Staro 08.11.2021., 18:15   #9421
Postovi: 8,487
Veli Lisa su da EYPC Milan-X Zen 3 sa sveukupno 800MB+ L3 cachea ima 50%+ porast u performansama u odnosu na "običan" EPYC Milan Zen 3.
Staro 08.11.2021., 18:21   #9422
Dr. Strange
Datum registracije: Aug 2020
Postovi: 899
I dionice su porasle oko 8%.
Staro 08.11.2021., 18:26   #9423
Dr. Strange
Postovi: 899
I koliko sam razumio koristili su 6nm za cache? nadam se da će i memorijski kontroler migrirati s 12nm gloflo na 6/7nm TSMC pa da svaki primjerak može raditi na 2000 FCLK što će donjeti dodatan boost pored cachea.
Staro 08.11.2021., 18:27   #9424
Postovi: 8,487
MCM CDNA 2 GPU na TSMC 6nm procesu sa 128GB HBM2e memorijom, dok je kakvih 2x do 4x brže od nVidia A100 rješenja.
AMD Announces Instinct MI200 Accelerator Family: Taking Servers to Exascale and Beyond
At the heart of AMD’s new products is the CDNA 2-based die. AMD hasn’t named it – or at least, isn’t sharing that name with us – but the company’s literature refers to it AMD Instinct MI200 Graphics Compute Die, or GCD. So for the sake of consistency, we’ll be referring to this sole CDNA 2 die as the GCD. The GCD is a modest chip built on TSMC’s N6 process technology, making this the first AMD product built on that line. According to AMD each GCD is 29 billion transistors, and at least for the moment, AMD isn’t sharing anything about die sizes. As far as major functional blocks go, the GCD contains 112 CUs, which are organized into 4 Compute Engines. This is paired with 4 HBM2E memory controllers, and 8 Infinity Fabric Links.
AMD Gives Details on EPYC Zen4: Genoa and Bergamo, up to 96 and 128 Cores
As part of AMD’s Data Center event today, the company is showcasing that its 4th Generation EPYC roadmap will consist of two segments: Genoa, with up to 96 Zen 4 cores, and Bergamo, with up to 128 Zen 4c cores. Not only are we getting official confirmation of core counts, but AMD is disclosing that Bergamo will be using a different type of core: the Zen 4c core. The ‘c’ in this instance means ‘cloud optimized’. AMD has built two different forms of Zen 4 core, one for most applications, and a higher density version for the cloud. This means that these two cores, while functionally identical, will use different sets of masks. The Zen 4c core has been redesigned to have the same functionality but offer more density combined with a different power/performance point on the voltage frequency curve. The Zen 4c chiplet, according to AMD, is built on an HPC variant of TSMC N5.
Izvor: AnandTech
Zadnje izmijenjeno od: The Exiled. 08.11.2021. u 18:50.
Staro 08.11.2021., 18:44   #9425
Dr. Strange
Postovi: 899
TSMC-ov 5nm omogućuje 2x density, 2x power efficiency i 1.28x performance, dobar boost samo od noda, plus promjene u arhitekturi. Zen 4 za desktop bi trebao u najmanju ruku biti ravnopravan sa Raptor Lake, plus naprednija verzija 3d cachea što će se najviše u gamingu osjetiti pa bi tu mogao i dominirati.
Staro 08.11.2021., 18:45   #9426
Dr. Strange
Postovi: 899
Moore's Law Is Dead ima dobre izvore .
edit: i btw dionice rastu kao lude haha.
Staro 08.11.2021., 18:51   #9427
Postovi: 8,487
Super je kaj su već svi ovi najavljeni proizvodi zapravo već kod klijeneta na korištenju ili testiranju. Sve u svemu nije loše, TSMC 6nm za GPU i 5nm za CPU komponente.
Staro 01.12.2021., 15:57   #9428
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
AMD Ryzen Desktop CPU Rumors: Zen 2 ‘Renoir X’ To Tackle Intel Core i3, Zen 3 ‘Vermeer X’ To Tackle Alder Lake, Zen 4 ‘Raphael’ To Tackle Raptor Lake, X670 & B650 Motherboards To Feature PCIe Gen 5 Support
Link: https://wccftech.com/amd-ryzen-deskt...e-raptor-lake/
Staro 01.12.2021., 17:55   #9429
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,338
Ja i dalje ne kužim zašto guraju Zen 2. Disco je u drugom threadu spomenuo moguće bolje yieldove, što je moguće, ali nigdje nije potvrđeno... Čini mi se kao umjetna segmentacija.
