#4951 |
Datum registracije: Nov 2021
Postovi: 4
tx ibme. Iz nikog posebnog razloga uvijek naginjem na intel, sad mi je tvoj build odmah slađi |
#4952 |
Lokacija: Doma
Postovi: 11
Pozdrav, Planiram obnoviti confu sa slijedećim komponentama: AMD Ryzen 5 5600 -200€ Arctic Freezer 34 eSports DUO weiss -38,86€ Gigabyte B550M Aorus Elite AMD B550 -97,79€ MSI Radeon RX 6600 Mech 2x DDR6 (Retail) -350€ 16GB G.Skill Aegis DDR4-3200 DIMM CL16 Dual Kit -58,80€ 1TB Crucial P2 M.2 PCIe 3.0 x4 3D-NAND QLC (CT1000P2SSD8)-86,80€ Što bi bilo 832,25€ .. ili dodati još razliku od 110€ za proc i grafu Ryzen 5600x cca 220€ XFX Radeon RX 6600 XT SWFT210 Core GAMING (Retail) -439€ (Sve su cijene sa Mindia) Zanima me dali je ovih 110€ isplativo, tada bi ulog bio 942€ |
#4953 |
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,628
XT jeste jača od obične RX6600 ali ne toliko da vrijedi 90€ više. Za CPU se ne isplati nikako. Zadnje izmijenjeno od: ibme74. 09.05.2022. u 20:16. |
#4955 |
Postovi: 1,628
1 * AMD Ryzen 5 5500, 6C/12T 3,6GHz/4,2GHz, 19MB, AM4 100-100000457BOX Šifra: amd-r5-5500 1 * ID-Cooling CPU Cooler - SE-223 BASIC Šifra: COLIDCSE223BASIC 1 * GIGABYTE Main Board Desktop B450M GAMING Šifra: B450M_GAMING 1 * Patriot Viper Steel PVS416G320C6K, 16GB DDR4 3200MHz, CL16, (2x8GB) Šifra: PVS416G320C6K 1 * Sapphire RX 6600 Pulse Gaming, 8GB GDDR6 11310-01-20G Šifra: sap-rx6600-pugm-8g 1 * SSD 1TB Intel 660p PCIe M.2 2280 NVMe SSDPEKNW010T8X1 Šifra: 0141108 1 * Corsair PSU, 650W, TX-M Series 80+ GOLD Šifra: COR-CP-9020132-EU 1 * NaviaTec Raptor Gaming case with 4x RGB Fans, Tempered Glass Side, Mesh front panel Šifra: NVT-RAPTOR ------------------------------------------------------------ Sveukupno s popustom: 7.673,86 Kn (-2%=7.519kn) Besplatno slaganje i dostava EDIT: ako bi rađe na Intela 1 * Intel Core i5-11400F Soc 1200 Šifra: ITL-BX8070811400F 1 * ID-Cooling CPU Cooler - SE-223 BASIC Šifra: COLIDCSE223BASIC 1 * GIGABYTE Main Board Desktop H510M H (S1200, H510, 2xDDR4, HDMI, VGA, 1xPCIex16, 2xPCIex1, ALC887, Realtek GbE LAN, 4xSATA III, 1xM.2, USB 3.2, USB 2.0, mATX, Retail) Šifra: H510M H 1 * Patriot Viper Steel PVS416G320C6K, 16GB DDR4 3200MHz, CL16, (2x8GB) Šifra: PVS416G320C6K 1 * Sapphire RX 6600 Pulse Gaming, 8GB GDDR6 11310-01-20G Šifra: sap-rx6600-pugm-8g 1 * SSD 1TB Intel 660p PCIe M.2 2280 NVMe SSDPEKNW010T8X1 Šifra: 0141108 1 * Corsair PSU, 650W, TX-M Series 80+ GOLD Šifra: COR-CP-9020132-EU 1 * NaviaTec Raptor Gaming case with 4x RGB Fans, Tempered Glass Side, Mesh front panel Šifra: NVT-RAPTOR ------------------------------------------------------------ Sveukupno s popustom: 7.679,46 Kn (-2%=7.525kn) Besplatno slaganje i dostava |
#4956 |
Datum registracije: Sep 2019
Lokacija: Mostar
Postovi: 355
U ovoj kategoriji je odličan izbor i3 12100F |
#4957 | |
MiningMod
Postovi: 8,715
CoolerMaster T20, 92mm PWM Asus PRIME H410M-A Patriot Viper Elite 2 DDR4, 2666Mhz, 16GB (2x8), CL16 SSD KIOXIA-Toshiba EXCERIA Series SATA 6Gbit/s 2.5-inch 480GB Tvrdi Disk Toshiba P300 1TB 3.5" 7.200o/min Grafička Palit GF RTX 3060 Dual, 12GB GDDR6 Fortron napajanje Hexa+ PRO 600W, 80+,active,12 cm AeroCool Split, MidiTower, 1x120mm, RGB cca 7400,00 Kn za gotovinu sa popust kodom "RACUNALA100" |
