#1801 |
Lokacija: München/Varaždin
Postovi: 4,876
Nadam se da ne radis ALT-F2 pa sudo komanda... ...visudo...(/etc/sudoers nikad ali NIKADA ne editiraj rucno). ![]() Po defaultu si vjerojatno u grupi koja ima pristup. Ak ne, brijem da su skemijali nekaj u kombinaciji sa seahorse (Passwords and Keys u GUI izdanju) da nakon logina te il ne pita il samo ponekad pita....Fedora 37 Gnome vrtim vec par dana i nisam naletio na taj problem. P.S.- naravno mozda je i BUG u BETA verziji OS-a ...no sumnjam....
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / OpenSuse Leap 16 |
#1803 |
Postovi: 4,876
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / OpenSuse Leap 16 Zadnje izmijenjeno od: tomek@vz. 08.11.2022. u 09:27. |
#1806 |
Postovi: 4,876
#1807 |
Lokacija: Grad na Dravi
Postovi: 580
visudo: Code:
# Sudoers allows particular users to run various commands as ## the root user, without needing the root password. ## ## Examples are provided at the bottom of the file for collections ## of related commands, which can then be delegated out to particular ## users or groups. ## ## This file must be edited with the 'visudo' command. ## Host Aliases ## Sudoers allows particular users to run various commands as ## the root user, without needing the root password. ## ## Examples are provided at the bottom of the file for collections ## of related commands, which can then be delegated out to particular ## users or groups. ## ## This file must be edited with the 'visudo' command. ## Host Aliases ## Groups of machines. You may prefer to use hostnames (perhaps using ## wildcards for entire domains) or IP addresses instead. # Host_Alias FILESERVERS = fs1, fs2 # Host_Alias MAILSERVERS = smtp, smtp2 ## User Aliases ## These aren't often necessary, as you can use regular groups ## (ie, from files, LDAP, NIS, etc) in this file - just use %groupname ## rather than USERALIAS # User_Alias ADMINS = jsmith, mikem ## Groups of machines. You may prefer to use hostnames (perhaps using ## wildcards for entire domains) or IP addresses instead. # Host_Alias FILESERVERS = fs1, fs2 # Host_Alias MAILSERVERS = smtp, smtp2 ## User Aliases ## These aren't often necessary, as you can use regular groups ## (ie, from files, LDAP, NIS, etc) in this file - just use %groupname ## rather than USERALIAS # User_Alias ADMINS = jsmith, mikem ## Command Aliases ## These are groups of related commands... ## Networking # Cmnd_Alias NETWORKING = /sbin/route, /sbin/ifconfig, /bin/ping, /sbin/dhclien> ## Installation and management of software # Cmnd_Alias SOFTWARE = /bin/rpm, /usr/bin/up2date, /usr/bin/yum ## Services # Cmnd_Alias SERVICES = /sbin/service, /sbin/chkconfig, /usr/bin/systemctl star> ## Updating the locate database # Cmnd_Alias LOCATE = /usr/bin/updatedb ## Storage # Cmnd_Alias STORAGE = /sbin/fdisk, /sbin/sfdisk, /sbin/parted, /sbin/partprobe> ## Delegating permissions # Cmnd_Alias DELEGATING = /usr/sbin/visudo, /bin/chown, /bin/chmod, /bin/chgrp ## Processes # Cmnd_Alias PROCESSES = /bin/nice, /bin/kill, /usr/bin/kill, /usr/bin/killall ## Drivers # Cmnd_Alias DRIVERS = /sbin/modprobe # Defaults specification # # Refuse to run if unable to disable echo on the tty. # Defaults !visiblepw # # Preserving HOME has security implications since many programs # use it when searching for configuration files. Note that HOME # is already set when the the env_reset option is enabled, so # this option is only effective for configurations where either # env_reset is disabled or HOME is present in the env_keep list. # Defaults always_set_home Defaults match_group_by_gid # Prior to version 1.8.15, groups listed in sudoers that were not # found in the system group database were passed to the group # plugin, if any. Starting with 1.8.15, only groups of the form # %:group are resolved via the group plugin by default. # We enable always_query_group_plugin to restore old behavior. # Disable this option for new behavior. Defaults always_query_group_plugin Defaults env_reset Defaults env_keep = "COLORS DISPLAY HOSTNAME HISTSIZE KDEDIR LS_COLORS" Defaults env_keep += "MAIL QTDIR USERNAME LANG LC_ADDRESS LC_CTYPE" Defaults env_keep += "LC_COLLATE LC_IDENTIFICATION LC_MEASUREMENT LC_MESSAGE> Defaults env_keep += "LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER LC_TELEPHONE" Defaults env_keep += "LC_TIME LC_ALL LANGUAGE LINGUAS _XKB_CHARSET XAUTHORIT> # # Adding HOME to