Staro 01.03.2022., 20:31   #1321
Postovi: 8,544
AMD Threadripper Pro 5000 and EPYC Milan-X join Ryzen 5800X3D for March availability
It will be an unexpectedly busy March for AMD, with the company launching three distinct products across its processor lines. The first one, which we reported earlier this morning, speaks of a late-March availability of the Ryzen 7 5800X3D 8-core/16-thread Socket AM4 processor, which AMD claims offers gaming performance on par with the Core i9-12900K "Alder Lake." It turns out, there are two more surprises.
Apparently the company is ready with Ryzen Threadripper Pro 5000 series workstation processors. Designed for Socket sWRX8 motherboards based on the only chipset option available—the AMD WRX80, these are the first Threadripper products based on the "Zen 3" microarchitecture, and feature 8-channel DDR4 memory, and up to 128 PCI-Express Gen4 lanes for workstation connectivity. Unfortunately, you can't buy one of these in the retail channel, as AMD is making them OEM-only. The first pre-built workstations will arrive as early as next week (March 8). At this point we still don't know if these chips use the newer "Zen 3" CCD with 3D Vertical Cache, or the conventional "Zen 3" CCD with 32 MB planar L3 cache.
Lastly, there are AMD's ambitious EPYC "Milan-X" processors, which are essentially server processors in the SP3 package, which use the "Zen 3" CCDs that have 3D Vertical Cache, which make up 100 MB of total cache per CCD, and 800 MB of total cache for the 64-core/128-thread model. AMD is claiming 3DV Cache to offer a generational performance uplift with several streaming data use-cases, and the lure of drop-in compatibility with existing SP3 infrastructure could win customers for these processors, in the run up to the next-generation EPYC "Genoa" processor that leverages "Zen 4" microarchitecture, and next-gen I/O, but needs a new Socket.
Izvor: TechPowerUp
Staro 02.03.2022., 21:28   #1322
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,557
i pale malo cijene, 5600x na 1900kn
Staro 03.03.2022., 06:32   #1323
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,381
Autor the_ghost Pregled postova
Kul, ali nije to to još. 1400kn bi bilo super.
Slobodno me dodajte na PSN
Disco je online   Reply With Quote
Staro 03.03.2022., 09:49   #1324
nub
PREMIUM
nub's Avatar
Datum registracije: Dec 2014
Postovi: 2,164
I eto moja ploča dobila support. Znači ako bubnem zadnji bios mogu zamijeniti proc s 5000 serijom? Ili još neke predradnje treba napraviti? Fakat želim da sve radi kak spada, tj da ne moram npr reinsallat winse zbog toga
I btw dal bu rami bolje radili? Tj, dal će moj sirotinjski non "b-die" raditi na deklariranoj brzini (3200mhz) ili da popišem trenutne custom tajminge?
Staro 03.03.2022., 09:55   #1325
Le0n
Groarrr
Le0n's Avatar
Postovi: 438
Meni je ploca s svakim updateom radila sve bolje po pitanju RAMa. Ni meni nije htjela na XMP pa sam mislio da je defektna.
Sent from my SM-N970F using Tapatalk
Staro 03.03.2022., 10:05   #1326
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,557
Autor Disco Pregled postova
potpisujem
Staro 05.03.2022., 13:36   #1327
Postovi: 8,544
AMD rumored to launch Ryzen 5 5500/5600 and Ryzen 7 5700X this month
AMD is expected to launch another two 6-core Ryzen 5000 SKUs: Ryzen 5 5500 and Ryzen 5 5600. While the clock speeds of both parts remain unknown, there is a major difference between both parts: the 5500 does not support SMT and therefore only has 6 threads. The 5500 is set to cost less than Intel’s Core i3-12100 CPU, which officially goes for 122 USD. The 5600 non-X on the other hand would cost less than i5-12400 with 192 USD price tag. AMD is also preparing an 8-core and 16-thread CPU known as Ryzen 7 5700X, this CPU would cost less than Core i5-12600KF (MSRP of 264 USD). It would therefore be offered alongside Ryzen 7 5700G based on Cezanne silicon but with more capable Radeon Vega graphics subsystem, but fewer PCIe lanes and smaller L3 Cache. Later this month the company will also launch Ryzen 7 5800X3D with 96MB of total L3 Cache. This push of Zen 3 architecture for desktop AM4 socket appears to be the last major update for the socket before AMD switches to AM5 and Ryzen 7000 Zen 4 “Raphael” architecture.