#4958 |
|CTS|MeanBoss|
Lokacija: Sinj
Postovi: 1,005
Ekipa ajd pomoć, frend kupuje sinu komp, treba mu sve osim tipkovnice i miša ! Limit nekih 7500-8000kn. Šta se monitora tiče, preferirao bi ovako nešto https://www.instar-informatika.hr/mo...32143/product/...zapravo to mu je moja preporuka(144hz, full hd i obavezno želi 27˝) . Može li se skombinirati nešto pristojno .. Hvala vam .. |
#4959 |
Postovi: 1,628
1 * AOC LCD 27" IPS , 4ms, HDMI, DP 144Hz Šifra: AOC-27G2U-EZ 1 * AMD CPU Desktop Ryzen 5 6C/12T 3600 (4.2GHz,36MB,65W,AM4), MPK with Wraith Stealth cooler Šifra: 100-100000031MPK 1 * Matična ploča GIGABYTE B450M GAMING, DDR4, mATX, s. AM4 B450M GAMING Šifra: 050.300.651 1 * KINGSTON DRAM 16GB 3200MHz DDR4 CL16 DIMM (Kit of 2) FURY Beast Black EAN: 740617319903 Šifra: KF432C16BBK2/16 1 * VGA AS DUAL-RX6600-8G 90YV0GP0-M0NA00 Šifra: 0001233093 1 * Kingston 1TB NV1 M.2 2280 NVMe SSD, up to 2100/1700MB/s, EAN: 740617316681 Šifra: SNVS/1000G 1 * Napajanje Seasonic S12III SS-550GB, 550W Bronze SSR-550GB3 Šifra: 0151689 1 * MS FIGHTER V315 gaming kućište 4 x 120mm Šifra: 0001197902 ------------------------------------------------------------ Sveukupno s popustom: 8.210,30 Kn (-2%=8.045kn) Besplatno slaganje i dostava |
#4961 |
Datum registracije: Jul 2009
Lokacija: Zagreb, Dubrava
Postovi: 61
Pozdrav svima, kolega treba računalo za sina (1. srednje) uvjeti: 1. do 7.500 - max. 8.000,- KEŠ 2. da ima kupljene Windows-e 3. solidna grafa za pokoju igricu (zadnje je bilo Fortnite aktualno) 4. bez periferije 5. nema potrebe za RGB điđi-miđi-jem (bolje kupiti kvalitetnije komponente) 6. kućište da je ipak malo bolje (da nije baš pero laka kategorija - ali bez prozora) 7. možda da je proc AMD-ov novije generacije Zahvaljujem unaprijed ![]() |
#4962 |
Postovi: 34,042
Zašto kupljene Winse od 1.000+ kn kada iste možeš sam kupiti online za <10€? btw, nekad su učenici imali pravo na besplatne winse. Raspitaj se o tome kod admina škole.
#4963 |
Postovi: 1,628
Ma ako nije na R1 skini si win sa ms stranice i sa aliexpressa za par dollara uzmeš key i aktiviraš i tako imaš org windows za par desetaka kuna umjesto da se pljuje 600-700kn za el. licencu i gubi na bitnim komponentama u kućištu: 1 * CPU AMD Ryzen 5 5600X TRAY !!+ cooler, s.AM4 Šifra: 100-100000065MPK- 1 * GIGABYTE Main Board Desktop B450M GAMING Šifra: B450M_GAMING 1 * Memorija PC-28800, 16 GB, ADATA XPG D30 Black Edition, AX4U36008G18A-DB30, DDR4 3600Mhz, 2x8GB AX4U36008G18A-DB30 Šifra: 010.504.013 1 * GIGABYTE Video Card NVidia GeForce RTX 3060 OC EAGLE 12G, LHR. Šifra: GV-N3060EAGLE OC-12GD 2.0 1 * SSD 1000 GB KINGSTON NV1 SNVS/1000G, M.2/NVMe PCIe, 2280, maks do 2100/1700 MB/s SNVS/1000G Šifra: 051.400.740 1 * Napajanje Seasonic B12 BC-650 Bronze B12-BC-650 Šifra: 0001233585 1 * Kućište BIT FORCE MidiTower Tiho PC kućište SHADOW SE-2, 3x120mm Šifra: 2911102-2 ------------------------------------------------------------ Sveukupno s popustom: 8.179,41 Kn (-2%=8.015kn) Besplatno slaganje i dostava |
