Povratak   PC Ekspert Forum > Računala > Storage > Mediji
Staro 08.02.2006., 23:50   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Problem s TDK CD-R
Frend mi je dofuro TDK CD-R Audio CD, tj 3 komada, i kad sam mu zaprzio muziku odnio ju je doma i ne svira... Kazem, ono donesi do mene ziher ti linija sere nekaj...:confused: Ubacimo kod mene u komp, ono "Blank CD"... Probam jos jednom zaprzit i isto javlja "Blank CD"... Cd inace kosta oko 8-9kn...
Inace prza je LG GCE-8525B, stara 2 god, nikad problema s njom i przi sve medije osim ovog TDK
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 09.02.2006., 01:44   #2
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
nebih te htio plasiti ali na taj nacin crknu przilice.....
tako da pogle da nije otisla u vjecna lovista
.i.
Razer Blade 15
Staro 09.02.2006., 11:30   #3
Facelessone
Facelessone's Avatar
Postovi: 4,203
nisi jedini ja sam prije tjedan dana kupil 10kom al običnih i od njih 10, 4 su krivo spržena. il piše blank il piše da je nekej zauzeto a kad se otvori nema nist zato se vračam traxdati
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 09.02.2006., 11:41   #4
Panzer
Panzer's Avatar
Postovi: 1,814
@Codiac-
Prza je dosta stara, ali sve normalno radi... I przi i cita bez problema, tak da mislim da je u CDovima problem...
@Facelessone
A onda ok, vec sam mislil da je prza rikla... A fakat mi je draga...
Da nisi mozda te CDove kupio u ERI u Samoboru?
UPGRADED...
Staro 09.02.2006., 11:45   #5
Facelessone
Postovi: 4,203
nažalost da
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 01.03.2006., 02:10   #6
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
dečki dragi to vam nisu TDK već "TDK", proizvođač ovih potonjih nije TDK već Moser Baer India zbog toga i ne valjaju.
Ak na fičeka staviš Cavallino Rampante-a ( propetog konjića ili ti znak od Ferraria) ne znači da imaš Ferarria.
Prave TDK skoro da se i ne mogu naći više
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
