Staro 15.02.2006., 23:56   #1
mat
Postovi: 2,105
nova konfiguracija
evo da uletim na forum s necim pametnim (ili mozda ne) ?
sto mislite o ovoj konfiguraciji, buduci da je cijena recimo nebo tj. vise love od toga nemam heh
cim ju sklepam namjeravam staviti vistu beta a kad sluzbeno izade i cijelu originalnu (to navodim tek tolko da su jasni zahtjevi - ne halam igrice [ok samo WoW ] )
eto pa recite, kako vam se svida i sto bi, u tom rangu cijene, vi mozda promjenili?
MBO ASUS P5ND2 SLI, nForce4 SLI IE, DDR2, zvuk, G-LAN, S-ATA, PCI-E, s. 775
Socket775 for IntelR Pentium Processor Extreme Edition / Pentium D* / Pentium 4 / Celeron CPU
Compatible with IntelR 05B/05A and 04B/04A processors
IntelR EM64T/ EIST*/Hyper-Threading Technology
* Refer to www.asus.com/support for IntelR Pentium D CPU and EIST support list
Chipset
NVIDIAR nForce4t SLI IntelR Edition
NVIDIAR MCP-04
Front Side Bus
1066 / 800 / 533MHz
Memory
Dual channel memory architecture
4 x 240-pin DIMM sockets support max. 8GB DDR2 667/533 non-ECC memory
Support NVIDIA DASP 3.0 (dynamic adaptive speculative preprocessor) and QuickSync features
Expansion Slots
2 x PCI Express x16
- SLI mode: x8, x8
- Default (Single VGA) mode: x16, x1
2 x PCI Express x1
3 x PCI
PCI 2.2
SLI
Under SLI mode: support two identical SLI-ready graphics cards
Under Default(Single VGA) mode:
- 1 x PCI Express x16 graphics card on the first slot (blue)
- 1 x PCI Express x1 card on second slot (black)
ASUS EZ Selector
ASUS EZ Plug
ASUS SLI Warning LED
ASUS two-slot thermal design
ASUS PEG Link for dual PCI Express graphics cards
Storage/RAID
NVIDIAR MCP-04 Southbridge supports NVRAID
- 2 x Ultra DMA 133/100/66/33
- 4 x Serial ATA 3 Gb/s
- NVRAID: RAID0, 1, 0+1, 5, and JBOD span cross Serial ATA and Parallel ATA drives
- Supports multi-RAID
- Supports up to 8 drives for RAID function
LAN
Intel 82540EM Gigabit LAN controller
Audio
Realtek ALC850 8-channel CODEC
Universal Audio Jack
Audio Sensing and Enumeration Technology
Coaxial/Optical S/PDIF out ports on back I/O
USB
Supports up 10 USB2.0 ports
Overclocking Features
Intelligent overclocking tools:
- AI NOS(Non-delay Overclocking System)
- AI Overclocking (intelligent CPU frequency tuner)
- ASUS PEG Link - Automatically performance tuning for single/dual graphics cards
- ASUS CPU Lock Free
- ASUS Ai Booster Utility
Precision Tweaker:
- vDIMM: 8-step DRAM voltage control
- vCore: Adjustable CPU voltage at 0.0125V increment SFS (Stepless Frequency Selection)
- FSB tuning from 133MHz up to 400MHz at 1MHz increment
- Memory tuning from 400MHz up increment
- PCI Express frequency tuning from 100MHz up to 150MHz at 1MHz increment
Overclocking Protection:
- ASUS C.P.R.(CPU Parameter Recall)
Other ASUS Special Features
Fanless Design
AI NET2 network diagnosis before entering OS
CrashFree BIOS 2
Q-Fan
MyLogo2
EZ Flash
Multi-language BIOS
BIOS
4 Mb Flash ROM, AWARD BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3
Back Panel I/O Ports
1 x Parallel
1 x Coaxial S/PDIF Output
1 x PS/2 Keyboard
1 x PS/2 Mouse
2 x RJ45
4 x USB 2.0/1.1
8-Channel Audio I/O
Internal I/O Connectors
1 x SLI selector card connector
3 x USB connectors supports additional 6 USB 2.0 ports
