Staro 15.04.2023., 16:08   #6511
the.elles.d
Datum registracije: Jul 2010
Postovi: 546
Autor strikoo Pregled postova
Imas revanced manager na githubu
pa sam specas YT
Nudi 50+ opcija. Ima li ikava lista što poklikati da bude kao yt vanced?
the.elles.d je online   Reply With Quote
Staro 16.04.2023., 09:45   #6512
D.O.M.I.
D.O.M.I.'s Avatar
Datum registracije: Jul 2009
Postovi: 279
Prekjučer mi crko Vanced pa sam napravio sve po ovim uputama i ReVanced dela bez greške.
https://www.reddit.com/r/revancedapp...e_for_dummies/
D.O.M.I. je offline   Reply With Quote
Staro 16.04.2023., 17:07   #6513
Dottore
Dottore's Avatar
Postovi: 7,653
Vjerujema da neki nisu ažurirali na zadnji MicroG pa je javilo problem.
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 16.04.2023., 22:46   #6514
axo
Datum registracije: Sep 2017
Postovi: 1,428
Autor D.O.M.I. Pregled postova
Zahvaljujem
Staro 17.04.2023., 20:13   #6515
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,196
pozdrav.
dali postoji neka aplikacija kojom mogu neke aplikacije disable-ati privremeno. mob nije root-an (Xiaomi A2). nekad davno na rootanim mobovima sam koristio titanium.
imam FX file manager instaliran na mobu i vidim da ima neku mogucnost "disable package", ali i baci ogromno upozorenje za to. jel to cemu?
disable-ao bi viber, signal, sykpe, whatsapp, google authenticator i aquamail.
Staro 17.04.2023., 20:31   #6516
Postovi: 10,095
Koliko cesto moras/zelis paliti/gasiti te appove? Sve to mozes s kompa preko adb komandi, ali je bezveze ako to radis vise od jednom dnevno.
https://www.xda-developers.com/unins...t-root-access/
Mozes ti napraviti i bat skriptu na kompu pa umjesto da upisujes x naredbi, lijepo spojis mob, pokrenes skriptu i disejbla ti appove. S drugom skriptom/setom naredbi ih upalis.
Staro 17.04.2023., 20:32   #6517
geronimo_2
geronimo_2's Avatar
Postovi: 4,196
ma ne. rjetko. to mi je backup mob, ap ikad zatreba ko sto je sad trenutno jer sam glavni mob spickao. al taj mob koriste i drugi ukucani pa kad ga njima dam u ruke zelim ove appove disable.
edit: ovo navedeno gore u FX-u sma probao i nemere, isto treba root :-(
koja glupost da nema u opcijama od moba da te neke non system app mozes temp disable. glupost.
a nemam vremana sad ic kopat satima i danima kako root-at taj mob samo da to mogu napravit.
Zadnje izmijenjeno od: geronimo_2. 17.04.2023. u 20:58.
Staro 19.04.2023., 04:26   #6518
Postovi: 33,982
Postoji li neki downloader manager koji podržava premium accounte (k2s, rapidgator & co.) slično JDownloaderu na Winsima?
Staro 20.04.2023., 10:53   #6519
nepalac
Datum registracije: Feb 2022
Lokacija: EU
Postovi: 830
Evo i meni Vanced prestao raditi, ne može otvoriti ni jedan video.
Morat ću se pozabavit s tim ReVancedom.
NewPipe mi je ok ali više mi paše Vanced sučelje pa ćemo vidjeti.
Staro 20.04.2023., 11:38   #6520
xXTheLuka1998xX
xXTheLuka1998xX's Avatar
Datum registracije: Feb 2015
Postovi: 353
Autor nepalac Pregled postova
Revanced sam i ja instalirao po ovom linku gore,ima istu ikonicu ko klasični yt ,al sve iste funkcionalnosti ko vanced.
Poslano sa mog SM-G996B koristeći Tapatalk
xXTheLuka1998xX je offline   Reply With Quote
Staro 20.04.2023., 22:54   #6521
nepalac
Lokacija: EU
Postovi: 830
Instalirao sam i ja ReVanced ali odmah uočavam jedan problem.
Aplikacija mi ne pamti pretragu.
Nisam logiran i ne želim biti, ali na starom Vancedu sve što sam pretraživao bi mi ostalo, a to mi je dosta korisno.
Pa ako netko zna riješenje...
P.S. I ne, nisam pauzirao povijest pretrage u postavkama.
Staro 21.04.2023., 09:32   #6522
okarm
Postovi: 772
instalirao i ja revanced, sve radi ok ali imam jedan problem koji nisam imao s vanced appom. imam galaxy sat i sada svaki put kad na mobu gledam nesto na revanced ili yt appu, na satu mi se aktivira music app i mogu upravljati s videom kojeg gledam.
problem je sto cak ako i to ne koristim on je aktivan u pozadini i brutalno trosi bateriju. pokusavao sam naci neku opciju koju bih iskljucio ali bez uspjeha. tako da trenutno na mobu imam iskljucen bt ako gledam yt.