Staro 01.12.2021., 18:11   #9430
BusMaster
BusMaster's Avatar
Postovi: 343
___________________________________________________________
Nije do yieldova, nego neka čudna strategija AMD-a, s obzirom da nemaju ili ne očigledno ne namjeravaju izbaciti 4-core proc sa ZEN3 jezgrom... idu protiv nadolazećeg AlderLakea i3 sa Renoirom bez IGP.a tj. bez grafike.
Da je čudan potez.. je, i to nemalo. Vjerojatno tj. sigurno će bit monolitni čip malih dimenzija i jeftin, a dovoljno nabrijan sa clockom da se može kako-tako nositi sa i3-AL.
Da su htjeli mogli su maknuti dvije jezgre i IGP sa R5-5600G, ali ko zna što je pozadina svega.. možda će to ići za OEM only i AIO desktope?
Staro 01.12.2021., 18:23   #9431
Postovi: 8,487
Uopće se postavlja pitanje zbog čega Intel u 2021. na pragu 2022. izdaje quad-core Core i3 i dual-core Pentium modele bazirane na Alder Lakeu.
Tak da po tom ključu nema razloga da AMD izda ikaj bolje od prepakiranih Zen 2 mobilnih APU-a kojih imaju na bacanje.
Osim toga, kad stigne 5nm Zen 4, postojeći 7nm Zen 2 i 3 modeli budu se još jedno dulje vrijeme proizvodili i prodavali.
Obzirom na situaciju unatrag skoro dvije godine, prodaje se apsolutno sve, a rijetko tko više i pita za cijenu.
Staro 01.12.2021., 19:11   #9432
Odinarius
All-rounder
Postovi: 1,338
Stoji, iako je odgovor na neka pitanja jednostavan - postoji segment jeftinih laptopa i desktopa kojima još ne treba ništa više od quada. Na poslu imam Ryzen 3500 mobile quad (znači 4/8 Zen+) i to radi bez greške, još ga nisam uspio preopteretiti u uredskom radu (danas sam enkodirao video dok sam držao prezentaciju u Teamsima plus 10 otvorenih tabova i još jedan program). Tako da to razumijem, manje jezgri=manji die=jeftinija proizvodnja.
Ono što ne razumijem je zašto ne ići na Zen 3 jezgre. Pretpostavka je da košta jednako kao i Zen 2 jezgra, a čisto je bolja. Postoje Zen 3 APU isto kao i Zen 2, jednako je kompleksno smanjiti i jednog i drugog iz postojećih proizvoda.
Staro 01.12.2021., 19:28   #9433
Postovi: 8,487
Nažalost, jednostavan odgovor na to pitanje je, zato jer mogu, šteta im je iskoristiti Zen 3 za takve izlete, jer ga još uvijek mogu naplatiti više, mada sama proizvodnja košta isto ko Zen 2.
Kaj se quad-core rješenja tiče, kod mene je također poslovni laptop upogonjen jednim takvim mobilnim Intel rješenjem i sve radi kak spada, čak se i dvije virtualne mašine istovremeno mogu pokrenuti.
Staro 02.12.2021., 09:21   #9434
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,360
Što se tiče izdavnaja 4-ero jezgrenih procova, treba se upitati i zašto AMD ne nudi neki pandan inetlovim xx400 6-ero jezgrašima?
Nešto za kilu kuna.
Slobodno me dodajte na PSN
Staro 02.12.2021., 09:52   #9435
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Autor Disco Pregled postova
Nešto za kilu kuna.
Da, tu su najviše manjkavi, na poslu sam dobio 10400 i čisto iznenađen sa price/performance
Valjda računaju da je 2600X i dalje OK
Staro 02.12.2021., 12:24   #9436
Postovi: 8,487
Ryzen 5 3600 je svojevremeno koliko-toliko poslužil kao konkurencija za Core i5-10400 modele, ali nažalost R5 3600 današnje cijene nemaju veze sa zdravim razumom.
Zadnje izmijenjeno od: The Exiled. 02.12.2021. u 16:25.
