#1021 |
Postovi: 8,226
Sent from AS/400. |
#1023 |
Postovi: 1,346
@Pupo https://www.ebay.com/itm/Intel-D975XBX2-D53347-404-D53347-Mainboard-Sockel-775-3xPCI-E-2xPCI-IDE-SATA-USB/372592987801?epid=62257736&hash=item56c045ce99:g:IZMAAOSwYwZcNKNr:rk:3 f:0https://www.ebay.com/itm/Intel-S975XBX2-ATX-DDR2-LGA775-No-Accessories/351389325404?epid=74082415&hash=item51d06f985c:m:mjY3ir3e1ndeiNdMOhldcjQ:rk:27 f:0https://www.ebay.com/itm/Intel-S975XBX2/254095788016?hash=item3b294a07f0:g:Gk8AAOSwrm9cScOA:rk:28 f:0https://www.ebay.com/itm/Intel-S975XBX2/254093306032?epid=74082415&hash=item3b292428b0:g:Gk8AAOSwrm9cScOA:rk:34 f:0
Dabogda ti Chris Bangle radio facelift. |
#1024 |
Postovi: 80
Pozdrav. Imam dvije matične+ram koje mi stoje pa me zanima koju se više isplati nadograditi s nekim i5/i7 tak da imam i neki pristojnu stolnu konfu - uzimajući u obzir omjer uloženo/dobiveno/cijena/performanse. Što je isplativije: nadograditi stariji Ivy Bridge ili noviji Skylake/KAby Lake i konkretno koji model cpu.a? od ostatka imam rx580,ssd i napajanje. Ako nađem vremena onda bi se tu mogla zaigrati i pokoja igra. mbo1:B75MA-E33 mbo2:Fatal1ty B150 Gaming K4/Hyper |
#1025 |
Lokacija: ZAGREB-DUBRAVA
Postovi: 1,075
H110M PRO-VD ploča pitanje
da li na ovu ploču H110M PRO-VD paše ako netko zna procesor: Intel Core i7-6700 @ 3.40GHz Class: Desktop Socket: LGA 1151 Clockspeed: 3.4 GHz Turbo Speed: 4.0 GHz Cores: 4 Threads: 8 Typical TDP: 65 W u specifikacijama ploče stoji Supports 6th Gen Intel® Core™ i3/i5/i7 processors, and Intel® Pentium® and Celeron® processors for Socket LGA1151 i nisam baš siguran pa pitam da se mijenjam za celeron G3900 uz moju nadoplatu https://www.msi.com/Motherboard/H110.../Specification Zadnje izmijenjeno od: robi64. 05.04.2021. u 00:49. |
#1026 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Ide taj CPU na tu MBO. Imaš ovdje listu svih procesora: https://www.msi.com/Motherboard/supp...vd#support-cpu
#1027 |
Postovi: 1,075
bios intel matične ploče H110M PRO-VD
da li se flashanjem najnovijim biosom i svi stariji biosi popravljaju nadogradnjom tog novog biosa da tako pitam dakle da li se popravljaju i svi nedostaci starijih biosa ili se mora flashati određeni bios za određeni popravak na ploči mislim da znate što hoću pitati, konkretno da li procesor Intel Core i7-6700 ES QH8F 4C 2.2GHz A0 LGA1151 14nm Skylake odgovara za ovu matičnu ploču flashanjem zadnjeg biosa ako netko zna (Verzija 7996v2H) Zadnje izmijenjeno od: robi64. 05.04.2021. u 20:58. |
#1028 |
Postovi: 23,583
Čemu nova tema, trebao si nastaviti u prethodnoj. Inače, odgovor je da, odr. verzija Biosa uključuje popravke prethodnih / starijih verzija. Ako to nije slučaj onda se posebno navede. |
#1029 |
Postovi: 34,037
Taj CPU je podržan od BIOSa 7996v20 https://www.msi.com/Motherboard/supp...vd#support-cpu
#1032 |
Postovi: 1,075
Intel HD Graphics 5500 ili Intel UHD Graphics 600
Intel HD Graphics 5500 ili Intel UHD Graphics 600 dakle koja od ove dvije grafike na laptopu je bolja oba imaju 4gb rama jedan ima CPU: INTER CELERON N4000 RAM: 4 GB DDR4 INTERNA: 64GB a drugi i5 5200U 4gb RAM DDR3 konkretno radi se o HP ProBook 430 G2 i5 5200U i ACER ASPIRE 1 - A114-32-C2P1 ili koji je bolji od ova dva laptopa cijena im je ista oko 1000kn. Zadnje izmijenjeno od: robi64. 26.01.2023. u 16:15. |
#1033 |
Postovi: 12,613
ProBook
#1034 |
Datum registracije: Jun 2014
Lokacija: ZD
Postovi: 10