1 x COM connector
1 x GAME/MIDI connector
CPU Fan / 2x Chassis Fan/ Power Fan connectors
Front panel audio connector
Chassis Intrusion connector
CD / AUX audio in
24-pin ATX Power connector
4-pin ATX 12V Power connector
4-pin EZ Plug power connector
Support CD
Drivers
ASUS PC Probe 2
ASUS Update
ASUS AI Booster
NVIDIA RAID
Anti-virus software (OEM version)
Accessories
1 x SLI connector
1 x SLI retention bracket
2 x SATA cables
SATA power cables for 2 devices
1 x UltraDMA 133/100/66 cable
1 x IDE cable
1 x FDD cable
1 x I/O Shield
User' s manual
Form Factor
ATX Form Factor, 12''x 9.6''(30.5cm x 24.5cm)
CPU INTEL Pentium 4 630 3000 MHz BOX, socket 775, 2 Mb c., FSB 800MHz, 64 bit
CPU Socket Standard: Socket 775
Requires System Board Central Processing Unit Bus Clock Rate: 800 MHz
Architecture Features: Streaming SIMD Extensions 3, Hyper-Threading Technology, Streaming SIMD Extensions, Streaming SIMD Extensions 2
Die Size: 90 micron
Cache Memory
Provides L2 Cache Memory Storage Capacity: 2048 KB
Dimensions&Weight
Nominal Weight: 0.634 kg
Cooler ZALMAN CNPS7000B-Cu, socket A/370/478/754/939
The 7000B has slightly improved upon the 7000A heatsink not only in performance, but in an 18g weight reduction. The 7000B comes with the easy-to-use Fan Mate 2, and even includes a high strength fiberglass reinforced plastic Backplate for use with AMD Sempron/AMD64 motherboards.
CNPS7000B-Cu
- Dimensions : 109 (L) x 109 (W) x 62 (H) mm
- Weight : 755g
- Base Material : Pure Copper
- Dissipation Area : 3,154 cm2
- Bearing Type : 2-Ball
- Speed : 1,350 č 2,600 rpm
- Thermal
Resistance : 0.27 č 0.20 ˇĆC/W
- Noise Level : 18.0 č 27.5 dB
FAN Speed Controller (FAN MATE 2)
- Dimensions : 70 (L) x 26 (W) x 26 (H) mm
- Weight : 20g
- Output Voltage : 5V č 11V ˇľ 2%
- Allowable Power : 6W or lower
- Connector : 3-Pin
ˇŘ Directions for Use
Napajanje LEVICOM 450W, VisiblePower, black, blue, dual fan, ATX2
Total output 450 Watts
+ 3.3 V of 26 A
+ 5 V of 28 A
+ 12 V of 30 A
- 5 V of 0.3 A
- 12 V of 0.8 A
+ 5 V of Vsb 2.0 A
max. Combined power (+5V, 12V and +3,3V) 430 Watts
number of 4-Pol Molexstecker 8 pieces
number of S-ATA 1 plug
2 pieces of ATX Main board plug 20 pole
number of exhausts 2 pieces
width approx.. 150 mm
height approx.. 85 mm of
depth approx.. 170 mm
20/24 PIN ATX2
RAM PC-4200, 512MB, DDR2, KINGMAX, DDR 533 MHz
DDR 2 memorijski modul
Kapacitet:512 MB
PC-4300
Radni takt: 533 MHz
VGA PCI-E SAPPHIRE ATI RADEON X550, 128MB DDR, DVI, TV
Chip set: X550
Engine clock: 400MHz
Memory clock: 500MHz
Memory interface: 128 bit
Memory Support: 256 MB
Bus Interface: PCI - Express
Variable Display Outputs: VGA + TV out + DVI
Max 3D resolution: 2048 x 1536 @ 85Hz (VGA); 1024 x 768 (TV out)
Hardware Features:
DirectXR 9
SmartShadert 2.0
SmoothVisiont 2.1
Fullstreamt
Software Feature: HydravisionTM
HDD 160.0 GB SEAGATE, Serial ATA II, 8MB cache, 7200.9
a sve to ću potrpati u:
Kućište Frontier Meridian ME09A/BK, crno, 400W ATX2, rev 2.0
TYPE MIDDLE TOWER
MAIN BOARD FULL SIZE(K7/P4)2BAY
DRIVE SPACE 5.1/4'' 4
DRIVE SPACE 3.1/2'' 4(4 HIDDEN)
EXPANSION SLOTS 7
POWER SUPPLY PSII / PSIII(Horizontal)
DIMENSION(LxWxH) 425x200x430mm
eto...
