#5492 | ||||
Postovi: 8,530
Sudeći prema Correcting HDMI Colour on nVidia and AMD GPUs članku, problem je tak jasno u šrot HDMI i DisplayPort standardima. Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 21.06.2022. u 23:54. |
#5493 | |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
#5494 | |
Postovi: 8,483
#5495 | |
Postovi: 8,530
Da, nije samo kabel, već cijela skalamerija očito, pa ako driver nešto prepozna kao TV rezoluciju, ode odmah i postavka na Limited, umjesto na Full range. Čušpajz sve u svemu. Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#5496 |
Lokacija: Požega
Postovi: 1,268
Ponukan raspravom o hlađenju odlučio sam maknuti prednji poklopac na kučištu Antec NX600 ispred kojeg rade tri ventilatora. Sada mogu neometano radit pošto im ne smeta RGB plastika. Uz to sam vratio stakleni bočni poklopac koji sam prethodno bio skinuo. Temp grafe su pale sa 73 na 65 i hotspot sa 86.1 na 77.8 u max loadu. Fan speed je pao sa 1735(59%) na 1335(41%). |
#5497 |
Prvoklasni Krkan
Postovi: 5,369
Gledam ovo što spominjete za reprodukciju boja i čini mi se da ste mrvu fulali. Čini mi se da se uvijek svi referiraju na video dio u driverima (''adjust video color settings'' tab pod ''video''), a to je izgleda samo za video, tj filmove ili štogod. Kod mene je npr pod ''Display'' pa ''change resolution'' tabom ispod odabira rezolucije uredno bilo stavljeno na full. Znam jer sam neki dan instalirao nove drivere, a prethodno stare uvijek mičem sa DDU. I samo napomena, meni win update uvijek instalira drivere za monitor pa je možda do toga, ali uglavnom, meni je to već odabrano. Pod Video dijelom nije, e tu ga sam prebacim. Inače imate i ovo za provjeru: There's a test image online for confirming if your display is properly showing RGB Full range: http://www.lagom.nl/lcd-test/img/blacktest.png which is easy enough to verify, you set your source to Full, your display to Full (black level: normal etc) and confirm if you can see the first row of black squares. I ako vidite prvi red, sve je OK, meni se recimo na monitoru uredno vidi dok na telki ne. I to je normalno jer je većina telki limited, a većina monitora full. |
#5498 |
Mirko, a ne Harry
Postovi: 5,493
S obzirom da je RTX 20X0 tema zamrla, nadam se da je oke da tu pitam kad već pišete o tome.. Imam 2060 Gigabyte 6GB, vrijedi li da pričam po nekim postavkama? Nisam neki zahtjevan korisnik i ne igram neke prezahtjevne igre pa bi možda undervolta-o ili tako nešto?
Hala Madrid! |
#5499 |
Datum registracije: Feb 2021
Lokacija: TRPI
Postovi: 456
Ako ne igras zahtjevne igre i ako imas adekvatno hladenje kucista, onda nema smisla podesavati karticu, testiraj sa otvorenom bocnom stranicom kucista, mozda temperature budu jos nize ![]() |
#5503 |
Postovi: 1,706
Nisam par dana palio komp, danas dodjem, instaliram Etype USB header na PCIE USB 3.1 adapter i nece da upali. Po kodovima ispada da ne prepoznaje GPU. Skinuo adapter, probao clearat CMOS, nista. Ventilatori se zavrte prilikom boota, no onda prestanu raditi i pocne "bipikat". Jedan dugi, tri kratka. Jel moguce da je adapter na neki nacin ubio GPU. Radi se o ovom: https://www.amazon.de/-/en/gp/aw/d/B...?ie=UTF8&psc=1 Ostatak kompa Asus 3070 dual OC 8GB Asus Prime Z-690 D4 Wifi 12600k 2x16 GB Kingston Fury Beast DDR4 Asus TUF 750W Sve staro par mjeseci. https://youtu.be/DMsgODLOdFw ![]() Sent from my SM-S908B using Tapatalk Zadnje izmijenjeno od: jucca. 02.07.2022. u 16:12. |
#5504 |
Postovi: 8,530
Probaj izvaditi GeForce GPU, pa ostavi samo Intel iGPU i podesi video-izlaze na matičnu. Isto tak možeš GeForce, ako se ispostavi da Intel iGPU daje sliku, prebaciti u drugi PCI-E. ![]()
#5506 |
Postovi: 8,530
F modeli nemaju iGPU, ali ako i iGPU ne prolazi onda možeš probati sve rastaviti, pa samo na stolu upogoniti CPU + iGPU, RAM, MBO i PSU, tak da eliminiraš ostale komponente. I provjeri za svaki slučaj da ti je u BIOS-u podešeno da se koristi iGPU za video izlaze, da ne ispadne da sve radi bez GeForce GPU, samo je bilo do postavke u BIOS-u. Možeš komotno i CPU izvaditi, pa Clear CMOS kad je sve na stolu rastavljeno, bez GeForce GPU-a, jer ako ni tada nemaš slike pomoću iGPU-a, onda je moguće ploča otišla.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 02.07.2022. u 17:37. |
#5507 | |
Postovi: 1,706
Skinuo sve, osim keksa memorije i proca, i opet isto. Problem je što ne mogu ni do BIOS.a. ne daje sliku. Sent from my SM-S908B using Tapatalk |
#5508 |
Postovi: 8,530
Nadopunil sam prethodni post, pa eventualno još da probaš ovaj dio s CPU-om, van iz socekta i nazad na mjesto uz Clear CMOS.
#5512 | |
Postovi: 1,706
Probam prije karticu kod prike, i usput pastu uzet ako bude trebalo proc vadit. Hvala ti 👍 Sent from my SM-S908B using Tapatalk |
#5513 |
Postovi: 1,706
Rjeseno. Probao grafu kod prike, radi sve. Nakon sto je cijelu noc ploca bila bez baterije, upalila je i dala sliku na iGPU. Vratio karticu, sve radi. Dodjem doma, ustekam monitor (43" Samsung UW CJ9), opet isto. No GPU detected. Ustekam drugi monitor na drugi DP, napokon boota, i naživo spojim ponovo 43" Samsunga, i sad konacno, sve radi. Ne kuzim sta mu bi. Sent from my SM-S908B using Tapatalk |
#5514 |
Lokacija: TRPI
Postovi: 456
@jucca Imao sam takav problem kad sam spajao DVI to HDMI adapter na R9 255, kad sam stavio kvalitetniji HDMI kabel proradilo je. |
#5516 |
Datum registracije: Jan 2010
Postovi: 392
Može vaše mišljenje, RTX3070 (Gigabyte Gaming OC ili MSI Gaming Z Trio) ? Ako sam dobro shvatio, MSI je nešto hladnija i nešto tiša ? Kakve su razlike po performansama ? Možda više nekako naginjem ka MSI, ali koliko vidim registracijom direktno na Gigabyte, dobije se 4 godine jamstva, dok je na MSI 3 godine ako se ne varam ? Btw., cijena je identična, sve ostalo nebitno. Unaprijed hvala Zadnje izmijenjeno od: zig. 24.07.2022. u 16:57. |
#5517 | |
¯\_(ツ)_/¯
Lokacija: Sibenik
Postovi: 1,156
