#6181 | ||
Datum registracije: Oct 2017
Lokacija: nigdje
Postovi: 475
pa NH ide bez fee na coinbase pa s coinbase na revolut za sepa nalog od 0,15€ jeftinie neznam dal ces nac Citiraj:
SAMOANA: Nije u šoldima sve Nadmudrivanje sa budalom je kao hrvanje sa svinjom u blatu ..... nakon nekog vremena skužiš da svinja uživa |
#6182 | |
Lokacija: Čakovec / AT
Postovi: 1,782
slow is smooth, smooth is fast... |
#6183 | |
Lokacija: nigdje
Postovi: 475
Eto sad ti je transakcije free prema coinbase i onda jos imas platit sepa prema revolut i to je to.
#6184 |
Datum registracije: Feb 2017
Postovi: 243
#6186 | |
Lokacija: nigdje
Postovi: 475
![]() ![]() Eto rijesen problem placanja skupih eth transakcija. Isprobao s nano adresom prema binance i radi.procedura traje cirka 2 sata. Minimalna isplata 2 dolara. jednom dnevno isplata. fee nema. jedino razlika u tecaju kupnje prodaje nanoa al to je mizerija. Joos moram probat btc prema coinbase jer coinbase nema nano, al ne vidim razlog da ne radi . samo umjesto eth adrese se upise btc adresa s coinbase. 10/22/2021 1:40 PM We started the exchange process of your mining reward 0.000879555 ETH. Please wait until all the steps are completed. At the end NANO will be paid out to your address: nano_3o3s469o3ogxbe93ph9bjezthijz8bepa4. 10/22/2021 1:42 PM We sent your coins to the Crypto Exchange. Your coins are sent together with other miners' coins. The transaction ID: 0x9ef6476cbd9832984c45c774a1dd12685. 10/22/2021 1:48 PM The Crypto Exchange received the coins. 10/22/2021 2:10 PM The exchange is in progress. 10/22/2021 2:10 PM We successfully exchanged 0.00087941938 ETH to 0.66189294 NANO. The exchange rate was 739.62221 NANO for 1 ETH. 10/22/2021 2:21 PM The coins were withdrawn from the Crypto Exchange. Your coins are coming together with other miners' coins. The transaction ID: 182D78DDD60A507CD8357FF8FECD874F1452. 10/22/2021 2:25 PM 2Miners Payment Gateway received your coins (0.66189013 NANO) from the Crypto Exchange. They will be paid out to your wallet address soon. 10/22/2021 2:36 PM We sent 0.66189013 NANO to your wallet address. The transaction fee was $0. The transaction ID: 6C2F48316D4FFAF54BFB7679506AA47609F.
SAMOANA: Nije u šoldima sve Nadmudrivanje sa budalom je kao hrvanje sa svinjom u blatu ..... nakon nekog vremena skužiš da svinja uživa Zadnje izmijenjeno od: livada2. 22.10.2021. u 19:08. |
#6187 |
Datum registracije: Jan 2018
Postovi: 500
#6191 |
Postovi: 500
#6193 |
Postovi: 174
Imao sam na probi 1070, nikako dobiti hash iznad 26. Preko Nicehash-a jedva 23-24, afterburnerom dobio nista bolje rezultate. Presao na Simplemining tamo uspio izvuci 26 MHz. |
#6195 |
Ovo ispod nisam ja! :)
Datum registracije: Sep 2002
Postovi: 1,692
Ekipa, kako spuštate temperature na 3090? Meni se memorija uredno kuha na nekih 105-108°C, čim se kartice upale za mining, bez obzira na overclock. Vrtnja ventilatora je na cca 70. Istina, ovo je test u sobi, bez nekog dodatnog hlađenja. Plan mi je postavit veliki podni ventilator, koji će sigurno ispuhat sve s riga, ali, hoće li bit dovoljno? Ili da se uhvatim stavljanja bar pasivnog hlađenja na stranu memorije? 3 su kartice, međusobno udaljenje cca 15cm.
