Staro 11.03.2023., 15:52   #1231
Dottore
Dottore's Avatar
Postovi: 7,638
I tako Adata SX8200 Pro nema već 5 godina firmware i health ostao na 95%
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 11.03.2023., 16:33   #1232
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,824
Autor Dottore Pregled postova
Eto, u Adati su dostigli savršenstvo s tim diskom i njegovim firmwareom
Staro 11.03.2023., 17:00   #1233
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,551
@kopija
Jesi li primjetio WD SN850/x postali best buy u zadnje vrijeme nakon 980pro/990pro? Svi portali preporučuju WD jer nemaju problema. Mašala.
Je, baš je jučer bilo i na prvom dnevniku HTV-a.
Ima da Samsung bankrotira u kratkom roku zbog aljkavog QC, kažu.
Staro 11.03.2023., 17:06   #1234
d0X
Kostolomac
d0X's Avatar
Postovi: 1,481
Autor Sinac Pregled postova
Tako da j€b€sh disk za koji ne trebaš njegov utility.
Fali ti jedan /s na kraju.
PSN Steam
Staro 11.03.2023., 20:17   #1235
domy_os
domy_os's Avatar
Postovi: 18,847
Pa nema ni moj 970 Evo Plus 2 TB nijedan novi firmware u 4-5 godina koliko ga imam. Imam još par Samsunga i nigdje updatea, malo mi to čudno...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 11.03.2023., 21:32   #1236
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,404
Autor kopija Pregled postova
Nema problema. Kolko para tolko muzike.
Ja bih ti preporučio da ne kupuješ ništa, A2000 500gb je čist pristojan disk povelikog kapaciteta za sistem/igrice. Nećeš primjetiti nikakvu razliku u brzini s NV2.
Baracuda za sve ostalo.
Primjećujem da se masa ljudi odjednom pomamila za novim diskovima ne zato što im trebaju nego zato što su im pale cijene.
Donirajte rađe pare Ukrajini.
Oke, malo sam razmislio, ajde neću uzeti 2TB SSD i mijenjati ovaj koji imam, nego bi uzeo još jedan dodatni od 1TB i ugradio ga na ovaj drugi M.2 slot na matičnoj, ali nemam pojma koja je razlika između ta dva slota i kad gledam SSD-ove, kako znam koji ide u jedan, a koji u drugi slot?
Evo npr. ovaj WD koji si mi ti preporučio, ide li on u taj drugi M.2 slot: https://www.nabava.net/ssd-disk/wd-b...jena-187491731
Uzimam sigurno nešto, volim imati više toga instaliranog na PC-u i živcira me kad moram nešto brisati jer nemam mjesta.
Hala Madrid!
Staro 12.03.2023., 07:03   #1237
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,551
Zaboravi na drugi slot, to bi bilo ko da ferrari voziš po makadamu.
1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module
Osim ako ga misliš koristiti za storage gdje ta SATA3 brzina neće biti problem.
Znači, prvi slot OS/programi/igrice, drugi slot filmovi.
Staro 12.03.2023., 08:49   #1238
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,404
A da uzmem obični 2.5 SSD?
Hala Madrid!
Staro 12.03.2023., 09:54   #1239
Facelessone
Facelessone's Avatar
Postovi: 4,204
Isto Sata3 brzina kak i na tom drugom slotu
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 12.03.2023., 10:04   #1240
popo1
Postovi: 228
Ja bi na tvojem mjestu uzeo ovo
https://www.adm.hr/orico-m2-nvme-to-...63349/product/
i upiknuo u to neki PCIe 4.0 NVMe SSD, danas sutra uzmeš novu matičnu i imaš disk za nju
popo1 je offline   Reply With Quote
Staro 12.03.2023., 13:13   #1241
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,551
Ne, nemoj ništa kupovati.
Strpi se do ljeta. Cijene drastično padaju.
Tada za današnju cijenu "hendikepiranog" NV2 uzmi npr. 2TB SN570.
Možda ćeš čak i primjetiti razliku u brzini naspram ovog A2000.
Bez kompromisa riješenje, samo malo strpljenja treba.
Staro 12.03.2023., 14:13   #1242
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,404
Ok, hvala svima na preporukama, za sad odustajem od kupovine tj. slušam kolegu kopija
Hala Madrid!
Staro 13.03.2023., 23:31   #1243
Warrior
Warrior's Avatar
Postovi: 1,012
Pitanjce, imam sistemski SSD ADATA SX8200PNP te mi HDD Sentinel kaže da ima 16,1TB Lifetime writes od 07.01.2020. To mi se čini puno. Koliko uopće ovaj SSD ima "pisanja" dok ne rikne?
Nekako mi se čini da će brzo propasti. Ili?
Everything is sooooo slow... Why? Oh, why?
