Staro 24.12.2021., 22:42   #1951
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Autor fler Pregled postova
Ma vidio sam,
no zanimaju me komentari
čovjeka iz mase u ulozi krajnjeg korisnika.
@ zwer
Hvala
Nista.
Ma sve u svemu, nije savrsen, no kod svakog cemo nac neku manu, a ja nisam tolko osjetljiv na monitore i neka srednja kvaliteta me zadovoljava... Nisam ocekivao nista specijalno i to sam i dobio, ali definitivno gaming je sada na nekom ljepsem nivou.
Staro 25.12.2021., 07:30   #1952
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,327
Autor kiki85 Pregled postova
Di ćeš na 4k bez skalinga, čak i na 43", skaling je obavezan. Nije to skaling kao u igrama da renderira na manjoj rezoluciji vec samo poveća ikone start bar i ostalo kako ti paše. Nađeš sredinu ugode i dovoljnog prostora
Bilo bi super da skaliranje u prozorima radi super kao na npr mobitelima.
Svaki drugi program je mutan.
Da znam, zaobilazi se preko compatibiltya ali ipak treba svaki prog posebno...
Slobodno me dodajte na PSN
Staro 28.12.2021., 16:08   #1953
Postovi: 8,396
Staro 04.01.2022., 08:14   #1954
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,195
The world’s first 4K 240Hz gaming monitor, ‘Odyssey Neo G8’
The Odyssey Neo G8, which Samsung Electronics will be unveiling at CES 2022, is a 32-inch size, 4K resolution (3,840 x 2,160), curved design with 1000R curvature, and is a product that applies ‘quantum mini LED’
As the world’s first monitor to feature a 4K (3,840 x 2,160) 1000R curved screen with 240Hz refresh rate and 1ms response time (GtG), Odyssey Neo G8 32” (Model Name: G85NB) is set to open a new chapter in gaming monitor innovation, offering razor-sharp performance for even the most dedicated PC gamers. Its performance matches its stunning picture quality featuring Quantum Mini LEDs, Quantum HDR 2000 with a 2,000nit peak brightness and a million-to-one static contrast ratio, bringing out the most subtle details for increased world building and immersion.
The new Odyssey Neo G8 is built with a similar design language as the Odyssey Neo G9, offering a sleek white exterior that stands out even when it’s turned off. Beautiful colors leap off the screen into a user’s real environment with CoreSync lighting. The core lighting found on the backside of the monitor automatically detects colors on the screen and projects them in real life to create a deeper sense of immersion.
više o Smart Monitor-u M8 i High Resolution Monitor-u S8 procitajte na:
https://videocardz.com/press-release...gaming-monitor
https://news.samsung.com/global/sams...le-2022-lineup
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 04.01.2022. u 08:20.
Blue Spirit je online   Reply With Quote
Staro 04.01.2022., 09:32   #1955
slavonac90
slavonac90's Avatar
Postovi: 1,526
Strah me i pomislit kolika će mu cijena biti, ali samo nek štanacaju, valjda se nađe i meni neki cijenovno prihvatljiv 2.1 HDMI monitor, ako ne ove godine, barem sljedeće onda
slavonac90 je offline   Reply With Quote
Staro 04.01.2022., 10:01   #1956
Mladenxy
Mladenxy's Avatar
Postovi: 4,390
Kaj RTX 3090 može tjerati 240 fpsa u 4k u novim igrama?
Staro 04.01.2022., 15:06   #1957
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,327
To je ''za budućnost''. Može li u toliko FPS-a gurat nešto novije u 1440p uopće?
Staro 04.01.2022., 22:09   #1958
sharyn
sharyn's Avatar
Datum registracije: Jun 2010
Lokacija: grubišno polje
Postovi: 566
neka neka, došlo je i to vrijeme 4k 144 + herca
sharyn je offline   Reply With Quote
Staro 06.01.2022., 07:29   #1959
Blue Spirit
Postovi: 2,195
Alienware 34 Curved QD-OLED Gaming Di
The ultra-wide panel mates the ultra-high contrast ratio of OLED with the improved brightness, color range and uniformity of a quantum dot pixel layer.
In theory, you won't have to compromise on either image quality or gaming performance — you'll get 99.3 percent of the DCI-P3 color gamut, a 1,000,000:1 contrast ratio and wide viewing angles, but you'll still have up to a 175Hz refresh rate and an 0.1ms gray-to-gray pixel response time.
