#9541 |
Datum registracije: Aug 2020
Postovi: 898
Pa zar će i Intel koristiti "ljepilo"? ![]() |
#9542 |
Postovi: 8,330
Ne samo to, nego je cijela stvar prezentirana kao njihova ideja i inicijativa. ![]() ![]()
#9544 |
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,191
Russia’s invasion of Ukraine adds to pressure on chip supply chain https://www.ft.com/content/ac8733c4-...8-4997a77ad33f Ukraine Crisis Cuts Neon Supply And Could Worsen Chip Shortage https://www.motor1.com/news/571764/u...p-crisis-neon/ TSMC 3nm Yield Problems May Derail AMD's CPU Plans https://www.tomshardware.com/news/ts...amds-cpu-plans TSMC Potentially Facing 3nm Yield Problems, Could Spell Problems For AMD & NVIDIA, Opportunity for Intel https://wccftech.com/tsmc-potentiall...ity-for-intel/ Ukraine supplies 70 percent of the world's output of neon, a critical gas that runs lasers needed to manufacture microchips. Nekoliko mjeseci "stari" ali itekako relevantni video uradci:
![]() /connect 185.107.96.125:28990 server rcon: oldschool COD2 PCekspert ekipa https://discord.com/invite/zZ4PeqVpBv Zadnje izmijenjeno od: Blue Spirit. 10.03.2022. u 16:57. |
#9545 | |||
Postovi: 8,330
![]() ![]() ![]() ![]() Citiraj:
#9546 |
Datum registracije: Feb 2021
Lokacija: TRPI
Postovi: 456
Kad se mogu ocekivati Apu 6000 za desktop? Laptopi sa Apu Rdna 2 grafikom su vec u prodaji. |
#9547 | |
Postovi: 8,330
AMD Ryzen 7000 "Raphael" Zen 4 CPU enter mass-production by April-May? ![]() Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 Zadnje izmijenjeno od: The Exiled. 30.03.2022. u 14:45. |
#9548 | |
Postovi: 8,330
AMD's Phoenix APU will reportedly challenge Nvidia's mobile RTX 3060 with integrated graphics ![]() Citiraj:
#9549 |
Postovi: 8,330
#9550 | |
Postovi: 8,330
AMD signals its intent to showcase Zen 4 at Computex 2022 ![]() Citiraj:
#9551 |
Prvoklasni Krkan
Postovi: 5,309
Kreće lagano vlakić za Zen4: TLDR: 5,3-5,5ghz SC boost 5.0ghz AC boost Svi Ryzeni će imati RDNA2 iGPU kao i Intelovi procovi cca 15% veći IPC u odnosu na Zen3 2 chipseta tj kao fol 3: -X670 extreme za OCere -X670 normalan -B650 PCIe 5.0 samo za nvme, grafa je valjda 4.0 Zadnje izmijenjeno od: Disco. 23.05.2022. u 16:42. |
#9553 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
IPC će vjerojatno biti veći za 3-5%, ako uopće bude i toliko, AMD je sad samo rekao za ukupne ST performanse da su najmanje 15% više od Zen 3. To ukuljučuje IPC + clock. za B650 može i slot za grafičku biti 5.0, ali nije obavezno. Ionako taj slot ide direkt iz CPU-a i nema veze s chipsetom.
