E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
Nvidia Quadro/RTX series
Samo kratak info, prije izvjesnog vremena ubacio sam dva fantasticna nVidia produkta, low-end Quadroice bazirane na Pascalu, P400 (najslabija) verzija, puta dva. Cijenom su mi bile i vise nego pogodne, ne trose skoro nista, i ne cuju se kada ne treba. 3x mini DP, gutaju i DP, i DVI (pa samim time i HDMI), i VGA. Samo malo podataka, fotki i slicno. ![]() ![]() Code:
hashcat (v3.40) starting in benchmark mode... * Device #1: Not a native Intel OpenCL runtime, expect massive speed loss You can use --force to override this but do not post error reports if you do so * Device #2: WARNING! Kernel exec timeout is not disabled, it might cause you errors of code CL_OUT_OF_RESOURCES See the wiki on how to disable it: https://hashcat.net/wiki/doku.php?id=timeout_patch * Device #3: WARNING! Kernel exec timeout is not disabled, it might cause you errors of code CL_OUT_OF_RESOURCES See the wiki on how to disable it: https://hashcat.net/wiki/doku.php?id=timeout_patch nvmlDeviceGetPowerManagementLimit(): Not Supported nvmlDeviceGetPowerManagementLimit(): Not Supported OpenCL Platform #1: Advanced Micro Devices, Inc. ================================================ * Device #1: Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz, skipped OpenCL Platform #2: NVIDIA Corporation ====================================== * Device #2: Quadro P400, 512/2048 MB allocatable, 2MCU * Device #3: Quadro P400, 512/2048 MB allocatable, 2MCU Hashtype: MD4 Speed.Dev.#2.....: 2477.6 MH/s (54.07ms) Speed.Dev.#3.....: 2537.5 MH/s (52.73ms) Speed.Dev.#*.....: 5015.2 MH/s Hashtype: MD5 Speed.Dev.#2.....: 1448.5 MH/s (92.54ms) Speed.Dev.#3.....: 1484.5 MH/s (90.22ms) Speed.Dev.#*.....: 2933.0 MH/s Hashtype: Half MD5 Speed.Dev.#2.....: 958.8 MH/s (69.91ms) Speed.Dev.#3.....: 979.8 MH/s (68.32ms) Speed.Dev.#*.....: 1938.6 MH/s Hashtype: SHA1 Speed.Dev.#2.....: 531.1 MH/s (63.08ms) Speed.Dev.#3.....: 545.0 MH/s (61.40ms) Speed.Dev.#*.....: 1076.1 MH/s Hashtype: SHA256 Speed.Dev.#2.....: 206.2 MH/s (80.94ms) Speed.Dev.#3.....: 211.6 MH/s (78.76ms) Speed.Dev.#*.....: 417.8 MH/s Hashtype: SHA384 Speed.Dev.#2.....: 69899.6 kH/s (59.85ms) Speed.Dev.#3.....: 71274.8 kH/s (58.65ms) Speed.Dev.#*.....: 141.2 MH/s Hashtype: SHA512 Speed.Dev.#2.....: 70650.4 kH/s (59.15ms) Speed.Dev.#3.....: 73033.5 kH/s (57.21ms) Speed.Dev.#*.....: 143.7 MH/s Hashtype: SHA-3(Keccak) Speed.Dev.#2.....: 57256.0 kH/s (73.06ms) Speed.Dev.#3.....: 58897.1 kH/s (70.92ms) Speed.Dev.#*.....: 116.2 MH/s Hashtype: SipHash Speed.Dev.#2.....: 1896.7 MH/s (70.62ms) Speed.Dev.#3.....: 1951.1 MH/s (68.53ms) Speed.Dev.#*.....: 3847.9 MH/s Hashtype: Skip32 Speed.Dev.#2.....: 396.0 MH/s (42.16ms) Speed.Dev.#3.....: 421.0 MH/s (39.66ms) Speed.Dev.#*.....: 816.9 MH/s Hashtype: RipeMD160 Speed.Dev.#2.....: 315.9 MH/s (52.82ms) Speed.Dev.#3.....: 320.7 MH/s (51.32ms) Speed.Dev.#*.....: 636.5 MH/s Hashtype: Whirlpool Speed.Dev.#2.....: 16698.8 kH/s (125.49ms) Speed.Dev.#3.....: 17245.2 kH/s (121.42ms) Speed.Dev.#*.....: 33944.0 kH/s Hashtype: GOST R 34.11-94 Speed.Dev.#2.....: 15845.2 kH/s (132.27ms) Speed.Dev.#3.....: 16316.1 kH/s (128.31ms) Speed.Dev.#*.....: 32161.3 kH/s Hashtype: GOST R 34.11-2012 (Streebog) 256-bit Speed.Dev.#2.....: 3311.2 kH/s (312.83ms) Speed.Dev.#3.....: 3416.5 kH/s (303.09ms) Speed.Dev.#*.....: 6727.6 kH/s Hashtype: GOST R 34.11-2012 (Streebog) 512-bit Speed.Dev.