Staro 08.11.2022., 08:31   #1801
tomek@vz
tomek@vz's Avatar
Postovi: 4,914
Nadam se da ne radis ALT-F2 pa sudo komanda...
...visudo...(/etc/sudoers nikad ali NIKADA ne editiraj rucno).
Po defaultu si vjerojatno u grupi koja ima pristup. Ak ne, brijem da su skemijali nekaj u kombinaciji sa seahorse (Passwords and Keys u GUI izdanju) da nakon logina te il ne pita il samo ponekad pita....Fedora 37 Gnome vrtim vec par dana i nisam naletio na taj problem.
P.S.- naravno mozda je i BUG u BETA verziji OS-a ...no sumnjam....
Staro 08.11.2022., 08:52   #1802
No123
Lokacija: Grad na Dravi
Postovi: 580
Stisnem Ctrl+Alt+t, otvori se terminal pa onda npr. sudo dnf upgrade i ne pita lozinku.
No123 je offline   Reply With Quote
Staro 08.11.2022., 09:22   #1803
tomek@vz
tomek@vz's Avatar
Postovi: 4,914
Autor No123 Pregled postova
Pogledaj ovo gore kaj sam napisao (visudo) + lupi "whoami" kad ti se terminal otvori...pa lupi tu info za sve.
Zadnje izmijenjeno od: tomek@vz. 08.11.2022. u 09:27.
Staro 08.11.2022., 09:26   #1804
No123
Postovi: 580
Fala ti ka bratu :-)
Staro 08.11.2022., 14:07   #1805
No123
Postovi: 580
Code:
:~> visudo
visudo: /etc/sudoers: Permission denied
i
Code:
::~> whoami
moje ime
Staro 08.11.2022., 14:43   #1806
tomek@vz
tomek@vz's Avatar
Postovi: 4,914
Code:
:~> visudo
i
Code:
::~> whoami
moje ime
visudo naravno izvodis kao root...dakle sudo su najprije pa onda visudo....
Staro 09.11.2022., 02:57   #1807
No123
Postovi: 580
visudo:
Code:
