#391 |
Prvoklasni Krkan
Postovi: 5,274
I još jedan hotfix: Third Hotfix (33.1.0.319 deployed on 3/25/2022): Resolves issue pairing Dual Shock 3, XBOX, and Switch controllers Resolves bug where video colors would be displayed incorrect when HW acceleration is enabled Fixes bug affecting streaming to twitch Adds helpful notifications when connecting or formatting removable storage Fixes bug where system would hang when access home screen after matching frame rate in Kodi Fixes bug where surround upmixer would stop working after playing Dolby audio streams Adds Plex support for latest Hauppauge WinTV-dualHD DVB-T tuner (EU only) Fixes bug where AI upscaling could not be changed in Netflix app Resolves issue where Documents UI cannot access external storage folders Resolves issue where SD card notification would be displayed when launching apps Resolves issue when capturing screenshots in GeForce NOW using NVIDIA Share Resolves crash issue with Google Play Games on 2015/2017 SHIELDs. Resolves localization issue with Canadian Language selection of energy start timers Resolves audio issues when connecting headset to 2015 SHIELD Controller |
#392 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,536
Iskočilo mi sinoć. A onako, nije losa ideja al' nije i da ce bas pomoci u moru streaming services. https://www.theverge.com/2022/4/5/23...atibility-beta
#394 |
Postovi: 10,074
9.0.2 je vani: https://www.nvidia.com/en-us/geforce...eleased-41222/ Zanimljivo, iako mi je oznaceno da svaki put skida full image, skinuo mi je 75MB inkrementalni update (bio sam na 9.0.1 bez hotfixeva).
#397 |
Postovi: 10,074
Ne bi se kladio, vjerojatno ti samo jos nije stigao. Ekipa (Ameri) koja zeli Disney+ bi ih pojela da zaglave na hotfixu umjesto da ga pregaze certificiranim buildom. Kad sam bio na hotfixevima na 9.0, uredno mi je na kraju dosao 9.0.1 i pregazio zadnji hotfix. Nisam ni siguran je li 9.0.1 donio ista novo naspram hotfixa prije njega. U ovoj zadnjoj rundi nisam ulazio u hotfix program, bio sam zadovoljan s 9.0.1
#398 | |
Prvoklasni Krkan
Postovi: 5,274
Today we released SHIELD Experience Upgrade v9.0.2 (33.1.0.319) Isto je, isti je ovaj build no, ili što god je to već. ![]() |
#399 |
Postovi: 10,074
Idemooo: https://i.imgur.com/C9Ht9Bi.jpeg Dogodilo mi se nekoliko puta na 9.0.1 da se app koji pusta mjuzu freeza, ali muzika ide i pjesme se redaju i ne skuzis da je freezan dok ne uzmes daljinski u ruke. Dogadjalo se s Plex klijent appom (vuce muziku sa NAS Plex servera) i Deezerom (vuce muziku s neta). A ovo na slici je kompletni raspad od jucer gdje prvi put vidim glitcheve (9.0.2). Rjesenje u svim navedenim slucajevima je cupanje napajanja jer na nis drugo ne trza.
#400 |
Datum registracije: Aug 2013
Postovi: 4,334
Al su uspjeli syebat taj fini box, svaka im cast.., ko da im Xiaomi radi softver ![]() |
#401 | |
Pink Floyd fan
Postovi: 5,536
#402 |
Postovi: 10,074
Nisam, ali budem. samo da skupim dovoljno logova pa da mogu izvući neki zaključak. Ako je hardverski issue, zanimljivo da se događa u dvije aplikacije koje efektivno najmanje vremena koristim.
#406 |
Postovi: 10,074
Nope, ni da stucne vise. Za vikend se vise/duze slusala mjuza (Plex, Deezer), a i igre sam zavrtio (Moonlight) - sve normalno. Nisam napomenuo, box nije bio ni mlak na dodir kad se to desilo. I daljinski nije mogao pauzirati mjuzu. Znaci bas se nesto raspalo iznutra, nadam se samo softverski ![]()
#410 |
Postovi: 10,074
Kada castate deezer ili yt music na shield tv, mozete li preko moba i google homea kontrolirati glasnocu shielda? Probao preko volume tipki (cast volume) - ne reagira. Ako otvorim onaj cast menu (u principu google home app) i tamo diram volume, isto nista. Ali uredno rade sve ostale kontrole za playback, skipanje, mute itd... Jedino kada radi volume control je kada otvorim home app, pa odaberem shield, pa remote control i tamo imam isto tipke za volume. Neki dan prodao chromecast audio puckove, znaci instant regret! ![]()
#411 |
Pink Floyd fan
Postovi: 5,536
Meni radi volume normalno kad castam na shield. Pritisnem volume na mobu i iskoci mi volume za cast... al' ne koristim deezer niti youtube music. Spotify to ima bolje rijeseno. Ako su mob i shield na istoj mrezi, starta app na shield i koristi neki svoj connect iako moze i chromecast ako app nije instalirana. Cak se kasnije mob moze maknuti sa iste mreze, remote za app connect jos uvijek radi. Ono izadjes van i mjenjas pjesme, volume doma ![]()
#412 |
Postovi: 10,074
#413 |
Pink Floyd fan
Postovi: 5,536
Uzbudjenju nikad kraja ![]() [SHIELD Remote 2019] Adds option to only wake SHIELD with power button or NETFLIX button Bolje nek dodaju da se moze Netflix button mapirati da starta nesto drugo, Plex recimo.
#414 |
Postovi: 10,074
Ako koristite USB DAC i izgubili ste volume slider kod pojacavanja/stisavanja zvuka, ne berite brigu. Odite u volume control postavke i ugasite CEC+USB fixed volume. Ne kuzim zasto je to sad tako, te postavke su takve od pamtivijeka, ali eto nakon updatea sam izgubio volume slider i malo rovio po postavkama u nadi da cu skuziti sto se zbiva. Ne znam jel to sada bug ili feature ![]()
#416 |
Postovi: 704
Pozdrav ekipica, kako riješiti ovaj problem sa kodi, ovo mi se događa kada zumiram sliku tako da nemam crnih crta gore i dolje na ekranu, takvih problema nisam imao na firesticku dok na nVidii imam.
Sig-5 redova normalne veličine max ![]() |
#418 | |
Postovi: 2,717
Nešto Button nešto se zove. Ovo sa zoomom, jednostavno na Shield ne radi. Radi na nekom drugom playeru, ne sjećam se kojem, Emby brijem, ali Kodi je Kodi.
MC |
#420 |
Postovi: 10,074
Button mapper je na 8.x radio ok, ako se ne varam, ali od Shield 9.x updejta app nije bio updejtan i ima bug kod remapiranja Netflix botuna. Barem je tako bilo dok sam ga koristio. Imao sam neke cudne probleme i prestao sam ga koristiti, ali sad se ne mogu sjetiti sto tocno me zaj*. Znam da se cesto kod reportanja bugova na Shield forumu savjetovalo "pokusaj ugasiti button remapper"... https://www.nvidia.com/en-us/geforce...-known-issues/ "App Issues that require app developer to resolve: Button mapper remap on Netflix button triggers Netflix button and the new button mapped" Button remapper last updated 6.1.'22.
