Povratak   PC Ekspert Forum > Računala > Mobilno > Tableti
Staro 17.08.2023., 11:31   #1
Bodisson
Bodisson's Avatar
Datum registracije: Dec 2014
Postovi: 246
Post N-one Tablet
Eto, posjetio Ali i kupio ovo:
N-one NPad X MTK G99 8-Cores Tablet PC
Zbunilo me ovo sa 16 GB RAMa. U pitanju je nekakva hibridna tehnoologija kakvu do sada nisam sreo. Tablet ima 8 GB...
Odmah nakon prvog pokretanja potjeran Google update.
Evo što (djelomično, editirano) kaže Aida:
AIDA64 for Android v1.94 Report
<<< System >>>
Manufacturer: N-one
Model: Npad X
Brand: N-one
Board: tb8781p1_64
Device: TAB005
Hardware: mt8781
Platform: mt6789
Product: NpadX
Installed RAM: 8 GB
Total Memory: 7780 MB
Available Memory: 3716 MB
Internal Storage Total Space: 108.79 GB
Internal Storage Free Space: 102.11 GB
Bluetooth Version: 4+
<<< CPU >>>
Core Architecture: 6x ARM Cortex-A55 @ 2000 MHz
2x ARM Cortex-A76 @ 2200 MHz
Instruction Set: 64-bit ARMv8-A
CPU Revision: r4p0
CPU Cores: 8
CPU Clock Range: 500 - 2200 MHz
Core 1 Clock: 650 MHz
Core 2 Clock: 650 MHz
Core 3 Clock: 650 MHz
Core 4 Clock: 650 MHz
Core 5 Clock: 650 MHz
Core 6 Clock: 650 MHz
Core 7 Clock: 1300 MHz
Core 8 Clock: 1300 MHz
Supported ABIs: arm64-v8a, armeabi-v7a, armeabi
Supported 32-bit ABIs: armeabi-v7a, armeabi
Supported 64-bit ABIs: arm64-v8a
AES: Supported
ASIMD/NEON: Supported
PMULL: Supported
SHA1: Supported
SHA2: Supported
<<< Display >>>
Screen Resolution: 1200 × 2000
Screen Size: 143 mm × 248 mm
Screen Diagonal: 11.27 inches
Pixel Density: 207 dpi (tvdpi)
xdpi / ydpi: 213 / 205 dpi
GPU Vendor: ARM
GPU Renderer: Mali-G57 MC2
Refresh Rate: 60 Hz
Default Orientation: Portrait
OpenGL ES Version: 3.2
GPU Version: OpenGL ES 3.2 v1.r32p1-01eac0.394145956bc7cd8e697b330aba11e3d3
<< Telephony >>
Phone Type: GSM
Network Operator Name: bonbon
Network Operator Code: 21901
Network Operator Country: Croatia
SIM Provider Name: bonbon
SIM Provider Code: 21901
SIM Provider Country: Croatia
SIM State: Ready
Network Type: Unknown
Data Connection State: Connected
Data Activity: None
Device Is Roaming: No
ICC Card: Present
<< Wi-Fi >>
State: Enabled
SSID:
BSSID: 02:00:00:00:00:00
Hidden SSID: No
IPv4 Address:
IPv6 Address:
Signal Strength: -64 dBm (Very Good)
Link Speed: 72 Mbps
Frequency: 5200 MHz
Gateway:
Netmask: 255.255.255.0
DNS1: 83.139.103.3
DNS2: 83.139.121.8
DHCP Lease Duration: 168 hours
5 GHz Band: Supported
Wi-Fi Aware: Not Supported
Wi-Fi Direct: Supported
<<< Battery >>>
Power Source: Battery
Level: 78 %
Status: Discharging
Health: Good
Technology: Li-ion
Temperature: 40.0°C
Voltage: 4.077 V
Charge Counter: 2297 mAh
Discharge Rate: 405 mA
Capacity (Reported by Android): 8600 mAh
<<< Android >>>
Android Version: 13 (Tiramisu)
API Level: 33
Android Security Patch Level: 2023-03-05
Rooted Device: No
Android ID: 28aa2f709492a3bb
Baseband: MOLY.LR13.R2.MP.V79.5,MOLY.LR13.R2.MP.V79.5
Build ID: M100TB.MY.657-MMI.T0.CEM4X.8G.2023071712.B2EFFC9CA49.USER
Codename: REL
Fingerprint: N-one/NpadX/TAB005:13/TP1A.220624.014/1675771234:user/release-keys
Incremental: 1675771234
Java Runtime Version: Android Runtime 0.9
Java VM Version: ART 2.1.0
Java VM Heap Size: 256 MB
Kernel Architecture: aarch64
Kernel Version: 5.10.149-android12-9-00031-g8d44cb1a9e42-ab9703858
Tags: release-keys
Type: user
Google Play Services Version: 23.30.13 (190400-552628474)
Huawei Mobile Services Version: < Not Present >
OpenSSL Version: OpenSSL 1.1.1 (compatible; BoringSSL)
ZLib Version: 1.2.11
ICU CLDR Version: 40.0
ICU Library Version: 70.1
ICU Unicode Version: 14.0
Android Language: English (United Kingdom)
Configured Time Zone: Central European Summer Time (UTC+02:00)
UpTime: 00:52:24
Ukoliko imate pitanja prije nego ga nakrcam multimedijom (uglavnom e-books i video, nešto malo glazbe), pitajte.
