Staro 04.12.2022., 19:45   #3271
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Mlacom nema nikad ništa što meni treba. Rade doduše gravuru...
Za ove druge nisam čuo. Hvala.
Sent from my SM-N986B using Tapatalk
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 04.12.2022., 19:55   #3272
SrKi
SrKi's Avatar
Postovi: 842
Ako je HR znakovlje must, imaš ga na logitechu. Jbg, tako je kako je, nisu loše logi tipkovnice.
SrKi je offline   Reply With Quote
Staro 04.12.2022., 21:49   #3273
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Ja se baš nisam usrećio s njima.
Na g915 clicky su mi počeli odlaziti switchevi na pola garancije. MX Keys ima 2-key rollover, iako je reklamirana kao 6-key rollover i na nju se ionako nikad nisam naviknuo. Prečudna mi je za pisanje. MX Mechanical nisam ni pokušao kupiti jer je vrlo očito loše kvalitete na prvi dodir. Neke rubberdome tipkuše iz jeftinijeg segmenta su im bile dobre, ali ove "high-end" su promošaj IMHO. Svaka čast njihovim miševima, ali MX Keys je zadnja Logi tipkovnica koju ću kupiti.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 05.12.2022., 11:18   #3274
SrKi
SrKi's Avatar
Postovi: 842
Jbg onda, odustani od hrv znakova Tak i tak je to samo stvar vizuala, ništa više.
Mene je isto to mučilo, ali navikao sam se.
Staro 05.12.2022., 11:30   #3275
domy_os
domy_os's Avatar
Postovi: 18,940
Autor SrKi Pregled postova
Nisu tu samo HR znakovi u pitanju, nego i sijaset drugih znakova. Ako se uzme UK layout + HR gravura, to je onda cirkus. DE još nekako, skoro sve je isto. Mene kao nekog "programera" koji ponekad piše i mijenja kojekakve skripte i kodove to baš ubija u pojam i samo zbog toga ću se riješiti mehaničke tipkovnice, makar sve ostalo bilo super.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 05.12.2022., 23:55   #3276
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Moj problem je u glavi s tim. Neka vrsta OCD-a. Nema tu pomoći.
Drugi ekstra znakovi mi zapravo ni nisu presudni, tako da bi prije uzeo UK+HR, nego DE+HR (ovo sam imao već) , ali i jedno i drugo bi mi manje-više išlo na živce i nakon par mjeseci bi vjerojatno opet razmišljao o drugoj tipkovnici.
Nadam se da će Mlacom ili ovi drugi pustiti neku od 100% od Ducky-a ili Das Keyboarda sa CRO/SLO layoutom...Do sad sam vidio samo Ducky One 2 Mini.
Pitam se koliko bi dobro ispalo da si isprintam sam keycap od ABS-a...
PBT na žalost ne mogu na svojem printeru jer PBT traži 300°C za nozzle i 120°C za hotbed...
Doubleshot bi vjeorjatno bio zahtjevan za precizno isprintati...ali kroz par pokušaja bi možda sjelo...
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 06.12.2022. u 00:19.
Staro 06.12.2022., 13:28   #3277
fler
These go to 11
fler's Avatar
Lokacija: Czarnia
Postovi: 1,853
Bilo je već pokušaja, pogledaj po netu (npr. ovaj tip).
Koliko ima smisla - nemam pojma.
Kako god, sretno
Staro 09.12.2022., 14:29   #3278
Elven
Elven's Avatar
Datum registracije: Sep 2002
Postovi: 2,721
upravo stigo BF poklon, Razer blackwidow V3 Pro, Green switches....
teško se navikavam jer su mi tipke preblizu na Roccat AIMO su mi taman bile, ovdje su toliko blizu da stalno fulavam i neprirodno mi je... a nemam neke ćevape niti velike dlanove... nevjerojatno, to nigdje nisam vidio kao feedback, pa šta su samo žene ili ljudi sa full sitnim rukama ovo testirali?
OSjet na switchevima mi je dobar, malo me smeta možda clicky, možda bi bilo bolje da sam uzeo yellow switch, ali ok.. vidjet ćemo... možda završi na tržnici uskoro.
Staro 09.12.2022., 23:39   #3279
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,875
ja još imam black widow v2 yelow switch sa o-ringsima,gledo uzet ne uzet što ću davat 1350 kuna bolje da u novi komp uložim dio ovog novca.
https://www.mall.hr/mehanicke-tipkov...03930100-r3m1-
Staro 10.12.2022., 14:24   #3280
Elven
Elven's Avatar
Postovi: 2,721
kupio sam je za 1150kn, ali da kužim te, ako ti dobro služi, zašto mjenjati...
mene je moja Roccat Vulcan AIMO počela jako zafrkavati, ne prima dobro tipke, pa recorda double keypress (što me prvo prepalo da nije neki keylogger, jer to zna bit njihov simptom)... pa sam trebao nešto novo... naviknut ću se već I guess, ali malo mi je žao sada što nisam uzeo linearne, iako ću većinu vremena tipkati... počinje mi klik ići na živce
Staro 10.12.2022., 14:49   #3281
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,329
Autor estugarda Pregled postova
E ekipa, nikako da si nađem neku mehaničku tipkovnicu koja bi mi bila po volji, pa razmišljam da probam sa totalno custom pričom. Problem je što nemam pojma kako to ide.
