Staro 19.07.2023., 11:08   #6361
Dottore
Dottore's Avatar
Postovi: 7,656
Autor mrva_zg Pregled postova
T14S g3, x1 carbon g8 T14 g2
Sve Inteli?
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 19.07.2023., 11:35   #6362
mrva_zg
mrva_zg's Avatar
Datum registracije: Feb 2010
Postovi: 948
Autor Dottore Pregled postova
Sve Inteli?
Da
Staro 19.07.2023., 17:18   #6363
domy_os
domy_os's Avatar
Postovi: 18,866
Jesi mu flasho bateriju.
Imali su neki update za power management da se ne budi iz standbya i da ne puni na docku
Mislim da jesam kad sam ga tek kupio, sad ništa ne nudi, sve je up to date.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 20.07.2023., 09:14   #6364
mrva_zg
mrva_zg's Avatar
Postovi: 948
i preko lenovo vantagea?
jer neke stvari ne ponudi preko win update-a
Staro 20.07.2023., 13:42   #6365
domy_os
domy_os's Avatar
Postovi: 18,866
Lenovo System Update koristim, a i preko weba sam sve dodatno checkirao.
Bio sam isključio modern standby i popratne servise, a Microsoft savjetuje da se nakon toga reinstaliraju Windowsi. Ne vidim razlog zbog čega, možda u tom grmu leži zec.
Staro 21.07.2023., 09:32   #6366
chillout23
Your God is in your mind.
chillout23's Avatar
Datum registracije: Jun 2017
Lokacija: Planet Earth
Postovi: 642
Nakon 2 (prislina - uzrok napisan ispod)) pražnjenja do kraja, primjetio sam sljedeće...
Kad se baterija napuni (nakon pražnjenja ide punjenje full ugašenog laptopa do kraja - bez paljenja) i upalim laptop, na office-internet mode-u (surfanje, word, YT...) traje nešto preko 4 sata, do nekih 20ak % baterije...i tu još piše da ima preko 1h korištenja.
Prvi put sam ga stavio u sleep mode na tom postotku i nakon par sati upalio...nakon 1 minute je baterija samo iscurila i ugasio se.
Drugi put, jučer poslije podne...opet upalio na 100% baterije, preko 4 sata istog korištenja i spustila se na 21%...pisalo još 1:15h. Ugasim ga oko 20:30, baš na Turn off.
Malo prije upalim, pokaže mi lock screen i samo se ugasi. Iscurila baterija opet do kraja.
Dakle, u radu je sve ok, ali čim ga stavim u sleep ili turn off, pocucla bateriju do kraja.
Jel neko imal sličnu situaciju, da mi može dat neki savjet?
Suludo mi je da se tak ponaša...
Mjesto rođenja: Zemlja, Rasa: čovjek, Politika: sloboda, Religija: ljubav
chillout23 je offline   Reply With Quote
Staro 21.07.2023., 09:46   #6367
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,553
Nema tu neke velike mudrosti ili savjeta koji će ti riješit problem, baterija ti ima skoro 400 ciklusa i izgubila je velik dio kapaciteta. Ta 4 sata koja dobivaš je zapravo pristojno za bateriju u ovom stanju, na tom modelu.
I da ga nisi stavio u sleep/shutdown bi ti sa tih 20% rapidno pala na par % i ugasio bi se, tako uvijek bude sa jako istrošenim baterijama. Meni je jedan Dell 5290 nakon 50% odmah padao na 2%
To što windowsi javljaju da može trajat još x sati možeš objesiti mačku o rep, javlja meni da bude trajala još jedan dan
Staro 21.07.2023., 10:01   #6368
chillout23
chillout23's Avatar
Postovi: 642
Ok...ma ne držim se za to preostalo vrijeme kak piše...ionak divlja na najjače ta informacija.
Bude 2 i pol sata, pa se digne na 5, pa padne na sat i pol, pa ide na 7 i pol sati ionda opet na 2 sata...baš sam pratil kroz korištenje kak se ponaša...
Gledam i svuda piše da je baterija 1 ova interna...a meni se čini ko da je vanjska...
