Staro 22.03.2022., 15:02   #3091
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Ekipa zanima me vaše mišljenje o ovom setupu:
Cilj su custom switchevi i keycapsi jednog dana.
Ima tko iskustva? Posebno oko kompatibilnosti switcheva i keycapsa?
Mogu li se negdje kupiti dobri PBT keycapsi sa HR znakovima?
Nisam našao puno info o bateriji...
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 22.03.2022. u 15:09.
estugarda je offline   Reply With Quote
Staro 22.03.2022., 17:17   #3092
grizli1
Datum registracije: Aug 2008
Lokacija: Daruvar
Postovi: 254
Autor estugarda Pregled postova
Ja imam k10 sa hotswap brown i bijelim osvjetljenjem, za bateriju ti ne znam točno reći jer ju na desktopu koristim sa žicom a na laptopu i tv-u bt-om. Na kompu imam neki bezvezni BT pa znam imat problema, ne kod pisanja nego npr kad igram igre zna mi ostat stuck input s npr "w" pa mi lik ide naprijed dok ne ugasim i upalim tipkovnicu. Na kablu nikakvih problema i kod normalnog pisanja.
Jedino smatram manom što je battery indicator ledica sa strane pored type-c a a ne kao kod nekih modela kod strijelica.
grizli1 je offline   Reply With Quote
Staro 22.03.2022., 19:37   #3093
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Dobro da sam pitao. Ima samo BT znači!? Nema 2.4Ghz wireless usb dongle? Ako nema, onda nije za mene...BT mi se pokazao nepouzdan za ovo što meni treba.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 23.03.2022., 01:03   #3094
tun3
tun3's Avatar
Datum registracije: Oct 2018
Lokacija: Matulji
Postovi: 355
Evo i relativno pristojnih slika Lyre :
Složena sa Beta PCB-om, Pom plateom, C3 Kiwi switchevima i fejk Olivia keycapsima. Sada je još treba programirati
tun3 je online   Reply With Quote
Staro 30.03.2022., 21:03   #3095
keyser_s()ze
Postovi: 590
Jedno seksi tipkalo (na žalost nije moje):
https://youtu.be/WcSYunYBE1Y
keyser_s()ze je offline   Reply With Quote
Staro 12.04.2022., 23:47   #3096
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,567
Za ekipu koja želi ISO rgb , na stocku su pa požurite
https://candykeys.com/product/tai-ha...eid=7ed72ecbe6
Kako izgledaju :
6-C91-C0-DF-360-D-4-D20-BFB4-0886-F4-F1-F228
Autor tun3 Pregled postova
Ovo izgleda bomba, koliko si je čekao i kojeg organa si se rješio ?
Staro 13.04.2022., 00:43   #3097
tun3
tun3's Avatar
Lokacija: Matulji
Postovi: 355
Autor JuiceBox Pregled postova
Nimalo, lik sa YugoMK Discorda ih je isao izradit kad je vidio kako je original autor zajebao ekipu na group buyu, napisao je na Discordu kad ce bit spremne, bio je nekih tjedan dana u HR, nasli se na pivi i naplatio mi covjek koliko je kostalo u izradi, a mislim da ih je tako i inace davao. Mozda ima jos koju, ja sam uzeo alfa i beta PCB i plate, a tipkovnica kao takva je trenutno na cekanju jer se ne stignem boriti sa QMK, ne mogu nac firmware za nju (a supporta QMK), VIA support ce "uskoro" ali jos nije...