Wireless mi više nije uvjet, s obzirom da ne mogu naći takvu, a da je kvalitetna i pokriva ostale potrebe.
Uvjeti:
- 100% size
- Cherry MX Blue ili nešto vrlo slično po kliku i zvuku
- HR layout (veliki enter, i ako je ikako moguće veliki lijevi shift.
- pozadinsko osvjetljenje, po mogućnosti bijelo
- crna tipkovnica
Je li moguće složiti tako nešto? I ako da, gdje i s kojim dijelovima?
Neznam jesi gledao Razer DetahStalker V2 ? Cini mi se da zadovoljava sve uvjete koje si naveo.
https://www.razer.com/eu-en/gaming-k...eathstalker-v2
Ja je korisitm nekih mjesec i pol dana i bas sam zadovoljan (Prije toga me Roccat Vulcan pocela zezati)
Razer ima i DeathStalker V2 Pro koja je ujedno i bezicna ako jos uvijek zelis platiti 400-500kn vise da nema zice .
Staro 10.12.2022., 16:04   #3282
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,875
Autor Elven Pregled postova
trebo si odmah yelow switcheve,2 o-ringa gore,nisam dobro space vratio nazad.
Staro 10.12.2022., 23:45   #3283
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor Lewis Pregled postova
Gledao sam i tu, ali mislim da kod nas svi nude samo Red linear switch, a linear ne podnosim. Ja sam clicky tip.
BTW jesu li HRV znakovi ugravirani, ili prolazi svjetlo kroz njih?
Iskreno, dosta mi je eksperimentiranja. Znam da mi najviše paše Cherry MX Blue. Tak da mislim da je to smjer za mene.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 11.12.2022., 00:15   #3284
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,329
Da nase tipke su gravirane ali zbog pozicije svjetla slabije se vide jer original slova nisu u sredini nego vise gore lijevo tako da su nase ugravirano dolje desno pa manje svjetle.
Ali dobra stvar mi je sto je plastika tipki drugacija od Roccata pa se tipke nisu izlizale/ulastile kao na Roccat Vulcanu gdje sam vec nakon mjesec dana ulastio space bar i ctrl..
Staro 11.12.2022., 01:00   #3285
Elven
Elven's Avatar
Postovi: 2,721
Ovaj put nemamo iste, ali smo obojica uzeli Razer nakon sto smo otprilike u isto vrijeme odustali od Roccat Aima.... bas me zanima sta cemo pisat za godinu dana ovdje
Sent from my SM-G996B using Tapatalk
Staro 11.12.2022., 01:03   #3286
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,513
Da nevalja razer kao ni roccat ayyyy
Staro 11.12.2022., 12:59   #3287
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,913
Najvjerojatnije, ali roccat je ja mislim u top 10 najgorih, nezz jednog covika da ga nije pocela zezat
OuttaControl je online   Reply With Quote
Staro 19.12.2022., 18:52   #3288
SrKi
SrKi's Avatar
Postovi: 842
Tek je naručena, tako da ćemo vidjeti. Platio s paypalom, žalit ću se ako bude problema.
Čisto da javim, došla je tipkovnica i odlična je. Candykeys je isto ok prošao, odmah poslali.
Staro 02.01.2023., 08:51   #3289
tun3
tun3's Avatar
Datum registracije: Oct 2018
Lokacija: Matulji
Postovi: 356
Poklon za novu godinu meni od mene
tun3 je offline   Reply With Quote
Staro 02.01.2023., 09:16   #3290
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Predivno, idealan kombo, ansi s nasim slovima, krasota.
Staro 02.01.2023., 13:25   #3291
GRdiamond9A
GRdiamond9A's Avatar
Datum registracije: May 2020
Postovi: 60
Autor tun3 Pregled postova
Prefora mousepad, di je kupljen
Poslano sa mog POCOPHONE F1 koristeći Tapatalk
GRdiamond9A je offline   Reply With Quote
Staro 02.01.2023., 13:53   #3292
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Autor GRdiamond9A Pregled postova
https://mykeyboard.eu/catalogue/yugo-deskmat_1421/
Staro 02.01.2023., 14:38   #3293
tun3
tun3's Avatar
Lokacija: Matulji
Postovi: 356
Evo kolega JuiceBox je brži, jedino deskmatovi su ostali od Yugo serije... Ako netko naleti na artisan keycap u prodaji neka javi
Staro 07.01.2023., 08:31   #3294
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Gadna dilema:
Uzeti Ducky One 2 TKL RGB ili Typone Mars Pro RGB
https://mechanicalkeyboards.com/shop..._detail&p=4284
https://mechanicalkeyboards.com/shop..._detail&p=8854
Prednost kod Duckya je da ima više switcheva u ponudi, obje su fiksne.