Kaj nije logičnije da vanjska ima veći broj punjenja?
btw...320 ciklusa kroz 4 i pol godine je puno? Svakih preko 5 dana na punjač...prvi put stavljen u opticaj 21.12.2018.
Našo odgovor na moje pitanje na Redditu: " The internal battery gets used first, by design...yes seriously stupid."
Nakon tolko mozganja ga ipak uzmem i eto...
A htel sam laptop da mogu vadit/mjenjat bateriju po potrebi, da ima full HD ekran i da ima LAN port, a T480 je zadnji koji to ima...sa T460 sam imal loše iskustvo (crkla matična) i nisam ga htel opet uzet zbog paranoje...
I sad si mislim jel ga ostavit i L460 dat na bubanj ili odma T480 dat na bubanj :/
Zadnje izmijenjeno od: chillout23. 21.07.2023. u 10:27.
Staro 21.07.2023., 11:14   #6369
Daten
Daten's Avatar
Postovi: 401
Autor chillout23 Pregled postova
Mislim da ti je rješenje da kupiš novu internu bateriju ako ti je baš potrebno da si na bateriji više od 4h.
Vanjska baterija se čini ok, ima 120 ciklusa trebala bi biti dobra.
Imam 2 laptopa T480 i kod mene se isto prazni prvo interna baterija pa onda eksterna, i meni je to isto glupo..
Ako ti je baš potrebna dobra baterija, možeš kao i ja kupiti onu najveću eksternu bateriju za T480 ( mislim da je oznaka 61++ ) koja ima 72 Wh. S njom i ispravnom internom baterijom možeš cijeli dan biti na bateriji
Daten je offline   Reply With Quote
Staro 21.07.2023., 11:18   #6370
chillout23
chillout23's Avatar
Postovi: 642
Autor Daten Pregled postova
Ne treba mi više od 4h na L460 mi traje oko 1 ipol do 2h ova manja, a veća i 4 sata...
Znam to i mislim da ću s vremenom tak i napravit...ali budem vidio sad još koji dan kak će se ponašat, pa ću odlučit kaj i kak
Hvala
Staro 21.07.2023., 11:38   #6371
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Umjesto da mozgaš i tražiš par dana po netu koja je koja, izvadi tu napaćenu vanjsku bateriju pa vidi u sustavu koje nema, odnosno koja je ostala - 1 ili 2.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 21.07.2023., 13:15   #6372
chillout23
chillout23's Avatar
Postovi: 642
ne mozgam više, shvatio sve...uz to, našao sam di je jedan dečko baš to napravio...meni nije palo na pamet prije
Staro 21.07.2023., 13:54   #6373
medo
#erase startup-config
medo's Avatar
Postovi: 3,714
Yup, tako je i na mojem T470 nažalost. Užasno glupo. Ideja powerbridge tehnologije je da možeš izvaditi eksternu bateriju bez da umre laptop. Teško ćeš u tome uspjeti ako interna baterija ima 2% ili 5% pogotovo ako je laptop opterećen.
Pokušao sam TLP-om u Linuxu nešto napraviti po tom pitanju ali bez uspjeha. Ispalo je da embedded controler (EC) kontrolira punjenje. Trebalo bi ga reprogramirati. Good luck with that. EC ima Lenovo proprietary firmware.
Staro 21.07.2023., 19:54   #6374
chillout23
chillout23's Avatar
Postovi: 642
Autor medo Pregled postova
Da, nevjerojatno su to složili hahaha
Imal sam jedan HP da uzmem ili T480 i odlučim ipak za Lenovo...ipak derem po njima već jako dugo, iako nisam power user...ali ok sad, kaj je tu je...samo kaj mi nova interna nosi popriličan trošak, ak se nastavi ovak ponašat, a dal sam maksimum koji sam mogo za "novi" laptop...samo da ne ispadne da mi to i nije baš trebalo
Staro 22.07.2023., 11:18   #6375
tetak dudo
tetak dudo's Avatar
Lokacija: 45.594-16.217
Postovi: 239
X 220
kad ste vidjeli zadnji puta novi x220,evo nabasao na novi (skoro) ali bez adaptera pa neznam stanje dok ne nabavim adapter. Po suportu je i5 2520
hd 320gb,4gb ram mislim da je win 7 pro još na njemu
ID:	26493   Click image for larger version
ID:	26494   Click image for larger version
Dell OptiPlex Micro
ThinkPad T470
tetak dudo je offline   Reply With Quote
Staro 22.07.2023., 11:40   #6376
strikoo
strikoo's Avatar
Postovi: 967
Autor tetak dudo Pregled postova
zavist na max
držim fige, iako ne sumnjam, da sve radi
strikoo je offline   Reply With Quote
Staro 22.07.2023., 12:58   #6377
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,217
zgleda super, al zast je to tak posebno? pitam info radi, da naucim.