# Sudoers allows particular users to run various commands as
## the root user, without needing the root password.
## Examples are provided at the bottom of the file for collections
## of related commands, which can then be delegated out to particular
## users or groups.
## This file must be edited with the 'visudo' command.
## Host Aliases
## Sudoers allows particular users to run various commands as
## users or groups.
## Host Aliases
## Groups of machines. You may prefer to use hostnames (perhaps using
## wildcards for entire domains) or IP addresses instead.
# Host_Alias     FILESERVERS = fs1, fs2
# Host_Alias     MAILSERVERS = smtp, smtp2
## User Aliases
## These aren't often necessary, as you can use regular groups
## (ie, from files, LDAP, NIS, etc) in this file - just use %groupname
## rather than USERALIAS
# User_Alias ADMINS = jsmith, mikem
## User Aliases
## Command Aliases
## These are groups of related commands...
## Networking
# Cmnd_Alias NETWORKING = /sbin/route, /sbin/ifconfig, /bin/ping, /sbin/dhclien>
## Installation and management of software
# Cmnd_Alias SOFTWARE = /bin/rpm, /usr/bin/up2date, /usr/bin/yum
## Services
# Cmnd_Alias SERVICES = /sbin/service, /sbin/chkconfig, /usr/bin/systemctl star>
## Updating the locate database
# Cmnd_Alias LOCATE = /usr/bin/updatedb
## Storage
# Cmnd_Alias STORAGE = /sbin/fdisk, /sbin/sfdisk, /sbin/parted, /sbin/partprobe>
## Delegating permissions
# Cmnd_Alias DELEGATING = /usr/sbin/visudo, /bin/chown, /bin/chmod, /bin/chgrp
## Processes
# Cmnd_Alias PROCESSES = /bin/nice, /bin/kill, /usr/bin/kill, /usr/bin/killall
## Drivers
# Cmnd_Alias DRIVERS = /sbin/modprobe
# Defaults specification
# Refuse to run if unable to disable echo on the tty.
Defaults   !visiblepw
# Preserving HOME has security implications since many programs
# use it when searching for configuration files. Note that HOME
# is already set when the the env_reset option is enabled, so
# this option is only effective for configurations where either
# env_reset is disabled or HOME is present in the env_keep list.
Defaults    always_set_home
Defaults    match_group_by_gid
# Prior to version 1.8.15, groups listed in sudoers that were not
# found in the system group database were passed to the group
# plugin, if any. Starting with 1.8.15, only groups of the form
# %:group are resolved via the group plugin by default.
# We enable always_query_group_plugin to restore old behavior.
# Disable this option for new behavior.
Defaults    always_query_group_plugin
Defaults    env_reset
Defaults    env_keep =  "COLORS DISPLAY HOSTNAME HISTSIZE KDEDIR LS_COLORS"
Defaults    env_keep += "MAIL QTDIR USERNAME LANG LC_ADDRESS LC_CTYPE"
Defaults    env_keep += "LC_COLLATE LC_IDENTIFICATION LC_MEASUREMENT LC_MESSAGE>
Defaults    env_keep += "LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER LC_TELEPHONE"
Defaults    env_keep += "LC_TIME LC_ALL LANGUAGE LINGUAS _XKB_CHARSET XAUTHORIT>
# Adding HOME to env_keep may enable a user to run unrestricted
# commands via sudo.
# Defaults   env_keep += "HOME"
Defaults    secure_path = /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sb>
## Next comes the main part: which users can run what software on
## which machines (the sudoers file can be shared between multiple
## systems).
## Syntax:
##      user    MACHINE=COMMANDS
## The COMMANDS section may have other options added to it.
## Allow root to run any commands anywhere
root    ALL=(ALL)       ALL
## Allows members of the 'sys' group to run networking, software,
## service management apps and more.
# %sys ALL = NETWORKING, SOFTWARE, SERVICES, STORAGE, DELEGATING, PROCESSES, LO>
## Allows people in group wheel to run all commands
%wheel  ALL=(ALL)       ALL
## Same thing without a password
# %wheel        ALL=(ALL)       NOPASSWD: ALL
## Allows members of the users group to mount and unmount the
## cdrom as root
# %users  ALL=/sbin/mount /mnt/cdrom, /sbin/umount /mnt/cdrom
## Allows members of the users group to shutdown this system
# %users  localhost=/sbin/shutdown -h now
## Read drop-in files from /etc/sudoers.d (the # here does not mean a comment)
#includedir /etc/sudoers.d
Staro 09.11.2022., 07:48   #1808
tomek@vz
tomek@vz's Avatar
Postovi: 4,914
Ovaj dio je bitan:
%wheel ALL=(ALL) ALL <<< dopustenje da izvodis kao sudo komande - nakon upisa lozinke (uneses jednom i neko vrijeme ne pita)
# %wheel ALL=(ALL) NOPASSWD: ALL <<< dopustenje izvodenja komandi kroz sudo elevaciju bez upita za lozinku (onemoguceno)
Staro 09.11.2022., 08:20   #1809
No123
Postovi: 580
Tako mi je nekad bilo, prvi put pita lozinku nakon sudo, a onda neko vrijeme ne pita, a sad me ne pita nikako.
Staro 16.11.2022., 06:04   #1810
No123
Postovi: 580
Jučer se pojavila finalna verzija Fedora 37. Upgrade s bete radi.
Staro 18.11.2022., 15:24   #1811
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,791
Da li netko zna kako na Synology preko CLI pronaći razlog zašto se ne želi openvpn client spojiti na server?
U zadnje vrijeme (zadnjih mjesec/dva) na DSM 7.1 mi pukne openVPN veza (Synology je client, koji se spaja na openVPN server) i ne želi se spojiti ponovno.
Sve što probam ne radi, uključujući i ručno GUI i CLI spajanje.
root@DSNAS216:/usr/syno/etc/synovpnclient# /usr/syno/bin/synovpnc reconnect --protocol=openvpn --name=DSVPN
get arguemnt protocol: openvpn
get arguemnt name: DSVPN
Reconnect [DSVPN] ... failed
Retry(1)...failed
I to je to. Failed, ali nemam pojma zašto.