Inace PCB i plate su izvana, a kuciste je radjeno na Viskovu u jednoj firmi. Anodizacija nije nesto ali sam case je odlican
Staro 13.04.2022., 11:43   #3098
T}{OR
DBS
T}{OR's Avatar
Datum registracije: Nov 2010
Postovi: 1,855
PSA: Ducky One 3 u klasičnoj crnoj i bijeloj izvedbi dostupne sa mechanicalkeyboards.com
Poslano koristeći Tapatalk
Staro 13.04.2022., 12:03   #3099
brodjo
Playmaker
brodjo's Avatar
Lokacija: Osijek/Wien
Postovi: 1,661
Trebale bi se pojavit i u ostalim EU shopovima za nekih tjedan dva
brodjo je offline   Reply With Quote
Staro 13.04.2022., 14:17   #3100
kreatinko
kreatinko's Avatar
Datum registracije: Sep 2012
Postovi: 193
Autor T}{OR Pregled postova
Na službenim stranicama nema niti bijele niti crne... da to nije neka DIY varijanta ?
Vidim da na mechanicalkeyboards.com imaju prozirna slova na keycapsima, a koliko ja znam One 3 ih nema...
kreatinko je offline   Reply With Quote
Staro 13.04.2022., 16:17   #3101
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Autor kreatinko Pregled postova
Mislim da im malo kasni službena stranica. Mechanicalkeyboars.com imaju ekskluzivu s Ducky-em koliko me sjećanje služi.
Ovo je full release koliko mi se čini. Moja One 2 TKL ima uredno prozirna slova. Kao i ostale podvarijante One 2, a sada i One 3.
Staro 13.04.2022., 17:06   #3102
Garro
Postovi: 2,392
Ako negdje vidite Ducky One 3 full size, UK layout, tactile/brown switchevi, da nije kričavo žuta i da ima RGB, javite!
Staro 13.04.2022., 17:44   #3103
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,567
Napisao je gore brodjo, kroz dva-tri tjedna gledaj caseking/candykeys/mykeyboard.
Staro 20.04.2022., 22:46   #3104
Thermaltake
1
Postovi: 3,588
Pozdrav, ekipo pitanjce. Frend mi je dofurao da mu počistim i zamijenim par switcheva na G910. Da li imate neku preporuku switcheva ili da uzimam ove plave kao šta su bili gore. I od kud uzimate ako ima neka preporuka ili random ebay pa najjeftinijeg da uzmem ?
Staro 20.04.2022., 23:14   #3105
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,567
Samo i mozes staviti te koji su bili (Romer G smeće), zbog keycapsa. Imas ih na aliju.
Staro 21.04.2022., 07:59   #3106
Thermaltake
1
Postovi: 3,588
a znam da smeće su ko i tipkovnica, al njemu je super kaže jbg ukusi su različiti. Hvala
Staro 21.04.2022., 14:50   #3107
Garro
Postovi: 2,392
Glupo pitanje, zašto su Romer G smeće?
Staro 21.04.2022., 15:25   #3108
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,567
Zato jer su nekvalitetni, jeftina verzija mx browna sa drukcijim stemom i nemozes mjenjati keycapse, na logi tipkusama takoder je dolje ne standardni row. Musicavi su, ne hvataju kako treba, vrlo kratak hod, osjecaj tipkanja je bezveze i crkavaju jako brzo.Takoder postoje samo kao tactile verzija sto je jos jedna glupost, a tipkovnice s njima kostaju kao da su zlatne, ustvari su preplaceni jeftilen. Jedina prednost je led u sredini pa imas bolji glow.
Staro 21.04.2022., 15:58   #3109
FerrZG
FerrZG's Avatar
Datum registracije: Oct 2016
Postovi: 171
Autor grizli1 Pregled postova
Upravo mi je stigla Keychron k10 hotswap s brown switchevima. sad se treba naviknut sa velikog entera na mali. Naša slova mi ne fale na njoj ali za sad se treba naviknut na drugačiji layout malog entera i slova ž ali doći će i to na svoje.
Za sad je spojena na žicu ali uskoro bi trebao i BT dongle s ali-a doći pa ide uparivanje i sa desktopom i laptopom i TV-om.