Warrior je offline   Reply With Quote
Staro 13.03.2023., 23:37   #1244
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,510
SX8200 od 1TB ima endurance 640TB pa sam procijeni je li 16TB puno.
Staro 13.03.2023., 23:50   #1245
Postovi: 10,031
U tri godine to je nista.
Moj je kupljen u 9.2020 i ima 11,5 TB zapisano (sistemac+aplikacije+igre+dokumenti, znaci sve). TBW ovisi o kapacitetu. Imam onu seriju koja je imala bolji kontroler prije nego su poceli fusariti, a vjerojatno je i tvoj takav. Negdje u doba kad sam ga kupio su bas poceli s tim promjenama.
Provjeri stanje i s Adata SSD Toolboxom.
256 GB ima 160 TBW
512 GB ima 320 TBW
1 TB ima 640 TBW
2 TB ima 1280 TBW
Staro 14.03.2023., 17:29   #1246
nepalac
Datum registracije: Feb 2022
Lokacija: EU
Postovi: 826
Koji NVMe je bolji:
Samsung 980 500GB (MZ-V8V500BW)
ili
Samsung 970 EVO Plus 500GB (MZ-V7S500BW)
Staro 14.03.2023., 19:25   #1247
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,551
Pridjevi "dobar, bolji najbolji" više nisu primjenjivi na Samsung proizvode. Vidi par stranica unazad.
Ako te zanima koji je gori, pitaj.
Staro 14.03.2023., 19:34   #1248
Dottore
Dottore's Avatar
Postovi: 7,638
Autor Warrior Pregled postova
Tvoj će umrijeti prije mog
Autor nepalac Pregled postova
Koji NVMe je bolji:
ili
980 ima Pablo kontroler ali mrvicu sporiji write i najveća prednost što manje cucla struje i manje grije - idealan za laptope. Uvjerio sam svojim očima sa 1Tb
Pablito 500gb po R/W ide 3,100 MB/s / 2600 MB/s
970 EVO Plus , ovisi koji naletiš. Prva generacija je brzi Phoenix kontroler , a sve je prisutniji Elpis (takav ima u 980 pro). Ekipa sa reddita i youtube kunu da druga generacija usporenija,a tehničke podatke su isto prepisivali od Phoenixa (kao da nema promjene)
Za Phoenix ide sigurno 3,500 MB/s / 3,200 MB/s. Epis na papiru isto kao Phoenix ali po testovima usporeniji ,više zagrije i throtla u većem zapisu
Link
Phoenix 500gb
Elpis 500gb
Yes, Samsung Is Swapping SSD Parts Too
Moja preporuka da nađeš sa Phoenix kontrolerom, najbolje je da vidiš uživo je li zapravo horizontalno pakiranje. Samo ga zgrabi.
Ja sam naletio na Phoenixa 2x 500Gb za 500kn i nikada nisam bio sretniji.
Trenutno jedan kuca na Lenovo X1 Yoga Gen 2.
Staro 14.03.2023., 19:45   #1249
nepalac
Lokacija: EU
Postovi: 826
To će biti malo teže, kupujem online, ali vjerovatno tih starijih kontrolera ni nema više po trgovinama nego su svi sad ovi lošiji.
A ništa, vidjet ću još malo, nije da sam neki power user pa mi neće puno smetati ni lošija verzija, a možda čak uzmem i ovaj običan 980, čak mi se sada čini kao bolja opcija.
Ali šteta šta svi nešto muljaju pa čak i samsung.
Uglavnom, thnx na iscrpnom odgovoru.
Staro 15.03.2023., 07:54   #1250
Warrior
Warrior's Avatar
Postovi: 1,012
Autor xlr Pregled postova
Zato i pitam. Ti imaš apsolutno sve na SSD-u i imaš manje pisanja od mene koji imam samo Win10 na SSD-u.
Ali ovom dinamikom bi trebao izdržati najmanje 96 godina. Nadam se da do tada neće drastično poskupiti SSD-ovi.
Ili da već sada kupim zamjenski pa sam siguran kada ovaj rikne?
Poslano s mog Samsung S21 Ultra koristeći Tapatalk
Staro 15.03.2023., 08:25   #1251
Postovi: 10,031
Nisam napisao mozda bitnu stvar u ovom slucaju - meni komp radi par sati na dan, ako i toliko. Sve redovno updejtam, Steam, Win... samo ga slabo koristim
Zadnje izmijenjeno od: xlr. 15.03.2023. u 08:47.
Staro 15.03.2023., 11:22   #1252
Dottore
Dottore's Avatar
Postovi: 7,638
Ne sekiraj se, proći će još barem 10 godina ako u međuvremenu mjenjaš OS, redoviti update, download materijala..