Ako napravim restart cijelog NAS-a, spoji se od prve, i tako sve dok ponovno ne zaglavi.
Zna li netko kako saznati što ga pati, gdje pukne.
Staro 28.11.2022., 13:52   #1812
c-shadow
c-shadow's Avatar
Postovi: 3,482
TP-Link vecinom dobro radi, najcesce out-of-the-box. Najcesce ti vec na kutiji lupaju tuxa
Realtek strikes again...
Evo onaj prethodni vikend sam se malo podružio s tp-link T4U, hardverska revizija v3.2
Code:
Bus 002 Device 011: ID 2357:0115 TP-Link
https://www.tp-link.com/us/home-netw...er/archer-t4u/
TL;DR
Ovaj post koji sam našao na redditu lijepo opisuje situaciju:
Why has RTL88x2BU not made it into mainline?
https://www.reddit.com/r/linux/comme...into_mainline/
"Because the driver is incredibly broken and no one is interested in fixing it."
Nema u kernelu drivera za tu reviziju iako je od 2018-19 vani, testirano na jubuntu kernel v 5.15, 5.19 i 6.0. Također na live gedori zadnjoj.
Ima nekoliko github repozitorija koji drže driver koji je isporučio tp-link, kompilira se bez problema.
Radi tak-tak, moglo bi i bolje. Pljucka čudne poruke u dmesg, po defaultu brzina je manja, radi kao da je USB/480Mbps. Može se modul učitati s posebnim parametrom, onda radi na punoj brzini, ali samo ako je uštekan u USB3 port. Ako se tako ušteka na USB2, onda ne radi, nekakav loop kod učitavanja modula.Postoji navodno eksperimentalni driver "rtw88-usb" kojeg nisam uspio nabrzinu kompilirati.
Nakon druženja od par sati sam odjebao to smetje i iskoristio taj stick na jednom windows 10 računalu. Tamo radi OOB, ali opet na manjoj brzini Nakon instalacije drivera s tp-link stranice, sada radi pod windowsima uredno, brzine pristojne.
Godinama sam izbjegavao wlan usb stickove na linuxu, vidim barem na ovom slučaju da se i dalje ništa nije promijenilo, support od proizvođača većinom loš i jedan veliki PITA za složiti
Tih par sati što sam se igrao s time, jednom kad se driver učita radi pristojno, ali jebo drivere gdje moraš paziti u koji USB port uštekaš tu kontrapciju
Staro 28.11.2022., 13:58   #1813
tomek@vz
tomek@vz's Avatar
Postovi: 4,914
Code:
TL;DR
Nemas srece Pada mi na pamet nesto sa Atheros cipovima ali s obzirom kak sam fulo motku gore sa "TP-Link just works"...jebiga googlaj , drugo nam ocito ne gine cim se "novoj tehnologiji" radi.
Staro 28.11.2022., 14:11   #1814
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,779
o da, atheros just works, koristim ga od 2006 do dana današnjega, nikad problema imao na linuxu, ali jesam bome na windowsima
Ivo_Strojnica je online   Reply With Quote
Staro 28.11.2022., 14:19   #1815
c-shadow
c-shadow's Avatar
Postovi: 3,482
Izgleda da je MTK dobro podržan, iz postova sa linka gore:
https://github.com/morrownr/USB-WiFi...nel_drivers.md
Što je isto fora izgleda da prve dvije revizije tod istog adaptera su imale nešto drugačiji chipset za koji imaju drivere u većini distri
Staro 28.11.2022., 17:01   #1816
domy_os
domy_os's Avatar
Postovi: 18,863
Koristi li netko aktivnije kombinaciju KDE, VirtualBox, TeamViewer i Flatpak aplikacije? Događa mi se to da miš djelomično prestane raditi, kao da se nađe neki nevidljivi layer između miša i aktivne aplikacije jer ga mogu pomicati, ali baš nigdje ne reagira na klikove i scroll. U Flatpak aplikacijama pak mogu klikati, ali ne radi scroll. Onda otvorim drugi TTY i u njemu restartam kwin, nekad je potrebno 2-3 puta da dođe k sebi. OS je Kubuntu 22.04.1 LTS, Plasma 5.24.6, nisam htio ubacivati neslužbeni repo za noviju.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 28.11.2022., 17:17   #1817
Dule
Dule's Avatar
Postovi: 648
Proizvođač koji je naveden na kutiji (u ovom slučaju, TP-Link) samo slaže wifi karticu oko nekog chipseta koji je proizveden od strane nekog drugog (Realtek, Atheros, Mediatek i sl). U puno slučajeva će kroz revizije uređaja promjeniti chipset, i staviti neki drugi.