Staro 02.12.2021., 16:01   #9437
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,360
Ryzen 5 3600 je svojevremeno koliko-toliko poslužil kao konkurencija za Core i5-12400 modele, ali nažalost R5 3600 današnje cijene nemaju veze sa zdravim razumom.
Koja konkurencija kad se kladim da će 12400 pobrisat pod sa 3600 vulgaris i to bez da gledamo nebuloznu cijenu od 1700+kn (možda će biti bolji i od 5600X, u najgorem slučaju će biti jednaki).
Nemoj zaboravit da je to najgori bin i da su im all core taktovi dosta niski (u prosjeku većina je na 3,8-3,9 kad ih se malo upregne), zanemari rivjuere koji dobivaju cherrypickane primjerke.
Staro 02.12.2021., 16:27   #9438
Postovi: 8,487
Ma krivo sam napisal, a linkal sam Core i5-10400 recenziju vezano za ovo kaj segregator priča, jer tak jasno da Zen 2 modeli nemaju šanse sa Core i5-12400. Tu jedino ulazi R5 5600X, ako ikad spuste cijenu.
Staro 02.12.2021., 21:20   #9439
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,585
Nema se tu što reći, sad AMD mora reagirati. Ili izbaciti nešto bolje po trenutnim cijenama ili drastično skinuti cijenu postojećim
Što se tiče quadova, još uvijek ima koristi od istih u office mašinama. Na htpc uz tv imam 2c4t tj. i5 4570T uz klasičan hdd. Koristim za netflix i browser i za to još gura, ali to postaje neki limit upotrebe, quad mora ostati minimum, poželjno sa SMT/HT. Vidi se da se malo kilavi, ne ne znam dali je sve do cpu-a, nešto je vjerojatno i do hdd-a
Staro 02.12.2021., 21:29   #9440
Postovi: 8,487
Da fora bude bolja, AMD već ima Zen 3 quad-core u vidu 5300G, ali su rezervirani za OEM ekipu. Samo jebiga, zahvaljujući situaciji koja eto ulazi u svoju drugu godinu, nema tog očekivanog spuštanja cijena.
Tak jasno da je običan R5 5600 za ~1.000 kn i više nego super, isto ko i quad-core verzija istog čipa samo da mu srežu dvije jezgre i lupe cijenu od 750 kn, ali jedno su želje, dok ovo ludilo ne posustaje.
Eto ga, Core i3-12100 se uspoređuje s dvije godine starim Zen 2 quad-core R3 3300X modelima, dok nVidia izdaje prepakiranu RTX 2060 12GB koja neće stići na tržište, a već bude nestala u kritpo rudnicima.
I to je nažalost realnost. Izađe Alder Lake i kaj se desilo, ama baš ništa, jer AMD službeno nije dirnul cijene, a ove BF i CM akcije za kraj godine su tragikomične.
Staro 02.12.2021., 21:30   #9441
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Vjeruj mi, vecinom je do HDD-a. Iako ni 2c/4t nije neka sreća, bolje bi bilo da je 4c/4t. No ako je za spomenute stvari dovoljan stari Athlon x2 7750 sa 8GB DDR2 RAM-a, SSDom i integriranom grafom na MBO (vrlo granično, ali ne radi probleme), onda je i taj i5.
Staro 03.12.2021., 22:28   #9442
Postovi: 8,487
Dakle službeno je, Intel CEO sere kvake kao nitko prije njega, a bilo je bisera samo takvih. Jao, frajer umjesto da šuti, on na dnevnoj bazi daje izjave koje su sve hit do hita.
Pričanje u prvom licu, dok ga se pita za Intel kao firmu bolje da i ne spominjem. Na kraju budu postali fabless, a u međuvremenu još uspiju i TSMC suradnju sjebati.
Onda bude nismo znali, ipak smo mi najveći i najbolji, rekordne zarade dok otkupljujemo vlastite dionice i tome slične pizdarije.