#2.....: 3314.6 kH/s (312.51ms) Speed.Dev.#3.....: 3419.2 kH/s (302.86ms) Speed.Dev.#*.....: 6733.7 kH/s Hashtype: DES (PT = $salt, key = $pass) Speed.Dev.#2.....: 1322.2 MH/s (50.44ms) Speed.Dev.#3.....: 1362.6 MH/s (48.95ms) Speed.Dev.#*.....: 2684.8 MH/s Hashtype: 3DES (PT = $salt, key = $pass) Speed.Dev.#2.....: 38603.4 kH/s (54.24ms) Speed.Dev.#3.....: 39880.5 kH/s (52.38ms) Speed.Dev.#*.....: 78483.9 kH/s Hashtype: phpass, MD5(Wordpress), MD5(phpBB3), MD5(Joomla) Speed.Dev.#2.....: 454.7 kH/s (70.54ms) Speed.Dev.#3.....: 475.2 kH/s (67.92ms) Speed.Dev.#*.....: 929.9 kH/s Hashtype: scrypt Speed.Dev.#2.....: 57169 H/s (17.23ms) Speed.Dev.#3.....: 58609 H/s (16.67ms) Speed.Dev.#*.....: 115.8 kH/s Hashtype: PBKDF2-HMAC-MD5 Speed.Dev.#2.....: 503.0 kH/s (63.43ms) Speed.Dev.#3.....: 518.9 kH/s (61.71ms) Speed.Dev.#*.....: 1021.9 kH/s Hashtype: PBKDF2-HMAC-SHA1 Speed.Dev.#2.....: 222.5 kH/s (60.58ms) Speed.Dev.#3.....: 228.4 kH/s (58.87ms) Speed.Dev.#*.....: 450.9 kH/s Hashtype: PBKDF2-HMAC-SHA256 Speed.Dev.#2.....: 81696 H/s (45.39ms) Speed.Dev.#3.....: 84643 H/s (83.97ms) Speed.Dev.#*.....: 166.3 kH/s Hashtype: PBKDF2-HMAC-SHA512 Speed.Dev.#2.....: 30476 H/s (62.56ms) Speed.Dev.#3.....: 31386 H/s (60.69ms) Speed.Dev.#*.....: 61861 H/s Hashtype: Skype Speed.Dev.#2.....: 851.0 MH/s (78.77ms) Speed.Dev.#3.....: 874.4 MH/s (76.56ms) Speed.Dev.#*.....: 1725.3 MH/s Hashtype: WPA/WPA2 Speed.Dev.#2.....: 27359 H/s (74.44ms) Speed.Dev.#3.....: 28183 H/s (72.29ms) Speed.Dev.#*.....: 55542 H/s Hashtype: IKE-PSK MD5 Speed.Dev.#2.....: 114.4 MH/s (73.16ms) Speed.Dev.#3.....: 119.7 MH/s (69.99ms) Speed.Dev.#*.....: 234.0 MH/s Hashtype: IKE-PSK SHA1 Speed.Dev.#2.....: 52769.0 kH/s (78.94ms) Speed.Dev.#3.....: 54724.6 kH/s (76.38ms) Speed.Dev.#*.....: 107.5 MH/s Hashtype: NetNTLMv1-VANILLA / NetNTLMv1+ESS Speed.Dev.#2.....: 1433.4 MH/s (93.54ms) Speed.Dev.#3.....: 1476.4 MH/s (90.77ms) Speed.Dev.#*.....: 2909.7 MH/s Hashtype: NetNTLMv2 Speed.Dev.#2.....: 107.6 MH/s (77.82ms) Speed.Dev.#3.....: 110.7 MH/s (75.56ms) Speed.Dev.#*.....: 218.4 MH/s Hashtype: IPMI2 RAKP HMAC-SHA1 Speed.Dev.#2.....: 114.3 MH/s (73.29ms) Speed.Dev.#3.....: 117.1 MH/s (71.48ms) Speed.Dev.#*.....: 231.4 MH/s Hashtype: Kerberos 5 AS-REQ Pre-Auth etype 23 Speed.Dev.#2.....: 19158.7 kH/s (54.47ms) Speed.Dev.#3.....: 20104.2 kH/s (104.11ms) Speed.Dev.#*.....: 39262.8 kH/s Hashtype: Kerberos 5 TGS-REP etype 23 Speed.Dev.#2.....: 19133.2 kH/s (54.55ms) Speed.Dev.#3.....: 20077.4 kH/s (104.26ms) Speed.Dev.#*.....: 39210.5 kH/s Hashtype: DNSSEC (NSEC3) Speed.Dev.#2.....: 223.0 MH/s (74.84ms) Speed.Dev.#3.....: 230.4 MH/s (72.31ms) Speed.Dev.#*.....: 453.5 MH/s Hashtype: PostgreSQL Challenge-Response Authentication (MD5) Speed.Dev.#2.....: 389.0 MH/s (86.08ms) Speed.Dev.#3.....: 401.2 MH/s (83.43ms) Speed.Dev.#*.....: 790.2 MH/s Hashtype: MySQL Challenge-Response Authentication (SHA1) Speed.Dev.#2.....: 155.0 MH/s (53.97ms) Speed.Dev.#3.....: 160.1 MH/s (52.12ms) Speed.Dev.#*.....: 315.2 MH/s Hashtype: SIP digest authentication (MD5) Speed.Dev.#2.....: 130.1 MH/s (64.38ms) Speed.Dev.#3.....: 134.0 MH/s (62.40ms) Speed.Dev.#*.....: 264.1 MH/s Hashtype: SMF > v1.1 Speed.Dev.#2.....: 453.1 MH/s (73.95ms) Speed.Dev.#3.....: 465.4 MH/s (71.88ms) Speed.Dev.#*.....: 918.5 MH/s Hashtype: vBulletin < v3.8.5 Speed.Dev.#2.....: 456.2 MH/s (73.46ms) Speed.Dev.#3.....: 469.5 MH/s (71.26ms) Speed.Dev.