Pozdrav,imam pc hp 6000 Pro sa matičnom 3048h (XU1 PROCESSOR), 8 gb ram i grafičkom 1 gb,Intel Pentium E6700,ssd. Želio bi staviti bolji procesor i više rama.Da li je to moguće na ovu matičnu. Hvala |
#1035 | |
Postovi: 17,089
Do 16GB rama možeš staviti i možeš staviti npr. neki Quad-Core. Ovo je lista quad-core-ova za tvoju matičnu: – Core 2 Quad Q9650 – Core 2 Quad Q9550 – Core 2 Quad Q9505 – Core 2 Quad Q9400 – Core 2 Quad Q8400 |
#1037 |
White Rabbit
Postovi: 5,178
(P.S.- oba su govna za gaming jer su grafe ...klasicne Intel integruse jel). Al ak bas moras odabrat > Probook ![]() |
#1038 |
Datum registracije: Dec 2021
Postovi: 36
dal mi se isplati prijeći sa i3 9100f na i7 9700k?znam da je razlika dan i noc u samim procesorima al muci me sto nebi trenutno izdvajao za novu maticnu, a imam asus h310-plus rev2. kaze da podrzava, al dal maticna moze bit bottleneck nekako? znam da h310 nema nista za oc, mada nemam neke namjere oc, casual gaming i streamanje....ostatak je strix rx570 i 2*8GB kingston hyperx fury 2666MHz druga opcija mi je bila uzet ryzen 5 2600x sa mbo, al mislim da tu nebi puno dobio naspram trenutnog i3, samo muku prodavanja ovog i3 |
#1039 | |
Prvoklasni Krkan
Postovi: 5,349
Ako ga dobijaš za neku smješnu/isplativu cijenu, možda možeš probat...neka još netko da savjet. Ja osobno bi vj išao an komplet sve novo da imam low end ploču. |
#1040 |
Postovi: 4,437
Slažem se, i5 9400F max na tu ploču kako bi radio na max klokovima. Također jako teško da buš našao i7 9700k za neku siću. Koliko vidim na njušci je najjeftiniji 1800 kn...a kupiš novi i5 10400f za 1200 kn i imaš otprilike isto. Cijena ploča je trenutno loša ali nađe se solidno za solidne novce u kombinaciji sa tim procesorom https://www.links.hr/hr/maticna-ploc...sora-050300548 A trenutnu ploču i CPU prodaš za 500 kn. |
#1042 | |
Postovi: 36
#1043 |
Postovi: 4,736
bok malo dosadilo, pa gledam nadogradnju ovo što je pod moj komp Z270M-ITX/ac
m2 ssd , grafa ostaje kao i ddr4 |
#1044 |
Vocna iglica u mudante
Lokacija: Beograd
Postovi: 2,837
#1045 |
Postovi: 36
gledam ovaj 10400f....mogu ici i na jeftiniju opciju sto se tice ploce? imam dva keksa po 8GB 2666MHz memorije i to necu dirati, znaci ne planiram tako skoro nista drugo dirati ionako, niti raditi neki oc, jel bitno da idem na b460 ili mogu recimo i h510 upiknut? |
#1046 | |
Postovi: 36
#1047 |
Postovi: 36
uzeo 10400f i msi h510m pro-e, htio sam uzeti ovu b460 al nisu imali na licu mjesta, jedina slicna solucija je bila neka b460 stotinjak kuna skuplja što mi je bilo van buđeta nazalost ![]() obzirom da nemam m2 ssd niti namjeravam uskoro uzimati, te dva ram slota su mi dovoljno, mislim da će me ova maticna sluziti ok....jedina greska u samoj kupovini je bio cpu cooler, silverstone kr03, ciji fan nema pwm..... ima netko preporuku za neki fan sa pwm? koliko vidim ovaj je 92mm fan i trebao bi mi tocno 92mm fan da bi mogao stavit postojece kopce koje su dosle s coolerom....ili da jednostavno odem i uzmem neki drugi cooler i pomirim se sa bacenim 90kn |
#1048 |
Lokacija: qǝɹƃɐz
Postovi: 441
Zašto bacati ventilator? Samo u biosu staviti umjesto "pwm" kontrole brzine cpu ventilatora "voltage" control. |
#1050 |
Postovi: 1,075
Intel core i-3-6100 procesor skylake pitanje
da li ovaj procesor odgovara za matičnu ploču H110M PRO-VD koliko vidim u spec.ploče trebao bi odgovarati pa ako netko može potvrditi pa da ga kupim da sam siguran Zadnje izmijenjeno od: robi64. 26.01.2023. u 16:15. |