Izvor: VideoCardz
Staro 05.03.2022., 15:27   #1328
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Nabijem ih na japanca.. Nema bez konkurencije ništa đabe
MojSkuter
Staro 05.03.2022., 17:09   #1329
spawn
spawn's Avatar
Postovi: 8,485
Hoće li ići i nove ploče za njih ili će stare imati nekakv support? Ako budu išli na stare ploče, bit će dobra stvar za potrošače ako budu i specsi slični intelu naravno.
Staro 05.03.2022., 17:16   #1330
Postovi: 8,544
Trebalo bi bez problema ići na ove postojeće ploče uz BIOS update, jer i dalje je sve to Zen 3 samo su kockice presložene.
Staro 05.03.2022., 21:09   #1331
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Eto ga na!
Očito trebalo konkurencije, a i vrijeme je vjv učinilo svoje (nova tura štancanja čipova)
Autor nub Pregled postova
Ooooo ofišl bios za 5000 ryzena na giga X370
Brko leaker ispao istinit
Staro 06.03.2022., 00:19   #1332
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,204
@nub
1. Kad kupiš Ryzen 5000 CPU prije nego što ga ugradiš onda samo flešaš novi BIOS , ne prije.
.... jer je moguce da onda možda neces moci koristit trenutni proc zbog 16 MB prostora na BIOS chipu.
... zavisi za koje su procesore maknuli kodove da bi sve stalo u tih 16 MB .... to je i bilo jedno od opravdanja da ne žele izdat support 5000 seriji na A320 , B350 , X370 plocama.
2. Ryzen 5000 CPU u sebi - na IO die / IOD chipletu (a ne na ploci - MBO) ima memorijski kontroler - IMC (Integrated Memory Controller) s kojim bi ti memorija trebala radit na 3200 MHz kojeg nativno podržava kad ukljucis DOCP (XMP) u UEFI (BIOS) postavkama od ploce.
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 06.03.2022. u 17:54.
Staro 06.03.2022., 16:39   #1333
nub
PREMIUM
nub's Avatar
Postovi: 2,164
@Blue Spirit thx, baš to sam trebao!
Staro 08.03.2022., 19:59   #1334
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,381
4xxx su navodno monolitni zen2 sa diseableanom igpu.
Moram priznat da AMD jako sporo odgovara na Intelove jeftinije procove...i dok svi ne izdaju BIOS za starije ploče, poprilično su si ograničili potencijalne kupce.
5700X izgleda donekle primamljivo.
Staro 08.03.2022., 21:01   #1335
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
5600 još više, rekao bih. Mogao bi biti ekvivalent 12400f, barem jednako dobar konkurent.
A da su spori, definitivno jesu. Dovoljno je pratiti Nvidiu kako AMD-u ne dopušta niti centimetar slobodnog prostora, instant nešto novo launchaju čim se ukaže prilika (makar bio i paper launch ).
Staro 08.03.2022., 22:20   #1336
Dottore
Dottore's Avatar
Postovi: 7,703
Jako je primamljiv 5700X. Pogotovo ako ne mjenja ploču na duže staze.
Sviđa mi 58003D. Dalje pratim cijenu
Отправлено через Pixel
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 09.03.2022., 11:22   #1337
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,381
Intelovanje do daske:
According to reports, AMD Ryzen 7 5800X3D does not enable overclocking.
Očito namjerno ograničavanje kako bi zen4 izgledao bolje.
Staro 09.03.2022., 11:40   #1338
Postovi: 8,544
Zen 4 bude svakak izgledal bolje u odnosu na sad već godinu i pol staru Zen 3 arhitekturu, ali isto tak ne treba odmah skakat na sve kaj se širi diljem neta, pogotovo kad onda isti ovi izvori začas imaju dijametralno suprotne naslove, a glavni izvor je uvijek neki tip s Twitter profilom. Taman da se i ne može clockati, mada ne kužim zbog čega i na koju foru ne bi, ako cijela Zen ponuda to nudi, IMHO tak svejedno. Ovo kaj sad izlazi od Zen 3 ponude, prije nego izbace novi Zen 4 + AM5, je ionak reda-radi i jer mogu. Skoro pola godine od izlaska Alder Lake za koji se očekivalo da će pomesti sve AMD i vratiti ih u predbankrotno stanje, AMD živo zaboli, jer baka s tim kolačima je odavno prošla, dok Alder Lake nije napravil očekivani Ryzen poraz i momentalno snižavanje cijena samo da se proda, kak je to bilo u Conroe vs. Athlon i Phenom vrijeme.
Uostalom ...
... tak da na naposljetku može biti svašta.
Staro 09.03.2022., 14:05   #1339
Dottore
Dottore's Avatar
Postovi: 7,703
Ne znam na koju foru ako još nisu službeno izdali biose za 5800x3D.