Npr. TL-WN722N V1 je koristio Atheros koji je bio vrh što se tiče kompatibilnosti, i onda su u TL-WN722N V2 prešli na Realtek, dok u dućanu kutija ista, sve isto
Uvijek se konzultiraj sa https://deviwiki.com/ da vidiš što kupuješ. U tvom slučaju imaš ovo:
https://deviwiki.com/wiki/TP-LINK_Archer_T4U_v3
Dule je online   Reply With Quote
Staro 28.11.2022., 17:25   #1818
tomek@vz
tomek@vz's Avatar
Postovi: 4,914
Autor domy_os Pregled postova
Zato izbjegavam Flatpak i Snap ko kugu. Smrdi na Bug u smjeru hid/dbus (vidi jel ima u journalu ista korisnog u to vrijeme) drivera... al daj malo vise detalja kako ti se to dogada....session kroz TW i na klijentu s druge strane Virtualbox ili kak? Jel se isto dogada kad koristis Virt-Manager/qemu umjesto Virtualboxa? KDE bi mogo biti uzrok problema posto provodi komunikaciju na toj razini ali po onome kaj sam vidio KDE i Plasma su u zadnje vrijeme tolko ispolirani da bih prije okrivio TW/Virtualbox combo....
Staro 28.11.2022., 17:41   #1819
domy_os
domy_os's Avatar
Postovi: 18,863
Ma mrzim i ja, ali kad nekih app uopće nema kao deb pa sam osuđen na Flatpak, a Snap sam skroz maknuo. Bio sam ga koristio samo za Authy i to je radio jako bugovito pa sam sve OTP-ove prebacio u KeePass i Authy logično više nije trebao.
Na KDE imam oboje lokalno instalirano, TV koristim za spajanje na druge PC-e kod kuće i kod klijenata, a VB za izolirani VPN, testiranje aplikacija i koječega na drugim OS-ovima. Od drugih hypervisora imam još VMware i ista stvar i s njim. Tijekom prebacivanja iz app u app se sporadično pojavi taj problem, ne mogu ga namjerno reproducirati.
KDE u Kubuntu ne zapisuje skoro ništa logova u journalctl, nisam se sjetio pogledati xsession errors. Koliko je Fedora previše verbose, toliko ovaj "šuti". Kad se dogodi ovakav bug, onda nemam ništa, vidim samo FW logove gdje je blokirao neku konekciju i moje skripte što se vrte u pozadini.
Ma imam ja još bugova sa KDE, nije to sve, ali ovo me baš nervira.
Staro 28.11.2022., 17:46   #1820
tomek@vz
tomek@vz's Avatar
Postovi: 4,914
Back to basics onda nazalost (XFCE/LXDE) i probaj reproducirat problem.
P.S.- koje aplikacije nema kao deb pakete?
Staro 28.11.2022., 17:55   #1821
domy_os
domy_os's Avatar
Postovi: 18,863
Evo cijela lista da sad ne prepisujem...