The bid for a no-compromise panel extends to the software. A Creator mode makes it easier to tweak gamma settings and even flip between DCI-P3 and sRGB color spaces. While there are only so many creators who'll consider curved displays (the panels can introduce reflections and distortion), this could be helpful if you moonlight as a photo editor.
This isn't quite a dream display. HDR brightness is limited to a modest DisplayHDR 400, and the 3,440 x 1,440 resolution won't thrill anyone used to 4K or beyond. You might still like the abundance of ports (four USB 3.2 Gen 1 downstream ports, one USB 3.2 Gen 1 upstream, two HDMI 2.0 and one DisplayPort 1.4), and Alienware is promising to fight OLED's burn-in risk with "improved" reliability and a three-year warranty that covers burn-in artifacts.
The 34 QD-OLED reaches North America on March 29th. Dell said it would only share pricing closer to the release date, but it's safe to presume you'll pay a premium. The Alienware team is clearly courting enthusiasts who want do-it-all monitors, and OLED doesn't come cheap at these sizes.
https://www.engadget.com/alienware-q...KTjbp-oOCcXv4U
EDIT:
OLED Monitors In 2022: The Current Market Status https://www.displayninja.com/best-oled-monitor/
Zadnje izmijenjeno od: Blue Spirit. 07.01.2022. u 00:58.
Staro 09.01.2022., 15:42   #1960
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Autor slavonac90 Pregled postova
a kaj bi uopce dobio s tim, a da display port vec ne podrzava?
Staro 09.01.2022., 20:46   #1961
slavonac90
slavonac90's Avatar
Postovi: 1,526
Autor zwer54 Pregled postova
Na ps 5 bi dobio pun potencijal konzole, za PC bi mi bi ok i bilo kakav bolji 1440p monitor, od 32 inča ali ovako jedino HDMI 2.1 dolazi u obzir.
Staro 09.01.2022., 21:50   #1962
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
plejka je za tv, pa nebus na desktop monitoru plejku igral... ili?
Staro 10.01.2022., 00:18   #1963
slavonac90
slavonac90's Avatar
Postovi: 1,526
Pa i trenutno igram ps 5 na monitoru, ne vidim u čemu je problem.
Staro 11.01.2022., 06:34   #1964
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,327
Pa ne mora sjedit 5m od monitora.
Vj igra kao da se igra i na kompu, efekt mu je onda vj isti kao na telki.
Staro 12.01.2022., 18:00   #1965
Igor_Zg
Igor_Zg's Avatar
Postovi: 909
nedavno sam se odlučio za Gigabyte M32u i taj 4K će mi vrhunski pomoći oko prostora na ekranu za posao a kasnije ubodem PS5 u njega i imam full rezu i odaziv za gejmanje poslije posla, a lako PS5 preseli čovjek i u boravak na veću teku (iako nije 4k)
I to sve radi PRE skupog HW da si složiš osrednji gaming rig za 4k
Igor_Zg je offline   Reply With Quote
Staro 12.01.2022., 18:51   #1966
d0X
Kostolomac
d0X's Avatar
Postovi: 1,522
Nema uopće problema, bunca tip.
PSN Steam
Staro 12.01.2022., 19:51   #1967
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,113
Ima sigurno 5+ godina igranja na PS5, tko zna što će biti u tom periodu.
Prije par tjedana bio kod čovjeka u stanu koji igra Xbox One X na 24" FHD monitoru. Smiješno za vidjeti, ali tko zna što planira za koji dan ili mjesec. Kupio dok se dalo kupiti
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 13.01.2022., 13:45   #1968
slavonac90
slavonac90's Avatar
Postovi: 1,526
Ja ne vidim tu ništa sporno...na kompu se ok igrati na monitoru dok na konzoli ne valja, wtf? Pa logično je ako ću spojiti playstation na monitor, da neću sjesti 3 metra dalje nego blizu monitora i dojam identičan kao da si na kompu ili gledaš TV s 3 metra. Razumijem da se netko voli zavaliti u kauč i igrati na što većem ekranu, ali to nije pisano pravilo. To kao da kažem nekom tko je kupio terenca "nećeš ga valjda po gradu vozit"
Trenutno mi je ps5 kao i komp spojen na 27 inča FHD monitor i tako peglam non stop jer se ne moram natezati sa ženom oko TV-a. Kada se želim izvalit dofuram si umjesto stolice fotelju i meni super. Jedino gledam sada neki ekran koji će mi dati punu podršku za ps 5, a da mi ujedno bude dobar i za desktop monitor, a tu mi se najbolje ukplapaju 32 inča modeli sa 2.1 HDMI, jedino što ih ima svega par na tržištu pa drže cijene, ali nadam se da ih se pojavi još na tržištu pa da se malo cijene stabiliziraju.