Npr. moja ploča sa cpu support https://www.gigabyte.com/Ajax/Suppor...uct&Value=6892
Trenutno sam na R5 2600x. Uostalom, overclocking za mene prošlost. Hoću , stabilno i manje temperature.
AM5 ne namjeravam barem 4-5god dok imam 32gb memorije.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 09.03.2022., 14:14   #1340
Odinarius
All-rounder
Postovi: 1,342
Smanjene frekvencije na 3D modelu upućuju na probleme sa zagrijavanjem, odnosno hlađenjem tog stacka... To bi bio moj prvi pick zašto ograničenja. Vidjet ćemo.
Staro 09.03.2022., 14:28   #1341
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,381
AMD Asks Motherboard Makers to Remove Overclocking Options for Ryzen 7 5800X3D
Potvrđeno sada.
When we asked for a reason as to why this was the case, we were told that AMD was keeping that information to themselves for the time being. The details provided by AMD are short and to the point "5800X3D 8C16T 100-000000651 105 W AGESA: PI 1206b 1/28 Please hide Vermeer-X CPU OC BIOS SETUP options since PI 1206b".
Staro 09.03.2022., 14:59   #1342
Postovi: 8,544
Moguće, ali čak i bez ručne OC mogućnosti, ostaje Precision Boost.
Potvrđeno sada.
Milan-X 3D cache modeli su ionak već u pogonu kod klijenata, ali budemo vidjeli kaj su na kraju s ovim 5800X3D non-OC primjerkom izveli.
Zadnje izmijenjeno od: The Exiled. 09.03.2022. u 15:04.
Staro 09.03.2022., 18:40   #1343
Mladenxy
Mladenxy's Avatar
Postovi: 4,468
5800X3D non-OC bude super gaming CPU, vrh. Jedino kaj bu i koštal, srećom cijene grafa padaju pa gaming CPU od 4000 kn opet ima smisla
Staro 09.03.2022., 18:48   #1344
Dottore
Dottore's Avatar
Postovi: 7,703
Potvrđeno sada.
Po ovome AGESA V2 1.2.0.6 B je zasada u beti.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 11.03.2022., 15:57   #1345
Postovi: 8,544
Polako su krenuli novi BIOS-i (AGESA 1.2.0.6c) s Ryzen 7 5800X3D podrškom.
  • Security Patch for Raven Ridge / Picasso APU
  • Support Vermeer-X CPU (Ryzen 7 5800X3D)
  • Performance Improvements
Staro 12.03.2022., 11:25   #1346
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,837
Da li je za 5800x dovoljno imati 120mm AIO Arctic hlađenje? Bez OC, samo standardne postavke. Normalno korištenje, povremeni gaming i productivity, ali ne stalno pod opterećenjem.
Nemam baš mjesta za 240mm, tako da mi jedino preostaje 120mm.
Kako i 5900x stoji sa istim hladnjakom i korištenjem pošto on ima nešto drugačije postaje tih chipleta?
Staro 12.03.2022., 11:57   #1347
emilblomsky
emilblomsky's Avatar
Lokacija: karlovac
Postovi: 2,078
Autor Libertus Pregled postova
Iskreno. Ja imam 360mm,i pumpa mi je sa 5800x često uključena, i dosta se čuje. Sa 5600x je nikada nisam čuo. Tako da sa 120mm,ne očekuj čuda. Bolje uzmi klasični zračni hladnjak.
Phil of the future!
Staro 12.03.2022., 13:39   #1348
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Kako mislis cesto ukljucena, pumpa je uvijek ukljucena...
Staro 12.03.2022., 18:50   #1349
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Ja sam imao celsius 240 i presao na kelvina 360 i osjeti se da bolje drzi 5900x
Gaming ti nije problem, i općenito nece biti procesoru nista ako stavis aio120 , mozda bude manje boostao i to je sve, a mozda bude sve isto kao i da si na 240 uz mozda koji ° vise
Vidim da ne očekuješ čuda, tako da po meni nema potrebe ni za strah
Razmisli vise o polozaju radijatora, i protoku zraka, bez obzira koji AIO stavio, slicno je vazno kao i kod zracnjaka
MojSkuter
Zadnje izmijenjeno od: Eladio. 12.03.2022. u 18:56.
Staro 12.03.2022., 19:08   #1350
emilblomsky
Lokacija: karlovac
Postovi: 2,078
Ma krivo sam se izrazio,sorry!
Mislim da ju konstantno čujem kako radi.Sa 5600x je bila nečujna.
Ipak 65w vs 105w.Dosta je to razlike.
Phil of the future!