Code:
domy@Domy-NB:~$ flatpak list
F: Filesystem suffix "create" is not applicable for --nofilesystem
Name                                              Application ID                                       Version                Branch            Installation
RetroShare-gui                                    cc.retroshare.retroshare-gui                         0.6.6                  stable            system
Flatseal                                          com.github.tchx84.Flatseal                           1.8.1                  stable            system
Video Downloader                                  com.github.unrud.VideoDownloader                     0.10.10                stable            system
Simplenote                                        com.simplenote.Simplenote                            2.21.0                 stable            system
Viber                                             com.viber.Viber                                      18.2.0.2               stable            system
XnView MP                                         com.xnview.XnViewMP                                  1.3.1                  stable            system
HandBrake                                         fr.handbrake.ghb                                     1.4.2                  stable            system
IntelMediaSDK plugin for HandBrake                fr.handbrake.ghb.Plugin.IntelMediaSDK                                       1                 system
FreeTube                                          io.freetubeapp.FreeTube                              0.18.0 Beta            stable            system
Flatpak External Data Checker                     org.flathub.flatpak-external-data-checker                                   stable            system
Freedesktop Platform                              org.freedesktop.Platform                             21.08.16               21.08             system
Freedesktop Platform                              org.freedesktop.Platform                             22.08.3                22.08             system
Mesa                                              org.freedesktop.Platform.GL.default                  21.1.8                 20.08             system
Mesa                                              org.freedesktop.Platform.GL.default                  21.3.9                 21.08             system
Mesa                                              org.freedesktop.Platform.GL.default                  22.1.7                 22.08             system
Intel                                             org.freedesktop.Platform.VAAPI.Intel                                        20.08             system
Intel                                             org.freedesktop.Platform.VAAPI.Intel                                        21.08             system
Intel                                             org.freedesktop.Platform.VAAPI.Intel                                        22.08             system
ffmpeg-full                                       org.freedesktop.Platform.ffmpeg-full                                        21.08             system
openh264                                          org.freedesktop.Platform.openh264                    2.1.0                  2.0               system
openh264                                          org.freedesktop.Platform.openh264                    2.1.0                  2.2.0             system
Freedesktop SDK                                   org.freedesktop.Sdk                                  21.08.16               21.08             system
Freedesktop SDK                                   org.freedesktop.Sdk                                  22.08.3                22.08             system
GNOME Application Platform version 40             org.gnome.Platform                                                          40                system
GNOME Application Platform version 42             org.gnome.Platform                                                          42                system
GNOME Application Platform version 43             org.gnome.Platform                                                          43                system
Breeze GTK theme                                  org.gtk.Gtk3theme.Breeze                             5.26.3                 3.22              system
KDE Application Platform                          org.kde.Platform                                                            5.15              system
Signal Desktop                                    org.signal.Signal                                    5.63.1                 stable            system
Telegram Desktop                                  org.telegram.desktop                                 4.3.1                  stable            system
Telegram Desktop Webview Add-on                   org.telegram.desktop.webview                         2.38.2                 stable            system
Zoom                                              us.zoom.Zoom                                         5.12.6.173             stable            system
Staro 28.11.2022., 18:49   #1822
tomek@vz
tomek@vz's Avatar
Postovi: 4,914
Code:
RetroShare-gui
We distribute current RetroShare for Ubuntu through our OBS repository. To add it you can use the following commands:
#1 source /etc/os-release
#2 wget -qO - https://download.opensuse.org/repositories/network:/retroshare/xUbuntu_${VERSION_ID}/Release.key | sudo apt-key add -
#3 sudo sh -c "echo 'deb https://download.opensuse.org/repositories/network:/retroshare/xUbuntu_${VERSION_ID}/ /' > /etc/apt/sources.list.d/retroshare_OBS.list"
Then install RetroShare with:
#1 sudo apt-get update
#2 sudo apt-get install retroshare-gui
Video Downloader > Youtube-DL (CLI-Only)
$ youtube-dl https://www.youtube.com/watch?v=Film-ID
$ youtube-dl -o '~/videos/film.mp4' Film-URL
$ youtube-dl -F Film-URL
$ youtube-dl -f Nummer Film-URL
$ youtube-dl --playlist-start 3 --playlist-end 5 Playlist-URL
Alternativno > https://www.4kdownload.com/
Simplenote
https://github.com/Automattic/simple...es/tag/v2.21.0
XnView MP > osobno preferiram nativne KDE/Gnome aplikacije zbog integracije u GUI
https://download.xnview.com/XnViewMP-linux-x64.deb
HandBrake > dostupan u universe repo
FreeTube
https://github.com/FreeTubeApp/FreeT...18.0_amd64.deb
Signal Desktop
https://signal.org/en/download/linux/
Telegram Desktop
https://www.how2shout.com/linux/how-...ackage_Manager
Zoom
https://zoom.us/client/5.12.9.367/zoom_amd64.deb
Viber
https://download.cdn.viber.com/cdn/d...inux/viber.deb
A sto se tice prvog problema > Xubuntu ak se drzis Ubuntu okruzenja i probaj reproducirat problem.