geronimo_2 je online   Reply With Quote
Staro 22.07.2023., 13:05   #6378
tetak dudo
tetak dudo's Avatar
Postovi: 239
iskreno ni ja neznam,ali predpostavljam da su prva tj.druga serija sa intel procesorima I serije plus mnogo hvaljena tipkovnica al ima tu strućnijih kolega od mene pa bu neko odgovoril
Dell OptiPlex Micro
ThinkPad T470
Staro 22.07.2023., 14:31   #6379
geronimo_2
geronimo_2's Avatar
Postovi: 4,217
a da, vidi se da je tipkovnica ona "prava". takva je na prastarom nekom ibm thinkpadu kojeg mi stari ima jos negdje pohranjenog u ormaru. ima valjda 20ak g. mislim da je p4 unutra.
Staro 23.07.2023., 08:15   #6380
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Tipkovnica i eksterna baterija. To su dva glavna aduta.
Spoiler alert!
Staro 23.07.2023., 13:31   #6381
Exy
Exy's Avatar
Postovi: 2,553
Nažalost, tipkovnice postaju iz modela u model sve lošije. I dalje su bolje od konkurencije, ako ništa drugo
X220 je bio zanimljiv jer nema ultra low power cpu nego punokrvni sandy bridge, zapravo je trebalo dosta vremena da ga nasljednici prestignu u performansama, low power dual core cpu-i tipa 4300U (iz x240 npr.) mu nisu bili ni do koljena. Jasno, danas je ipak riječ o dobrano zastarjelom debelom i teškom (za veličinu ekrana) modelu, kojeg ultraprijenosnici počevši sa kaby lake-om (X280) gaze po pitanju brzine, težine, trajanja baterije itd.
Jedino je tipkovnica i dalje bolja jer Lenovo inzistira neprestano na smanjenju debljine pa i po cijenu kraćeg hoda tipki, ukidanja redova i mijenjanja rasporeda...
Meni izgleda potpuno očuvano i nekorišteno.
Kako misliš adapter? Nisam razumio.
Vjerojatno misli na punjač
Zadnje izmijenjeno od: Exy. 23.07.2023. u 13:45.
Staro 23.07.2023., 13:42   #6382
Dottore
Dottore's Avatar
Postovi: 7,656
@De5tr0yer
T490, T495 T14G1 i G2 koriste potpuno istu tipkovnicu kao T480s, ista tipkovnica se može koristiti na svim ovim modelima:
T14 G1, T14 G2, T480s, E480, L490, L480, E490, P43s, P14s G1/G2, T490, T495, i eventualno neka druga L ili E serija
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 23.07.2023., 16:14   #6383
tetak dudo
tetak dudo's Avatar
Postovi: 239
@De5tr0yer
nabavio punjač,laptop je imao pasword windowsa 7 pa nisam mogao ući da vidim koliko ima sati rada,sad sam stavio novi ssd 500gb i win 10 i imal sam doma još 2gb rama ddr3 tako da sada ima 6gb rama,moram se još poigrat sa baterijom bila mi pokazivala i onda sam ažurilal power manager i sad mi govori da nema baterije(nešto sam zeznul)
inaće mali radi i izgleda ko ispod čekića
Dell OptiPlex Micro
ThinkPad T470
Staro 23.07.2023., 17:06   #6384
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,165
brzinsko pitanje
koi od ovih modela bi bio najbolji deal za mene kao laganog korisnika.
znaci surf/gledanje serija.
cijena oko 400 eura
x280
t490s
x1 carbon g6 ili g7
Zadnje izmijenjeno od: Gemmy. 23.07.2023. u 17:17.