#*.....: 925.7 MH/s Hashtype: vBulletin > v3.8.5 Speed.Dev.#2.....: 316.3 MH/s (52.74ms) Speed.Dev.#3.....: 325.3 MH/s (51.20ms) Speed.Dev.#*.....: 641.6 MH/s Hashtype: IPB2+, MyBB1.2+ Speed.Dev.#2.....: 327.7 MH/s (50.90ms) Speed.Dev.#3.....: 336.2 MH/s (49.50ms) Speed.Dev.#*.....: 663.9 MH/s Hashtype: WBB3, Woltlab Burning Board 3 Speed.Dev.#2.....: 89235.4 kH/s (93.83ms) Speed.Dev.#3.....: 91825.6 kH/s (91.09ms) Speed.Dev.#*.....: 181.1 MH/s Hashtype: OpenCart Speed.Dev.#2.....: 140.3 MH/s (59.70ms) Speed.Dev.#3.....: 144.1 MH/s (58.03ms) Speed.Dev.#*.....: 284.4 MH/s Hashtype: Joomla < 2.5.18 Speed.Dev.#2.....: 1446.5 MH/s (92.68ms) Speed.Dev.#3.....: 1489.0 MH/s (89.97ms) Speed.Dev.#*.....: 2935.5 MH/s Hashtype: PHPS Speed.Dev.#2.....: 456.7 MH/s (73.37ms) Speed.Dev.#3.....: 470.0 MH/s (71.21ms) Speed.Dev.#*.....: 926.7 MH/s Hashtype: Drupal7 Speed.Dev.#2.....: 3739 H/s (67.66ms) Speed.Dev.#3.....: 3856 H/s (65.61ms) Speed.Dev.#*.....: 7594 H/s Hashtype: osCommerce, xt:Commerce Speed.Dev.#2.....: 849.4 MH/s (78.84ms) Speed.Dev.#3.....: 873.5 MH/s (76.62ms) Speed.Dev.#*.....: 1722.9 MH/s Hashtype: PrestaShop Speed.Dev.#2.....: 565.2 MH/s (59.29ms) Speed.Dev.#3.....: 580.4 MH/s (57.65ms) Speed.Dev.#*.....: 1145.5 MH/s Hashtype: Django (SHA-1) Speed.Dev.#2.....: 452.9 MH/s (73.95ms) Speed.Dev.#3.....: 465.7 MH/s (71.85ms) Speed.Dev.#*.....: 918.6 MH/s Hashtype: Django (PBKDF2-SHA256) Speed.Dev.#2.....: 4100 H/s (50.60ms) Speed.Dev.#3.....: 4237 H/s (49.05ms) Speed.Dev.#*.....: 8337 H/s Hashtype: Mediawiki B type Speed.Dev.#2.....: 421.9 MH/s (79.44ms) Speed.Dev.#3.....: 434.3 MH/s (77.13ms) Speed.Dev.#*.....: 856.2 MH/s Hashtype: Redmine Project Management Web App Speed.Dev.#2.....: 183.1 MH/s (91.14ms) Speed.Dev.#3.....: 188.6 MH/s (88.38ms) Speed.Dev.#*.....: 371.8 MH/s Hashtype: PunBB Speed.Dev.#2.....: 183.1 MH/s (91.16ms) Speed.Dev.#3.....: 188.6 MH/s (88.43ms) Speed.Dev.#*.....: 371.7 MH/s Hashtype: PostgreSQL Speed.Dev.#2.....: 1447.3 MH/s (92.62ms) Speed.Dev.#3.....: 1487.0 MH/s (89.98ms) Speed.Dev.#*.....: 2934.3 MH/s Hashtype: MSSQL(2000) Speed.Dev.#2.....: 546.9 MH/s (61.24ms) Speed.Dev.#3.....: 562.4 MH/s (59.50ms) Speed.Dev.#*.....: 1109.3 MH/s Hashtype: MSSQL(2005) Speed.Dev.#2.....: 546.5 MH/s (61.31ms) Speed.Dev.#3.....: 562.5 MH/s (59.49ms) Speed.Dev.#*.....: 1109.0 MH/s Hashtype: MSSQL(2012) Speed.Dev.#2.....: 67866.2 kH/s (61.64ms) Speed.Dev.#3.....: 69676.9 kH/s (59.98ms) Speed.Dev.#*.....: 137.5 MH/s Hashtype: MySQL323 Speed.Dev.#2.....: 3165.3 MH/s (84.71ms) Speed.Dev.#3.....: 3262.1 MH/s (82.08ms) Speed.Dev.#*.....: 6427.4 MH/s Hashtype: MySQL4.1/MySQL5 Speed.Dev.#2.....: 248.0 MH/s (67.27ms) Speed.Dev.#3.....: 254.8 MH/s (65.43ms) Speed.Dev.#*.....: 502.8 MH/s Hashtype: Oracle H: Type (Oracle 7+) Speed.Dev.#2.....: 67205.6 kH/s (62.06ms) Speed.Dev.#3.....: 68921.7 kH/s (60.41ms) Speed.Dev.#*.....: 136.1 MH/s Hashtype: Oracle S: Type (Oracle 11+) Speed.Dev.#2.....: 529.6 MH/s (63.26ms) Speed.Dev.#3.....: 546.2 MH/s (61.26ms) Speed.Dev.#*.....: 1075.8 MH/s Hashtype: Oracle T: Type (Oracle 12+) Speed.Dev.#2.....: 7506 H/s (67.94ms) Speed.Dev.#3.....: 7707 H/s (66.18ms) Speed.Dev.#*.....: 15212 H/s Hashtype: Sybase ASE Speed.Dev.#2.....: 19181.3 kH/s (53.92ms) Speed.Dev.#3.....: 19626.6 kH/s (52.67ms) Speed.Dev.#*.....: 38807.9 kH/s Hashtype: EPiServer 6.x < v4 Speed.Dev.#2.....: 457.9 MH/s (73.19ms) Speed.Dev.#3.....: 465.8 MH/s (71.86ms) Speed.Dev.