Staro 28.11.2022., 19:32   #1823
domy_os
domy_os's Avatar
Postovi: 18,863
RetroShare-gui
Simplenote
FreeTube
Signal Desktop
Telegram Desktop
Zoom
Viber
E svaka ti čast na ovome, stvarno si si dao truda, naklon do poda. Tražio sam ovo sve prije dvije god kada sam negdje počeo s Linuxom i postojao je valjda samo youtube-dl, a ovo sve drugo je trebalo komplajlirati što mi je overkill za toliko aplikacija. Bacam se u migraciju.
Staro 28.11.2022., 19:38   #1824
tomek@vz
tomek@vz's Avatar
Postovi: 4,914
Kad je Ubuntu u pitanju debian paketi su cesto kompatibilni ali moras pazit koju verziju opet instaliras. Tu moras malo pazit da ne skrsis neki interni lib dependency al najcesce sljaka
Staro 29.11.2022., 09:26   #1825
Ivo_Strojnica
PRO
Postovi: 4,779
Da vas pitam za savjet:
Imam laptop sa integrušom + nvidia karticom.
nvidia ne radi, krepala, pa isključivo vrtim windowse na integruši (samo disableam NVidia GPU u device manageru).
Ne mogu je disableati u BIOSu.
E sad, instaliram si Ubuntu na taj laptop, on odmah prilikom boota ima drivere od nvidie, pa mi ode boot kvragu.
U GRUB sam stavio nomodeset, pa se boota Ubuntu, no sad ne znam kako disableati GPU karticu.
Ima tko savjet?
Staro 29.11.2022., 09:35   #1826
tomek@vz
tomek@vz's Avatar
Postovi: 4,914
Ima tko savjet?
OpenSource driver je u svakom kernelu...Proprietary Nvidia driver od nvidie moras rucno instalirat uvijek. Moras blacklistat kernel modul da se ne loada...
https://linuxconfig.org/how-to-disab...al-fossa-linux
Ak te zeza kod instalacije probaj ovu opciju dodat:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash modprobe.blacklist=nouveau"
Staro 29.11.2022., 09:41   #1827
Ivo_Strojnica
PRO
Postovi: 4,779
hvala ti, probam.
gleda sam oću li disableati module u kernelu, no mislija sam da ima neki jednostavniji način za disable, no zapravo ima smisla.
Staro 30.11.2022., 20:43   #1828
Ivo_Strojnica
PRO
Postovi: 4,779
Evo pišem sa kompa, uspješno disablean driver.
Jako fino radi ovaj Ubuntu KDE, stavio sam još Edna temu + Kvantum theme manager, jednostavno i lijepo izgleda.
I naravno, btrfs.
Staro 01.12.2022., 07:47   #1829
tomek@vz
tomek@vz's Avatar
Postovi: 4,914
I naravno, btrfs.
Nepopravljiv Ja sam ga unazad mjesec dana koristio na Fedori, 2 tjedna ukupno. Sporiji je od EXT4 - a meni je osobno to trenutno najbitnije. Snapshotovi me ne hebu, za to imam rsnapshot backup i LVM
Staro 01.12.2022., 09:53   #1830
medo
#erase startup-config
medo's Avatar
Postovi: 3,714
BTRFS fuj.