ukupno kartica: 5.745,83 KN
ukupno gotovina: 5.379,07 KN
e da i za staru mašinu koja će mi bit router/server i stajat na balkonu trebam uzet nešto tipa ovo:
14` max, crnobijeli bilokakav samo nek radi, 50kn dam max pa ak netko zna ili ima usput, nek se javi
btw trenutno imam nelošu ali dosta staru kantu sa asusovom pločom, 512 DDR-a, celeronom ( ) 2,8 gHz i rivom TNT-2 koja je svojedobno rokala tržište heh
mat je offline   Reply With Quote
Staro 16.02.2006., 00:40   #2
psf[i]-[Tomek]
-nVidiot-
psf[i]-[Tomek]'s Avatar
Lokacija: Varaždin/Zabreg
Postovi: 962
Pošto namjeravaš staviti Vistu ako ju želiš gledati u punome sjaju neće ti baš X550 biti dosta ... Btw ni G71 (7900) nisu Vista ready!
Ako se ne varam nVidia se baš nije proslavila sa čipsetom za Intel... Mislim da su Intelova rješenja kvalitetnija.
psf[i]-[Tomek] je offline   Reply With Quote
Staro 16.02.2006., 00:52   #3
mat
Postovi: 2,105
mislis da x550 nece biti dosta? hmmmmmmmmmmmmmmmmmmmm
sto se tice maticne pokusavao sam i pokusavao ali nisam mogao naci nijednu bolju koja mi fura ddr2 i ima kolko-tolko valjanu podrsku za P4
ako bih mjenjao maticnu onda bi skinuo ddr2 i metnuo agp i to nvidiinu
hmmmmmmm neznam :/
Staro 16.02.2006., 00:58   #4
psf[i]-[Tomek]
-nVidiot-
Postovi: 962
Gle full support bu tek imal G80/R600 zgog DX10! Kužim te... Kolko dođe uopće ta ploča? Ja nisam baš neki ljubitelj ASUS-a.. Imaš u HgSpotu Abiticu za 1200Kn.. nVidia je nedugo predstavila nove chipsete za Intel... Jedan Ultra i dva SLI-a (2 puta 8 staza i 2 puta 16 staza - osnovna razlika). Da malo pričekaš da to stigne?!
Ako ti netreba 3D "shit" onda ti bi i MX400 bila dosta
Staro 16.02.2006., 01:06   #5
mat
Postovi: 2,105
to recimo nisam uopce vidio o cemu pricas...
budem bas proguglao
gledaj na stvar ovako:
nisam ni mislio imati konfu tip-top spremnu za vistu s ovim - NARAVNO DA NE!
ali za instalirati betu, procackati po svim rupama, novotarijama, glupostima i potrebnosti je cini mi se ovo ok.. neznam budem jos malo pogledao onu listu sto je allen cini mi se objavio u nekom intervjuu (heh treba i to sad opet iskopat)
a ovo cu i za 6-7 mjeseci moc uvalit za dobru lovu i opet uzet novo, kvalitetnije ili adaptivnije za vistu jel
sve se svodi na spremnost 2007. kad svi pocnu manijakalno sorat vistu na kompove pa kad zapne... a koga ce zvati? sve neki xp strucnjaci... - eto mene hehe
Staro 16.02.2006., 01:39   #6
E.T.
E.T.'s Avatar
Postovi: 2,458
Intel 955X imho najbolji chipset za Pentium4 procesore...