#*.....: 923.8 MH/s Hashtype: EPiServer 6.x > v4 Speed.Dev.#2.....: 185.9 MH/s (89.79ms) Speed.Dev.#3.....: 189.3 MH/s (88.13ms) Speed.Dev.#*.....: 375.2 MH/s Hashtype: md5apr1, MD5(APR), Apache MD5 Speed.Dev.#2.....: 684.8 kH/s (94.01ms) Speed.Dev.#3.....: 697.8 kH/s (92.17ms) Speed.Dev.#*.....: 1382.7 kH/s Hashtype: ColdFusion 10+ Speed.Dev.#2.....: 121.1 MH/s (69.21ms) Speed.Dev.#3.....: 122.6 MH/s (68.29ms) Speed.Dev.#*.....: 243.6 MH/s Hashtype: hMailServer Speed.Dev.#2.....: 185.9 MH/s (89.79ms) Speed.Dev.#3.....: 189.3 MH/s (88.11ms) Speed.Dev.#*.....: 375.2 MH/s Hashtype: SHA-1(Base64), nsldap, Netscape LDAP SHA Speed.Dev.#2.....: 535.7 MH/s (62.48ms) Speed.Dev.#3.....: 546.3 MH/s (61.24ms) Speed.Dev.#*.....: 1082.1 MH/s Hashtype: SSHA-1(Base64), nsldaps, Netscape LDAP SSHA Speed.Dev.#2.....: 535.6 MH/s (62.49ms) Speed.Dev.#3.....: 545.6 MH/s (61.22ms) Speed.Dev.#*.....: 1081.2 MH/s Hashtype: SSHA-256(Base64), LDAP {SSHA256} Speed.Dev.#2.....: 208.0 MH/s (80.21ms) Speed.Dev.#3.....: 212.0 MH/s (78.58ms) Speed.Dev.#*.....: 420.0 MH/s Hashtype: SSHA-512(Base64), LDAP {SSHA512} Speed.Dev.#2.....: 71706.9 kH/s (58.33ms) Speed.Dev.#3.....: 73173.3 kH/s (57.08ms) Speed.Dev.#*.....: 144.9 MH/s Hashtype: LM Speed.Dev.#2.....: 1331.4 MH/s (50.10ms) Speed.Dev.#3.....: 1358.9 MH/s (48.99ms) Speed.Dev.#*.....: 2690.3 MH/s Hashtype: NTLM Speed.Dev.#2.....: 2492.5 MH/s (53.74ms) Speed.Dev.#3.....: 2540.2 MH/s (52.67ms) Speed.Dev.#*.....: 5032.6 MH/s Hashtype: Domain Cached Credentials (DCC), MS Cache Speed.Dev.#2.....: 724.5 MH/s (92.52ms) Speed.Dev.#3.....: 737.1 MH/s (90.77ms) Speed.Dev.#*.....: 1461.6 MH/s Hashtype: Domain Cached Credentials 2 (DCC2), MS Cache 2 Speed.Dev.#2.....: 22367 H/s (71.31ms) Speed.Dev.#3.....: 22907 H/s (69.84ms) Speed.Dev.#*.....: 45274 H/s Hashtype: MS-AzureSync PBKDF2-HMAC-SHA256 Speed.Dev.#2.....: 783.8 kH/s (69.42ms) Speed.Dev.#3.....: 803.7 kH/s (67.87ms) Speed.Dev.#*.....: 1587.6 kH/s Hashtype: descrypt, DES(Unix), Traditional DES Speed.Dev.#2.....: 65275.8 kH/s (63.99ms) Speed.Dev.#3.....: 66420.0 kH/s (62.63ms) Speed.Dev.#*.....: 131.7 MH/s Hashtype: BSDiCrypt, Extended DES Speed.Dev.#2.....: 102.4 kH/s (105.83ms) Speed.Dev.#3.....: 104.4 kH/s (103.91ms) Speed.Dev.#*.....: 206.8 kH/s Hashtype: md5crypt, MD5(Unix), FreeBSD MD5, Cisco-IOS MD5 Speed.Dev.#2.....: 685.9 kH/s (93.95ms) Speed.Dev.#3.....: 697.9 kH/s (92.23ms) Speed.Dev.#*.....: 1383.7 kH/s Hashtype: bcrypt, Blowfish(OpenBSD) Speed.Dev.#2.....: 1030 H/s (30.14ms) Speed.Dev.#3.....: 1053 H/s (29.46ms) Speed.Dev.#*.....: 2083 H/s Hashtype: sha256crypt, SHA256(Unix) Speed.Dev.#2.....: 25854 H/s (62.61ms) Speed.Dev.#3.....: 26386 H/s (61.36ms) Speed.Dev.#*.....: 52239 H/s Hashtype: sha512crypt, SHA512(Unix) Speed.Dev.#2.....: 11094 H/s (74.29ms) Speed.Dev.#3.....: 11329 H/s (72.76ms) Speed.Dev.#*.....: 22423 H/s Hashtype: OSX v10.4, v10.5, v10.6 Speed.Dev.#2.....: 456.5 MH/s (73.42ms) Speed.Dev.#3.....: 466.3 MH/s (71.80ms) Speed.Dev.#*.....: 922.8 MH/s Hashtype: OSX v10.7 Speed.Dev.#2.....: 63220.5 kH/s (66.20ms) Speed.Dev.#3.....: 64304.7 kH/s (64.92ms) Speed.Dev.#*.....: 127.5 MH/s Hashtype: OSX v10.8+ Speed.Dev.#2.....: 873 H/s (67.77ms) Speed.Dev.#3.....: 898 H/s (66.31ms) Speed.Dev.#*.....: 1771 H/s Hashtype: AIX {smd5} Speed.Dev.#2.....: 685.1 kH/s (93.94ms) Speed.Dev.#3.....: 697.6 kH/s (92.12ms) Speed.Dev.#*.....: 1382.7 kH/s Hashtype: AIX {ssha1} Speed.Dev.