virtualkama raznim. A i na ono govno od novog gnometa me nitko ne može natjerati ![]() Ja sam malo stariji i oldschool pa me jako iritiraju te novotarije gdje uspijevaju zakenjati GUI programa, sve su manje ergonomični i prilagođeni valjda nekoj ekipi koja po tabletu nabada prstima, a ne radi mišem na većem ekranu kao ja. |
#2626 | |
Postovi: 4,707
Iskreno...meni Gnome pase. Po defaultu je ultra okrljasten - dodam extenzije koje zelim i mozak na pasu. KDE faze imam ali uvijek sam se vracao na Gnome. Najbolje radi sa Waylandom i sucelje nije prenatrpano opcijama ko KDE. XFCE sam najduze ganjao al nekako me sve to proslo i poceo sam opet biti sucker za eye candy ![]() P.S.- APT i DNF se ne razlikuju tak puno , brzo bi se prilagodio ![]() ![]()
#2627 |
Postovi: 3,464
Baš taj eye candy mi ništa ne znači, ja sam generacija odrasla na DOSu i NC :-) Bemti, na faksu smo učili internalije DOSa u sklopu kolegija oper. sustava. Ovo pišem kao krajnji korisnik xfce sučelja jer ne tipkam u vimu niti privantno niti profesionalno.... Ako ćemo već oko GUIa, xfceu je falio bolji file manager i thunar je u zadnjoj verziji (koju je Mint dobio tek prelaskom na 21.2) dobio dosta novih stvari: - search po dorektorijima/datotekama. Pravo čudo da u 2023 postoji file manager koji to nema ![]() - copy proces je poboljšan, sad ima pauzu, background i ostale "napredne" fičure koji su drugi file manageri imali pred 15 godina - restore tabova na startupu - undo operacija - split view - itd. Dosada je čak i winblows exploder bio upotrebljivi nego thunar. xfce je i dalje ružan za današnje pojmove, ali ima jako spori razvoj i stabilan je što mi osobno odgovara. |
#2628 |
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,016
Meni novi gnome nije legao pa koristim Matu. Čak sam nedavno skužio da instaliram jedan paket pa Gnome programi dobiju isto titlebar kakav ima Mate.
tomek@vz: ajd nemoj | Mali Čile SAD Češka Peru | Windows Free |
#2629 |
Postovi: 3,464
Apropo egonomije u modernim sučeljima... Primjer, simple scan, GTK aplikacija za skeniranje, praktički jedina jednostavna i da je "just works" ako se ne koristi KDE ili neka egzota od sučelja/aplikacije. Koristim taj program već dugo i iz generacije u generaciju je sve lošiji, ovo je zadnja verzija: - tipka scan je gore lijevo - save je okomita strelica gore desno - za novi dokument tipka je dolje lijevo - crop i ovih par gumbi su iz nekog nepoznatog razloga dolje na sredini Sad kad pokrećem skeniranje, kliknem mišem gore lijevo, za spremiti prolazim mišem cijeli ekran do gore desno za spremiti. Za novi dokument idem dijagonalno preko ekrana dolje lijevo. To je jako puno šetanja mišem preko cijelog ekrana. U starijim verzijama bio je standardni toolbar i svi gumbići jedan kraj drugoga. E, da, ako ste mislili da nakon pokretanja zeleni gumb "Scan" ima fokus pa da se samo stisne enter, varate se ![]() Ostaje ili dobiti sindrom karpalnog tunela ili naučiti napamet još jedan set key shortcuta ![]() Pokušavam shvatiti za koga, za kakvo sučelje i kakav način upravljanja su developeri ovo napravili? |
#2630 |
Postovi: 4,707
#2631 | |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,322
#2632 |
Postovi: 892
Masu ljudi mi je došlo sa starim laptopima koji nisu sposobni optimalno vrtiti Windowse i instalirao sam im Mint, zadovoljni su, ne primjećuju neku veliku razliku osim što im je laptop brži ![]() |
#2633 |
Lokacija: Grad na Dravi
Postovi: 580
Jučer nakon "zypper dup" Švabo mi se zbleso, sad me na početku pita lozinku iako je namješteno na auto login i kad upišem lozinku kaže mi da je neispravna, čini mi se da je to sve radi NVIDIA drivera i kako da ja sad njega maknem da ostane samo onaj od linuxa nouveau? I da maknem NVIDIA repos? I neće instalirati glibc-32bit. |
#2634 | |
Postovi: 4,707
Kao osoba koja dnevno radi sa OpenSuse i SLES sustavima - nekaj si gadno usro ![]() P.S.- OpenSuse i SLES inace imaju dosta dobru dokumentaciju online: https://en.opensuse.org/Main_Page https://documentation.suse.com/
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / 1TB Micron M.2 2242 / nVidia Geforce RTX 4050 / Windows 11 Pro Lenovo Thinkpad T540p || Intel Core i7-4700MQ / 16GB DDR3 / 240GB Sandisk SSD Plus / nVidia Geforce GT 730 / FreeBSD 14.3 Zadnje izmijenjeno od: tomek@vz. 22.08.2023. u 08:01. |
#2635 | |
Lokacija: Sesvete
Postovi: 1,016
Za skeniranje koristim XSane i dalje, samo šteta kaj nije sve jednom prozoru nego su razbacani. Čak razmišljam Vue kupiti ali...
#2636 |
Postovi: 580
Imam Tumbleweed, repos od nvidie mi se sam pojavio, ja ga nisam stavio. Kad se diže normalno dođe do onog prozorčića gdje trebam upisati lozinku i kada ju upišem kaže mi da ne valja mada je ispravna. Probao sam maknuti repos od nividie ali mi ne da, javi neku grešku, sad nisam kod kuće pa ne znam što napiše. |
#2638 | |
Postovi: 4,707
Bitno je shvacat greske koje ti OS izbaci. Al "whatever floats your boat"