Potpisujem! Zadnje izmijenjeno od: Rivi. 31.10.2021. u 08:48. |
#6196 |
Datum registracije: Dec 2013
Postovi: 1,697
Zamjena nekih i dodavanje novih thermalpadova. Prednja i zadnja strana grafe. Po mogućnosti neki koji se lako kompresiraju - gelid extreme. Sebi smanjio na 3080 sa 108 ja 82c Sent from my Pixel 4a (5G) using Tapatalk |
#6197 | |
Postovi: 1,692
Znaš li možda gdje ima kupit pasivnih hladnjaka, malo većih, neće štetit da zalijepim uz backplate nešto...
Potpisujem! |
#6198 |
Postovi: 1,697
E to nebih znao, nisam sebi trazio. Ovako na prvu bi rekao, ebay,amazon, alix..pa ako ti nije hitno neka putuje, ovisno gdje nades. Ako budes isao na varijantu mjenjanja padova, onda dobro istrazi za svoj model koje su sve debljine i te uzmi, milimetar gore ili dole i nece biti dobro. |
#6199 | |
Postovi: 1,692
Di si ti svoju uzeo?
Potpisujem! |
#6200 |
Datum registracije: Aug 2016
Lokacija: Bestovje,Sv.Nedelja
Postovi: 2,821
Padovi moraju biti točne dimenzije, ne pola milimetra deblji ili tanji .... Tako da google u ruke i za svoju točno vidi koji padovi ti trebaju ... Nebi bilo i da negdje u tvornici nisu stavili padove ... |
#6201 |
Postovi: 1,697
Tocno to, nije da uzmes padove koje se daju kompresirati pa time nadomjestis krivu debljinu. Kopresivne padove uzmes jer em bolje provode toplinu em se prosire po memy bolje i po samom PCB-u sa straznje strane. Znaci tocna debljina. Arctic mozes zaboraviti, probao i 0 bodova, koje god stavio. Ne vrijede. Niti grizzly. Najbolja opcija koja radi iz prve su gelid extreme, ako ih bas nigjde ne mozes naci onda eventualnu thermalight - ali sa njima je 50/50. |
#6202 | |
Postovi: 1,692
Apropo debljine, koliko vidim, 2mm su padovi na mojim Gigabajticama 3090... https://www.nicehash.com/blog/post/t...-and-3090-gpus
Potpisujem! |
#6203 |
Postovi: 1,697
Uhh..nisam ni vidio da si pitao ![]() U nas nema, samo vanka. tipa amazon https://www.amazon.de/s?k=gelid+extr...f=nb_sb_noss_2 ili direkt od njih, tak sam ja. https://gelidstore.com/collections/gp-extreme |
#6204 |
Postovi: 2,821
Za te cijene bolje sa amazona, našao prime 85x45x2 za 15 eura .... iz hong konga će još i pdv i carinu .... Jedino kaj bi trebao pogledati koliko toga trebaš ... https://www.amazon.de/-/en/Thermalri...W%2CB07KMSP65C |
#6205 | |
Postovi: 1,692
Amazon mi je špansko selo, pa dok nađem odakle dolazi proizvod...komedija... Uglavnom, zahvaljujem obojici na pomoći.
Potpisujem! |
#6206 |
Postovi: 2,821
Amazon.de je uglavnom sve iz Njemačke što šalju, pogotovo ako gledaš prime stvari ... Ima stvari koje se isto tako šalju iz kine i okolice,ali vidiš po datumu dostave ... U pravilu sa amazona sve stiže u dan/dva na mailbox,pa od tamo 3-4 dana do tebe ... Ima sad i dostave kod nas,ali moraš malo pretražiti, samo će ti shipping biti malo uvećan ... |
#6207 | |
Lokacija: Zabok
Postovi: 388
Ja isto razmišljam da na svojim 3080 (gigabyte) promjenim termal padove jer sada u ovo "hladnije" vrijeme mi je tem. u redu, ali si nekeko mislim što će biti sljedeće ljeto... Koliko te došao shipping? Citiraj:
#6208 |
Master Of Disaster
Datum registracije: Nov 2002
Postovi: 1,265
#6210 |
Postovi: 1,697