To sta bi Vista trebala donjeti DirectX10 to ne znaci da ce DirectX10 graficke biti potrebne za njeno pokretanje, vec se samo navodi da je preporuceno imati 128 MB memorije na grafickoj...
@mat
smiri malo dojmove...moze?
novi si tu a vec dobivam pm-ove sa prituzbama....
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 16.02.2006., 01:49   #7
mat
Postovi: 2,105
k k, isprike
iako stvarno neznam zbog cega ali velim, isprike svima kojima sam nanio psihicko stanje u kojem su morali slati prituzbu :/
Staro 16.02.2006., 04:05   #8
Lvx Demos
Postovi: 37
Gotta love forums...
mat - ako smijem predložiti... Nema smisla "pripremati se" za Vistu kad i sam Micro$oft nezna kaj će na kraj bit unutra a kaj ne. Do bete 2 su izbacili pol tog kaj je bilo u beti 1. Tek kad se prašina slegne, znat će se dali je Vista zapravo bolja od Xp. No čak i da nije, pretpostavljam da će svi preć na Vistu zbog marketinga i hypea. Ako se sjećaš, tako je i bilo s XPom koji je samo maknuo BSODe i zamjenio ih za "Send error report to MS". Znači ne resetira se više čitav komp već samo kernel. Jeeej!!
A što se tiče novog hardvera, zbilja ne razumijem zašto kupovati komponente za betu koja, po definiciji, mora bit bugovita i neoptimizirana. A i ovak i onak neće trebati više od integriranog GPUa za Vistu. Pa nije M$ lud da shebe sve one poslovne korisnike. Nebu valjda oni kupovali 7800GTXice za Office i Solitaire!?! :confused:
Moja preporuka je da kupiš zbilja dobru matičnu i proc pa pričekaš izlazak viste za novu generaciju grafičkih.
PS - nemoj molim te u ime svega dobrog i svetog na ovome svijetu više postati sve te specifikacije koje si našao na netu. Ili to ljudi već znaju ili si mogu nać ako žele. Zašto misliš da mi moramo znati koliko ležajeva ima tvoj odabrani hladnjak??
I ja sam nov ovdje, ali ipak znam da nije razumno kopirat slikice diska u post... BTW kad to već nitko nije rekao, welcome!
Lvx Demos je offline   Reply With Quote
Staro 16.02.2006., 11:29   #9
mat
Postovi: 2,105
I ja sam nov ovdje, ali ipak znam da nije razumno kopirat slikice diska u post... BTW kad to već nitko nije rekao, welcome! [/B]
nisam ih našao na netu, na jednom sajtu trgovine u kojoj kupujem
mislio sam da bi bilo interesantno, ekipa je raznolika pa kao što kažeš svi to ili vec znaju ili nemaju pojma sto znaci pa je stvarno, nepotrebno
nebum vise
a to je inace c/p s jednog drugog foruma
sve u svemu, kako vam se svida konfiguracija za tu cijenu?
Staro 16.02.2006., 11:30   #10
mat
Postovi: 2,105
i hvala na dobrodošlici
Staro 16.02.2006., 13:35   #11
veve
woot!!!
veve's Avatar
Postovi: 2,494
Bas ti mora biti INTEL konfa ili moze i AMD biti?
Kolko vidim ovaj zalmanov cooler ne podrzava sck 775!
veve je offline   Reply With Quote
Staro 16.02.2006., 13:41   #12
ZED
a.k.a. LOPOV
ZED's Avatar
Postovi: 2,022
Tu plocu nemoj uzimat, ako ims love uzmi p5wd2, ako ne onda p5ld2 koja dođe tu negdje kao i ova sa nvidijom
Edit sad sam vidio da nemas love znaci p5ld2
Hdd ne taj segate nego hitachi sata 2 160 taj je 20kn skuplji a dosta bolji
Hladnjak ne taj zalman vec freezer 7pro ili thermaltake sonic tower
I napajanje, recimo chieftek 400W il 410w
Al prije 400w
Zabranjene reklama u sigu.
Staro 16.02.2006., 13:57   #13
Lvx Demos
Postovi: 37
Vidi fakat...