#2.....: 3177.0 kH/s (72.84ms) Speed.Dev.#3.....: 3239.7 kH/s (71.40ms) Speed.Dev.#*.....: 6416.7 kH/s Hashtype: AIX {ssha256} Speed.Dev.#2.....: 1143.5 kH/s (53.71ms) Speed.Dev.#3.....: 1168.1 kH/s (52.58ms) Speed.Dev.#*.....: 2311.6 kH/s Hashtype: AIX {ssha512} Speed.Dev.#2.....: 460.3 kH/s (67.42ms) Speed.Dev.#3.....: 469.1 kH/s (65.92ms) Speed.Dev.#*.....: 929.4 kH/s Hashtype: Cisco-PIX MD5 Speed.Dev.#2.....: 1070.5 MH/s (62.58ms) Speed.Dev.#3.....: 1091.9 MH/s (61.35ms) Speed.Dev.#*.....: 2162.4 MH/s Hashtype: Cisco-ASA MD5 Speed.Dev.#2.....: 1091.0 MH/s (61.43ms) Speed.Dev.#3.....: 1111.0 MH/s (60.25ms) Speed.Dev.#*.....: 2202.0 MH/s Hashtype: Cisco-IOS SHA256 Speed.Dev.#2.....: 208.2 MH/s (80.17ms) Speed.Dev.#3.....: 212.2 MH/s (78.57ms) Speed.Dev.#*.....: 420.4 MH/s Hashtype: Cisco $8$ Speed.Dev.#2.....: 4156 H/s (50.04ms) Speed.Dev.#3.....: 4218 H/s (49.06ms) Speed.Dev.#*.....: 8374 H/s Hashtype: Cisco $9$ Speed.Dev.#2.....: 886 H/s (576.93ms) Speed.Dev.#3.....: 905 H/s (565.10ms) Speed.Dev.#*.....: 1791 H/s Hashtype: Juniper Netscreen/SSG (ScreenOS) Speed.Dev.#2.....: 842.4 MH/s (79.56ms) Speed.Dev.#3.....: 859.7 MH/s (77.86ms) Speed.Dev.#*.....: 1702.1 MH/s Hashtype: Juniper IVE Speed.Dev.#2.....: 684.8 kH/s (93.98ms) Speed.Dev.#3.....: 698.0 kH/s (92.07ms) Speed.Dev.#*.....: 1382.8 kH/s Hashtype: Android PIN Speed.Dev.#2.....: 370.4 kH/s (87.33ms) Speed.Dev.#3.....: 378.0 kH/s (85.47ms) Speed.Dev.#*.....: 748.5 kH/s Hashtype: Citrix NetScaler Speed.Dev.#2.....: 495.5 MH/s (67.61ms) Speed.Dev.#3.....: 505.5 MH/s (66.28ms) Speed.Dev.#*.....: 1001.0 MH/s Hashtype: RACF Speed.Dev.#2.....: 179.6 MH/s (93.32ms) Speed.Dev.#3.....: 184.5 MH/s (90.73ms) Speed.Dev.#*.....: 364.1 MH/s Hashtype: GRUB 2 Speed.Dev.#2.....: 3058 H/s (67.66ms) Speed.Dev.#3.....: 3132 H/s (66.32ms) Speed.Dev.#*.....: 6191 H/s Hashtype: Radmin2 Speed.Dev.#2.....: 534.4 MH/s (62.71ms) Speed.Dev.#3.....: 546.4 MH/s (61.22ms) Speed.Dev.#*.....: 1080.8 MH/s Hashtype: SAP CODVN B (BCODE) Speed.Dev.#2.....: 175.7 MH/s (94.96ms) Speed.Dev.#3.....: 178.8 MH/s (93.23ms) Speed.Dev.#*.....: 354.5 MH/s Hashtype: SAP CODVN F/G (PASSCODE) Speed.Dev.#2.....: 76288.3 kH/s (109.84ms) Speed.Dev.#3.....: 77884.3 kH/s (107.55ms) Speed.Dev.#*.....: 154.2 MH/s Hashtype: SAP CODVN H (PWDSALTEDHASH) iSSHA-1 Speed.Dev.#2.....: 415.4 kH/s (77.83ms) Speed.Dev.#3.....: 423.5 kH/s (76.26ms) Speed.Dev.#*.....: 838.9 kH/s Hashtype: Lotus Notes/Domino 5 Speed.Dev.#2.....: 14385.8 kH/s (143.79ms) Speed.Dev.#3.....: 14503.5 kH/s (144.50ms) Speed.Dev.#*.....: 28889.4 kH/s Hashtype: Lotus Notes/Domino 6 Speed.Dev.#2.....: 4764.0 kH/s (109.91ms) Speed.Dev.#3.....: 4861.6 kH/s (107.62ms) Speed.Dev.#*.....: 9625.6 kH/s Hashtype: Lotus Notes/Domino 8 Speed.Dev.#2.....: 45594 H/s (71.07ms) Speed.Dev.#3.....: 46485 H/s (69.70ms) Speed.Dev.#*.....: 92080 H/s Hashtype: PeopleSoft Speed.Dev.#2.....: 552.0 MH/s (60.69ms) Speed.Dev.#3.....: 562.5 MH/s (59.47ms) Speed.Dev.#*.....: 1114.5 MH/s Hashtype: PeopleSoft PS_TOKEN Speed.Dev.#2.....: 217.4 MH/s (76.78ms) Speed.Dev.#3.....: 221.4 MH/s (75.29ms) Speed.Dev.#*.....: 438.8 MH/s Hashtype: 7-Zip Speed.Dev.#2.....: 625 H/s (49.15ms) Speed.Dev.#3.....: 653 H/s (95.37ms) Speed.Dev.#*.....: 1278 H/s Hashtype: WinZip Speed.Dev.#2.....: 75944 H/s (49.01ms) Speed.Dev.#3.....: 77390 H/s (48.06ms) Speed.Dev.#*.....: 153.3 kH/s Hashtype: RAR3-hp Speed.Dev.#2.....: 2487 H/s (51.21ms) Speed.Dev.