Tipkovnica je naručena tokom kinekse nove godine tako da nije poslana do 8.2, 18.2 je bila u lokalnom skladištu ali se potrefio vikend tako da je sad stigla DPD-om bez ikakvih davanja
Potvrdujem ovo boldano, narucio sam Q2 i tocno 2 tjedna od narudzbe je DPD-om sve stiglo uredno na adresu bez ikakvih dodatnih davanja.
Tipkovnica, kabel i palm rest su ispali $224 + $32 za shipping.
S obzirom da sam do sada koristio gamerske tipkovnice (Razer, Logitech i CoolerMaster) osjeti se golema razlika i za sada sam jako zadovoljan
FerrZG je offline   Reply With Quote
Staro 21.04.2022., 16:32   #3110
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Za ne vjerovat ali odlican su switch za gaming, sve ostalo stoji kako si napisao
Lud76 je offline   Reply With Quote
Staro 21.04.2022., 17:22   #3111
Garro
Postovi: 2,392
Lagano mi već ide na živce čekanje da postane dostupan full size crni Ducky One 3 s UK layoutom, a Logi G512 Tactile je na akciji u Linksu za 700 kn, pa sam je mislio uzeti dok se Ducky ne ukaže. Budem se zaletio do Linksa i isprobao jesu li čemu, ali nakon ovog tvog komentara, nisam optimističan.
Staro 21.04.2022., 17:41   #3112
Thermaltake
1
Postovi: 3,588
Sad kako tipkam po frendovoj tipkovnici nekako me ulovilo da si i ja piknem jednu nakon svoje dugogodišnje sa membranom. Kakve su Razerove ? Vidim da dosta mehaničkih tipkovnica nemaju veliki enter i backspace a ja patim na to
pa ako može kakva preporuka da imaju znači veliki enter i backspace i naše znakove.
P.S i da nije logitech jer su smeće
Zadnje izmijenjeno od: Thermaltake. 21.04.2022. u 18:13.
Staro 21.04.2022., 19:26   #3113
Garro
Postovi: 2,392
Ako ti je Logi smeće (a ne kažem da nije), ni Razer te neće pretjerano oduševiti.
Staro 21.04.2022., 20:10   #3114
Thermaltake
1
Postovi: 3,588
Autor Garro Pregled postova
Pa kolko sam vidio i tipkao Razer Huntsman V2 je odlična tipkovnica sa optičkim switchevima, samo mi smeta šta tamo di sam probavao nema europski layout tj. sa veliki enterom, inače mi je tipkovnica super.
Staro 21.04.2022., 20:19   #3115
Garro
Postovi: 2,392
Ovu sam ciljao: https://www.mall.hr/misevi-i-tipkovn...-uk-hr-gravura , ali ne prolazi svjetlo kroz ugravirana hr slova. I vidim da je otišla s cijenom na sulude razine…
Staro 21.04.2022., 20:22   #3116
Thermaltake
1
Postovi: 3,588
O njoj i pričam, samo ima mali enter. No guglao sam postoji i sa velikim enterom, ali nema naša slova...
A niš idemo dalje sa preporukama
Staro 21.04.2022., 21:17   #3117
Garro
Postovi: 2,392
Koliko znam, ako je UK layout, ima veliki enter.
Staro 21.04.2022., 21:21   #3118
Thermaltake
1
Postovi: 3,588
A da nisam pročitao UK je, ali su sliku stavili od US pa me zbunilo. A vidim da ih u protisu ima, ali ne znam da li je laserski ugravirano ili samo print na tipku. Poslat ću mail pa vidit šta kažu.
Staro 21.04.2022., 21:37   #3119
Garro
Postovi: 2,392
Ovo piše na opisu u Mall-u: Tipkovnica ima hrvatsku gravuru. Zbog višeslojnog dizajna tipki graviranje je otežano pa svjetlost ne prolazi kroz ugravirane hrvatske znakove.
Staro 21.04.2022., 21:46   #3120
Thermaltake
1
Postovi: 3,588
Baš me zanima jel to ista ko i ova iz protisa, predpostavljam da je isto dobavljač pa da je, ali čekam da mi jave.