env_keep may enable a user to run unrestricted # commands via sudo. # # Defaults env_keep += "HOME" Defaults secure_path = /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sb> ## Next comes the main part: which users can run what software on ## which machines (the sudoers file can be shared between multiple ## systems). ## Syntax: ## ## user MACHINE=COMMANDS ## ## The COMMANDS section may have other options added to it. ## ## Allow root to run any commands anywhere root ALL=(ALL) ALL ## Allows members of the 'sys' group to run networking, software, ## service management apps and more. # %sys ALL = NETWORKING, SOFTWARE, SERVICES, STORAGE, DELEGATING, PROCESSES, LO> ## Allows people in group wheel to run all commands %wheel ALL=(ALL) ALL ## Same thing without a password # %wheel ALL=(ALL) NOPASSWD: ALL ## Allows members of the users group to mount and unmount the ## cdrom as root # %users ALL=/sbin/mount /mnt/cdrom, /sbin/umount /mnt/cdrom ## Allows members of the users group to shutdown this system # %users localhost=/sbin/shutdown -h now ## Read drop-in files from /etc/sudoers.d (the # here does not mean a comment) #includedir /etc/sudoers.d |
#1808 |
Postovi: 4,876
Ovaj dio je bitan: ## Allows people in group wheel to run all commands %wheel ALL=(ALL) ALL <<< dopustenje da izvodis kao sudo komande - nakon upisa lozinke (uneses jednom i neko vrijeme ne pita) ## Same thing without a password # %wheel ALL=(ALL) NOPASSWD: ALL <<< dopustenje izvodenja komandi kroz sudo elevaciju bez upita za lozinku (onemoguceno)
#1811 | |
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,783
Da li netko zna kako na Synology preko CLI pronaći razlog zašto se ne želi openvpn client spojiti na server? U zadnje vrijeme (zadnjih mjesec/dva) na DSM 7.1 mi pukne openVPN veza (Synology je client, koji se spaja na openVPN server) i ne želi se spojiti ponovno. Sve što probam ne radi, uključujući i ručno GUI i CLI spajanje. Citiraj:
Ako napravim restart cijelog NAS-a, spoji se od prve, i tako sve dok ponovno ne zaglavi. Zna li netko kako saznati što ga pati, gdje pukne. |
#1812 | |
Postovi: 3,478
Realtek strikes again... Evo onaj prethodni vikend sam se malo podružio s tp-link T4U, hardverska revizija v3.2 Code:
Bus 002 Device 011: ID 2357:0115 TP-Link TL;DR Ovaj post koji sam našao na redditu lijepo opisuje situaciju: Why has RTL88x2BU not made it into mainline? https://www.reddit.com/r/linux/comme...into_mainline/ "Because the driver is incredibly broken and no one is interested in fixing it." Nema u kernelu drivera za tu reviziju iako je od 2018-19 vani, testirano na jubuntu kernel v 5.15, 5.19 i 6.0. Također na live gedori zadnjoj. Ima nekoliko github repozitorija koji drže driver koji je isporučio tp-link, kompilira se bez problema. Radi tak-tak, moglo bi i bolje. Pljucka čudne poruke u dmesg, po defaultu brzina je manja, radi kao da je USB/480Mbps. Može se modul učitati s posebnim parametrom, onda radi na punoj brzini, ali samo ako je uštekan u USB3 port. Ako se tako ušteka na USB2, onda ne radi, nekakav loop kod učitavanja modula.Postoji navodno eksperimentalni driver "rtw88-usb" kojeg nisam uspio nabrzinu kompilirati. Nakon druženja od par sati sam odjebao to smetje i iskoristio taj stick na jednom windows 10 računalu. Tamo radi OOB, ali opet na manjoj brzini ![]() Godinama sam izbjegavao wlan usb stickove na linuxu, vidim barem na ovom slučaju da se i dalje ništa nije promijenilo, support od proizvođača većinom loš i jedan veliki PITA za složiti ![]() Tih par sati što sam se igrao s time, jednom kad se driver učita radi pristojno, ali jebo drivere gdje moraš paziti u koji USB port uštekaš tu kontrapciju ![]() |
#1813 | |
Postovi: 4,876
Nemas srece ![]()
#1815 | |
Postovi: 3,478
Izgleda da je MTK dobro podržan, iz postova sa linka gore: https://github.com/morrownr/USB-WiFi...nel_drivers.md Citiraj:
#1816 |
Postovi: 18,858
Koristi li netko aktivnije kombinaciju KDE, VirtualBox, TeamViewer i Flatpak aplikacije? Događa mi se to da miš djelomično prestane raditi, kao da se nađe neki nevidljivi layer između miša i aktivne aplikacije jer ga mogu pomicati, ali baš nigdje ne reagira na klikove i scroll. U Flatpak aplikacijama pak mogu klikati, ali ne radi scroll. Onda otvorim drugi TTY i u njemu restartam kwin, nekad je potrebno 2-3 puta da dođe k sebi. OS je Kubuntu 22.04.1 LTS, Plasma 5.24.6, nisam htio ubacivati neslužbeni repo za noviju.