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 07.01.2023., 16:34   #3295
Elven
Elven's Avatar
Postovi: 2,721
Autor micek_kc Pregled postova
Gadna dilema:
Ovaj Typone Mars mi izgleda toliko fenomenalno da cu si ja narucit, i ako ie dobra prodajem poklon koji sam si kupio za BF...
Staro 07.01.2023., 23:50   #3296
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
To sam i ja isto rekao, za Ducky znam da je odllična, svi ju hvale, ali ovo sa printom slova na bocnoj stranici mi je bas fora. I jos dobra stvar je da ima USB
pass-through pa ju mozes koristiti kao Hub. Samo nemoj zaboraviti da naš layout za nju ne postoji tako da se privikni odmah na US layout.
Jedino nisam siguran između MX Silver i Silent Red switcheva.
Logitech MX500
DELL 2007FP
Abit AV8
Staro 08.01.2023., 00:00   #3297
T}{OR
DBS
T}{OR's Avatar
Datum registracije: Nov 2010
Postovi: 1,855
Gadna dilema:
Ako ideš na Ducky, ja bih definitivno uzeo One 3 RGB verziju radi hot swap-a:
https://mechanicalkeyboards.com/shop..._detail&p=9252
Ima dodatni damping u odnosu na One 2 verziju, i hot swap. Sve ostalo je skoro pa identično.
Ova Typone Mars Pro je #drool samo takav. No otkad imam One 2 od Duckya, već godinama nisam imao potrebe išta mijenjati. Pa nisam u toku s recenzijama itd...
Staro 08.01.2023., 03:55   #3298
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor T}{OR Pregled postova
Da, to sam baš ujutro gledao a cijena samo 10$ veća u Americi. Trenutno sam na projektu u Americi pa mi je lakše kupiti bilo što.
Stvarno se čini kao solidan izbor. Jedno pitanje, tvoja je RGB? Jel ima onaj mod kao dok stisnes tipku da rezonira oko nje, kao water wave nesto?
Je, I uporno pokušavam naći neki english based review ali svi su na kineskom
Stvarno je samo ja sam overthinking budala pa ću prevrnuti sve 80 puta prije nego odluku donesem.
Dolazim u napast naručiti ovo čisto da probam i vratim je ako ne valja:
https://www.amazon.com/EVGA-Keyboard...s%2C104&sr=8-3
Ova korisnička prava u Americi su vrh, mozes bilo koji proizvod vratiti ako ti se ne dopada.
Logitech MX500
DELL 2007FP
Abit AV8
Staro 08.01.2023., 11:49   #3299
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Gadna dilema:
Ni jednu. Uzmi od keychrona Q3, imas sve sto imaju ove, plus je aluminijska i jos hotswap. Sto se povrata tice i kod nas mozes sve vratiti u roku 2 tjedna ako ti se ne svidja.
Ova evga, asus , roccat i ostala ina gejming sranja uopce nemoj gledati, to je u principu sve ista tipkovnica samo se placa njihova sposobnost tko moze bolje umotati govno u alu foliju.
Staro 08.01.2023., 12:44   #3300
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Te RGB efekte ne koristim, već sam na profilima 2-6 složio svoje, ovisno o igri. S time da možeš spremati do 2 po profilu.
Ima taj efekt gdje je jedan klik pa ripple okolo. Zatim samo da osvjetli tu jednu tipku koju si stisnuo, te da osvjetli cijeli red tipki ovisno koju si stisnuo - plus još jedno 4-5 drugih koje lako vidiš na recenzijama online.
Autor JuiceBox Pregled postova
Kakav je software kod Q3? QMK pretpostavljam? Jer kod Ducky-a je apsolutni vrh, em zauzima 32 MB i jedino što radiš s njim je podešavanje RGB profila. Sve ostalo se radi direktno na tipkovnici i ne treba ti software uopće. Doduše ako si napredni korisnik pretpostaviti ću da je QMK prednost, no za 99% ekipe ovo što Ducky radi je više nego dovoljno.
Apsolutno. Em ćeš preplatiti tipkovnicu, em ćeš dobiti duplo lošiju u usporedbi sa spomenutima. Been there sa svoje prve 3 mehaničke.
Doduše mala kritika i kod Ducky-a ovdje je da se preporuča dodatno podmazati stabilizatore. Nisam to radio na svojima, i sad nakon 3 godine nema promjene na gore - ali čitam da se preporuča i mislim da je netko to tu radio već.
