#241 | ||||||||
Postovi: 8,485
![]() Citiraj:
EDIT:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 04.01.2023. u 11:17. |
#242 | |
Lokacija: Zabok
Postovi: 3,412
. Al fino da im je netko dokazao da problem postoji i zašto postoji. Nek se sad čupaju van kak znaju. Govna.Ispada da je Intel imao najbolji launch 2022. |
#243 |
Postovi: 8,485
AMD i nVidiju su snašle pizdarije sfušanih proizvoda treće strane, a Intel je super prošel, jer se kartice praktični nisu mogle ni kupiti. ![]() ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#244 |
Datum registracije: May 2003
Postovi: 1,116
A ništa, kad presveta firma izda novu liniju proizvoda, prvo tečaj ili večernja škola, izdavanje svjedodžbe, itek onda kupovina ![]()
SS |
#245 |
Postovi: 4,437
Sve ja to razumijem ako bez puno pitanja preuzmu jedni i drugi i zamjene za ispravnu. I skupocjene aute u stotinama tisuća primjeraka sfušaju i javno objavljuju da je potreban masovni servis. Meni se gade jedni i drugi zbog drugog/ih razloga, ove sfušane konektore koji traže pažnju ili sfušane hladnjake nije problem ispraviti uz malo dobre volje. Dugoročno najmanji problem i previše se na to fokusira kako bi se dokazalo ovo ili ono. Slično kao sigurnosne rupe na Intelu. |
#246 |
Postovi: 1,116
Greške se dogode, korektne firme reagiraju i problemi budu rješeni. Problem je u pokušajima prodavanja nekih firmi kao savršenih i bezgrešnih..... i uvjek je neko drugi kriv....
SS |
#247 | |
Lokacija: Zabok
Postovi: 3,412
Zadnje izmijenjeno od: stef. 06.01.2023. u 14:14. |
#249 |
1
Postovi: 3,602
Evo šta de8auer kaže za hotspot I Jay Srećom pa sam AMD hejter od prije još, a s ovom glupošću su mi još više pali u očima.
P: Razne PC i serverske komponente, Laptope, Dijelove za laptope... Zadnje izmijenjeno od: Thermaltake. 09.01.2023. u 20:04. |
#252 |
Postovi: 8,485
Vapor gate including failure of the entire quality management? Background on the cooler problem of the AMD Radeon RX 7900 XTX (MBA) ![]() Citiraj:
#253 |
Postovi: 1,116
Izgleda da je neko usro i šefa i stanicu i šest kilometara pruge. AMD Radeon RX 6000 GPUs Mysteriously Start Dying, German Repair Shop Receives 48 Cards With Cracked Chips https://wccftech.com/amd-radeon-rx-6...cracked-chips/
SS |
#254 | |
Prvoklasni Krkan
Postovi: 5,357
Sumnja za početak pada na drivere...hmmm...Fajn Vajn™ Ali slike su odlične, kao kad ti izgore kolači pa ostanu zaljepljeni za tepsiju...u ovom slučaju se kolačić kvalitetno zapekao za kuler. ![]() A Vaporgate kako su ga nazvali ko naša birokratija, svi krive onog drugog i obrati se njemu sa FT1P obrazcem. ![]() Zadnje izmijenjeno od: Disco. 11.01.2023. u 14:15. |
#255 | |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,704
AMD runs out of RX 7900 XTX cards |
#256 | |
Lokacija: Zabok
Postovi: 3,412
. Ili stvarno nemaju pojma što je sve afektirano, ili muljaju. |
#258 |
Lokacija: Zagreb, Črnomerec
Postovi: 2,628
Ajd probaj zamislit da si složiš nekakvu konfu sa xtx-om i da ispadne da seasonic 850w nije dosta Kakva bi to bila potrošnja, kakve bi to bile temperature, to američke utičnice polako već ne mogu izdržati, morat će stavljati PC na jednu strujnu utičnicu a GPU na drugu ![]() P.S. 7900xtx sa konfom i tvojim cpu-om ne prelazi 500w u full loadu. |
#259 | |
Postovi: 1,116
https://www.youtube.com/watch?v=8Ejlt-7-h9o
SS |
#260 | |
Prvoklasni Krkan
Postovi: 5,357
![]() Jel to to ili je zaključak neki drugi...vidim da video traje 24 min pa mi se neda... Pa vi kupujte od majnera. |
#261 | ||
Postovi: 8,485
U nekoliko različitih tema (uključujući ovu koja nema veze s tim karticama) unazad nekoliko postova je ovo već pokriveno. Kaj se kripto kartica tiče, ima tu svega: Gamers beware: miners are now painting GPU memory to make them look as new ![]() Citiraj:
#263 |
Postovi: 8,485
Da, pa koliko je samo bilo upita na tu temu i svaki put je ispalo da su kripto kartice čak i bolje od novih, jer rade u kontroliranim uvjetima, itd. Dok se tu farbaju memorije da izgledaju ko nove, a pranje miniwashom ne treba ni komentirati. ![]() ![]()
#266 |
Datum registracije: Dec 2009
Postovi: 438
Po meni je amd s ovom serijom grafi totalno drop the ball sto bi rekli u nfl zargonu.. Umjesto da su uletili s 30% nizim cjenama od nvidije. oni naprave ovako sranje.. A nisam niciji fanboy. osim svog novcanika.. |
#267 |
All-rounder
Datum registracije: Sep 2013
Postovi: 1,338
XTX jesu 20% jeftinije od 4080 u USA valjda, ali kod nas u Europi su cijene drugačije, XTX i 4080 koštaju jednako. Neka velika muljaža, čini mi se. XT i 4070ti imaju omjer kako bi i trebale prema MSRP. |
#270 |
Datum registracije: Feb 2021
Lokacija: TRPI
Postovi: 456
Veci je fail skupa a kastrirana 4070ti sa samo 12gb vram, neke AAA igre vec sada u 1440p koriste do 16gb vrama a sto ce tek biti kroz 2024-2025. |