#1817 | ||
Postovi: 646
Npr. TL-WN722N V1 je koristio Atheros koji je bio vrh što se tiče kompatibilnosti, i onda su u TL-WN722N V2 prešli na Realtek, dok u dućanu kutija ista, sve isto ![]() Uvijek se konzultiraj sa https://deviwiki.com/ da vidiš što kupuješ. U tvom slučaju imaš ovo: https://deviwiki.com/wiki/TP-LINK_Archer_T4U_v3 |
#1818 | |
Postovi: 4,876
Zato izbjegavam Flatpak i Snap ko kugu. Smrdi na Bug u smjeru hid/dbus (vidi jel ima u journalu ista korisnog u to vrijeme) drivera... al daj malo vise detalja kako ti se to dogada....session kroz TW i na klijentu s druge strane Virtualbox ili kak? Jel se isto dogada kad koristis Virt-Manager/qemu umjesto Virtualboxa? KDE bi mogo biti uzrok problema posto provodi komunikaciju na toj razini ali po onome kaj sam vidio KDE i Plasma su u zadnje vrijeme tolko ispolirani da bih prije okrivio TW/Virtualbox combo....
#1819 | |
Postovi: 18,858
Na KDE imam oboje lokalno instalirano, TV koristim za spajanje na druge PC-e kod kuće i kod klijenata, a VB za izolirani VPN, testiranje aplikacija i koječega na drugim OS-ovima. Od drugih hypervisora imam još VMware i ista stvar i s njim. Tijekom prebacivanja iz app u app se sporadično pojavi taj problem, ne mogu ga namjerno reproducirati. KDE u Kubuntu ne zapisuje skoro ništa logova u journalctl, nisam se sjetio pogledati xsession errors. Koliko je Fedora previše verbose, toliko ovaj "šuti". Kad se dogodi ovakav bug, onda nemam ništa, vidim samo FW logove gdje je blokirao neku konekciju i moje skripte što se vrte u pozadini. Ma imam ja još bugova sa KDE, nije to sve, ali ovo me baš nervira.
#1820 | |
Postovi: 4,876
Back to basics onda nazalost (XFCE/LXDE) i probaj reproducirat problem. P.S.- koje aplikacije nema kao deb pakete?
#1821 |
Postovi: 18,858
Evo cijela lista da sad ne prepisujem... Code:
domy@Domy-NB:~$ flatpak list F: Filesystem suffix "create" is not applicable for --nofilesystem Name Application ID Version Branch Installation RetroShare-gui cc.retroshare.retroshare-gui 0.6.6 stable system Flatseal com.github.tchx84.Flatseal 1.8.1 stable system Video Downloader com.github.unrud.VideoDownloader 0.10.10 stable system Simplenote com.simplenote.Simplenote 2.21.0 stable system Viber com.viber.Viber 18.2.0.2 stable system XnView MP com.xnview.XnViewMP 1.3.1 stable system HandBrake fr.handbrake.ghb 1.4.2 stable system IntelMediaSDK plugin for HandBrake fr.handbrake.ghb.Plugin.IntelMediaSDK 1 system FreeTube io.freetubeapp.FreeTube 0.18.0 Beta stable system Flatpak External Data Checker org.flathub.flatpak-external-data-checker stable system Freedesktop Platform org.freedesktop.Platform 21.08.16 21.08 system Freedesktop Platform org.freedesktop.Platform 22.08.3 22.08 system Mesa org.freedesktop.Platform.GL.default 21.1.8 20.08 system Mesa org.freedesktop.Platform.GL.default 21.3.9 21.08 system Mesa org.freedesktop.Platform.GL.default 22.1.7 22.08 system Intel org.freedesktop.Platform.VAAPI.Intel 20.08 system Intel org.freedesktop.Platform.VAAPI.Intel 21.08 system Intel org.freedesktop.Platform.VAAPI.Intel 22.08 system ffmpeg-full org.freedesktop.Platform.ffmpeg-full 21.08 system openh264 org.freedesktop.Platform.openh264 2.1.0 2.0 system openh264 org.freedesktop.Platform.openh264 2.1.0 2.2.0 system Freedesktop SDK org.freedesktop.Sdk 21.08.16 21.08 system Freedesktop SDK org.freedesktop.Sdk 22.08.3 22.08 system GNOME Application Platform version 40 org.gnome.Platform 40 system GNOME Application Platform version 42 org.gnome.Platform 42 system GNOME Application Platform version 43 org.gnome.Platform 43 system Breeze GTK theme org.gtk.Gtk3theme.Breeze 5.26.3 3.22 system KDE Application Platform org.kde.Platform 5.15 system Signal Desktop org.signal.Signal 5.63.1 stable system Telegram Desktop org.telegram.desktop 4.3.1 stable system Telegram Desktop Webview Add-on org.telegram.desktop.webview 2.38.2 stable system Zoom us.zoom.Zoom 5.12.6.173 stable system