#3.....: 2578 H/s (49.33ms) Speed.Dev.#*.....: 5065 H/s Hashtype: RAR5 Speed.Dev.#2.....: 2512 H/s (50.04ms) Speed.Dev.#3.....: 2570 H/s (48.98ms) Speed.Dev.#*.....: 5082 H/s Hashtype: AxCrypt Speed.Dev.#2.....: 7716 H/s (215.85ms) Speed.Dev.#3.....: 7903 H/s (211.04ms) Speed.Dev.#*.....: 15620 H/s Hashtype: AxCrypt in memory SHA1 Speed.Dev.#2.....: 514.1 MH/s (65.13ms) Speed.Dev.#3.....: 524.9 MH/s (63.80ms) Speed.Dev.#*.....: 1039.0 MH/s Hashtype: TrueCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit Speed.Dev.#2.....: 18724 H/s (51.93ms) Speed.Dev.#3.....: 19111 H/s (50.90ms) Speed.Dev.#*.....: 37834 H/s Hashtype: TrueCrypt PBKDF2-HMAC-SHA512 + XTS 512 bit Speed.Dev.#2.....: 28810 H/s (61.42ms) Speed.Dev.#3.....: 29390 H/s (60.22ms) Speed.Dev.#*.....: 58199 H/s Hashtype: TrueCrypt PBKDF2-HMAC-Whirlpool + XTS 512 bit Speed.Dev.#2.....: 2382 H/s (211.55ms) Speed.Dev.#3.....: 2441 H/s (206.38ms) Speed.Dev.#*.....: 4823 H/s Hashtype: TrueCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit + boot-mode Speed.Dev.#2.....: 35678 H/s (48.85ms) Speed.Dev.#3.....: 36387 H/s (47.91ms) Speed.Dev.#*.....: 72064 H/s Hashtype: VeraCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit Speed.Dev.#2.....: 31 H/s (53.17ms) Speed.Dev.#3.....: 31 H/s (52.12ms) Speed.Dev.#*.....: 62 H/s Hashtype: VeraCrypt PBKDF2-HMAC-SHA512 + XTS 512 bit Speed.Dev.#2.....: 31 H/s (67.16ms) Speed.Dev.#3.....: 62 H/s (65.82ms) Speed.Dev.#*.....: 93 H/s Hashtype: VeraCrypt PBKDF2-HMAC-Whirlpool + XTS 512 bit Speed.Dev.#2.....: 0 H/s (213.33ms) Speed.Dev.#3.....: 0 H/s (208.71ms) Speed.Dev.#*.....: 0 H/s Hashtype: VeraCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit + boot-mode Speed.Dev.#2.....: 93 H/s (53.19ms) Speed.Dev.#3.....: 93 H/s (52.15ms) Speed.Dev.#*.....: 186 H/s Hashtype: VeraCrypt PBKDF2-HMAC-SHA256 + XTS 512 bit Speed.Dev.#2.....: 62 H/s (53.25ms) Speed.Dev.#3.....: 62 H/s (52.14ms) Speed.Dev.#*.....: 124 H/s Hashtype: VeraCrypt PBKDF2-HMAC-SHA256 + XTS 512 bit + boot-mode Speed.Dev.#2.....: 186 H/s (53.24ms) Speed.Dev.#3.....: 186 H/s (52.09ms) Speed.Dev.#*.....: 372 H/s Hashtype: Android FDE <= 4.3 Speed.Dev.#2.....: 56209 H/s (71.96ms) Speed.Dev.#3.....: 57411 H/s (70.51ms) Speed.Dev.#*.....: 113.6 kH/s Hashtype: Android FDE (Samsung DEK) Speed.Dev.#2.....: 20298 H/s (49.02ms) Speed.Dev.#3.....: 20761 H/s (47.94ms) Speed.Dev.#*.....: 41060 H/s Hashtype: eCryptfs Speed.Dev.#2.....: 928 H/s (66.52ms) Speed.Dev.#3.....: 962 H/s (65.21ms) Speed.Dev.#*.....: 1890 H/s Hashtype: MS Office <= 2003 MD5 + RC4, oldoffice$0, oldoffice$1 Speed.Dev.#2.....: 15138.0 kH/s (69.09ms) Speed.Dev.#3.....: 15438.3 kH/s (67.63ms) Speed.Dev.#*.....: 30576.4 kH/s Hashtype: MS Office <= 2003 MD5 + RC4, collision-mode #1 Speed.Dev.#2.....: 21390.5 kH/s (97.77ms) Speed.Dev.#3.....: 22107.0 kH/s (94.63ms) Speed.Dev.#*.....: 43497.5 kH/s Hashtype: MS Office <= 2003 SHA1 + RC4, oldoffice$3, oldoffice$4 Speed.Dev.#2.....: 20085.4 kH/s (104.20ms) Speed.Dev.#3.....: 20547.2 kH/s (101.77ms) Speed.Dev.#*.....: 40632.5 kH/s Hashtype: MS Office <= 2003 SHA1 + RC4, collision-mode #1 Speed.Dev.#2.....: 22165.4 kH/s (94.51ms) Speed.Dev.#3.....: 22632.7 kH/s (92.42ms) Speed.Dev.#*.....: 44798.2 kH/s Hashtype: Office 2007 Speed.Dev.#2.....: 8994 H/s (74.23ms) Speed.Dev.#3.....: 9153 H/s (72.81ms) Speed.Dev.#*.....: 18147 H/s Hashtype: Office 2010 Speed.Dev.#2.....: 4483 H/s (74.27ms) Speed.Dev.