Staro 21.04.2023., 13:43   #6523
tomasini_
tomasini_'s Avatar
Lokacija: Usa
Postovi: 1,164
da li stvarno whatsapp pop obavijesti nisu moguće na androidu 10? probao sam nekoliko googlanih savjeta ali i dalje kaže da ništa od obavijesti na desetki. kako je to moguće?
divovski kompjuteri
tomasini_ je offline   Reply With Quote
Staro 21.04.2023., 14:18   #6524
axo
Postovi: 1,428
Microg zadnjih 7 dana koristi 1.4 %, revanced 1.1 al baš i ne gledam na mobu yt i to na a53 5g.
Uključen BTW stalno, 120hz na revancedu itd.
Staro 29.04.2023., 11:50   #6525
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,833
Ata ce ti 120 na revancedu ako nema videa priko 60
Meni na revancedu ne radi automatsko pauziranje videa nakon x min, osim ako nije upaljen ekran, na premiumu mi to radi
Staro 29.04.2023., 12:14   #6526
AndroiOs
AndroiOs's Avatar
Datum registracije: Jan 2018
Lokacija: KA
Postovi: 574
A pusti ti to
Mora revanced ispast pametniji izbor od nas glupih koji plaćamo premium koji je naravno bolji i ispravniji
Poslano sa mog SM-G991B koristeći Tapatalk
AndroiOs je offline   Reply With Quote
Staro 29.04.2023., 12:53   #6527
nepalac
Lokacija: EU
Postovi: 830
Ne bih youtube plaćao ni da košta 1 lipu.
Moj izbor, najviše zato što ne želim uopće koristit YT dok sam logiran, a ni ne želim uopće biti vezan za google usluge više nego što moram.
Tako da ne kužim čemu stalno isticanje kako postoji neki indijski/turski/kirgistanski YT account za 1.4$... who gives s fuck - neću plaćati.
Dakle, ReVanced je zakon, ima neke mušice ali popeglat će se to, većinom radi savršeno...
Staro 29.04.2023., 15:57   #6528
Postovi: 10,095
Bolje spomenuti kirgistanski primijum nego da se netko lud zaleti i plati hrvatski primijum
Staro 29.04.2023., 20:02   #6529
locks
Datum registracije: Mar 2010
Lokacija: Vukovar
Postovi: 3,608
Imam ReVanced i stari Vanced koji rade kako treba. Da plaćam korporacijama koje se valjaju u novcima, ne pada mi na pamet, pa makar bilo i 1 cent...
Staro 01.05.2023., 12:59   #6530
Deamon101
Deamon101's Avatar
Postovi: 694
Pozdrav svima i sretan Prvi maj. te obljetnica Bljeska.
Zna li netko kako obrisati sms poruka sve odjednom?
Aplikacija dopušta samo selektiranje, pa brisanje, a poruka ima 5 godina
Hvala svima.
edit > uspio preko Honor suite.
Zadnje izmijenjeno od: Deamon101. 01.05.2023. u 14:44.
Deamon101 je offline   Reply With Quote
Staro 23.05.2023., 08:42   #6531
Buger
Postovi: 4,390
Gdje skidate zadnju verziju Youtube Revanceda? Vidim da ima više stranica..
Staro 23.05.2023., 08:46   #6532
strikoo
strikoo's Avatar
Postovi: 964
Autor Buger Pregled postova
github revanced manager i sam zbildaš
strikoo je offline   Reply With Quote
Staro 23.05.2023., 08:48   #6533
Buger
Postovi: 4,390
Ajd mi ovo zbildaš objasni
Staro 23.05.2023., 10:25   #6534
locks
Lokacija: Vukovar
Postovi: 3,608
Ja skinem gotov apk, instaliram i sve radi....
Staro 23.05.2023., 11:14   #6535
Neo-ST
Neo-ST's Avatar
Postovi: 8,369
Autor locks Pregled postova
Samo pazi odakle skidaš, da netko ne uvali trojan u taj apk, pa i njega instaliraš...
Staro 23.05.2023., 11:27   #6536
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,245
Ma kakvo bildanje, skini i instaliraj
https://revancedextended.com/
Staro 29.05.2023., 15:21   #6537
okarm
Postovi: 772
ono sto sam ja primjetio je da revanced zdere bateriju puno vise od starod vanceda.
Staro 29.05.2023., 19:33   #6538
Dottore
Dottore's Avatar
Postovi: 7,653
Na koji revanced misliš? Do sada nisam primjetio brzo trošenje.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 20.06.2023., 19:08   #6539
c-shadow
c-shadow's Avatar
Postovi: 3,479
Preporuke za dobar android file manager?
Uvjet mi je da ima dobru podršku za konekcije na ssh i samba server.
Poželjno da je s 2 panela
Koristio sam godinama x-plore međutim šteka u oba zahtjeva i izgleda da autor ne misli to ažurirati.
Staro 20.06.2023., 19:27   #6540
Postovi: 10,095
Root explorer ako su ti tabovi oke. Probao preci na x-plore i fx ali nikako. Na tvu mi je xplore top, na mobu ipak root explorer
