Staro 26.09.2022., 03:38   #1381
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,539
Da, ali je vecina zasnovana na istom engine, Chromium. Ako je to ogranicenje u enginu...Rijetko tko voli reklame al' isto tako rijetko tko je voljan platiti za sadrzaj na netu
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 26.09.2022., 05:26   #1382
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,625
Teorije zavjere na stranu, činjenica jest da će M3 spasiti korisnike od njih samih.
Za ilustraciju, bacite pogled na "related articles" na kraju ovog članka.
Krediti u švicarcima u browseru, ekvivalent toga.
Raja masovno radi sranja pa ih Google spašava s M3.
Adblockeri su collateral damage.
Staro 26.09.2022., 10:36   #1383
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,073
Ja se nadam da će Firefox dobiti na usage-u sad
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 26.09.2022., 10:37   #1384
Dottore
Dottore's Avatar
Postovi: 7,664
Autor Mario92 Pregled postova
Bojim da će Firefox i Opera završiti jer su na Chrome engine.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 26.09.2022., 10:39   #1385
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,421
hm, ffox sigurno nije na kromiumu, opera je
Staro 26.09.2022., 10:53   #1386
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,625
Da, skočit će na 50% garant.
Isto ko što su svi prešli na Linux nakon W8 debakla.
Isto ko što je FB propao nakon što su ih razotkrili da prodaju korisnike.
Isto ko što je 50% amerikanaca napustilo Twitter nakon što su bannali čovjeka za kojeg su glasali.
Isto ko što će HDZ izgubiti slijedeće izbore.
Staro 26.09.2022., 13:23   #1387
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,073
Autor Dottore Pregled postova
Firefox još uvijek ima svoj engine i ne daju se bez obzira na sve
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 26.09.2022., 13:31   #1388
Neo-ST
Neo-ST's Avatar
Postovi: 8,442
Autor kopija Pregled postova
Te stvari koje si naveo je ipak "malo" teže realizirati od...promjene defaultnog web browsera.
Kad malo bolje razmislim, jedino šta me veže za Chrome je sinkronizacija bookmarksa i historya između desktop Chromea i mobilnog, te automatski translate stranica na stranim jezicima, a siguran sam da se sve to može dobiti i na Firefoxu pomoću nekih pluginova.
Ako moram birati između toga i gledanja ad-ova, rješavam se Chromea bez problema.
Baš me zanima šta će Brave napraviti po tom pitanju.
Također ne zaboravimo i sistemske ad-blockere poput Adguarda, koji ne ovise o browseru niti pluginovima, ako netko baš hoće zadržati Chrome.
Staro 26.09.2022., 13:37   #1389
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,565
Vivaldi kako kažu ne bi trebao imat problema. Meni okej, Vivaldi mi je primarni browser već dulje vrijeme
AdGuard je naveo s čim se bore i kako je zadnja verzija ekstenzije slabija
Staro 26.09.2022., 14:34   #1390
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,803
Autor Neo-ST Pregled postova
FF Sync je dostupan već godinama.
Translate cijele webstranice nema ugrađen, ali vjerojatno postoji plugin.
Staro 26.09.2022., 15:28   #1391
Postovi: 10,119
Sve to je i mene vezalo za Chrome, pa sam davnih dana presao na Vivaldi koji radi jednako dobro i ima te funkcije. Trazio sam syncanje i castanje.
A reklame sam rijesio piholeom/raspberryjem na razini cijele mreze - ne na individualnim browserima/uredjajima.
Staro 26.09.2022., 15:30   #1392
Neo-ST
Neo-ST's Avatar
Postovi: 8,442
Autor xlr Pregled postova
Možeš na pm poslati kako si to izveo?
Hvala
Staro 26.09.2022., 15:45   #1393
Postovi: 10,119
U principu tutoriala ima milijon, a krenuo sam od ove teme:
http://forum.pcekspert.com/showthread.php?t=303543
Treba samo sada imati srece i naci rpi, em su cijene poludile, em ih nema vise na svakom koraku. Mozes traziti i mali zero w, zero wh, zero 2 - oni rade preko wifija pinkicu sporije nego preko lan-a.
Ako te bude sta konkretnije zanimalo, baci poruku u gornju temu ili na pm, ali bez brige, pratim temu
Staro 26.09.2022., 16:33   #1394
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,250
Mozes ga puknut i u docker container na nekoj pc masini, kako ti lakse.
Staro 26.09.2022., 16:42   #1395
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,803
Je offtopic, ali ne zanima kako ukloni reklame ako koristiš HTTPS?
Staro 26.09.2022., 16:57   #1396
Postovi: 10,119
Autor Cuky Pregled postova
Sve je dobro dok tu masinu ne rebootas (pre)cesto. Jer kada dns padne (a pihole je dns), kuca ostane bez neta A pitanje je koliko se nekome da uciti (u ovom slucaju) docker.