#3.....: 4553 H/s (72.80ms) Speed.Dev.#*.....: 9035 H/s Hashtype: Office 2013 Speed.Dev.#2.....: 622 H/s (66.16ms) Speed.Dev.#3.....: 625 H/s (64.81ms) Speed.Dev.#*.....: 1247 H/s Hashtype: PDF 1.1 - 1.3 (Acrobat 2 - 4) Speed.Dev.#2.....: 22742.7 kH/s (91.99ms) Speed.Dev.#3.....: 23266.0 kH/s (89.89ms) Speed.Dev.#*.....: 46008.7 kH/s Hashtype: PDF 1.1 - 1.3 (Acrobat 2 - 4) + collider-mode #1 Speed.Dev.#2.....: 24669.3 kH/s (84.89ms) Speed.Dev.#3.....: 25201.8 kH/s (82.99ms) Speed.Dev.#*.....: 49871.1 kH/s Hashtype: PDF 1.4 - 1.6 (Acrobat 5 - 8) Speed.Dev.#2.....: 1111.7 kH/s (57.00ms) Speed.Dev.#3.....: 1134.8 kH/s (55.71ms) Speed.Dev.#*.....: 2246.4 kH/s Hashtype: PDF 1.7 Level 3 (Acrobat 9) Speed.Dev.#2.....: 207.7 MH/s (80.32ms) Speed.Dev.#3.....: 212.1 MH/s (78.57ms) Speed.Dev.#*.....: 419.8 MH/s Hashtype: PDF 1.7 Level 8 (Acrobat 10 - 11) Speed.Dev.#2.....: 2390 H/s (356.64ms) Speed.Dev.#3.....: 2480 H/s (343.69ms) Speed.Dev.#*.....: 4870 H/s Hashtype: Password Safe v2 Speed.Dev.#2.....: 20188 H/s (24.34ms) Speed.Dev.#3.....: 19148 H/s (25.96ms) Speed.Dev.#*.....: 39336 H/s Hashtype: Password Safe v3 Speed.Dev.#2.....: 81584 H/s (49.86ms) Speed.Dev.#3.....: 83242 H/s (48.85ms) Speed.Dev.#*.....: 164.8 kH/s Hashtype: Lastpass Speed.Dev.#2.....: 157.5 kH/s (51.02ms) Speed.Dev.#3.....: 159.4 kH/s (50.38ms) Speed.Dev.#*.....: 316.9 kH/s Hashtype: 1Password, agilekeychain Speed.Dev.#2.....: 223.8 kH/s (71.42ms) Speed.Dev.#3.....: 229.8 kH/s (69.70ms) Speed.Dev.#*.....: 453.6 kH/s Hashtype: 1Password, cloudkeychain Speed.Dev.#2.....: 742 H/s (67.54ms) Speed.Dev.#3.....: 777 H/s (66.16ms) Speed.Dev.#*.....: 1519 H/s Hashtype: Bitcoin/Litecoin wallet.dat Speed.Dev.#2.....: 309 H/s (66.54ms) Speed.Dev.#3.....: 311 H/s (65.21ms) Speed.Dev.#*.....: 620 H/s Hashtype: Blockchain, My Wallet Speed.Dev.#2.....: 5500.4 kH/s (23.63ms) Speed.Dev.#3.....: 5639.9 kH/s (23.20ms) Speed.Dev.#*.....: 11140.3 kH/s Hashtype: Keepass 1 (AES/Twofish) and Keepass 2 (AES) Speed.Dev.#2.....: 9148 H/s (152.05ms) Speed.Dev.#3.....: 9353 H/s (148.80ms) Speed.Dev.#*.....: 18500 H/s Hashtype: ArubaOS Speed.Dev.#2.....: 457.6 MH/s (73.23ms) Speed.Dev.#3.....: 465.9 MH/s (71.77ms) Speed.Dev.#*.....: 923.5 MH/s Started: Fri Mar 24 15:59:50 2017 Stopped: Fri Mar 24 16:15:15 2017
Datum registracije: Mar 2010
Postovi: 2,057
To je uvod u review ili ... ? |
8-bit Gen.
Lokacija: Giethoorn - ZG
Postovi: 3,143
Jucer pitam u generalnoj temi za mini DP adaptere na DVI/VGA koje trebam NVS i Quadro, jer nisam mogao naci kutiju, pa malocas sam sebi odgovaram u istoj. Te me iznenadi da ime Quadro proizvoda nestade iz oznacavanje Pro Nvidia kartica. Sve isto samo bezlicne oznake. Detaljnije : Nvidia Quadro is Gone - No More Quadro - Quadro is Retired! Znam, nije ispod cekica, ali nisam uopce znao do danas, te je bas bezveze potez. NVIDIA confirmed to drop Quadro designation The main reason is that currently NVIDIA graphics are starting to be used in more and more segments. The number of graphics cards of the company for computing tasks have increased in quantity very noticeably. Dobri komentari : More On NVIDIA Quadro Brand Retirement: Embracing the Graphics and Compute Overlap ... |
Postovi: 207
Tko kaže da nema više Quadro? https://quadro.com.hr/web/en/brand/3-quadro Ima svega od TV-a do Toaster-a. ![]() Možda je NVidia izgubila pravo na navedeni brand, kao i Toblerone na Matherhorn. |
#5 | |
...samo te gledam...