I budite malo strpljivi, ne "visim" cijelo vrijeme na forumu...
Bodisson je offline   Reply With Quote
Staro 17.08.2023., 12:01   #2
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,483
Ja sam preko Aliexpressa za 130$ kupio N-One NPad Pro.
Po specifikacijama odličan tablet, 2000x1000 FHD ekran, 8GB RAM-a, 128GB ROM, Android 12.
Ekran je dosta taman, ne dobijam dojam da je toliko bolji, FHD, pozadina na početnom ekranu kako god se postavi bude pikselizirana.
Iako ima 8GB RAM-a, Lenovo tablet s 3GB RAM-a radi brže ili jednako kao ovaj.
Ima 18W QC punjenje, no nakon svega 3min punjenja, brzina punjenja pada na 5W ili 0W uz poruku da se baterija pregrijava!?
Radi svega, dobio povrat od 20$ od Aliexpressa, razočaran.
Na papiru jak osmojezgreni proc, puno RAM-a, odličan ekran, u stvarnosti veliki flop.
OS: Android 12
CPU: Unisoc Tiger T616
Graphics Chip: G57
Storage RAM: 8GB
Hard Disk Memory: 128GB
Network WIFI: 802.11a/b/g/n/ac Band: 2.4GHz/5GHz
Bluetooth: BT5.0
Camera Front Camera: 5MP
Rear Camera: 13MP
Connectivity
Type-C(USB2.0) *1
One dual-card slot, support two Nano-SIM cards or Nano-SIM card + MicroSD card
Power Battery: 6600mAh/3.8V
Power Device Type: Type-c
Charging Voltage: 9V2A
Prije mjesec dana sam kupio i Npad S model, ok je za tu cijenu, on nema nikakav problem, mislim da ću ga prodati jer kod kupnje nisam vidio da nema 4G (SIM utor).
Ima 4+64GB i radi jednako brzo kao i 8GB model.
https://www.aliexpress.com/item/1005005719708985.html
Zadnje izmijenjeno od: Ag008. 17.08.2023. u 12:08.
Staro 17.08.2023., 13:59   #3
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,520
Ti tableti spadaju pod staru dobru kategoriju nisam dovoljno bogat da kupujem jeftino.
Bolje uzeti kakav S5E/S6 rabljeni, ili možda stariji iPad ako odgovara iOS.
P.S. za brzinu rada to da li tablet ima 4 ili 8 gb rama je potpuno svejedno, bitno je kakav tip flash memorije ima i kakav procesor je unutra.
Staro 17.08.2023., 14:00   #4
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,556
Kartman ti stvarno voliš opasno živjeti
Staro 17.08.2023., 14:57   #5
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,798
Autor Exy Pregled postova
Ili novi redmi pad, redmi pad se, realme pad...
Staro 17.08.2023., 15:05   #6
Ag008
Ag008's Avatar
Postovi: 7,483
Npad S ima Mediatekov osmojezgreni procesor, isti model kao iAmazonov tablet. (Kojeg prodajem)
Taj tablet mi se po performansama čini jednak kao puno skuplji s 8Gb npad pro kojeg zadržavam.
Dosta sam razočaran sa Unisoc procesorom, na papiru se činio puno bolji.