EDIT: Konkretno pikiram kao i kolega u par postova iznad Gigabyte m32u , ali mu je cijena kod nas 7300 (Protis) što mi je puno, ali valjda naštancaju još modela do kraja godine pa se bude moglo uzeti nešto i za manje para. A da ne pričam kako bi bilo odlično da izbace i neki monitor sa istim specifikacijama, ali pravim HDR-om, no tu cijena bude onda i preko 10k
Zadnje izmijenjeno od: slavonac90. 13.01.2022. u 13:52.
Staro 13.01.2022., 14:38   #1969
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,327
Protis izbjegavaj, baci malo oko na temu o iskustvima. Neki puta neke uštede izgleda nisu vrijedne...
I da, načekat ćeš se da HRR 4k monitori pojeftine i to dosta. Najgore je što PS5 ne podržava niti VRR niti 1440p za razliku od XSX. I posebnu pažnju treba obratiti na rivjue, na npr HWU rivjue monitora gdje imaju onu bullshit tablicu gdje se piše između ostalog da li je podržan upotrebljiv HDR i HDMI 2.1 pravih specifikacija.
I M28U je isto stravično skup, po meni bzvz jer za tu lovu kupiš poštenu telku i to popriličnih proporcija. Znam, nije isto, ali opet...
Staro 13.01.2022., 15:16   #1970
slavonac90
slavonac90's Avatar
Postovi: 1,526
Hvala na upozorenju, nisam nikada od njih ništa naručivao, vidio sam da tamo imaju navedeni monitor pa ih naveo kao primjer, ali ne budem kod njih uzimao ništa, iskreno najsretniji sam do sada uvijek bio sa Linksom, no da nejdem u off previše.
Sony je odradio šupački potez s tim što nisu dali podršku za 1440p, jer da je tako definitivno bih uzeo neki bolji 32 1440p monitor i mir, a ovako kemijam preko pola godine s čim zamjeniti postojeći ekran, a da je veći i da je dobar za ps 5, ali mi se čini da je to trenutno znanstvena fantastika.
Čak sam razmišljao o najavljenom LG 42 OLED televizoru, ali me strah ga upariti za desktop s obzirom na burn-in o kojemu svi trube. Problem je što ja tražim jedinstveno riješenje za komp i ps5 jer za još jedan TV u sobi nemam mjesta pa mi je ovaj kombo koji sada imam odličan, samo da je bolji ekran...
Što se tiče HDR-a na monitoru znam da ih ima možda svega par modela da daju pravi HDR prikaz,a o cijeni bolje da ne pričam...ovi HDR 400 što ih imaju maltane svi monitori koliko sam shvatio nekada je bolje imati to ugašeno kao što je to i na jefitnijim televizorima (tipa moj Samsung na kojemu mi HDR izblijedi sliku samo), ali aj opet nije na odmet da ima čisto psihološki.
Gledao sam i taj m28u ali je možda 1000 kn jeftiniji od 32 inčnog,a opet što se tiče veličine razliku od jednog inča neću baš primjetiti, tako da ciljam baš na 32.
Uglavnom nemam neko adekvatno riješenje za zamjenu monitora, a da mi ulazi u prihvatljivi budžet, jednostavno mi preostaje čekati i nadati se padu cijena ili da će se Sony smilovat i dati podršku za 1440p, a ne znam iskreno što je nerealnije da će se dogoditi u skorije vrijeme od te dvije opcije. Već sam negdje prije spomenuo da mi najpametnije batalit gaming i okrenuti se pecanju, jeftinije, zdravije, a i živci su u zen stanju, sve u svemu win/win situacija
Staro 14.01.2022., 13:25   #1971
Igor_Zg
Igor_Zg's Avatar
Postovi: 909
Autor Disco Pregled postova
Kaj se ne bi PS5 mogao spojit na FHD telku?