Taj Zalman ti neće ić na tvoju matičnu, heh uzmi radije Titan Vanessu L Type ili Thermaltake Big Typhoon. Osim toga jesi li siguran da ti treba hladnjak? Jer ako nemisliš overclockat hladnjak koji već dolazi sa procesorom (u BOX verziji) je sasvim dosta.
Jesi siguran da ti treba SLI izvedba matične ploče? Jer to ti nebu išlo s ATIjem. :confused: SLI je za NVidiu a Crossfire za ATI, ali mislim da tebi nijedno ni drugo nije potrebno, pogotovo ako misliš uzeti tu grafičku.
Čuj, nemoj se ljutiti ali moram pitati... Koliko ti uopće znaš o računalima? Kao tek si počeo ili jednostavno se nisi dosada bavio hardwareom?
Staro 17.02.2006., 14:53   #14
mat
Postovi: 2,105
ne ljutim se i ne mogu se nazvati pc ekspertom ali ne mogu reci da o hardwareu znam malo... znam dosta a sto se ti ce coolera sam izgleda fulao (iako neznam kako bas sam pazio na sve budem pogledao)
cooler mi treba posebni jerbo koristim kompjuter za razne namjene (nerijetko odjednom) i doista tlacim proc tako da se za tih 100-200kn hladnjaka mislim isplati biti siguran
da i sto se tice SLI maticne - prvobitan plan JEST bio uzeti nvidiu ali nisam mogao naci toliko jeftinu PCI-E pa sam se odlucio za ovu
to bih isto trebao provjeriti dali stvarno ne pase
i da, mora biti intel konfa, ne volim amd
Staro 17.02.2006., 15:21   #15
dDario
dDario's Avatar
Datum registracije: Jun 2004
Postovi: 1,567
BOX hladnjaci su postali mrcine ko i ovi za OC tak da prvo pogledaj kako radi prije nego daš XXXkn za drugi hladnjak. Ploču neku ASUS sa intel chipsetom, napajanje Chiftec 410W je i više nego dosta i za duplo jače konfe. A za HDD moram reć da mi je porikavalo sve osim Seagatea.
dDario je offline   Reply With Quote
Staro 17.02.2006., 16:34   #16
E.T.
E.T.'s Avatar
Postovi: 2,458
A koja je namjera te konfiguracije (osim pokretanje operativnog sustava )?
Ono sta ljudi zele reci da kupujes najjeftiniju graficku karticu i SLI plocu! Sta zelis u buducnosti uzeti dvije 6800GS ili 7800GT (iskesirati 3000-5000Kn za graficke kartice zbog 20-60% povecanja perfomansi u pojedinim igrama)?
Staro 18.02.2006., 16:23   #17
mat
Postovi: 2,105
NE IGRAM IGRICE!
ma igram WoW al za to je ionako dobra skoro svaka konfa tako da se ne mjerim prema tome
sto se tice maticne i graficke... graficka mi je bitno da bude pci-e i ima bar 128 ddr-a sto mislim da je sasvim u redu za pokretanje PS-a, freehanda, FL-a i slicnih gluposti kojima se bavim
i vidio sam da si stavio na tvrdnju da ce se konfa koristiti za podizanje OS-a => pa da, upravo o tome se radi. ako se necim bavim onda su to OS i njegove pikanterije a da si pazljivije citao sto sam napisao gore znao bi da mi cilj i je raditi NA OS-u te mi za to i treba novi hardware
Staro 18.02.2006., 23:00   #18
Lvx Demos
Postovi: 37
ROFLMAO...
Staro 18.02.2006., 23:33   #19
psf[i]-[Tomek]
-nVidiot-
Postovi: 962
Originally posted by E.T.
Nazalost i prepazljivo sam procitao sve tvoje postove i dosao do vrlo jasnih spoznaja koje cu zadrzati za sebe...
Ajde budi drug... Postoji i PM ako nećeš baš na "sva zvona"...
Staro 18.02.2006., 23:42   #20
E.T.
E.T.'s Avatar
Postovi: 2,458
Ej, necemo spamati...ja sam pobrisao svoj post...ako tko hoce pomoci covjeku nek posta...dosta OT..