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 18.03.2023., 15:09   #1253
Postovi: 8,217
Sveopće i generalno NVMe s(r)tanje.
Fake Samsung 980 PRO SSDs
Counterfeit Samsung 980 Pro SSDs have seemingly entered the Asian PC market with several users affected by these fake storage devices. The Firmware and storage device name have been tampered with to make it show as a Samsung 980 Pro SSD but in reality, it offers far less read and write speeds than what the 980 Pro is capable of. The SSD only managed around 4.8 GB/s Reads and 4.4 GB/s Write speeds which are well below the 7.0 GB/s and 5.1 GB/s (Read / Write) speeds of the drive. The SSD even has the properly labeled sticker of the Samsung 980 Pro 2 TB device but it's under the sticker where everything is wrong. The controller has the Maxio branding which is produced over in China. Do remember that Samsung produces its controllers entirely at its own fabrication facilities in South Korea. Furthermore, the Maxio "MAP1602-I" drives stated here comes with a DRAM-less design but they do support PCIe Gen 4 NVMe 2.0 standard.
Izvor: OC3D
Staro 20.03.2023., 17:01   #1254
Getriba
Postovi: 234
Može mi netko reći može li NVMe, instaliran na PCIe adapter, služiti kao OS disk? Odnosno, hoće li ga matična prepoznati kao bootable drive?
Razmišljam uzeti ovo što je popo1 preporučio u svom post-u plus neki malo bolji drive, tipa Kingston KC3000.
Da, mogu uzeti SSD većeg kapaciteta i olakšati si, ali sam znatiželjan kako bi navedena kombinacija o kojoj razmišljam funkcionirala. Također si mogu onda iskoristiti taj disk kad ću piknuti novi komp nekad u drugoj polovici godine.
Getriba je offline   Reply With Quote
Staro 20.03.2023., 17:27   #1255
Dottore
Dottore's Avatar
Postovi: 7,638
Ne znam kakav je kontroler, imam predosjećaj da prilikom bootanja instalacije windowsa neće odmah prepoznati disk i treba ubaciti drivere da raspozna disk. ( ovisiti će koji je OS)
Drugi problem koliko će pcie sabrnica podnijeti iz ploče. Računaj da Kingston KC3000 radi na PCIe 4.0a raditi će na adapteru ograničeno ispod PCIe 3.0
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 20.03.2023., 17:31   #1256
domy_os
domy_os's Avatar
Postovi: 18,847
Autor Getriba Pregled postova
Može, možda ćeš trebati samo modificirati BIOS, meni radi normalno kao boot disk na Z68 chipsetu.
Staro 20.03.2023., 18:48   #1257
Postovi: 23,518
Treba provjeriti iskustva po netu za konkretnu mobo, eventualno provjeriti support / Bios update i jeli dodan support za boot sa Nvme diska.
Po defaultu ga često nema u tim starijim chipsetima.
Alternative:
- sami boot loader na nekom sata stirage + da onda on "zove" os na Nvme
- zeznututija varijanda je raditi custom varijantu biosa da se doda modul za boot sa Nvme
Staro 20.03.2023., 19:56   #1258
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
______________________________________________________________
Ne znam koju matičnu imaš, ali ako je novija platforma nebi trebalo bit problema.
Ja imam ICY-BOX "RAIDSONIC IB-PCI215M2" PCIe karticu (cca. 22 Eur)za dva M2 diska, dolazi sa hladnjacima i thermal padovima (hrpa njih)..
upiknut je WD RED SN700 od 500GB, vidi ga u Biosu bez problema. Matična je ASUS B-550F Wifi II.
I da moraš paziti u koji slot češ ubost takvu karticu zbog brzine, je obično PCI-e slotovi imaju sherani bandwidth. Za punu brzinu moraš imati slot sa aktivne 4 PCIe linije.. pogledaj u manual od matične. LP..
https://icybox.de/en/product.php?id=367
Staro 20.03.2023., 19:57   #1259
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,849
Gledam 970 evo plus i 980 pro što ću kupovat evo plus kad je 980 pro 100 kuna skuplji a brži,mađare izbacio.
https://www.nabava.net/ssd-disk/sams...-sata-82800371
https://www.nabava.net/ssd-disk/sams...nvme-141012581
znam da su 2 Tb idealno bi bilo 2 x 2 Tb i izbacit komplet ssd-ove
Zadnje izmijenjeno od: demetrius. 20.03.2023. u 20:08.
Staro 20.03.2023., 20:00   #1260
BusMaster
BusMaster's Avatar
Postovi: 343
PS. Zaboravio napisat, za taj kontroler netrebaš nikakav driver, čak ga ni Bios ne prijavljuje na ekranu, kao npr. standardne Raid kontrolere i sl.... Windowsi ga isto prepoznaju nativno.