Staro 14.01.2022., 14:05   #1972
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,327
Autor Igor_Zg Pregled postova
Pa naravno da bi.
Staro 14.01.2022., 16:21   #1973
Igor_Zg
Igor_Zg's Avatar
Postovi: 909
Pa naravno da bi.
a onda kaj... reza ne bude full ali se da igrat - to je bitno
Staro 15.01.2022., 10:34   #1974
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,327
Pa IMHO nije ni bitno da li je 4k kad je 1080p nativna i sigurno će igre izgledat odlično.
Nego, evo napokon normalni dućani (Futura IT i PCSHOP/MagazinRS) dobili M32Q, samo je cijena mrvu paprena...ahhh...nikad zadovoljan.
Vidim taj monitor ima dobru konkurenciju u LG 32GP850-B. Samo je taj čak i skuplji osim kod nekih megabajt.hr iz St za koje nikada nisam čuo, nemaju ni istaknuto trajanje jamstva.
Staro 15.01.2022., 17:01   #1975
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
ma sve jasno, nego, na kompu ne koristimo te ogromne ekrane ponajvise zbog prostora i jer nekad nisu ni postojali, a komp spojen na tv nije bila neka sreca do prije koju godinu... I zato je tu konzola uletila ko bogom dana da mozes uzivat u velikom ekranu pa mi konzola na desktop monitor ne ide jedno s drugim...
Naravno da nema problema u tome, to je cisto moje osobno misljenje... Inace ne igram na gamepad nit posjedujem konzole...
Uzeo sam Xbox za 4k 55" telku, igrao svega par sati i prodao konzolu dalje jer mi se ne igra nis na konzoli...
Staro 15.01.2022., 17:29   #1976
Mladenxy
Mladenxy's Avatar
Postovi: 4,390
spajao još CRT televizije preko svideo izlaza, a HDMI na grafama imamo prek deset godina, di ćeš jednostavnije i sretnije
Staro 15.01.2022., 19:37   #1977
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Autor estugarda Pregled postova
Ima li tko konkretno iskustvo sa BenQ PD3200u, PD3220u ili Asus ProArt 329Q/C?
Naime, to su monitori koje pratim, pošto trebam 32" 4K monitor sa preciznim bojama za mix CAD/photo/video. Baš sad kako sam krenuo u realizaciju, ispalo je da se za sva 3 modela pojavilo puno prijavljenih problema sa matricama; veliki brojevi dead i stuck pixela, poluispravna pozadinska osvjetljenja, loš QC i slično...
Prst mi je na BUY gumbu za BENQ PD3200U, ali još uvijek me trta losih recenzija i navodnih QC problema. Zato BUMP-am svoje pitanje u nadi da se možda javi netko s iskustvom
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 15.01.2022., 21:44   #1978
kiki85
Datum registracije: Jul 2021
Postovi: 86
Što se sekiraš, kupi, možeš vratiti u roku 14 dana ako ne budeš zadovoljan. (ako kupuješ kod našeg dućana u HR preko weba)
kiki85 je offline   Reply With Quote
Staro 15.01.2022., 21:58   #1979
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
da samo kaj slika nikad nije bila jednako ostra ko na monitoru... tek sad na novijim telkama zadnjih par godina ima dobar prikaz...
Staro 17.01.2022., 09:31   #1980
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,327
+1
Ja sam se spajao na telke još od doba GF 256 i to je bilo sve samo ne dobra slika. Eventualno je moglo proći za pogledat kakav divx film, ali za bilo što drugo je bilo loše. BTW, dan danas imam jednu od tih CRT telki u sobi sa spojenim mediaplayerom, 72cm ravni ekran, 100hz, milina, IMHO bolje od ovih LCD govnarija, samo je teška..
Tek od HDMI/LCD je upotrebljivo.
Samo se LCDima što se monitora tiče mora priznat da su u jednom nemjerljivo bolji od CRT-a...geometriji, pa hebote ono prije je bilo lutrija uspjet namjestit da vidljiva slika bude što veća, pa promjeniš rezu ili osvježavanje pa opet niš ne štima, pa staviš zvučnik blizu pa moraš pokrenut degauss jer se boje shebu...ah...