Intel CEO: I haven't lost share to AMD, I've given share to AMD
By all accounts, AMD is back in the game with its Zen architecture, and has especially hit its stride with Zen 3. From the desktop (Ryzen) to the data center (EPYC), AMD has been gaining ground on its rival, and at times has even laid claim to the performance crown. Be that as it may, Intel CEO Pat Gelsinger has a very interesting perspective on Intel's market share losses and AMD's gains. "I haven't lost share to AMD, I've given share to AMD, because I didn't have capacity. So a lot of this is just catch up to our growing market and years of under investment," Gelsinger said at the 25th Credit Suisse Technology Conference. That's quite the statement. It's also a truncated one in need of context. Gelsinger was responding to a question about CapEx and Intel's core business playing catch-up with the lack of supply, as well as the chip maker's massive investments in capacity. The person who posed the question pointed out that Intel's investments seem fueled by a "demand curve that looks very aggressive," and that margins could suffer if Intel's projections are off.
Izvor: HotHardware
Staro 14.12.2021., 03:08   #9443
BusMaster
BusMaster's Avatar
Postovi: 343
AMD CES 2022 Event to Highlight Ryzen 3D V-Cache, Radeon Updates
Link: https://www.tomshardware.com/news/am...radeon-keynote
Staro 22.12.2021., 20:24   #9444
Postovi: 8,487
AMD to briefly talk about Zen 4 at CES 2022
In an exclusive interview with Antony Leather (Forbes/CrazyTechLab), AMD CTO Mark Papermaster confirmed that Zen 4 architecture will be part of the CES 2022 press conference, however, the primary focus will be on updated Zen 3 architecture with 3D V-Cache. On January 4th, AMD is to unveil its next-gen Ryzen 6000 series for laptops. The company is also expected to launch Zen 3 desktop processors featuring 3D V-Cache technology, and high-end desktop Threadripper PRO 5000 series. When it comes to other CPU products, such as Zen 4 architecture, those are not currently expected to launch sooner than the third quarter of 2022. In the interview Papermaster confirmed that some details on Zen4 will be mentioned at CES 2022, with more annoucement coming througout 2022. It does not seem that AMD is ready to unveil product specifications just yet, but a brief mention of fundamental changes arriving with the next-gen Ryzen 7000 series might be on a table. The latest rumors suggest AMD might formally announce its Zen4 consumer products at Computex 2022.
Izvor: Interneti
Staro 23.12.2021., 18:51   #9445
Dr. Strange
Postovi: 899
Ostaje samo pitanje da li će 3d cache biti od početka implementiran u Zen 4 ili će opet naknadno pustiti te modele ovisno o Intelu.
Staro 23.12.2021., 19:15   #9446
Postovi: 8,487
Da, ali mogli bi komotno 3D cache složiti za cijelu Zen 4 ponudu odjednom i to je to.
Ionak su rekli da je 3D cache orginalno planiran za Zen 2, pa nije prošlo, a sad ide s ovim Zen 3 modelima.
Onda nek bude sastavni dio svih Zen 4 modela i voljno. Pogotovo, ako slože i RDNA 2 iGPU za sve modele.
Staro 25.12.2021., 19:49   #9447
BusMaster
BusMaster's Avatar
Postovi: 343
AMD Ryzen 9 6900HX ‘Rembrandt’ APU Specs Leak Out: 8 Enhanced 6nm Zen 3 Cores, 20 MB Cache, 4.6 GHz Boost & Radeon 680M ‘RDNA 2’ Integrated Graphics
Link: https://wccftech.com/amd-ryzen-9-690...ated-graphics/
AMD Next-Gen Ryzen 7000 Raphael ‘Zen 4’ CPU Rumors: Computex Announcement, X670 Flagship Chipset With DDR5 & PCIe 5 Support, RDNA 2 iGPU
Link: https://wccftech.com/amd-next-gen-ry...t-rdna-2-igpu/
Staro 26.12.2021., 09:04   #9448
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,360
Uf, ako se pokaže istinitim to da će od sada i svaki AMD proc imat igpu, to će biti fantastično. Pa kakva god da je ta RDNA2 igpu, bit će bolja od ničeg u ovo debilno vrijeme kada grafe koštaju ko mali auto.
Staro 26.12.2021., 14:52   #9449
Postovi: 8,487
RDNA 2 iGPU bi se po pitanju performansi mogla smjestiti iznad desktop verzije GTX 1050 Ti modela.
Staro 27.12.2021., 09:15   #9450
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,360
Opa, ako bud etako, bit će to odlično.
Onda će se moći igrat barem noviji naslov na low 720/1080, a stariji (bubam napamet, ali do 2013-2014) vj i sa višim detaljima.
