Datum registracije: Dec 2014
Postovi: 243
![]() Eto, posjetio Ali i kupio ovo: N-one NPad X MTK G99 8-Cores Tablet PC Zbunilo me ovo sa 16 GB RAMa. U pitanju je nekakva hibridna tehnoologija kakvu do sada nisam sreo. Tablet ima 8 GB... Odmah nakon prvog pokretanja potjeran Google update. Evo što (djelomično, editirano) kaže Aida: AIDA64 for Android v1.94 Report <<< System >>> Manufacturer: N-one Model: Npad X Brand: N-one Board: tb8781p1_64 Device: TAB005 Hardware: mt8781 Platform: mt6789 Product: NpadX Installed RAM: 8 GB Total Memory: 7780 MB Available Memory: 3716 MB Internal Storage Total Space: 108.79 GB Internal Storage Free Space: 102.11 GB Bluetooth Version: 4+ <<< CPU >>> Core Architecture: 6x ARM Cortex-A55 @ 2000 MHz 2x ARM Cortex-A76 @ 2200 MHz Instruction Set: 64-bit ARMv8-A CPU Revision: r4p0 CPU Cores: 8 CPU Clock Range: 500 - 2200 MHz Core 1 Clock: 650 MHz Core 2 Clock: 650 MHz Core 3 Clock: 650 MHz Core 4 Clock: 650 MHz Core 5 Clock: 650 MHz Core 6 Clock: 650 MHz Core 7 Clock: 1300 MHz Core 8 Clock: 1300 MHz Supported ABIs: arm64-v8a, armeabi-v7a, armeabi Supported 32-bit ABIs: armeabi-v7a, armeabi Supported 64-bit ABIs: arm64-v8a AES: Supported ASIMD/NEON: Supported PMULL: Supported SHA1: Supported SHA2: Supported <<< Display >>> Screen Resolution: 1200 × 2000 Screen Size: 143 mm × 248 mm Screen Diagonal: 11.27 inches Pixel Density: 207 dpi (tvdpi) xdpi / ydpi: 213 / 205 dpi GPU Vendor: ARM GPU Renderer: Mali-G57 MC2 Refresh Rate: 60 Hz Default Orientation: Portrait OpenGL ES Version: 3.2 GPU Version: OpenGL ES 3.2 v1.r32p1-01eac0.394145956bc7cd8e697b330aba11e3d3 << Telephony >> Phone Type: GSM Network Operator Name: bonbon Network Operator Code: 21901 Network Operator Country: Croatia SIM Provider Name: bonbon SIM Provider Code: 21901 SIM Provider Country: Croatia SIM State: Ready Network Type: Unknown Data Connection State: Connected Data Activity: None Device Is Roaming: No ICC Card: Present << Wi-Fi >> State: Enabled SSID: BSSID: 02:00:00:00:00:00 Hidden SSID: No IPv4 Address: IPv6 Address: Signal Strength: -64 dBm (Very Good) Link Speed: 72 Mbps Frequency: 5200 MHz Gateway: Netmask: 255.255.255.0 DNS1: 83.139.103.3 DNS2: 83.139.121.8 DHCP Lease Duration: 168 hours 5 GHz Band: Supported Wi-Fi Aware: Not Supported Wi-Fi Direct: Supported <<< Battery >>> Power Source: Battery Level: 78 % Status: Discharging Health: Good Technology: Li-ion Temperature: 40.0°C Voltage: 4.077 V Charge Counter: 2297 mAh Discharge Rate: 405 mA Capacity (Reported by Android): 8600 mAh <<< Android >>> Android Version: 13 (Tiramisu) API Level: 33 Android Security Patch Level: 2023-03-05 Rooted Device: No Android ID: 28aa2f709492a3bb Baseband: MOLY.LR13.R2.MP.V79.5,MOLY.LR13.R2.MP.V79.5 Build ID: M100TB.MY.657-MMI.T0.CEM4X.8G.2023071712.B2EFFC9CA49.USER Codename: REL Fingerprint: N-one/NpadX/TAB005:13/TP1A.220624.014/1675771234:user/release-keys ID: TP1A.220624.014 Incremental: 1675771234 Java Runtime Version: Android Runtime 0.9 Java VM Version: ART 2.1.0 Java VM Heap Size: 256 MB Kernel Architecture: aarch64 Kernel Version: 5.10.149-android12-9-00031-g8d44cb1a9e42-ab9703858 Tags: release-keys Type: user Google Play Services Version: 23.30.13 (190400-552628474) Huawei Mobile Services Version: < Not Present > OpenSSL Version: OpenSSL 1.1.1 (compatible; BoringSSL) ZLib Version: 1.2.11 ICU CLDR Version: 40.0 ICU Library Version: 70.1 ICU Unicode Version: 14.0 Android Language: English (United Kingdom) Configured Time Zone: Central European Summer Time (UTC+02:00) UpTime: 00:52:24 Ukoliko imate pitanja prije nego ga nakrcam multimedijom (uglavnom e-books i video, nešto malo glazbe), pitajte. I budite malo strpljivi, ne "visim" cijelo vrijeme na forumu... |
RESPECT MY AUTHORITAH
Postovi: 7,473
Ja sam preko Aliexpressa za 130$ kupio N-One NPad Pro. Po specifikacijama odličan tablet, 2000x1000 FHD ekran, 8GB RAM-a, 128GB ROM, Android 12. Ekran je dosta taman, ne dobijam dojam da je toliko bolji, FHD, pozadina na početnom ekranu kako god se postavi bude pikselizirana. Iako ima 8GB RAM-a, Lenovo tablet s 3GB RAM-a radi brže ili jednako kao ovaj. Ima 18W QC punjenje, no nakon svega 3min punjenja, brzina punjenja pada na 5W ili 0W uz poruku da se baterija pregrijava!? Radi svega, dobio povrat od 20$ od Aliexpressa, razočaran. Na papiru jak osmojezgreni proc, puno RAM-a, odličan ekran, u stvarnosti veliki flop. OS: Android 12 CPU: Unisoc Tiger T616 Graphics Chip: G57 Storage RAM: 8GB Hard Disk Memory: 128GB Network WIFI: 802.11a/b/g/n/ac Band: 2.4GHz/5GHz Bluetooth: BT5.0 Camera Front Camera: 5MP Rear Camera: 13MP Connectivity Type-C(USB2.0) *1 One dual-card slot, support two Nano-SIM cards or Nano-SIM card + MicroSD card Power Battery: 6600mAh/3.8V Power Device Type: Type-c Charging Voltage: 9V2A ![]() Prije mjesec dana sam kupio i Npad S model, ok je za tu cijenu, on nema nikakav problem, mislim da ću ga prodati jer kod kupnje nisam vidio da nema 4G (SIM utor). Ima 4+64GB i radi jednako brzo kao i 8GB model. https://www.aliexpress.com/item/1005005719708985.html
. Zadnje izmijenjeno od: Ag008. 17.08.2023. u 12:08. |
Lokacija: Zagreb, Črnomerec
Postovi: 2,492
Ti tableti spadaju pod staru dobru kategoriju nisam dovoljno bogat da kupujem jeftino. Bolje uzeti kakav S5E/S6 rabljeni, ili možda stariji iPad ako odgovara iOS. P.S. za brzinu rada to da li tablet ima 4 ili 8 gb rama je potpuno svejedno, bitno je kakav tip flash memorije ima i kakav procesor je unutra. |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,472
Kartman ti stvarno voliš opasno živjeti ![]() |
#5 | |
Lokacija: Dalmacija
Postovi: 5,779
Ili novi redmi pad, redmi pad se, realme pad... |
Postovi: 7,473
Npad S ima Mediatekov osmojezgreni procesor, isti model kao iAmazonov tablet. (Kojeg prodajem) Taj tablet mi se po performansama čini jednak kao puno skuplji s 8Gb npad pro kojeg zadržavam. Dosta sam razočaran sa Unisoc procesorom, na papiru se činio puno bolji.