#4964 |
MiningMod
Postovi: 8,715
Ne vidim razloga uzimanja lošeg kućišta samo da nema staklo, jer ima odličnih kutija koje ne blješte ali ipak imaju staklo jer je to danas normalno... 1 * Intel Core i5 12400f, 2,5/4.4GHz,6C/12T,LGA1700 1 * Hladnjak DeepCool GAMMAXX 400S, S.1700/Intel/AMD 1 * Matična Asus PRIME H610M-A D4 CSM, M.2, VGA/HDMI/DP 1 * Samsung SSD 980 Evo 1TB M.2 PCIE Gen 3.0 NVME PCIEx4, 3500/3000 MB/s 1 * Napajanje EVGA 600W W1, 80+ White 1 * Grafička Palit GF RTX 3060 Dual, 12GB GDDR6 1 * Phanteks Eclipse P400 Tempered Glass, black 1 * Microsoft Windows 10 Professional 32/64-bit ESD + Instalacija (Samo uz kupnju računala) 8000 kn * Bez winsa je 7500kn |
#4965 |
Lokacija: tu
Postovi: 79
Pozdrav, ako moze neka konfa do (oko) 8000 kn. PC ce se uglavnom koristiti za programiranje, 3D modeliranje i video editing. Povremeni gaming, trenutno jos uvijek zvacem GTA 5 i watch dogs, ali bi mozda i neke novije naslove iz Tom Clancy's kolekcije ili neke nadolazece igrice. Imam neki prastari monitor koji je na izmaku snaga, pa bi trebao i monitor, ostalu periferiju imam. Placanje - ca$h Fala puno ![]()
hm.. |
#4968 |
Postovi: 1,628
1 * AOC LED 24", IPS, DP, 2xHDMI, HAS, 144Hz, 4xUSB3.0 24G2U Šifra: aoc-24g2u 1 * CPU AMD Ryzen 5 5500 100-100000457BOX Šifra: 0001258709 1 * GIGABYTE Main Board Desktop B450M GAMING Šifra: B450M_GAMING 1 * Memorija PC-28800, 16 GB, ADATA XPG D30 Black Edition, AX4U36008G18A-DB30, DDR4 3600Mhz, 2x8GB AX4U36008G18A-DB30 Šifra: 010.504.013 1 * XFX AMD Video Card RX-6600 SWIFT210 CORE 8GB GDDR6, 3x DP, HDMI, 2 fan, 2 slot Šifra: RX-66XL8LFDQ 1 * SSD 1000 GB KINGSTON NV1 SNVS/1000G, M.2/NVMe PCIe, 2280, maks do 2100/1700 MB/s SNVS/1000G Šifra: 051.400.740 1 * Napajanje Seasonic S12III SS-550GB, 550W Bronze SSR-550GB3 Šifra: 0151689 1 * MS FIGHTER V315 gaming kućište 4 x 120mm Šifra: 0001197902 ----------------------------------------------------------- Sveukupno s popustom: 8.201,01 Kn (2%=8.036kn) Besplatno slaganje i dostava |
#4969 |
Datum registracije: Aug 2022
Lokacija: U svom filmu
Postovi: 2
Pozdrav eksperti, Treba mi konfiguracija s periferijom za pcvr konkretno za oculus quest 1. Plafon 8000 bez popusta. Po mogućnosti da sve izgleda što manje gamersko. |
#4970 |
Postovi: 1,628
1 * AMD Ryzen 5 5600X, 6C/12T 3,7GHz/4,6GHz, 35MB, AM4 AW100100000065BOX Šifra: amd-r5-5600x 1 * Matična ploča GIGABYTE B450M GAMING, DDR4, mATX, s. AM4 B450M GAMING Šifra: 050.300.651 1 * Memorija PC-28800, 16 GB, ADATA XPG D30 Black Edition, AX4U36008G18A-DB30, DDR4 3600Mhz, 2x8GB AX4U36008G18A-DB30 Šifra: 010.504.013 1 * VGA AS DUAL-RX6650XT-O8G 90YV0HL0-M0NA00 Šifra: 0001261608 1 * SSD 1TB KIN NV1 PCIe M.2 2280 NVMe SNVS/1000G Šifra: 0001213228 1 * Corsair PSU, 650W, TX-M Series 80+ GOLD Šifra: COR-CP-9020132-EU 1 * Aerocool Graphite v1 Midi-Tower - black Šifra: CAAC3753 2 * BIT FORCE PC ventilator CHILL 120 crni Šifra: 3010101 Sveukupno s popustom: 8155,69 Kn (-2%=7.991kn) Besplatno slaganje i dostava EDIT: ako bi rađe nvidiu mozes staviti RTX3060 Zadnje izmijenjeno od: ibme74. 19.08.2022. u 12:36. |
#4971 |
Postovi: 2