#9554 | ||
Postovi: 8,330
IMHO na kraju budu IPC računice slične onima (1 - 2) za Zen 3, ali morali budemo pričekati službene recenzije za detalje, mada sve u svemu izgleda obećavajuće. Nagurali su dosta toga u novu platformu. Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 Zadnje izmijenjeno od: The Exiled. 23.05.2022. u 18:54. |
#9555 |
Prvoklasni Krkan
Postovi: 5,309
Ma kakogod bi IMHO trebalo pričekati Zen5, a i više detalja o Zen4. Heatspreader mi izgleda grozno i tu će biti fešta kada se pasta zavuče posvuda. ![]() Nadam se da su ovaj put poradili na disipaciji topline, pa da će se toplina bolje prenositi nego na Zen 2 i 3. A i vidim ne spominje se 3DC, dakle i u ovoj genreaciji će to biti za ''gaming'' CPU-e izgleda, to sam i pomislio. Najbolja stvar mi je iGPU, to je spas ako crkne grafa. Spominje se da će to biti nešto jako rudimentarno, a da bi trebali izaći i APUi sa jačim RDNA iGPU-ima. No to su sve nagađanja dok ne dobijemo potvrdu. ![]() |
#9556 | |
Postovi: 898
#9557 | |
Postovi: 14,584
Također uspoređuju sa običnim Zen 3, ne i sa ovim 3d chache, pa je pitanje koliko i dali će to biti brže od 5800X3D u singlethreadu, gamingu.... Ispada da bi takve performanse, odnosno malo bolje samo postale standard po svim linijama, a ne kao ovaj 5800X3d, kao poseban skupi gaming cpu BTW ovaj zen 4 je dizajniran naknadno, jer su u doba Jim Kellera udarili temelje sve do zen 3. Nadam se da zen arhitektura ne posustaje, no bez nekog velikog IPC pomaka, tu nije ni napravljen core/thread bump, tako da iskreno nisam nešto jako impresioniran. Jedino je clock impresivan, no tu je vjv node odradio svoje Priča se da ni Raptor Lake nema neki veliki IPC bump (cca 5%), što nije u skladu s drugim leakovima, tako da je sve upitno. No i intelu će clock rasti, te bi efikasnost trebala biti bolja |
#9558 |
All-rounder
Datum registracije: Sep 2013
Postovi: 1,335
Da, ovo se više čine kao poboljšanja proizvodnog procesa nego pomaci u arhitekturi. Pitanje je da li će stavljati taj dodatni cache, imaju li taj dizajn planiran (odnosno već mora biti gotov) ili dolazi kasnije kao refresh, i kako će to tehnički funkcionirati pokraj povećane potrošnje (170W). Možda je dobitak od cachea manji od dobitka na frekvenciji, pa ga nema smisla stavljati na ovako vruć procesor? |
#9559 |
Postovi: 8,330
Čisto da se poCjetimo: Kaj se same Zen 4 arhitekture tiče, obzirom da pripremaju 96 i 128-core modele EPYC modele, posustajanja nema, jedino desktop ostaje na "samo" 16C/32T kombinaciji, ako se i to do jeseni ne presloži, jer nije ovo prvi put da AMD nešto pokaže, a na kraju imaju još toga za dodati, a da nije bilo u procurenim materijalima diljem neta. Sve u svemu IMHO, AMD nakon svega kaj su dosad plasirali na tržište, ne bude odustal samo tako, mada bude se Zen arhitektura u jednoj od svojih nadolazećih iteracija sigurno izmijenila skoro kompletno. Mislim, od 2017. i Intelovog ismijavanja, u 5 godina smo došli do toga da Intel radi iste stvari koje je AMD prezentiral s prvom Zen generacijom, tak očito nekog vraga rade kak spada: chiplet dizajn, MCM pristup svemu, stacked + infinity cache i ko zna kaj još imaju spremno za godine koje dolaze.
#9560 | |
Postovi: 14,584
#9561 |
Postovi: 8,330
Tak i bude, 3D cache Zen 4 modeli kasnije, a 3D cache općenito je primarno namijenjen EPYC modelima, dok usput ima koristi od toga na drugim sistemima i sustavima.
#9562 | ||
MadModerator
Lokacija: N/A
Postovi: 5,195
Ryzen 7 5800X3D ima cca 35% slabiji rezultat u 1T CB R23 testu od 12900KS, ali u igrama su izjednačeni. Citiraj:
5800X3D ima all-core clock od oko 4,3 GHz, 5800X ~4,6 GHz.
#9563 | |
Postovi: 898
#9564 |
Postovi: 8,330
#9566 | ||||
Postovi: 8,330
#9567 | |
MadModerator
Lokacija: N/A
Postovi: 5,195
Adored opet nastavlja sa svojim teorijama ![]() AMD Answers Our Zen 4 Tech Questions, with Robert Hallock Citiraj:
#9568 | |
Postovi: 14,584
Ovdje postoji opcija da je jedan chiplet 12 jezgreni. Ako nije sad sa zen4, bit će sigurno kasnije povećanja, praktično su to i rekli za socket Ono što smo pričali cijelo vrijeme se i obistinilo. Mislim ono, bilo je očito ![]() |
#9569 |
Lokacija: Zabok
Postovi: 3,392
Al opet onih (samo) +15% performansi je skroz čudno. Ian Cutress je komentirao da je 10% do clocka, a 5% arhitektura i veći L2 cache. Blender test u kojem su pregazili Intel je test u kojem i sad gaze Intel tak da ... IMHO izgleda ko AMD-ov "tick". |
#9570 | |
Postovi: 8,330