Autor Libertus Pregled postova
Nemam pojma, imas neki primjer? Danas su i ovako valjda svi sajtovi u https-u pa ne znam mislis li na nesto specificno.
Ne uklanja yt reklame, to treba naglasiti.
Staro 26.09.2022., 17:28   #1397
Dottore
Dottore's Avatar
Postovi: 7,664
Već ima svoj memory leak. Sa 30 otvorenih tabova pojede veselo 2,8gb memorije u loadu. Nakon 3 sata u loadu, ode na 3,4gb i primjeti se sporo čitanje stranica kao u ISDN vezi.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 26.09.2022., 17:31   #1398
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
A i da pihole radi samo doma, na kucnoj mrezi
MacBook M1 Pro
MacBook Air M2
Moto Edge
Zadnje izmijenjeno od: LAcy. 26.09.2022. u 17:36.
Staro 26.09.2022., 17:33   #1399
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,625
To je tih 50%, mislio sam na zauzeće memorije s 8GB rama
Staro 26.09.2022., 17:35   #1400
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,803
Ok, iz ovoga pretpostavljam da moraš tu mašinu narediti kao DNS server za cijelu mrežu. Vjerojatno samo jednostavno dropa domene koje su povezane sa oglašavanjem.
Staro 26.09.2022., 17:57   #1401
Postovi: 10,119
Autor LAcy Pregled postova
Ima nacina i da preko vpn-a (openvpn, wireguard, tailscale, vjerojatno i ostali) saljes dns upite kucnom piholeu - dok si vani. Ili koristis private dns (neka druga usluga nevezano uz pihole), ako pricamo o mobovima. Ma ima nacina, ja jednostavno ne vidim da je jedan add-on na jednom browseru na jednom uredjaju iole prakticno rjesenje. Blokiras reklame u browseru, ali ne i u appovima - na istom uredjaju. Blokiras reklame na jednom uredjaju, a sto je s drugim laptopima, mobovima koje imas. Sto sa tetkom koja i dalje browsa u IE-u. Tko to sve onda podesava, odrzava, ima li slobode da hendlas white/block liste. Noup
Tako je, pihole je dns resolver. Ako je nesto na blocklisti, vraca prazan odgovor.
Staro 26.09.2022., 18:43   #1402
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,250
Zato iza imam "pametan" router, u mom slucaju mikrotik koji sa skriptom provjerava svakih par min jel pihole ziv. Ako nije automatski prebaci dns na google npr. 😁
Staro 26.09.2022., 19:00   #1403
Postovi: 10,119
Ili slozen keepalived s dva rpi-ja/piholea na dva odvojena napajanja i ups-u, pa ako jedan rpi krepa, dobijem info i drugi ulijece na njegovo mjesto. Za nas s losijim ruterima
Staro 26.09.2022., 19:29   #1404
Taproot7
mag.math.
Taproot7's Avatar
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 363
otkad je firefox na chrome enginu
Taproot7 je offline   Reply With Quote
Staro 26.09.2022., 20:36   #1405
Postovi: 23,543
Prvo je bio gecko, pa od 58 ide quantum engine,
sad ide neki drugi ....
https://en.m.wikipedia.org/wiki/Geck...tware)#Quantum
Staro 26.09.2022., 22:17   #1406
Taproot7
mag.math.
Taproot7's Avatar
Postovi: 363
ali nije chrome i firefox vjerojatno nikad nece preci na chromium engine jer to onda vise nije firefox tj barem ne ono sto tvrde o sebi.
Staro 27.09.2022., 00:03   #1407
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,250
Trebas te silne rpi-je iskoristit za nesto bolje 🤓
Staro 27.09.2022., 00:59   #1408
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Da, to bas zvuci jednostavnije od installacije jednog plugina
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 10.10.2022., 11:41   #1409
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,191
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 19.05.2023., 12:16   #1410
Javorko
Postovi: 144
Poštovani svi,
ljubazno Vas molim za pomoć u svezi dragog nam Chrome-a.
Naime u zadnja 2 dana mi se Chrome konstantno ruši.
Pregledan plaćenim Nod32 (0 prijetnji).
Pregledan Malwarebytesom (0 prijetnji).
Očišćeni cookiesi, cache.....reinstal odrađen, ali ništa nije pomoglo.
Imam nešto ekstenzija (uglavnom vezani uz kripto i jedan password manager) - ništa egzotično.
Chrome se ruši kada otvaram/zatvaram tabove ili sam od sebe, gledajući YT videa.
(niije da imam premalo RAM-a.....32gb)
Komp je dovoljno jak da podnese i 20+ tabova.
Molio bih Vas sve savjet što mi je činiti kako bih ponovno omogućio korištenje Chrome-a.
Unaprijed hvala.
EDIT: kao da je sve počelo s instalacijom nove verzije Chrome, nisam 100% siguran.
Javorko je offline   Reply With Quote