Da, Nvidia bolje radi s oculusom. Cijena tu negdje? Treba mi i monitor, ali pretostavljam da ću se za to morati dodatno isprsiti. Aoc iz par postova gore je best buy? Koji shop? Hvala. |
#4972 |
Postovi: 1,628
Propustio sam dio za periferiju. Ako ces uzimat i periferiju onda RTX3060 nece stati unutat tog budzeta a morat ces i na drugim stvarima kresat budzet. Da taj AOC je neki BB sto se 1080p 144hz tice. |
#4973 |
Datum registracije: Oct 2022
Lokacija: Prelog
Postovi: 1
Pozdrav, zanima me je li ovo ok za neki gaming PC u budžetu od 7000kn ili bi što promijenili? Procesor: Intel i5 10400F Hladnjak: Intel Original AiR Matična ploča: Intel H510M LGA 1200 Memorija: DDR4 16GB 3400Mhz Brzi disk (OS): 2,5" SSD 500GB Nvme Tvrdi disk (pohrana): 1TB Grafička: GeForce RTX 3050 Napajanje: 500W 80+ 120MM Kućište: Midi ATX |
#4974 |
Postovi: 8,464
Konfiguracije u rangu od 6.000 do 7.000 kn
Dodaj jos malo za 3060 i miran si. Ja imam 3050 i radi mi super ali dolazi dosta novih naslova pa ce ti mozda 3050 biti knap. Jos ako uzmes 2k monitor jednog dana ako ga nemas 3060 ce biti taman |
#4975 |
Lokacija: Mostar
Postovi: 355
Neki dan sam pazario 1650 super za 1100 kuna koja je još 2 godine pod jamstvom, a slabija je 20% od 3050 koja je oko 3000 kuna. Puno bolja je opcija polovne GPU. |
#4978 |
Lokacija: Mostar
Postovi: 355
Ako mora biti novo 3060 je sweet spot i kupovina 3050 je bacanje para.... |
#4980 |
Lokacija: Bec
Postovi: 1,202
Hello pipl. Evo vrijeme je da se nakon više od 10 godina zamijeni postojeća konfa sa novom, pa me zanima vaše mišljenje. Buđet mi je u početku bio do 6 hiljada ali sam ga dosta probio. Konfa bi mi služila za stvari koje radim i na postojećoj staroj konfi tako da mi netreba jača. Klokanje me ne zanima, eventualno pbo na on ali i to ako cu biti dobre volje ![]() Znači za Wow, SC2, Autocad i 3Ds max za skvo. Evenutalno mozda neka novija igra, moze u nekih 40fps na midijumu i full hdu. 1. Ryzen 5500 Box - 111 eu 2. Iako je to box verzija ne vidim da se spominje cooler pa bih uzeo beQuiet pure rock 2- 52 eu 3. Gigabyte b550M ds3h -110 eu 4. Corsair 16 GB (2*8) 3200Mhz - 64eu 5. Sapphire radeon rx6600 8GB - 334 eu 6. Seasonic g12 gc 550w - 85 eu 7. Ms armor v300 -51 eu 8. Samsung SSD 1TB - 113 eu 9. Toshiba 2TB 3.5" 7200 rpm -70 eu Total 1000 eu Par pitanja 2. Dvoumio sam se između pure rock 2 i Noctua NH-L9a-AM4 ali po recenzijama mi se cini da je blaga prednost na strani pure rock 2. S obzirom da nista od klokanja stavljam naglasak na tišinu 3. Iako sam mogao malo uštediti i uzeti B450M ploču čini mi se možda bolje za neku buducu nadogradnju? S tim da ne želim ASrock 5. Vidim da je rx6500xt jeftinija za nekih 80 eu, ali ju je ekipa dosta spljuvala i vidim da je razlika nekih 30% u performansama.. 6. jedini mi je problem sto napajanje nije modularno, ima 550w seasonic modularno ali je skuplje za 300 kuna 7. valjda jedino kuciste da na nesto liči. S obzirom da ide u kutiju (nogu) stola gumbi/utori moraju biti s prednje strane a ne gornje. 9. Trebam jos jedan hard zbog storiđa Hvala ljudi na komentarima/prijedlozima Zadnje izmijenjeno od: Master_Hrc. 13.02.2023. u 16:51. |