Postovi: 2,818
Postovi: 23,512
Zaboravljaš: - naravno da je lakše za proizvodnju kada je razlika samo pozicija otpornika i eventualno drugi bios - po defaultu su profi Quadro kartice x puta skuplje |
Postovi: 2,818
Jesu skuplje, ali koja korist kad im je pala prodaja. Ne gledaš samo trošak proizvodnje u cijeloj priči, gledaš konačnu zaradu. EDIT= Da nadopunim: Što Nvidia radi s neprodanim Quadro karticama? Snizi cijenu ako je u pitanju starija generacija? Transportira natrag u tvornicu da ih preprave u klasične gamerske kartice i prepakiraju u drugu ambalažu? Koliki je gubitak novca u svemu tome? Zadnje izmijenjeno od: Sinac. 12.03.2023. u 09:23. |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,771
Ni meni nije ni najmanje cudno da su ih maknuli. Jos jedan razlog je sto je lakse zamagljivati brojeve na investor callovima, bez da netko analizira podjele izmedju mininga, gaminga, AI-ja i slicnog. |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,688
Pa nije da su nestale. Sta nisu samo rebrandirane? https://www.nvidia.com/en-us/design-...ktop-graphics/ |
#10 | |
8-bit Gen.
Postovi: 3,143
![]() ![]() Citiraj:
![]() Nije Quadro umirovljena kao linija proizvoda, vec je samo naziv Quadro maknut kao (do sada) prepoznatljivi naziv. Identicne kartice su samo izgubile ima Quadro u oznacavanju. No, ako se pogleda u ponude po webu, pa cak i (pojedinih) nasih trgovcaca i dalje se koriste naziv Quadro kao kategorija. Navika je razumljiva. U drugi dio o pretvorbi necu, jer cemo otici u tri nove teme. Velim, datumski me mimoisla promjena pa sam pozelio komentirat. Nvidia Architecture Generation ... |
#11 | ||
Postovi: 2,818
Zadnje izmijenjeno od: Sinac. 12.03.2023. u 14:14. |
8-bit Gen.
Postovi: 3,143
Kolega Sinac, ma na ide posebno tebi, ostali su se nadovezali, pa sam tebe prvog citirao. Velim, vjerovao netko u Quadro selekciju, testiranje, drivere... ali te karte ostaju u identicnom procesu validacije i cijene, samo su makli ime. Takve odluke su (meni blesave) no vidjene cesto u industriji danas, ali dobro... |
#14 | |
Postovi: 2,818
Quadro kartice imaju optimizirane drajvere za CAD/CAM/3D pa čak i 2D aplikacije koji omogućuju višestruko brži rad u pojedinim dijelovima (ne svim) izvođenja programa nego klasične grafičke kartice. To se pogotovo odnosi na pomicanje slike (pan) i skrolanje, zumiranje, rotaciju itd. gdje je bitna brzina ponovnog iscrtavanja ekrana jer Quadro kartice znaju to izvesti višestruko brže nego njihov generacijski pandan među klasičnim grafičkim karticama. Obrati pažnju da nisam isticao razliku u hardveru, to je siva zona za koju ćeš naći različite informacije jer službene nisu dostupne i Nvidija ih skriva ko zmija noge. Zadnje izmijenjeno od: Sinac. 12.03.2023. u 17:00. |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,688
Za autocad imas brdo pluginova koji iz pointclud-a rade as-built solid modele. Ja sam prije dobivao takve modele i high end gtx kartice (tipa 1080ti) kakvu sam ja koristio su se gusile u takvim .dwg-ovima, makar su imali svega par mb. S druge strane, ta ista kartica je bila sposobna vrtiti point cloud od stotina milijuna tocaka. |
#16 |
8-bit Gen.
Postovi: 3,143
Baci oko na tekst, pa onda kontroverzu komentara ispod, koju uvijek izaziva tema. Slicne rasprava je prije izazivala Radeon / FirePro tematika. Evo, bas gledam, nisam ni znao da se FirePro isto preimenovala, te je sad Radeon Pro. ... |
#17 | |
Postovi: 2,818
I opet ponavljam, uz sve dijagrame mi ne znamo koja je zapravo realna razlika između klasične i profi kartice zasnovane na istom grafičkom procesoru. Ako pogledamo napredak grafičkih kartica, sjetimo se da je prije RTX serije bio san imati gamersku grafičku karticu koja ray tracing izvodi on-fly u igrama. |
#19 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Jedina hardverska razlika je bila u tome što su Quadro kartice ponekad imale više VRAM-a, sve ostalo je isto GeForce modelima. Quadro su dolazile s "certificiranim" driverima za neke programe koji su to znali iskoristiti i zato su bile brže.
#20 |
Kostolomac
Postovi: 1,476
Sjećam se da sam soft-modao staru Nvidia 6800 u Quadro 4000 i dobivao bolje performanse u OpenGL igrama. |
#21 |
Prečupavi mod
Postovi: 9,107
ECC memorija na Quadricama je isto nezanemariva razlika ![]()
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
#22 |
Postovi: 5,771
Aha, znaci samo se ime mijenja, ali i dalje ce biti drukcije i imenom i izvedbom od geforcea. Onda, ono, koga briga ![]() |
#23 |
Xulos :)
Postovi: 7,549
Pa da, sve ostaje isto, nije vise quadro nego je RTX Axxx , tipa RTX A6000 Full lineup: https://www.nvidia.com/en-us/design-...ktop-graphics/ |
#24 |
Postovi: 33,934
Bilo bi zanimljivo kada bi netko napravio usporedbu gamerske grafe i RX pandana, kako u igrama tako i u profi programima pa da vidimo imaju li one uopće smisla i da li performanse opravdavaju znatno višu cijenu.
#25 | |
Postovi: 2,818
https://www.cgdirector.com/pro-vs-consumer-gpus/ Za profi aplikacije - definitivno da. Za mješovitu upotrebu - definitivno ne. |
#26 | |
Xulos :)
Postovi: 7,549
#27 |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,688
ima materijala na yt-u: https://www.youtube.com/watch?v=HEagFvmjW4w https://www.youtube.com/watch?v=EDwNZXVGR3w https://www.youtube.com/watch?v=xtN9dX0oWzY Zaključak: ovisno o aplikaciji koja se koristi, Za allroundere definitivno nije. |