Staro 23.07.2023., 18:29   #6385
Exy
Exy's Avatar
Postovi: 2,553
Pa nisu to baš neki multimedija strojevi ali ako ćeš surfati i gledati serije baš na laptopu, znači koristit ćeš thinkpadov ekran i thinkpadove zvučnike onda je izbor lak. X280 ima 12,5" ekran, dok t490s i carbon imaju 14".
T490s i carbon g6/g7 su relativno slični laptopi, sa tim da je carbon lakši nekih 200 grama.
T490S i carbon G6 imaju iste jadne piskutave zvučnike, dok G7 carbon ima dosta jak audio upgrade (u biti generacijski g6->g7 najveći upgrade) u vidu 4 zvučnika umjesto 2 i to zvuči jako dobro za jedan business ultraportable.
Staro 23.07.2023., 18:53   #6386
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,165
ali, ali... uvjek sam htio thinkpada
za njih sam cuo da su vjecni pa zato gledam
imam lenovo g700 koji mi je preglomazan za teglit stalno na dosao, a ne igram se vise na njemu, pa gledam nesto manje/lakse
na poslu se spajam na 22" monitor, a doma na kaucu bi sluzio kao tablet, posto imam glavni PC, i koji je spojen na TV i monitor
jel ima jos sta dobro za do 500 eura polovno od konkurencije?
Staro 23.07.2023., 19:20   #6387
Exy
Exy's Avatar
Postovi: 2,553
Aha, to bi služilo i za posao, ne samo za multimediju. Nisam rekao da to nisu dobri strojčeki, ali za ovo što opisuješ (tablet na kauču) baš i nisu optimalna stvar. Za to je optimalan tablet , i to po mogućnosti amoled tablet.
Ako je prenosivost bitna za nositi na posao pa spajati na vanjski ekran a doma slušati i gledati serije, uzmi onda carbona g7. Vječni jesu bili, nekada
Staro 23.07.2023., 19:25   #6388
Dottore
Dottore's Avatar
Postovi: 7,656
Autor Gemmy Pregled postova
Od konkurencije nemamo baš pozitivno.
T490s i X1 Carbon gen 6/7 su Intel CPU.
T495s je AMD CPU i najsličniji T490s po izgledu. Samo što moraš paziti zalemljenu količinu memorije. Nemaš mogućnost nadogradnje osm NVME diska. U 2023 godini 8Gb će postati tijesno i upitno. 16Gb će sasvim dobro raditi.
Ako želiš jedan slot memorije slobodan, gledaš isključivo T490 . Samo što T14 Gen 1 ide van tvog budžeta.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 23.07.2023., 22:57   #6389
chillout23
chillout23's Avatar
Postovi: 642
Da, baš sam nezadovoljan ponašanjem baterija na T480
Kad ga upalim (nakon turn offa i sa punom baterijom) i ne gasim ga, odradi oko 5 sati bez problema.
Ako ga stavim na sleep ili turn off, neovisno koliko je vremena bio upaljen, prvo sljedeće paljenje se gasi nakon maksimalno par minuta...i sa baterijom preko 60%
Ne shvaćam kak je moguće da je tolko pocucla u sleepu ili turn offu...
Na L460 bar znam da mi manja baterija radi oko 2 sata i ova veća oko 4 sata i mir...nema nikakvih trzavica niti ničega....a tu ne mogu nikaj ni započet pošteno i već se gasi frajer..
Odlučil sam da ide i on i L460 na bubanj, pa koji prvi ode...sad bi najradije da se rješim T480.
A ako ode prvo L460, jel može preporuka di uzet novu original internu bateriju? Vjerojatno bi onda te novce uložil u novu bateriju...ili čak baterije, da uzmem i vanjsku novu ako bude i s njom problema...
Zadnje izmijenjeno od: chillout23. 23.07.2023. u 23:11.
Staro 24.07.2023., 10:35   #6390
Dottore
Dottore's Avatar
Postovi: 7,656
Baterija može biti stara, a i kada ima mali gubitak kapaciteta. Jesi li možda vidio fizičko stanje baterije - nabubrenja? Pošalji mail u Zel-Cos raspoložive baterije. Jesi li apdejtao bios?
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