#1822 | |
Postovi: 4,876
RetroShare-gui We distribute current RetroShare for Ubuntu through our OBS repository. To add it you can use the following commands: #1 source /etc/os-release #2 wget -qO - https://download.opensuse.org/repositories/network:/retroshare/xUbuntu_${VERSION_ID}/Release.key | sudo apt-key add - #3 sudo sh -c "echo 'deb https://download.opensuse.org/repositories/network:/retroshare/xUbuntu_${VERSION_ID}/ /' > /etc/apt/sources.list.d/retroshare_OBS.list" Then install RetroShare with: #1 sudo apt-get update #2 sudo apt-get install retroshare-gui Video Downloader > Youtube-DL (CLI-Only) $ youtube-dl https://www.youtube.com/watch?v=Film-ID $ youtube-dl -o '~/videos/film.mp4' Film-URL $ youtube-dl -F Film-URL $ youtube-dl -f Nummer Film-URL $ youtube-dl --playlist-start 3 --playlist-end 5 Playlist-URL Alternativno > https://www.4kdownload.com/ Simplenote https://github.com/Automattic/simple...es/tag/v2.21.0 XnView MP > osobno preferiram nativne KDE/Gnome aplikacije zbog integracije u GUI https://download.xnview.com/XnViewMP-linux-x64.deb HandBrake > dostupan u universe repo FreeTube https://github.com/FreeTubeApp/FreeT...18.0_amd64.deb Signal Desktop https://signal.org/en/download/linux/ Telegram Desktop https://www.how2shout.com/linux/how-...ackage_Manager Zoom https://zoom.us/client/5.12.9.367/zoom_amd64.deb Viber https://download.cdn.viber.com/cdn/d...inux/viber.deb ![]() A sto se tice prvog problema > Xubuntu ak se drzis Ubuntu okruzenja i probaj reproducirat problem.
#1823 | |
Postovi: 18,858
#1824 | |
Postovi: 4,876
Kad je Ubuntu u pitanju debian paketi su cesto kompatibilni ali moras pazit koju verziju opet instaliras. Tu moras malo pazit da ne skrsis neki interni lib dependency al najcesce sljaka ![]()
#1825 |
PRO
Postovi: 4,760
Da vas pitam za savjet: Imam laptop sa integrušom + nvidia karticom. nvidia ne radi, krepala, pa isključivo vrtim windowse na integruši (samo disableam NVidia GPU u device manageru). Ne mogu je disableati u BIOSu. E sad, instaliram si Ubuntu na taj laptop, on odmah prilikom boota ima drivere od nvidie, pa mi ode boot kvragu. U GRUB sam stavio nomodeset, pa se boota Ubuntu, no sad ne znam kako disableati GPU karticu. Ima tko savjet?
#1826 | |
Postovi: 4,876
OpenSource driver je u svakom kernelu...Proprietary Nvidia driver od nvidie moras rucno instalirat uvijek. Moras blacklistat kernel modul da se ne loada... https://linuxconfig.org/how-to-disab...al-fossa-linux Ak te zeza kod instalacije probaj ovu opciju dodat: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash modprobe.blacklist=nouveau"
#1827 |
PRO
Postovi: 4,760
hvala ti, probam. gleda sam oću li disableati module u kernelu, no mislija sam da ima neki jednostavniji način za disable, no zapravo ima smisla. ![]()
#1828 |
PRO
Postovi: 4,760
Evo pišem sa kompa, uspješno disablean driver. Jako fino radi ovaj Ubuntu KDE, stavio sam još Edna temu + Kvantum theme manager, jednostavno i lijepo izgleda. I naravno, btrfs. ![]()
#1829 |
Postovi: 4,876
#1830 |
#erase startup-config
Postovi: 3,711
BTRFS fuj. |
